path: root/drivers/usb/image
2017-11-13Merge tag 'usb-4.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB/PHY updates from Greg KH: "Here is the big set of USB and PHY driver updates for 4.15-rc1. There is the usual amount of gadget and xhci driver updates, along with phy and chipidea enhancements. There's also a lot of SPDX tags and license boilerplate cleanups as well, which provide some churn in the diffstat. Other major thing is the typec code that moved out of staging and into the "real" part of the drivers/usb/ tree, which was nice to see happen. All of these have been in linux-next with no reported issues for a while" * tag 'usb-4.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (263 commits) usb: gadget: f_fs: Fix use-after-free in ffs_free_inst USB: usbfs: compute urb->actual_length for isochronous usb: core: message: remember to reset 'ret' to 0 when necessary USB: typec: Remove remaining redundant license text USB: typec: add SPDX identifiers to some files USB: renesas_usbhs: rcar?.h: add SPDX tags USB: chipidea: ci_hdrc_tegra.c: add SPDX line USB: host: xhci-debugfs: add SPDX lines USB: add SPDX identifiers to all remaining Makefiles usb: host: isp1362-hcd: remove a couple of redundant assignments USB: adutux: remove redundant variable minor usb: core: add a new usb_get_ptm_status() helper usb: core: add a 'type' parameter to usb_get_status() usb: core: introduce a new usb_get_std_status() helper usb: core: rename usb_get_status() 'type' argument to 'recip' usb: core: add Status Type definitions USB: gadget: Remove redundant license text USB: gadget: function: Remove redundant license text USB: gadget: udc: Remove redundant license text USB: gadget: legacy: Remove redundant license text ...
2017-11-07USB: add SPDX identifiers to all remaining MakefilesGreg Kroah-Hartman
It's good to have SPDX identifiers in all files to make it easier to audit the kernel tree for correct licenses. This updates the remaining drivers/usb/*Makefile* that were missing SPDX identifiers. They all get the following identifier: SPDX-License-Identifier: GPL-2.0 The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Kate Stewart <kstewart@linuxfoundation.org> Cc: Philippe Ombredanne <pombredanne@nexb.com> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: Johan Hovold <johan@kernel.org> Acked-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-04USB: image: Remove redundant license textGreg Kroah-Hartman
Now that the SPDX tag is in all USB files, that identifies the license in a specific and legally-defined manner. So the extra GPL text wording can be removed as it is no longer needed at all. This is done on a quest to remove the 700+ different ways that files in the kernel describe the GPL license text. And there's unneeded stuff like the address (sometimes incorrect) for the FSF which is never needed. No copyright headers or other non-license-description text was removed. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-04USB: add SPDX identifiers to all remaining files in drivers/usb/Greg Kroah-Hartman
It's good to have SPDX identifiers in all files to make it easier to audit the kernel tree for correct licenses. Update the drivers/usb/ and include/linux/usb* files with the correct SPDX license identifier based on the license text in the file itself. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This work is based on a script and data from Thomas Gleixner, Philippe Ombredanne, and Kate Stewart. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Kate Stewart <kstewart@linuxfoundation.org> Cc: Philippe Ombredanne <pombredanne@nexb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> Acked-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-01usb: image: mdc800: mark expected switch fall-throughGustavo A. R. Silva
In preparation to enabling -Wimplicit-fallthrough, mark switch cases where we are expecting to fall through. Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-22USB: microtek: remove unneeded DRIVER_VERSION macroGreg Kroah-Hartman
No one uses the DRIVER_VERSION define in this driver, so just delete it. Cc: Oliver Neukum <oneukum@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-02sched/headers: Prepare to move signal wakeup & sigpending methods from ↵Ingo Molnar
<linux/sched.h> into <linux/sched/signal.h> Fix up affected files that include this signal functionality via sched.h. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-07usb: microtek: Use "foo *bar" instead of "foo * bar".Sandhya Bankar
Use "foo *bar" instead of "foo * bar". Signed-off-by: Sandhya Bankar <bankarsandhya512@gmail.com> Acked-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-31scsi: Do not set cmd_per_lun to 1 in the host templateHannes Reinecke
'0' is now used as the default cmd_per_lun value, so there's no need to explicitly set it to '1' in the host template. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-03-18USB: image: use msecs_to_jiffies for time conversionNicholas Mc Guire
This is only an API consolidation and should make things more readable it replaces var * HZ / 1000 by msecs_to_jiffies(var). Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09USB: use %*ph specifier in mikrotek driverAndy Shevchenko
There is a %*ph specifier that allows to dump small buffers. This patch converts the code to use the specifier. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08USB: image: correct spelling mistake in commentRahul Bedarkar
Signed-off-by: Rahul Bedarkar <rahulbedarkar89@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08usb: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-09USB: regroup all depends on USB within an if USB blockFlorian Fainelli
This patch removes the depends on USB from all config symbols in drivers/usb/host/Kconfig and replace that with an if USB / endif block as suggested by Alan Stern. Some source ... Kconfig lines have been shuffled around to permit a better regroupment of the Kconfig files depending on "config USB" item. No functionnal change is introduced. Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-01USB: mdc800.c: remove dbg() usageGreg Kroah-Hartman
dbg() was a very old USB-specific macro that should no longer be used. This patch removes it from being used in the driver and uses dev_dbg() instead. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-11-18USB: convert drivers/usb/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/usb/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Simon Arlott <cxacru@fire.lp0.eu> Cc: Duncan Sands <duncan.sands@free.fr> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Oliver Neukum <oliver@neukum.name> Cc: Juergen Stuber <starblue@users.sourceforge.net> Cc: Cesar Miquel <miquel@df.uba.ar> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Michael Hund <mhund@ld-didactic.de> Cc: Zack Parsons <k3bacon@gmail.com> Cc: Melchior FRANZ <mfranz@aon.at> Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Cc: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-10drivers/usb: Remove unnecessary return's from void functionsJoe Perches
Greg prefers this to go through the trivial tree. http://lkml.org/lkml/2010/6/24/1 There are about 2500 void functions in drivers/usb Only a few used return; at end of function. Standardize them a bit. Moved a statement down a line in drivers/usb/host/u132-hcd.c Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-02USB: BKL removal: mdc800Oliver Neukum
BKL not needed at all. Removed without replacement. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: Push BKL on open down into the driversOliver Neukum
Straightforward push into the drivers to allow auditing individual drivers separately Signed-off-by: Oliver Neukum <oliver@neukum.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB image: make USB device id constantNémeth Márton
The id_table field of the struct usb_device_id is constant in <linux/usb.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Németh Márton <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: remove unneeded printks from microtek driverOliver Neukum
These printks can be removed as they only provide information about the driver not the device and nobody has ever provided feedback. Signed-off-by: Oliver Neukum <oliver@neukum.org>
2009-03-24USB: replace uses of __constant_{endian}Harvey Harrison
The base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-17USB: image/mdc800, fix lock imbalanceJiri Slaby
There is an omitted unlock in mdc800_usb_probe's fail path. Add it. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Henning Zabel <henning@uni-paderborn.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: change interface to usb_lock_device_for_reset()Alan Stern
This patch (as1161) changes the interface to usb_lock_device_for_reset(). The existing interface is apparently not very clear, judging from the fact that several of its callers don't use it correctly. The new interface always returns 0 for success and it always requires the caller to unlock the device afterward. The new routine will not return immediately if it is called while the driver's probe method is running. Instead it will wait until the probe is over and the device has been unlocked. This shouldn't cause any problems; I don't know of any cases where drivers call usb_lock_device_for_reset() during probe. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove err() macro from more usb driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove err() and use the system-wide standard of dev_err() wherever possible. In the few places that will not work out, use a basic printk(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove info() macro from remaining usb driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. In the few places that will not work out, use a basic printk(). Clean up the remaining usages of this in the drivers/usb/ directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove warn() macro from usb driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove warn() and use the system-wide standard of dev_warn() wherever possible. In the few places that will not work out, use a basic printk(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24usb: replace remaining __PRETTY_FUNCTION__ occurrencesHarvey Harrison
The kernel is written in C, not C++, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: Remove EXPERIMENTAL designation from USB MDC800 support.Robert P. J. Day
Since support for the USB Mustek MDC800 Digital Camera has apparently been around since the beginning of the git repository, it's safe to assume it's no longer experimental. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: microtek: remove unused semaphoreDaniel Walker
No current references, so removing it. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Drop unnecessary continue in a few driversJulia Lawall
Continue is not needed at the bottom of a loop. The semantic patch implementing this change is as follows: @@ @@ for (...;...;...) { ... if (...) { ... - continue; } } Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: make the microtek driver and HAL cooperateOliver Neukum
to make HAL like the microtek driver's devices the parent must be correctly set. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12[SCSI] microtek: use data accessors and !use_sg cleanupBoaz Harrosh
- use scsi_cmnd data accessors - Clean the !use_sg code paths Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> [jejb: merge conflict fix] Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-19USB: image: microtek: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19USB: image: mdc800: clean up urb->status usageGreg Kroah-Hartman
2007-02-07USB: race on disconnect in mdc800Oliver Neukum
I overlooked one. Setting the flag and killing the URBs must be under the lock so that no URB is submitted after usb_kill_urb() Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01usb: microtek possible memleak fixMariusz Kozlowski
Possible memleak fix on error path. The changes: - out_kfree2 and out_free_urb replaced - missing scsi_host_put() added Here it goes: Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-28USB: microtek usb scanner: Scsi_Cmnd conversionHenrik Kretzschmar
Converts obsolete typedef'd Scsi_Cmnd into struct scsi_cmnd. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
