commit d6169d04097fd9ddf811e63eae4e5cd71e6666e2 upstream.
If a URB is killed while the host is removed we can end up in a situation
where the hub thread takes the roothub device lock, and waits for
the URB to be given back by xhci-hcd, blocking the host remove code.
xhci-hcd tries to stop the endpoint and give back the urb, but can't
as the host is removed from PCI bus at the same time, preventing the normal
way of giving back urb.
Instead we need to rely on the stop command timeout function to give back
the urb. This xhci_stop_endpoint_command_watchdog() timeout function
used a XHCI_STATE_DYING flag to indicate if the timeout function is already
running, but later this flag has been taking into use in other places to
mark that xhci is dying.
Remove checks for XHCI_STATE_DYING in xhci_urb_dequeue. We are still
checking that reading from pci state does not return 0xffffffff or that
host is not halted before trying to stop the endpoint.
This whole area of stopping endpoints, giving back URBs, and the wathdog
timeout need rework, this fix focuses on solving a specific deadlock
issue that we can then send to stable before any major rework.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 90797aee5d6902b49a453c97d83c326408aeb5a8 upstream.
xhci_setup_device() should return failure with correct error number
when xhci host has died, removed or halted.
During usb device enumeration, if usb host is not accessible (died,
removed or halted), the hc_driver->address_device() should return
a corresponding error code to usb core. But current xhci driver just
returns success. This misleads usb core to continue the enumeration
by reading the device descriptor, which will result in failure, and
users will get a misleading message like "device descriptor read/8,
error -110".
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
All kmalloc-based functions print enough information on failures.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Pull timer updates from Thomas Gleixner:
"This update provides the following changes:
- The rework of the timer wheel which addresses the shortcomings of
the current wheel (cascading, slow search for next expiring timer,
etc). That's the first major change of the wheel in almost 20
years since Finn implemted it.
- A large overhaul of the clocksource drivers init functions to
consolidate the Device Tree initialization
- Some more Y2038 updates
- A capability fix for timerfd
- Yet another clock chip driver
- The usual pile of updates, comment improvements all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (130 commits)
tick/nohz: Optimize nohz idle enter
clockevents: Make clockevents_subsys static
clocksource/drivers/time-armada-370-xp: Fix return value check
timers: Implement optimization for same expiry time in mod_timer()
timers: Split out index calculation
timers: Only wake softirq if necessary
timers: Forward the wheel clock whenever possible
timers/nohz: Remove pointless tick_nohz_kick_tick() function
timers: Optimize collect_expired_timers() for NOHZ
timers: Move __run_timers() function
timers: Remove set_timer_slack() leftovers
timers: Switch to a non-cascading wheel
timers: Reduce the CPU index space to 256k
timers: Give a few structs and members proper names
hlist: Add hlist_is_singular_node() helper
signals: Use hrtimer for sigtimedwait()
timers: Remove the deprecated mod_timer_pinned() API
timers, net/ipv4/inet: Initialize connection request timers as pinned
timers, drivers/tty/mips_ejtag: Initialize the poll timer as pinned
timers, drivers/tty/metag_da: Initialize the poll timer as pinned
We now have implicit batching in the timer wheel. The slack API is no longer
used, so remove it.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrew F. Davis <afd@ti.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Chris Mason <clm@fb.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: George Spelvin <linux@sciencehorizons.net>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Len Brown <lenb@kernel.org>
Cc: Mathias Nyman <mathias.nyman@intel.com>
Cc: Pali Rohár <pali.rohar@gmail.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Reichel <sre@kernel.org>
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Cc: linux-block@vger.kernel.org
Cc: linux-mmc@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160704094342.189813118@linutronix.de
If the last trb before a link is not packet size aligned, and is not
splittable then use a bounce buffer for that chunk of max packet size
unalignable data.
Allocate a max packet size bounce buffer for every segment of a bulk
endpoint ring at the same time as allocating the ring.
If we need to align the data before the link trb in that segment then
copy the data to the segment bounce buffer, dma map it, and enqueue it.
Once the td finishes, or is cancelled, unmap it.
For in transfers we need to first map the bounce buffer, then queue it,
after it finishes, copy the bounce buffer to the original sg list, and
finally unmap it
commit b1c127ae990b ("usb: host: xhci: plat: make use of new methods in
xhci_plat_priv") sets xhci->quirks before calling xhci_gen_setup(), which
will overwrite them.
Don't overwite the quirks, just add the new ones
Fixes: b1c127ae990b ("usb: host: xhci: plat: make use of new methods in xhci_plat_priv")
Reported-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Felipe Balbi <felipe.balbi@linux.intel.com>
Under stress occasions some TI devices might not return early when
reading the status register during the quirk invocation of xhci_irq made
by usb_hcd_pci_remove. This means that instead of returning, we end up
handling this interruption in the middle of a shutdown. Since
xhci->event_ring has already been freed in xhci_mem_cleanup, we end up
accessing freed memory, causing the Oops below.
commit 8c24d6d7b09d ("usb: xhci: stop everything on the first call to
xhci_stop") is the one that changed the instant in which we clean up the
event queue when stopping a device. Before, we didn't call
xhci_mem_cleanup at the first time xhci_stop is executed (for the shared
HCD), instead, we only did it after the invocation for the primary HCD,
much later at the removal path. The code flow for this oops looks like
this:
xhci_pci_remove()
usb_remove_hcd(xhci->shared)
xhci_stop(xhci->shared)
xhci_halt()
xhci_mem_cleanup(xhci); // Free the event_queue
usb_hcd_pci_remove(primary)
xhci_irq() // Access the event_queue if STS_EINT is set. Crash.
xhci_stop()
xhci_halt()
// return early
The fix modifies xhci_stop to only cleanup the xhci data when releasing
the primary HCD. This way, we still have the event_queue configured
when invoking xhci_irq. We still halt the device on the first call to
xhci_stop, though.
I could reproduce this issue several times on the mainline kernel by
doing a bind-unbind stress test with a specific storage gadget attached.
I also ran the same test over-night with my patch applied and didn't
observe the issue anymore.
[ 113.334124] Unable to handle kernel paging request for data at address 0x00000028
[ 113.335514] Faulting instruction address: 0xd00000000d4f767c
[ 113.336839] Oops: Kernel access of bad area, sig: 11 [#1]
[ 113.338214] SMP NR_CPUS=1024 NUMA PowerNV
[c000000efe47ba90] c000000000720850 usb_hcd_irq+0x50/0x80
[c000000efe47bac0] c00000000073d328 usb_hcd_pci_remove+0x68/0x1f0
[c000000efe47bb00] d00000000daf0128 xhci_pci_remove+0x78/0xb0
[xhci_pci]
[c000000efe47bb30] c00000000055cf70 pci_device_remove+0x70/0x110
[c000000efe47bb70] c00000000061c6bc __device_release_driver+0xbc/0x190
[c000000efe47bba0] c00000000061c7d0 device_release_driver+0x40/0x70
[c000000efe47bbd0] c000000000619510 unbind_store+0x120/0x150
[c000000efe47bc20] c0000000006183c4 drv_attr_store+0x64/0xa0
[c000000efe47bc60] c00000000039f1d0 sysfs_kf_write+0x80/0xb0
[c000000efe47bca0] c00000000039e14c kernfs_fop_write+0x18c/0x1f0
[c000000efe47bcf0] c0000000002e962c __vfs_write+0x6c/0x190
[c000000efe47bd90] c0000000002eab40 vfs_write+0xc0/0x200
[c000000efe47bde0] c0000000002ec85c SyS_write+0x6c/0x110
[c000000efe47be30] c000000000009260 system_call+0x38/0x108
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Roger Quadros <rogerq@ti.com>
Cc: joel@jms.id.au
Cc: stable@vger.kernel.org
Reviewed-by: Roger Quadros <rogerq@ti.com>
Cc: <stable@vger.kernel.org> #v4.3+
Tested-by: Joel Stanley <joel@jms.id.au>
Remove duplicate function xhci_urb_to_transfer_ring from xhci.c.
We have same function in xhci-ring.c.
Signed-off-by: Alexandr Ivanov <alexandr.sky@gmail.com>
PCI hotpluggable xhci controllers such as some Alpine Ridge solutions will
remove the xhci controller from the PCI bus when the last USB device is
disconnected.
Add a flag to indicate that the host is being removed to avoid queueing
configure_endpoint commands for the dropped endpoints.
For PCI hotplugged controllers this will prevent 5 second command timeouts
For static xhci controllers the configure_endpoint command is not needed
in the removal case as everything will be returned, freed, and the
controller is reset.
For now the flag is only set for PCI connected host controllers.
On some xHCI controllers (e.g. R-Car SoCs), the AC64 bit (bit 0) of
HCCPARAMS1 is set to 1. However, the xHCs don't support 64-bit
address memory pointers actually. So, in this case, this driver should
call dma_set_coherent_mask(dev, DMA_BIT_MASK(32)) in xhci_gen_setup().
Otherwise, the xHCI controller will be died after a usb device is
connected if it runs on above 4GB physical memory environment.
So, this patch adds a new quirk XHCI_NO_64BIT_SUPPORT to resolve
such an issue.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Reviewed-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Give USB3 devices a better chance to enumerate at USB 3 speeds if
they are connected to a suspended host.
Solves an issue with NEC uPD720200 host hanging when partially
enumerating a USB3 device as USB2 after host controller runtime resume.
Tested-by: Mike Murdoch <main.haarp@gmail.com>
We want the USB fixes in here as well.
xhci driver frees data for all devices, both usb2 and and usb3 the
first time usb_remove_hcd() is called, including td_list and and xhci_ring
structures.
When usb_remove_hcd() is called a second time for the second xhci bus it
will try to dequeue all pending urbs, and touches td_list which is already
freed for that endpoint.
Reported-by: Joe Lawrence <joe.lawrence@stratus.com>
Tested-by: Joe Lawrence <joe.lawrence@stratus.com>
In most cases the devices with the speed set to USB_SPEED_SUPER_PLUS
are handled like regular SuperSpeed devices.
The module should fail to load.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
CC: stable@kernel.org
if a full speed hub connects to a high speed hub which
supports MTT, the MTT field of its slot context will be set
to 1 when xHCI driver setups an xHCI virtual device in
xhci_setup_addressable_virt_dev(); once usb core fetch its
hub descriptor, and need to update the xHC's internal data
structures for the device, the HUB field of its slot context
will be set to 1 too, meanwhile MTT is also set before,
this will cause configure endpoint command fail, so in the
case, we should clear MTT to 0 for full speed hub according
to section 6.2.2
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Cc: stable <stable@vger.kernel.org>
There some vendor quirks for MTK xhci host controller:
1. It defines some extra SW scheduling parameters for HW
to minimize the scheduling effort for synchronous and
interrupt endpoints. The parameters are put into reseved
DWs of slot context and endpoint context.
2. Its IMODI unit for Interrupter Moderation register is
8 times as much as that defined in xHCI spec.
3. Its TDS in Normal TRB defines a number of packets that
remains to be transferred for a TD after processing all
Max packets in all previous TRBs.
Tested-by: Daniel Thompson <daniel.thompson@linaro.org>
Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org>
This patch cleanups the hcd private size to suitable size.
The previous code has "sizeof(struct xhci_hcd *)" in xhci_hc_driver
as hcd_priv_size and sizeof(struct xhci_hcd) in xhci_plat_overrides
or xhci_pci_overrides as extra_priv_size. However, the xhci driver
uses a "sizeof(struct xhcd_hcd)" memory space in each hcd
(main_hcd and shared_hcd) actually.
Existing Intel xHCI controllers require a delay of 1 mS,
after setting the CMD_RESET bit in command register, before
accessing any HC registers. This allows the HC to complete
the reset operation and be ready for HC register access.
Without this delay, the subsequent HC register access,
may result in a system hang, very rarely.
Verified CherryView / Braswell platforms go through over
5000 warm reboot cycles (which was not possible without
this patch), without any xHCI reset hang.
Signed-off-by: Rajmohan Mani <rajmohan.mani@intel.com>
This change avoids DMA error in the cases where dma_mask and
coherent_dma_mask of a 32-bit controller get configured as
DMA_BIT_MASK(64) when running on a 64-bit system.
Signed-off-by: Duc Dang <dhdang@apm.com>
Set the controller speed to HCD_USB31 to if host hardware supports USB 3.1
For PCI xhci controllers the USB 3.1 support is checked from SBRN bits in
pci config space. Platform controllers will need to set xhci->sbrn == 0x31
to indicate USB 3.1 support before calling xhci_gen_setup().
Also make sure xhci driver works correctly with speed set to HCD_USB31
xhci 1.1 capable controllers have a new HCCPARAMS2 registers
with bits indicating support for new xhci 1.1 capabilities.
Also add support for the new xhci 1.1 bits in the config operational
opertational register that used to be reserved
[modified and left out parts not related to HCCPARAMS2 -Mathias]
During quick plug/removal of OTG adapter during dual-role testing
it can happen that xhci_alloc_device() is called for the newly
detected device after the DRD library has called xhci_stop to
remove the HCD.
If that is the case, just fail early to prevent the following warning.
[ 154.732649] hub 4-0:1.0: USB hub found
[ 154.742204] hub 4-0:1.0: 1 port detected
[ 154.824458] hub 3-0:1.0: state 7 ports 1 chg 0002 evt 0000
[ 154.854609] hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 154.944430] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 154.951009] xhci-hcd xhci-hcd.0.auto: xhci_setup_device
[ 155.038191] xhci-hcd xhci-hcd.0.auto: remove, state 4
[ 155.043315] usb usb4: USB disconnect, device number 1
[ 155.055270] xhci-hcd xhci-hcd.0.auto: xhci_stop
[ 155.060094] xhci-hcd xhci-hcd.0.auto: USB bus 4 deregistered
[ 155.066576] xhci-hcd xhci-hcd.0.auto: remove, state 1
[ 155.071710] usb usb3: USB disconnect, device number 1
[ 155.077124] xhci-hcd xhci-hcd.0.auto: xhci_setup_device
[ 155.082389] ------------[ cut here ]------------
[ 155.087690] WARNING: CPU: 0 PID: 72 at drivers/usb/host/xhci.c:3800 xhci_setup_device+0x410/0x484 [xhci_hcd]()
[ 155.097861] Modules linked in: sd_mod usb_storage scsi_mod usb_f_ss_lb g_zero libcomposite ipv6 xhci_plat_hcd xhci_hcd usbcore dwc3 udc_core evdev ti_am335x_adc joydev kfifo_buf industrialio snd_soc_simple_cc
[ 155.146734] CPU: 0 PID: 72 Comm: kworker/0:3 Tainted: G W 4.1.4-00834-gcd9380b-dirty #50
[ 155.156073] Hardware name: Generic AM43 (Flattened Device Tree)
[ 155.162117] Workqueue: usb_hub_wq hub_event [usbcore]
[ 155.167249] Backtrace:
[ 155.169751] [<c0012af0>] (dump_backtrace) from [<c0012c8c>] (show_stack+0x18/0x1c)
[ 155.177390] r6:c089d4a4 r5:ffffffff r4:00000000 r3:ee46c000
[ 155.183137] [<c0012c74>] (show_stack) from [<c05f7c14>] (dump_stack+0x84/0xd0)
[ 155.190446] [<c05f7b90>] (dump_stack) from [<c00439ac>] (warn_slowpath_common+0x80/0xbc)
[ 155.198605] r7:00000009 r6:00000ed8 r5:bf27eb70 r4:00000000
[ 155.204348] [<c004392c>] (warn_slowpath_common) from [<c0043a0c>] (warn_slowpath_null+0x24/0x2c)
[ 155.213202] r8:ee49f000 r7:ee7c0004 r6:00000000 r5:ee7c0158 r4:ee7c0000
[ 155.220051] [<c00439e8>] (warn_slowpath_null) from [<bf27eb70>] (xhci_setup_device+0x410/0x484 [xhci_hcd])
[ 155.229816] [<bf27e760>] (xhci_setup_device [xhci_hcd]) from [<bf27ec10>] (xhci_address_device+0x14/0x18 [xhci_hcd])
[ 155.240415] r10:ee598200 r9:00000001 r8:00000002 r7:00000001 r6:00000003 r5:00000002
[ 155.248363] r4:ee49f000
[ 155.250978] [<bf27ebfc>] (xhci_address_device [xhci_hcd]) from [<bf20cb94>] (hub_port_init+0x1b8/0xa9c [usbcore])
[ 155.261403] [<bf20c9dc>] (hub_port_init [usbcore]) from [<bf2101e0>] (hub_event+0x738/0x1020 [usbcore])
[ 155.270874] r10:ee598200 r9:ee7c0000 r8:ee7c0038 r7:ee518800 r6:ee49f000 r5:00000001
[ 155.278822] r4:00000000
[ 155.281426] [<bf20faa8>] (hub_event [usbcore]) from [<c005754c>] (process_one_work+0x128/0x340)
[ 155.290196] r10:00000000 r9:00000003 r8:00000000 r7:fedfa000 r6:eeec5400 r5:ee598314
[ 155.298151] r4:ee434380
[ 155.300718] [<c0057424>] (process_one_work) from [<c00578f8>] (worker_thread+0x158/0x49c)
[ 155.308963] r10:ee434380 r9:00000003 r8:eeec5400 r7:00000008 r6:ee434398 r5:eeec5400
[ 155.316913] r4:eeec5414
[ 155.319482] [<c00577a0>] (worker_thread) from [<c005cc40>] (kthread+0xdc/0xf8)
[ 155.326765] r10:00000000 r9:00000000 r8:00000000 r7:c00577a0 r6:ee434380 r5:ee4441c0
[ 155.334713] r4:00000000 r3:00000000
[ 155.338341] [<c005cb64>] (kthread) from [<c000fc08>] (ret_from_fork+0x14/0x2c)
[ 155.345626] r7:00000000 r6:00000000 r5:c005cb64 r4:ee4441c0
[ 155.356108] ---[ end trace a58d34c223b190e6 ]---
[ 155.360783] xhci-hcd xhci-hcd.0.auto: Virt dev invalid for slot_id 0x1!
[ 155.574404] xhci-hcd xhci-hcd.0.auto: xhci_setup_device
[ 155.579667] ------------[ cut here ]------------
Signed-off-by: Roger Quadros <rogerq@ti.com>
xhci_stop will be called twice, once for the shared hcd
and again for the primary hcd.
We stop the XHCI controller in any case so clean up
everything on the first call else we can timeout
waiting for pending requests to complete.
For whatever reason if XHCI died in the previous instant
then it will never recover on the next xhci_start unless we
clear the DYING flag.
Else it races with xhci_setup_device
This commit checks for the URB_ZERO_PACKET flag and creates an extra
zero-length td if the urb transfer length is a multiple of the endpoint's
max packet length.
Signed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com>
Replace redundant variable use in return statement.
Signed-off-by: Saurabh Karajgaonkar <skarajga@visteon.com>
We want the USB fixes that went into that release in this branch as
well.
Fix "though" to "through" in documentation of xhci_alloc_streams().
Signed-off-by: Luis de Bethencourt <luis@debethencourt.com>
When resetting a device the number of active TTs may need to be
corrected by xhci_update_tt_active_eps, but the number of old active
endpoints supplied to it was always zero, so the number of TTs and the
bandwidth reserved for them was not updated, and could rise
unnecessarily.
This affected systems using Intel's Patherpoint chipset, which rely on
software bandwidth checking. For example, a Lenovo X230 would lose the
ability to use ports on the docking station after enough suspend/resume
cycles because the bandwidth calculated would rise with every cycle when
a suitable device is attached.
The correct number of active endpoints is calculated in the same way as
in xhci_reserve_bandwidth.
Signed-off-by: Brian Campbell <bacam@z273.org.uk>
This resolves a merge issue in musb_core.c and we want the fixes that
were in Linus's tree in this branch as well for testing.
The comment stating that xhci_setup_device() is protected by the address
mutex is not true since
commit 6fecd4f2a58c ("USB: separate usb_address0 mutexes for each bus")
as xhci handles two buses.
Signed-off-by: Chris Bainbridge <chris.bainbridge@gmail.com>
In the OTG case, the controller might not yet have been
added or is removed before the system suspends.
Assign xhci->main_hcd during probe to prevent NULL
pointer de-reference in xhci_suspend/resume().
Use the hcd->state flag to check if HCD is halted
and if that is so do nothing for xhci_suspend/resume().
[Only for xhci-plat devices, pci devices need it in gen_setup -Mathias]
Don't set xhci->shared_hcd to NULL in xhci_stop() as we have
still not de-allocated it. It was resulting in a NULL pointer
de-reference if usb_add/remove_hcd() is called repeatedly.
We want repeated add/remove to work for the OTG use case.
HCD core allocates memory for HCD private data in
usb_create_[shared_]hcd() so make use of that
mechanism to allocate the struct xhci_hcd.
Introduce struct xhci_driver_overrides to provide
the size of HCD private data and hc_driver operation
overrides. As of now we only need to override the
reset and start methods.
Regression in commit 638139eb95d2 ("usb: hub: allow to process more usb
hub events in parallel")
The regression resulted in intermittent failure to initialise a 10-port
hub (with three internal VL812 4-port hub controllers) on boot, with a
failure rate of around 8%, due to multiple race conditions when
accessing addr_dev and slot_id in struct xhci_hcd.
This regression also exposed a problem with xhci_setup_device, which
"should be protected by the usb_address0_mutex" but no longer is due to
With separate buses (and locks) it is no longer the case that a single
lock will protect xhci_setup_device from accesses by two parallel
threads processing events on the two buses.
Fix this by adding a mutex to protect addr_dev and slot_id in struct
xhci_hcd, and by making the assignment of slot_id atomic.
Fixes multiple boot errors:
[ 0.583008] xhci_hcd 0000:00:14.0: Bad Slot ID 2
[ 0.583009] xhci_hcd 0000:00:14.0: Could not allocate xHCI USB device data structures
[ 0.583012] usb usb1-port3: couldn't allocate usb_device
And:
[ 0.637409] xhci_hcd 0000:00:14.0: Error while assigning device slot ID
[ 0.637417] xhci_hcd 0000:00:14.0: Max number of devices this xHCI host supports is 32.
[ 0.637421] usb usb1-port1: couldn't allocate usb_device
And:
[ 0.753372] xhci_hcd 0000:00:14.0: ERROR: unexpected setup context command completion code 0x0.
[ 0.753373] usb 1-3: hub failed to enable device, error -22
[ 0.753400] xhci_hcd 0000:00:14.0: Error while assigning device slot ID
[ 0.753402] xhci_hcd 0000:00:14.0: Max number of devices this xHCI host supports is 32.
[ 0.753403] usb usb1-port3: couldn't allocate usb_device
And:
[ 11.018386] usb 1-3: device descriptor read/all, error -110
And:
[ 5.753838] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
Tested with 200 reboots, resulting in no USB hub init related errors.
Fixes: 638139eb95d2 ("usb: hub: allow to process more usb hub events in parallel")
Link: https://lkml.kernel.org/g/CAP-bSRb=A0iEYobdGCLpwynS7pkxpt_9ZnwyZTPVAoy0Y=Zo3Q@mail.gmail.com
Cc: <stable@vger.kernel.org> # 3.18+
[changed git commit description style for checkpatch -Mathias]
Fixed regression. After commit 29e409f0f761 ("xhci: Allow xHCI drivers to
be built as separate modules") the module xhci_hcd became non-removable.
That behaviour is not expected and there're no notes about it in commit
message. The module should be removable as it blocks PM suspend/resume
functions (Debian Bug#666406).
Signed-off-by: Arthur Demchenkov <spinal.by@gmail.com>
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Cc: <stable@vger.kernel.org> # v3.18+
This reverts commit 27082e2654dc ("xhci: Clear the host side toggle manually")
Turns out this fix to enable soft resetting endpoints wasn't mature enough.
It caused regression with some usb DVB-T devices and needs some more tuning
to get the endpiont ring pointers set correctly.
The original commit was tagged for stable 3.18, and should be reverted
from there as well.
Cc: stable <stable@vger.kernel.org> # v3.18
Main benefit of this is to get xhci connected USB scanners to work.
Some devices use a clear endpoint halt request as a 'soft reset' even if
the endpoint is not halted. This will clear the toggle and sequence on the
device side. xHCI however refuses to reset a non-halted endpoint, so instead
we need to issue a configure endpoint command on xHCI to clear its host side
toggle and sequence, and get it in sync with the device side.
Tested-by: Mike Mammarella <mikem@crystalorb.net>
When re-applying the configuration after a successful usb device reset,
xhci_discover_or_reset_device has already dropped the endpoints, and free-ed
the rings.
The endpoints already being dropped is expected, and should not lead to
warnings. Use the fact that the rings are also free-ed in this scenario to
detect this, and suppress the "xHCI xhci_drop_endpoint called with disabled
ep ..." message in this case.
Changes in v2:
Move the ring check to only guard the xhci_warn, so as to avoid side-effects
in case we have a scenario where the rings are free-ed, but the endpoint is
not yet dropped.
To help debugging xhci problems.
We want the usb fixes in this branch as well.
Some parameters are not used by functions in xhci-mem.c, just
remove it.
Changes compared to v1:
- Rebase to the latest usb-next branch
Signed-off-by: Lin Wang <lin.x.wang@intel.com>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.data = d;
-t.function = f;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Parameter 'xhci' is no longer be used in function xhci_handshake(),
just remove it.
This patch removes unused variable "out_ctx" and avoid multiple calls
to function xhci_get_endpoint_flag().
