path: root/drivers/usb/host/sl811-hcd.c
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-13USB: sl811: add Kconfig option for ISOCHRONOUS modeMike Frysinger
Some bluetooth dongles want ISO mode, and the limited support that the sl811 offers today is sufficient. So add a Kconfig option for people to optionally get access to the partial functionality. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-13USB 3.0 Hub ChangesJohn Youn
Update the USB core to deal with USB 3.0 hubs. These hubs have a slightly different hub descriptor than USB 2.0 hubs, with a fixed (rather than variable length) size. Change the USB core's hub descriptor to have a union for the last fields that differ. Change the host controller drivers that access those last fields (DeviceRemovable and PortPowerCtrlMask) to use the union. Translate the new version of the hub port status field into the old version that khubd understands. (Note: we need to fix it to translate the roothub's port status once we stop converting it to USB 2.0 hub status internally.) Add new code to handle link state change status. Send out new control messages that are needed for USB 3.0 hubs, like Set Hub Depth. This patch is a modified version of the original patch submitted by John Youn. It's updated to reflect the removal of the "bitmap" #define, and change the hub descriptor accesses of a couple new host controller drivers. Signed-off-by: John Youn <johnyoun@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Max Vozeler <mvz@vozeler.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <dbrownell@users.sourceforge.net>
2011-03-13USB: Remove bitmap #define from hcd.hSarah Sharp
Using a #define to redefine a common variable name is a bad thing, especially when the #define is in a header. include/linux/usb/hcd.h redefined bitmap to DeviceRemovable to avoid typing a long field in the hub descriptor. This has unintended side effects for files like drivers/usb/core/devio.c that include that file, since another header included after hcd.h has different variables named bitmap. Remove the bitmap #define and replace instances of it in the host controller code. Cleanup the spaces around function calls and square brackets while we're at it. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Max Vozeler <mvz@vozeler.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <dbrownell@users.sourceforge.net>
2011-02-03USB SL811HS HCD: Fix memory leak in sl811h_urb_enqueue()Jesper Juhl
In drivers/usb/host/sl811-hcd.c::sl811h_urb_enqueue(), memory is allocated with kzalloc() and assigned to 'ep'. If we leave via the 'fail' label due to 'if (ep->maxpacket > H_MAXPACKET)', then 'ep' will go out of scope without having been assigned to anything, so we'll leak the memory we allocated. This patch fixes the leak by simply calling kfree(ep); before jumping to the 'fail' label. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10usb: host: sl811-hcd: check kzalloc() resultKulikov Vasiliy
If kzalloc() fails exit with -ENOMEM. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: straighten out port feature vs. port status usageAlan Stern
This patch (as1349b) clears up the confusion in many USB host controller drivers between port features and port statuses. In mosty cases it's true that the status bit is in the position given by the corresponding feature value, but that's not always true and it's not guaranteed in the USB spec. There's no functional change, just replacing expressions of the form (1 << USB_PORT_FEAT_x) with USB_PORT_STAT_x, which has the same value. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: remove bogus USB_PORT_FEAT_*_SPEED symbolsAlan Stern
This patch (as1348) removes the bogus USB_PORT_FEAT_{HIGHSPEED,SUPERSPEED} symbols from ch11.h. No such features are defined by the USB spec. (There is a PORT_LOWSPEED feature, but the spec doesn't mention it except to say that host software should never use it.) The speed indicators are port statuses, not port features. As a temporary workaround for the xhci-hcd driver, a fictional USB_PORT_STAT_SUPER_SPEED symbol is added. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: make hcd.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hcd.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-30USB: sl811-hcd: Fix device disconnectMichael Hennerich
A while ago I provided a patch that fixed device detection after device removal (USB: sl811-hcd: Fix device disconnect). Chris Brissette pointed out that the detection/removal counter method to distinguish insert or remove my fail under certain conditions. Latest SL811HS datasheet (Document 38-08008 Rev. *D) indicates that bit 6 (SL11H_INTMASK_RD) of the Interrupt Status Register together with bit 5 (SL11H_INTMASK_INSRMV) can be used to determine whether a device has been inserted or removed. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: host: SL811: fix unaligned accessesMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: sl811-hcd: Fix device disconnect:Hennerich, Michael
SL811 Device detected after removal used to be working in linux-2.6.22 but then broke somewhere between 2.6.22 and 2.6.28. Current hub_port_connect_change() in drivers/usb/core/hub.c won't call usb_disconnect() in case the SL811 driver sets portstatus USB_PORT_FEAT_CONNECTION upon removal. AFAIK the SL811 has only a combined Device Insert/Remove detection bit, therefore use a count to distinguish insert or remove. Signed-Off-By: Michael Hennerich <hennerich@blackfin.uclinux.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: make transfer_buffer_lengths in struct urb field u32Greg Kroah-Hartman
Roel Kluin pointed out that transfer_buffer_lengths in struct urb was declared as an 'int'. This patch changes this field to be 'u32' to prevent any potential negative conversion and comparison errors. This triggered a few compiler warning messages when these fields were being used with the min macro, so they have also been fixed up in this patch. Cc: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Let some USB host controllers get IRQ flags from resourceMarc Zyngier
[This version fixes a thinko in the r8a66597 driver] This patch let a few discrete USB host controllers drivers (isp116x-hcd, r8a66597-hcd and sl811-hcd) obtain IRQ flags from their IORESOURCE_IRQ resource if configured as such, much like it's been done for the smc91x driver. It spares people writing support for specific boards the burden to configure the interrupt controller independantly, and keeps all IRQ related information in a single resource. HCD that are integrally part of a SoC have been left aside, as there is probably no "wiring" options... Tested on an Xscale PXA-255 based platform with isp116x-hcd. Signed-off-by: Marc Zyngier <marc.zyngier@altran.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-25Rename WARN() to WARNING() to clear the namespaceArjan van de Ven
We want to use WARN() as a variant of WARN_ON(), however a few drivers are using WARN() internally. This patch renames these to WARNING() to avoid the namespace clash. A few cases were defining but not using the thing, for those cases I just deleted the definition. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Greg KH <greg@kroah.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21USB: usb dev_name() instead of dev->bus_idKay Sievers
The bus_id field is going away, use the dev_name() function instead. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-29usb: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28drivers/usb annotations and fixesAl Viro
* endianness annotations * endianness fixes * missing get_unaligned/put_unaligned It's pretty much all over the place, changes to different files are independent. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Serial-parts-Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove dev->power.power_stateAlan Stern
power.power_state is scheduled for removal. This patch (as1053) removes all uses of that field from drivers/usb. Almost all of them were write-only, the most significant exceptions being sl811-hcd.c and u132-hcd.c. Part of this patch was written by Pavel Machek. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-11usb host: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable USB HCDs, to allow re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers; registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12USB: Eliminate urb->status usage!Alan Stern
This patch (as979) removes the last vestiges of urb->status from the host controller drivers and the root-hub emulator. Now the field doesn't get set until just before the URB's completion routine is called. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: reorganize urb->status use in sl811-hcdAlan Stern
This patch (as976) reorganizes the way sl811-hcd sets urb->status. It now keeps the information in a local variable until the last moment. The patch also improves the handling of faults during the status stage of a control transfer, since it no longer needs to retain the error information from the earlier stages. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add urb->unlinked fieldAlan Stern
This patch (as970) adds a new urb->unlinked field, which is used to store the status of unlinked URBs since we can't use urb->status for that purpose any more. To help simplify the HCDs, usbcore will check urb->unlinked before calling the completion handler; if the value is set it will automatically override the status reported by the HCD. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: centralize -EREMOTEIO handlingAlan Stern
This patch (as969) continues the ongoing changes to the way HCDs report URB statuses. The programming interface has been simplified by making usbcore responsible for clearing urb->hcpriv and for setting -EREMOTEIO status when an URB with the URB_SHORT_NOT_OK flag ends up as a short transfer. By moving the work out of the HCDs, this removes a fair amount of repeated code. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: remove unnecessary tests in isp116x and sl811Alan Stern
This patch (as962) cleans up some code I forgot to remove earlier in the isp116x and sl811 HCDs. There is no longer any need to check for unlink-during-submit; it can't happen since the endpoint queues are now under the protection of the HCD-private spinlock. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: make HCDs responsible for managing endpoint queuesAlan Stern
This patch (as954) implements a suggestion of David Brownell's. Now the host controller drivers are responsible for linking and unlinking URBs to/from their endpoint queues. This eliminates the possiblity of strange situations where usbcore thinks an URB is linked but the HCD thinks it isn't. It also means HCDs no longer have to check for URBs being dequeued before they were fully enqueued. In addition to the core changes, this requires changing every host controller driver and the root-hub URB handler. For the most part the required changes are fairly small; drivers have to call usb_hcd_link_urb_to_ep() in their urb_enqueue method, usb_hcd_check_unlink_urb() in their urb_dequeue method, and usb_hcd_unlink_urb_from_ep() before giving URBs back. A few HCDs make matters more complicated by the way they split up the flow of control. In addition some method interfaces get changed. The endpoint argument for urb_enqueue is now redundant so it is removed. The unlink status is required by usb_hcd_check_unlink_urb(), so it has been added to urb_dequeue. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Tony Olech <tony.olech@elandigitalsystems.com> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25PM: USB HCDs use PM_EVENT_PRETHAWDavid Brownell
This teaches several USB host controller drivers to treat PRETHAW as a chip reset since the controller, and all devices connected to it, are no longer in states compatible with how the snapshotted suspend() left them. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-02[PATCH] irq-flags: usb: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit Resource: convert a few remaining drivers to use ↵Greg Kroah-Hartman
resource_size_t where needed Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: move hardware-specific <linux/usb_*.h> to <linux/usb/*.h>David Brownell
This moves header files for controller-specific platform data from <linux/usb_XXX.h> to <linux/usb/XXX.h> to start reducing some clutter. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB core and HCDs: don't put_device while atomicAlan Stern
This patch (as640) removes several put_device and the corresponding get_device calls from the USB core and HCDs. Some of the puts were done in atomic contexts, and none of them are needed since the core now guarantees that every endpoint will be disabled and every URB completed before a USB device is released. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: central handling for host controllers that were reset during ↵Alan Stern
suspend/resume This patch (as515b) adds a routine to usbcore to simplify handling of host controllers that lost power or were reset during suspend/resume. The new core routine marks all the child devices of the root hub as NOTATTACHED and tells khubd to disconnect the device structures as soon as possible. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: hcd uses EXTRA_CFLAGS for -DDEBUGDavid Brownell
This modifies the HCD builds to automatically "-DDEBUG" if CONFIG_USB_DEBUG is selected. It's just a minor source code cleanup, guaranteeing consistency. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: wakeup flag updates (1/3) sl811-hcdDavid Brownell
This makes the SL811 HCD use the driver model wakeup flags for its controller, not the flags in the HCD glue (which will be removed). From: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/sl811-hcd.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: add owner initialisation to host driversBen Dooks
Add .owner initialisation to the device drivers in drivers/usb/host so that when built as module the device_driver refers to the owning module Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: Rename hcd->hub_suspend to hcd->bus_suspendAlan Stern
This patch (as580) is perhaps the only result from the long discussion I had with David about his changes to the root-hub suspend/resume code. It renames the hub_suspend and hub_resume methods in struct usb_hcd to bus_suspend and bus_resume. These are more descriptive names, since the methods really do suspend or resume an entire USB bus, and less likely to be confused with the hub_suspend and hub_resume routines in hub.c. It also takes David's advice about removing the layer of bus glue, where those methods are called. And it implements a related change that David made to the other HCDs but forgot to put into dummy_hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
