path: root/drivers/usb/host
2009-08-07USB: EHCI: fix counting of transaction error retriesAlan Stern
This patch (as1274) simplifies the counting of transaction-error retries. Now we will count up from 0 to QH_XACTERR_MAX instead of down from QH_XACTERR_MAX to 0. The patch also fixes a small bug: qh->xacterr was not getting initialized for interrupt endpoints. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Matthijs Kooijman <matthijs@stdin.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07USB: EHCI: fix two new bugs related to Clear-TT-BufferAlan Stern
This patch (as1273) fixes two(!) bugs introduced by the new Clear-TT-Buffer implementation in ehci-hcd. It is now possible for an idle QH to have some URBs on its queue -- this will happen if a Clear-TT-Buffer is pending for the QH's endpoint. Consequently we should not issue a warning when someone tries to unlink an URB from an idle QH; instead we should process the request immediately. The refcounts for QHs could get messed up, because submit_async() would increment the refcount when calling qh_link_async() and qh_link_async() would then refuse to link the QH into the schedule if a Clear-TT-Buffer was pending. Instead we should increment the refcount only when the QH actually is added to the schedule. The current code tries to be clever by leaving the refcount alone if an unlink is immediately followed by a relink; the patch changes this to an unconditional decrement and increment (although they occur in the opposite order). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Tested-by: Manuel Lauss <manuel.lauss@gmail.com> Tested-by: Matthijs Kooijman <matthijs@stdin.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Stall handling bug fixes.Sarah Sharp
Correct the xHCI code to handle stalls on USB endpoints. We need to move the endpoint ring's dequeue pointer past the stalled transfer, or the HW will try to restart the transfer the next time the doorbell is rung. Don't attempt to clear a halt on an endpoint if we haven't seen a stalled transfer for it. The USB core will attempt to clear a halt on all endpoints when it selects a new configuration. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Support for 64-byte contextsJohn Youn
Adds support for controllers that use 64-byte contexts. The following context data structures are affected by this: Device, Input, Input Control, Endpoint, and Slot. To accommodate the use of either 32 or 64-byte contexts, a Device or Input context can only be accessed through functions which look-up and return pointers to their contained contexts. Signed-off-by: John Youn <johnyoun@synopsys.com> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Always align output device contexts to 64 bytes.Sarah Sharp
Make sure the xHCI output device context is 64-byte aligned. Previous code was using the same structure for both the output device context and the input control context. Since the structure had 32 bytes of flags before the device context, the output device context wouldn't be 64-byte aligned. Define a new structure to use for the output device context and clean up the debugging for these two structures. The copy of the device context in the input control context does *not* need to be 64-byte aligned. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Scratchpad buffer allocationJohn Youn
Allocates and initializes the scratchpad buffer array (XHCI 4.20). This is an array of 64-bit DMA addresses to scratch pages that the controller may use during operation. The number of pages is specified in the "Max Scratchpad Buffers" field of HCSPARAMS2. The DMA address of this array is written into slot 0 of the DCBAA. Signed-off-by: John Youn <johnyoun@synopsys.com> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Fail gracefully if there's no SS ep companion descriptor.Sarah Sharp
This is a work around for a bug in the SuperSpeed Endpoint Companion Descriptor parsing code. It fails in some corner cases, which means ep->ss_ep_comp may be NULL. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Handle babble errors on transfers.Sarah Sharp
Pass back a babble error when this error code is seen in the transfer event TRB. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Setup HW retries correctly.Sarah Sharp
The xHCI host controller can be programmed to retry a transfer a certain number of times per endpoint before it passes back an error condition to the host controller driver. The xHC will return an error code when the error count transitions from 1 to 0. Programming an error count of 3 means the xHC tries the transfer 3 times, programming it with a 1 means it tries to transfer once, and programming it with 0 means the HW tries the transfer infinitely. We want isochronous transfers to only be tried once, so set the error count to one. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Check if the host controller died in IRQ handler.Sarah Sharp
2009-07-28USB: xhci: Don't oops if the host doesn't halt.Sarah Sharp
2009-07-28USB: xhci: Make debugging more verbose.Sarah Sharp
Add more debugging to the irq handler, slot context initialization, ring operations, URB cancellation, and MMIO writes. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Correct Event Handler Busy flag usage.Sarah Sharp
The Event Handler Busy bit in the event ring dequeue pointer is write 1 to clear. Fix the interrupt service routine to clear that bit after the event handler has run. xhci_set_hc_event_deq() is designed to update the event ring dequeue pointer without changing any of the four reserved bits in the lower nibble. The event handler busy (EHB) bit is write one to clear, so the new value must always contain a zero in that bit in order to preserve the EHB value. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Handle short control packets correctly.Sarah Sharp
When there is a short packet on a control transfer, the xHCI host controller hardware will generate two events. The first event will be for the data stage TD with a completion code for a short packet. The second event will be for the status stage with a successful completion code. Before this patch, the xHCI driver would giveback the short control URB when it received the event for the data stage TD. Then it would become confused when it saw a status stage event for the endpoint for an URB it had already finished processing. Change the xHCI host controller driver to wait for the status stage event when it receives a short transfer completion code for a data stage TD. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Represent 64-bit addresses with one u64.Sarah Sharp
There are several xHCI data structures that use two 32-bit fields to represent a 64-bit address. Since some architectures don't support 64-bit PCI writes, the fields need to be written in two 32-bit writes. The xHCI specification says that if a platform is incapable of generating 64-bit writes, software must write the low 32-bits first, then the high 32-bits. Hardware that supports 64-bit addressing will wait for the high 32-bit write before reading the revised value, and hardware that only supports 32-bit writes will ignore the high 32-bit write. Previous xHCI code represented 64-bit addresses with two u32 values. This lead to buggy code that would write the 32-bits in the wrong order, or forget to write the upper 32-bits. Change the two u32s to one u64 and create a function call to write all 64-bit addresses in the proper order. This new function could be modified in the future if all platforms support 64-bit writes. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Use GFP_ATOMIC while holding spinlocks.Sarah Sharp
The xHCI functions to queue an URB onto the hardware rings must be called with the xhci spinlock held. Those functions will allocate memory, and take a gfp_t memory flags argument. We must pass them the GFP_ATOMIC flag, since we don't want the memory allocation to attempt to sleep while waiting for more memory to become available. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Deal with stalled endpoints.Sarah Sharp
When an endpoint on a device under an xHCI host controller stalls, the host controller driver must let the hardware know that the USB core has successfully cleared the halt condition. The HCD submits a Reset Endpoint Command, which will clear the toggle bit for USB 2.0 devices, and set the sequence number to zero for USB 3.0 devices. The xHCI urb_enqueue will accept new URBs while the endpoint is halted, and will queue them to the hardware rings. However, the endpoint doorbell will not be rung until the Reset Endpoint Command completes. Don't queue a reset endpoint command for root hubs. khubd clears halt conditions on the roothub during the initialization process, but the roothub isn't a real device, so the xHCI host controller doesn't need to know about the cleared halt. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: Set TD size in transfer TRB.Sarah Sharp
The 0.95 xHCI specification requires software to set the "TD size" field in each transaction request block (TRB). This field gives the host controller an indication of how much data is remaining in the TD (including the buffer in the current TRB). Set this field in bulk TRBs and data stage TRBs for control transfers. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: xhci: fix less- and greater than confusionRoel Kluin
Without this change the loops won't start Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: ehci-orion: Call ehci_reset before ehci_haltSimon Kagstrom
I noticed that USB initialization didn't setup correctly on my kirkwood based board (OpenRD base) if I hadn't initialized USB in U-boot first. The error message looks like this: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver orion-ehci orion-ehci.0: Marvell Orion EHCI orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1 orion-ehci orion-ehci.0: can't setup orion-ehci orion-ehci.0: USB bus 1 deregistered orion-ehci orion-ehci.0: init orion-ehci.0 fail, -110 orion-ehci: probe of orion-ehci.0 failed with error -110 which is caused by ehci_halt() timing out in the handshake() call. I noticed that U-boot does a reset before calling handshake(), so this patch does the same thing for Linux. USB now works for me. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: OMAP: OHCI: hc_driver's stop method should call ohci_stopAnand Gadiyar
OMAP: OHCI: hc_driver's stop method should call ohci_stop Without this, the ohci-omap driver will not cleanup the debugfs nodes when the driver is unloaded. So the next insmod will fail, if CONFIG_DEBUG_FS and CONFIG_USB_DEBUG are both selected. Reported-by: vikram pandita <vikram.pandita@ti.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (48 commits) USB: otg: fix module reinsert issue USB: handle zero-length usbfs submissions correctly USB: EHCI: report actual_length for iso transfers USB: option: remove unnecessary and erroneous code USB: cypress_m8: remove invalid Clear-Halt USB: musb_host: undo incorrect change in musb_advance_schedule() USB: fix LANGID=0 regression USB: serial: sierra driver id_table additions USB serial: Add ID for Turtelizer, an FT2232L-based JTAG/RS-232 adapter. USB: fix race leading to a write after kfree in usbfs USB: Sierra: fix oops upon device close USB: option.c: add A-Link 3GU device id USB: Serial: Add support for Arkham Technology adapters USB: Fix option_ms regression in 2.6.31-rc2 USB: gadget audio: select SND_PCM USB: ftdi: support NDI devices Revert USB: usbfs: deprecate and hide option for !embedded USB: usb.h: fix kernel-doc notation USB: RNDIS gadget, fix issues talking from PXA USB: serial: FTDI with product code FB80 and vendor id 0403 ...
2009-07-12USB: EHCI: report actual_length for iso transfersAlan Stern
This patch (as1259b) makes ehci-hcd return the total number of bytes transferred in urb->actual_length for Isochronous transfers. Until now, the actual_length value was unaccountably left at 0. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: EHCI: check for STALL before other errorsAlan Stern
This patch (as1257) revises the way ehci-hcd detects STALLs. The logic is a little peculiar because there's no hardware status bit specifically meant to indicate a STALL. You just have to guess that a STALL was received if the BABBLE bit (which is fatal) isn't set and the transfer stopped before all its retries were used up. The existing code doesn't do this properly, because it tests for MMF (Missed MicroFrame) and DBE (Data Buffer Error) before testing the retry counter. Thus, if a transaction gets either MMF or DBE the corresponding flag is set and the transaction is retried. If the second attempt receives a STALL then -EPIPE is the correct return value. But the existing code would see the MMF or DBE flag instead and return -EPROTO, -ENOSR, or -ECOMM. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: EHCI: use the new clear_tt_buffer interfaceAlan Stern
This patch (as1256) changes ehci-hcd and all the other drivers in the EHCI family to make use of the new clear_tt_buffer callbacks. When a Clear-TT-Buffer request is in progress for a QH, the QH is not allowed to be linked into the async schedule until the request is finished. At that time, if there are any URBs queued for the QH, it is linked into the async schedule. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: fix the clear_tt_buffer interfaceAlan Stern
This patch (as1255) updates the interface for calling usb_hub_clear_tt_buffer(). Even the name of the function is changed! When an async URB (i.e., Control or Bulk) going through a high-speed hub to a non-high-speed device is cancelled or fails, the hub's Transaction Translator buffer may be left busy still trying to complete the transaction. The buffer has to be cleared; that's what usb_hub_clear_tt_buffer() does. It isn't safe to send any more URBs to the same endpoint until the TT buffer is fully clear. Therefore the HCD needs to be told when the Clear-TT-Buffer request has finished. This patch adds a callback method to struct hc_driver for that purpose, and makes the hub driver invoke the callback at the proper time. The patch also changes a couple of names; "hub_tt_kevent" and "tt.kevent" now look rather antiquated. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: buildfix ppc randconfigArnd Bergmann
We could just make the USB_OHCI_HCD_PPC_OF option implicit and selected only if at least one of USB_OHCI_HCD_PPC_OF_BE and USB_OHCI_HCD_PPC_OF_LE are set. [ dbrownell@users.sourceforge.net: fix patch manglation and dependencies ] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Subrata Modak <subrata@linux.vnet.ibm.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: isp1760: use __devexit_p() for remove functionMike Frysinger
The isp1760_plat_remove function is declared with __devexit, so the .remove assignment needs to be wrapped with __devexit_p(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: EHCI: update toggle state for linked QHsAlan Stern
This is an update to the "usb-ehci-update-toggle-state-for-linked-qhs" patch. Since an HCD's endpoint_reset method can be called in interrupt context, it mustn't assume that interrupts are enabled or that it can sleep. So we revert to the original way of refreshing QHs' toggle bits. Now the endpoint_reset method merely clears the toggle flag in the device structure (as was done before) and starts an async QH unlink. When the QH is linked again, after the unlink finishes and an URB is queued, the qh_refresh() routine will update the QH's toggle bit. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: David <david@unsolicited.net> CC: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: fhci: mutually exclusive port_statusRoel Kluin
FHCI_PORT_DISABLED, -LOW and -FULL are mutually exclusive as status. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05usb: allow sh7724 to enable on-chip r8a66597Magnus Damm
The sh7724 processor has two on-chip r8a66597 blocks, so add it to the list of processors for SUPERH_ON_CHIP_R8A66597. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-18Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (143 commits) USB: xhci depends on PCI. USB: xhci: Add Makefile, MAINTAINERS, and Kconfig entries. USB: xhci: Respect critical sections. USB: xHCI: Fix interrupt moderation. USB: xhci: Remove packed attribute from structures. usb; xhci: Fix TRB offset calculations. USB: xhci: replace if-elseif-else with switch-case USB: xhci: Make xhci-mem.c include linux/dmapool.h USB: xhci: drop spinlock in xhci_urb_enqueue() error path. USB: Change names of SuperSpeed ep companion descriptor structs. USB: xhci: Avoid compiler reordering in Link TRB giveback. USB: xhci: Clean up xhci_irq() function. USB: xhci: Avoid global namespace pollution. USB: xhci: Fix Link TRB handoff bit twiddling. USB: xhci: Fix register write order. USB: xhci: fix some compiler warnings in xhci.h USB: xhci: fix lots of compiler warnings. USB: xhci: use xhci_handle_event instead of handle_event USB: xhci: URB cancellation support. USB: xhci: Scatter gather list support for bulk transfers. ...
2009-06-15USB: xhci depends on PCI.Paul Mundt
While it looks like xhci was written with both PCI and non-PCI in mind, apparently only the former has seen any testing. xhci-mem.o can be "fixed" with a linux/dmapool.h include, but there are still parts of the code that make use of struct pci_dev directly. So, at least more work is needed before this can be turned on for non-PCI builds: CC drivers/usb/host/xhci-mem.o drivers/usb/host/xhci-mem.c: In function 'xhci_segment_alloc': drivers/usb/host/xhci-mem.c:45: error: implicit declaration of function 'dma_pool_alloc' drivers/usb/host/xhci-mem.c:45: warning: assignment makes pointer from integer without a cast drivers/usb/host/xhci-mem.c: In function 'xhci_segment_free': drivers/usb/host/xhci-mem.c:67: error: implicit declaration of function 'dma_pool_free' drivers/usb/host/xhci-mem.c: In function 'xhci_alloc_virt_device': drivers/usb/host/xhci-mem.c:239: warning: assignment makes pointer from integer without a cast drivers/usb/host/xhci-mem.c:248: warning: assignment makes pointer from integer without a cast drivers/usb/host/xhci-mem.c: In function 'xhci_mem_cleanup': drivers/usb/host/xhci-mem.c:578: error: implicit declaration of function 'dma_pool_destroy' drivers/usb/host/xhci-mem.c: In function 'xhci_mem_init': drivers/usb/host/xhci-mem.c:657: error: implicit declaration of function 'dma_pool_create' drivers/usb/host/xhci-mem.c:658: warning: assignment makes pointer from integer without a cast drivers/usb/host/xhci-mem.c:663: warning: assignment makes pointer from integer without a cast make[3]: *** [drivers/usb/host/xhci-mem.o] Error 1 CC drivers/usb/host/xhci-pci.o drivers/usb/host/xhci-pci.c: In function 'xhci_pci_reinit': drivers/usb/host/xhci-pci.c:39: error: implicit declaration of function 'pci_set_mwi' drivers/usb/host/xhci-pci.c: At top level: drivers/usb/host/xhci-pci.c:151: error: 'usb_hcd_pci_probe' undeclared here (not in a function) drivers/usb/host/xhci-pci.c:152: error: 'usb_hcd_pci_remove' undeclared here (not in a function) drivers/usb/host/xhci-pci.c:155: error: 'usb_hcd_pci_shutdown' undeclared here (not in a function) drivers/usb/host/xhci-pci.c:159: warning: function declaration isn't a prototype drivers/usb/host/xhci-pci.c:164: warning: function declaration isn't a prototype make[3]: *** [drivers/usb/host/xhci-pci.o] Error 1 Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Add Makefile, MAINTAINERS, and Kconfig entries.Sarah Sharp
Add Makefile and Kconfig entries for the xHCI host controller driver. List Sarah Sharp as the maintainer for the xHCI driver. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Respect critical sections.Sarah Sharp
Narrow down time spent holding the xHCI spinlock so that it's only used to protect the xHCI rings, not as mutual exclusion. Stop allocating memory while holding the spinlock and calling xhci_alloc_virt_device() and xhci_endpoint_init(). The USB core should have locking in it to prevent device state to be manipulated by more than one kernel thread. E.g. you can't free a device while you're in the middle of setting a new configuration. So removing the locks from the sections where xhci_alloc_dev() and xhci_reset_bandwidth() touch xHCI's representation of the device should be OK. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xHCI: Fix interrupt moderation.Sarah Sharp
Mask off the lower 16 bits of the interrupt control register, instead of masking off the upper 16 bits. The interrupt moderation interval field is the lower 16 bytes, and is set to 0x4000 (1ms) by default. The previous code was adding 40 us to the default value, instead of setting it to 40 us. This makes performance really bad. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Remove packed attribute from structures.Sarah Sharp
The packed attribute allows gcc to muck with the alignment of data structures, which may lead to byte-wise writes that break atomicity of writes. Packed should only be used when the compile may add undesired padding to the structure. Each element of the structure will be aligned by C based on its size and the size of the elements around it. E.g. a u64 would be aligned on an 8 byte boundary, the next u32 would be aligned on a four byte boundary, etc. Since most of the xHCI structures contain only u32 bit values, removing the packed attribute for them should be harmless. (A future patch will change some of the twin 32-bit address fields to one 64-bit field, but all those places have an even number of 32-bit fields before them, so the alignment should be correct.) Add BUILD_BUG_ON statements to check that the compiler doesn't add padding to the data structures that have a hardware-defined layout. While we're modifying the registers, change the name of intr_reg to xhci_intr_reg to avoid global conflicts. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15usb; xhci: Fix TRB offset calculations.Sarah Sharp
Greg KH introduced a bug into xhci_trb_virt_to_dma() when he changed the type of offset to dma_addr_t from unsigned int and dropped the casts to unsigned int around the virtual address pointer subtraction. trb and seg->trbs are both valid pointers to virtual addresses, so the compiler will mod the subtraction by the size of union trb (16 bytes). segment_offset is an unsigned long, which is guaranteed to be at least as big as a void *. Drop the void * casts in the first if statement because trb and seg->trbs are both pointers of the same type (pointers to union trb). Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Make xhci-mem.c include linux/dmapool.hSarah Sharp
xhci-mem.c includes calls to dma_pool_alloc() and other functions defined in linux/dmapool.h. Make sure to include that header file. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: drop spinlock in xhci_urb_enqueue() error path.Sarah Sharp
Make sure the error path in xhci_urb_enqueue() releases the spinlock before it returns. Reported by Oliver in http://marc.info/?l=linux-usb&m=124091637311832&w=2 Reported-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: Change names of SuperSpeed ep companion descriptor structs.Sarah Sharp
Differentiate between SuperSpeed endpoint companion descriptor and the wireless USB endpoint companion descriptor. Make all structure names for this descriptor have "ss" (SuperSpeed) in them. David Vrabel asked for this change in http://marc.info/?l=linux-usb&m=124091465109367&w=2 Reported-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Avoid compiler reordering in Link TRB giveback.Sarah Sharp
Force the compiler to write the cycle bit of the Link TRB last. This ensures that the hardware doesn't think it owns the Link TRB before we set the chain bit. Reported by Oliver in this thread: http://marc.info/?l=linux-usb&m=124091532410219&w=2 Reported-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Clean up xhci_irq() function.Sarah Sharp
Drop spinlock in xhci_irq() error path. This fixes the issue reported by Oliver Neukum on this thread: http://marc.info/?l=linux-usb&m=124090924401444&w=2 Remove unnecessary register read reported by Viral Mehta: http://marc.info/?l=linux-usb&m=124091326007398&w=2 Reported-by: Oliver Neukum <oliver@neukum.org> Reported-by: Viral Mehta <viral.mehta@einfochips.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Avoid global namespace pollution.Sarah Sharp
Make all globally visible functions start with xhci_ and mark functions as static if they're only called within the same C file. Fix some long lines while we're at it. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Fix Link TRB handoff bit twiddling.Sarah Sharp
Make sure to preserve all bits *except* the TRB_CHAIN bit when giving a Link TRB to the hardware. We need to save things like TRB type and the toggle bit in the control dword. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: Fix register write order.Sarah Sharp
The 0.95 xHCI spec says that if the xHCI HW support 64-bit addressing, you must write the whole 64-bit address as one atomic operation, or write the low 32 bits, and then the high 32 bits. I had the register writes swapped in some places. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: fix some compiler warnings in xhci.hGreg Kroah-Hartman
This fixes the warning: drivers/usb/host/xhci.h:1083: warning: passing argument 1 of ‘xhci_to_hcd’ discards qualifiers from pointer target type drivers/usb/host/xhci.h:1083: warning: passing argument 1 of ‘xhci_to_hcd’ discards qualifiers from pointer target type Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: xhci: fix lots of compiler warnings.Greg Kroah-Hartman
Turns out someone never built this code on a 64bit platform. Someone owes me a beer... Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
