This will allow concentrating all input devices in one place
in {menu|x|q}config.
usb_buffer_free() now handles NULLs so remove unneeded checks
form callers.
In preparation for struct class_device -> struct device input
core conversion, switch to using input_dev->dev.parent when
specifying device position in sysfs tree.
Use input_get_drvdata() and input_set_drvdata() instead.
SLAB_ATOMIC is an alias of GFP_ATOMIC
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
This patch fixes a memory leak and a kernel oops when trying to unload
the driver, due to an unbalanced cleanup.
Thanks Ivar Jensen for spotting my mistake.
Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Move <linux/usb_input.h> to <linux/usb/input.h> and remove some
redundant includes.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
drivers/usb/input/yealink.c: In function `usb_probe':
drivers/usb/input/yealink.c:910: warning: int format, different type arg (arg 4)
This should fix things mentioned below:
"I was curious why my firewall was loading a 'phone driver'.
It turns out that the probing in the yealink driver is
a little too assuming..
static struct usb_device_id usb_table [] = {
{ USB_INTERFACE_INFO(USB_CLASS_HID, 0, 0) },
So it picked up my UPS, and loaded the driver.
Whilst no harm came, because it later checks the vendor/product IDs,
this driver should probably be rewritten to only probe
for the device IDs it actually knows about.
Dave"
It is no longer needed, so let's remove it, saving a bit of memory.
Input: convert drivers/iusb/input to dynamic input_dev allocation
This is required for input_dev sysfs integration
sparse still complains about the htons usage, but I'll leave that for
others to fix.
This patch aggregates all modifications in the -mm tree and adds
complete ringtone support.
The following features are supported:
- keyboard full support
- LCD full support
- LED full support
- dialtone full support
- ringtone full support
- audio playback via generic usb audio diver
- audio record via generic usb audio diver
For driver documentation see: Documentation/input/yealink.txt
For vendor documentation see: http://yealink.com
Signed-off-by: Henk <Henk.Vergonet@gmail.com>
