Individual controller driver has different requirement for wakeup
setting, so move it from core to itself. In order to align with
current etting the default wakeup setting is enabled (except for
chipidea host).
Pass compile test with below commands:
make O=outout/all allmodconfig
make -j$CPU_NUM O=outout/all drivers/usb
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Suspend scenario in case of ohci-sm501 glue was not
properly handled as it was not suspending generic part
of ohci controller. Alan Stern suggested, properly
handle ohci-sm501 suspend scenario.
Calling explicitly the ohci_suspend() routine in
ohci_sm501_suspend() will ensure proper handling of suspend
scenario.
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
Signed-off-by: Manjunath Goudar <csmanjuvijay@gmail.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Commit cfa49b4b (USB: ohci: merge ohci_finish_controller_resume with
ohci_resume) merged ohci_finish_controller_resume with ohci_resume but forgot
to update the ohci-sm501 driver accordingly, thus causing the folllowing build
failure:
drivers/usb/host/ohci-sm501.c: In function 'ohci_sm501_resume':
drivers/usb/host/ohci-sm501.c:241:2: error: implicit declaration of function
'ohci_finish_controller_resume' [-Werror=implicit-function-declaration]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This patch (as1500) removes all uses of the objectionable hcd->state
variable from the ohci-hcd family of drivers. It is replaced by a
private ohci->rh_state field, just as in uhci-hcd and ehci-hcd.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
This ioremap() was leaked on an error path.
This patch (as1069c) changes the way OHCI root-hub status-change
interrupts are enabled. Currently a special HCD method,
hub_irq_enable(), is called when the hub driver is finished using a
root hub. This approach turns out to be subject to races, resulting
in unnecessary polling.
The patch does away with the method entirely. Instead, the driver
automatically enables the RHSC interrupt when no more status changes
are present. This scheme is safe with controllers using
level-triggered semantics for their interrupt flags.
The bus_id field is going away, use the dev_name() function instead.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This reverts commit e872154921a6b5256a3c412dd69158ac0b135176.
Andrey Borzenkov reports that it resulted in a totally hung machine for
him when loading the OHCI driver. Extensive netconsole capture with
SysRq output shows that modprobe gets stuck in ohci_hub_status_data()
when probing and enabling the OHCI controller, see for example
http://lkml.org/lkml/2008/7/5/236
for an analysis.
The problem appears to be an interrupt flood triggered by the commit
that gets reverted, and Andrey confirmed that the revert makes things
work for him again.
Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
drivers/usb/host/ohci-sm501.c:93:24: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3254:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3267:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3277:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3285:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3293:9: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch (as1069b) changes the way OHCI root-hub status-change
Drivers in the ohci-hcd family should perform certain tasks whenever
their controller device is resumed. These include checking for loss
of power during suspend, turning on port power, and enabling interrupt
requests.
Until now these jobs have been carried out when the root hub is
resumed, not when the controller is. Many drivers work around the
resulting awkwardness by automatically resuming their root hub
whenever the controller is resumed. But this is wasteful and
unnecessary.
To simplify the situation, this patch (as1066) adds a new core
routine, ohci_finish_controller_resume(), which can be used by all the
OHCI-variant drivers. They can call the new routine instead of
resuming their root hubs. And ohci-pci.c can call it instead of using
its own special-purpose handler.
ohci_hcd_sm501_drv_remove()
platform_get_resource() may return null, so although it seems it will never
do so here unless there's a bug elsewhere, it does no harm to be defensive
and test.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Magnus Damm <magnus.damm@gmail.com>
power.power_state is scheduled for removal. This patch (as1053)
removes all uses of that field from drivers/usb. Almost all of them
were write-only, the most significant exceptions being sl811-hcd.c and
u132-hcd.c.
Part of this patch was written by Pavel Machek.
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Pavel Machek <pavel@ucw.cz>
resume
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Magnus Damm <damm@igel.co.jp>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable USB HCDs,
to allow re-enable auto loading.
[dbrownell@users.sourceforge.net: more drivers; registration fixes]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <greg@kroah.com>
usb: ohci-sm501 driver V2
This patch adds sm501 ohci support. It's all very straightforward with the
exception of dma_declare_coherent_memory() and HCD_LOCAL_MEM. Together they
are used to ensure that usb data is allocated using dma_alloc_coherent(),
and that only valid dma memory is used to allocate from. This driver is
a platform device, and the mfd driver sm501.c is already creating one
usb host controller instance per sm501.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
