[ Upstream commit bde0716d1f076e4c913c7946bcc858f71243c7a0 ]
For AMD Promontory xHCI host, although you can disable USB ports in
BIOS settings, those ports will be enabled anyway after you remove a
device on that port and re-plug it in again. It's a known limitation of
the chip. As a workaround we can clear the PORT_WAKE_BITS.
[commit and code comment rephrasing -Mathias]
Signed-off-by: Joe Lee <asmt.swfae@gmail.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The Renesas uPD72020x XHCI controller seems to suffer from a really
annoying bug, where it may retain some of its DMA programming across a XHCI
reset, and despite the driver correctly programming new DMA addresses.
This is visible if the device has been using 64-bit DMA addresses, and is
then switched to using 32-bit DMA addresses. The top 32 bits of the
address (now zero) are ignored are replaced by the 32 bits from the
*previous* programming. Sticking with 64-bit DMA always works, but doesn't
seem very appropriate.
A PCI reset of the device restores the normal functionality, which is done
at probe time. Unfortunately, this has to be done before any quirk has
been discovered, hence the intrusive nature of the fix.
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
CC: stable@vger.kernel.org # v4.11+
When USB Ethernet is plugged in ASMEDIA ASM1042A xHCI host, bad
performance was manifesting in Web browser use (like download
large file such as ISO image). It is known limitation of
ASM1042A that is not compatible with driver scheduling,
As a workaround we can modify flow control handling of ASM1042A.
The register we modify is changes the behavior
[use quirk bit 28, usleep_range 40-60us, empty non-pci function -Mathias]
Cc: <stable@vger.kernel.org>
Signed-off-by: Jiahau Chang <Lars_chang@asmedia.com.tw>
Signed-off-by: Ian Pilcher <arequipeno@gmail.com>
a lot of embeded system SOC (e.g. freescale T2080) have both
PCI and USB modules. But USB module is controlled by registers directly,
it have no relationship with PCI module.
when say N here it will not build PCI related code in USB driver.
Signed-off-by: yuan linyu <Linyu.Yuan@alcatel-sbell.com.cn>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
This commit fixes the following sparse warning:
drivers/usb/host/pci-quirks.c:
- 252: warning: symbol 'usb_hcd_amd_remote_wakeup_quirk' was not
declared. Should it be static?
This function is exported so the fix was to add it's declaration to the
header file.
Signed-off-by: Konrad Zapalowicz <bergo.torino@gmail.com>
Commit "usb: pci-quirks: refactor AMD quirk to abstract AMD chipset types"
introduced a new AMD chipset type to filter AMD platforms with different
chipsets.
According to a recent thread [1], this patch updates SB800 prefetch routine
in AMD PLL quirk. And make it use the new chipset type to represent SB800
generation.
[1] http://marc.info/?l=linux-usb&m=138012321616452&w=2
Signed-off-by: Huang Rui <ray.huang@amd.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
chipsets.
According to a recent thread [1], this patch updates USB subsystem hang
symptom quirk which is observed on AMD all SB600 and SB700 revision
0x3a/0x3b. And make it use the new chipset type to represent.
Fix warning when CONFIG_PCI is not enabled
(from commit 296365781903226a3fb8758901eaeec09d2798e4).
drivers/usb/host/pci-quirks.h: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default]
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Moiz Sonasath <m-sonasath@ti.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Make the Linux xHCI driver automatically try to switchover the EHCI ports to
xHCI when an Intel xHCI host is detected, and it also finds an Intel EHCI host.
This means we will no longer have to add Intel xHCI hosts to a quirks list when
the PCI device IDs change. Simply continuing to add new Intel xHCI PCI device
IDs to the quirks list is not sustainable.
During suspend ports may be swicthed back to EHCI by BIOS and not properly
restored to xHCI at resume. Previously both EHCI and xHCI resume functions
switched ports back to XHCI, but it's enough to do it in xHCI only
because the hub driver doesn't start running again until after both hosts are resumed.
Note that this changes is part of separating the ohci pci host controller
driver from ohci-hcd host code.
This contains :
-Moved sb800_prefetch() function from ohci-pci.c to pci-quirks.c file
and EXPORTed, this is part of the effort to move the ohci pci related
code to generic pci code.
-Passed "device" argument instead of "ohci_hcd" in sb800_prefetch()
function to avoid extra include file in pci-quirks.c.
V2:
-Passed "device" argment instead of "pci_dev", then we use to_pci_dev()
to get the "pci_dev" structure.
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
For non PCI-based stacks, this function call
usb_disable_xhci_ports(to_pci_dev(hcd->self.controller));
made from xhci_shutdown is not applicable.
Ideally, we wouldn't have any PCI-specific code on
a generic driver such as the xHCI stack, but it looks
like we should just stub usb_disable_xhci_ports() out
for non-PCI devices.
[ balbi@ti.com: slight improvement to commit log ]
This patch should be backported to kernels as old as 3.0, since the
commit it fixes (e95829f474f0db3a4d940cae1423783edd966027 "xhci: Switch
PPT ports to EHCI on shutdown.") was marked for stable.
Signed-off-by: Moiz Sonasath<m-sonasath@ti.com>
Signed-off-by: Ruchika Kharwar <ruchika@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Cc: stable@vger.kernel.org
The Intel desktop boards DH77EB and DH77DF have a hardware issue that
can be worked around by BIOS. If the USB ports are switched to xHCI on
shutdown, the xHCI host will send a spurious interrupt, which will wake
the system. Some BIOS will work around this, but not all.
The bug can be avoided if the USB ports are switched back to EHCI on
shutdown. The Intel Windows driver switches the ports back to EHCI, so
change the Linux xHCI driver to do the same.
Unfortunately, we can't tell the two effected boards apart from other
working motherboards, because the vendors will change the DMI strings
for the DH77EB and DH77DF boards to their own custom names. One example
is Compulab's mini-desktop, the Intense-PC. Instead, key off the
Panther Point xHCI host PCI vendor and device ID, and switch the ports
over for all PPT xHCI hosts.
The only impact this will have on non-effected boards is to add a couple
hundred milliseconds delay on boot when the BIOS has to switch the ports
over from EHCI to xHCI.
This patch should be backported to kernels as old as 3.0, that contain
the commit 69e848c2090aebba5698a1620604c7dccb448684 "Intel xhci: Support
EHCI/xHCI port switching."
Reported-by: Denis Turischev <denis@compulab.co.il>
Tested-by: Denis Turischev <denis@compulab.co.il>
The Intel Panther Point chipsets contain an EHCI and xHCI host controller
that shares some number of skew-dependent ports. These ports can be
switched from the EHCI to the xHCI host (and vice versa) by a hardware MUX
that is controlled by registers in the xHCI PCI configuration space. The
USB 3.0 SuperSpeed terminations on the xHCI ports can be controlled
separately from the USB 2.0 data wires.
This switchover mechanism is there to support users who do a custom
install of certain non-Linux operating systems that don't have official
USB 3.0 support. By default, the ports are under EHCI, SuperSpeed
terminations are off, and USB 3.0 devices will show up under the EHCI
controller at reduced speeds. (This was more palatable for the marketing
folks than having completely dead USB 3.0 ports if no xHCI drivers are
available.) Users should be able to turn on xHCI by default through a
BIOS option, but users are happiest when they don't have to change random
BIOS settings.
This patch introduces a driver method to switchover the ports from EHCI to
xHCI before the EHCI driver finishes PCI enumeration. We want to switch
the ports over before the USB core has the chance to enumerate devices
under EHCI, or boot from USB mass storage will fail if the boot device
connects under EHCI first, and then gets disconnected when the port
switches over to xHCI.
Add code to the xHCI PCI quirk to switch the ports from EHCI to xHCI. The
PCI quirks code will run before any other PCI probe function is called, so
this avoids the issue with boot devices.
Another issue is with BIOS behavior during system resume from hibernate.
If the BIOS doesn't support xHCI, it may switch the devices under EHCI to
allow use of the USB keyboard, mice, and mass storage devices. It's
supposed to remember the value of the port routing registers and switch
them back when the OS attempts to take control of the xHCI host controller,
but we all know not to trust BIOS writers.
Make both the xHCI driver and the EHCI driver attempt to switchover the
ports in their PCI resume functions. We can't guarantee which PCI device
will be resumed first, so this avoids any race conditions. Writing a '1'
to an already set port switchover bit or a '0' to a cleared port switchover
bit should have no effect.
The xHCI PCI configuration registers will be documented in the EDS-level
chipset spec, which is not public yet. I have permission from legal and
the Intel chipset group to release this patch early to allow good Linux
support at product launch. I've tried to document the registers as much
as possible, so please let me know if anything is unclear.
This patch moves the AMD PLL quirk code in OHCI/EHCI driver to pci-quirks.c,
and exports the functions to be used by xHCI driver later.
AMD PLL quirk disable the optional PM feature inside specific
SB700/SB800/Hudson-2/3 platforms under the following conditions:
1. If an isochronous device is connected to OHCI/EHCI/xHCI port and is active;
2. Optional PM feature that powers down the internal Bus PLL when the link is
in low power state is enabled.
Without AMD PLL quirk, USB isochronous stream may stutter or have breaks
occasionally, which greatly impair the performance of audio/video streams.
Currently AMD PLL quirk is implemented in OHCI and EHCI driver, and will be
added to xHCI driver too. They are doing similar things actually, so move
the quirk code to pci-quirks.c, which has several advantages:
1. Remove duplicate defines and functions in OHCI/EHCI (and xHCI) driver and
make them cleaner;
2. AMD chipset information will be probed only once and then stored.
Currently they're probed during every OHCI/EHCI initialization, move
the detect code to pci-quirks.c saves the repeat detect cost;
3. Build up synchronization among OHCI/EHCI/xHCI driver. In current
code, every host controller enable/disable PLL only according to
its own status, and may enable PLL while there is still isoc transfer on
other HCs. Move the quirk to pci-quirks.c prevents this issue.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Alex He <alex.he@amd.com>
This reverts commit b7d5b439b7a40dd0a0202fe1c118615a3fcc3b25.
It conflicts with commit baab93afc2844b68d57b0dcca5e1d34c5d7cf411 "USB:
EHCI: ASPM quirk of ISOC on AMD Hudson" and merging the two just doesn't
work properly.
Cc: Andiry Xu <andiry.xu@amd.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
make them cleaner;
This patch adds a header file with proper prototypes for two functions
in drivers/usb/host/pci-quirks.c.
