path: root/drivers/usb/misc/Makefile
2010-10-22usb: makefile cleanupmatt mooney
For all modules, change <module>-objs to <module>-y; remove if-statements and replace with lists using the kbuild idiom; move flags to the top of the file; and fix alignment while trying to maintain the original scheme in each file. None of the dependencies are modified. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22usb: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: add driver for Meywa-Denki & Kayac YUREXTomoki Sekiyama
Meywa-Denki/Kayac YUREX is a leg-shakes sensor device. See http://bbu.kayac.com/en/about/ for further information. This driver support read/write the leg-shakes counter in the device via a device file /dev/yurex[0-9]*. [minor coding style cleanups fixed by gregkh] Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., ↵Dennis O'Brien
devices and spectrometers This patch removes the vstusb driver and support from the Linux tree. This driver provided support for Vernier Software & Technology devices and spectrometers (Ocean Optics). This driver is being replaced by a user space - libusb - implementation. Signed-off-by: Jim Collar <jim.collar@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: remove the berry_charge driverGreg Kroah-Hartman
The Barry project's userspace program, bcharge, can better handle this device and functionality, and it also works with the latest phones, which this driver does not support. So remove it, as the userspace code should be used instead. Cc: Chris Frey <cdfrey@foursquare.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: remove phidget drivers from kernel tree.Greg Kroah-Hartman
These devices are better controlled with the LGPL userspace library found at: http://www.phidgets.com/downloads.php?os_id=3 and full documentation at: http://www.phidgets.com/documentation/web/cdoc/index.html Cc: Chester Fitchett <fitchett@phidgets.com> Acked-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17usb: vstusb.c : new driver for spectrometers used by Vernier Software & ↵Stephen Ware
Technology, Inc. This patch adds the vstusb driver to the drivers/usb/misc directory. This driver provides support for Vernier Software & Technology spectrometers, all made by Ocean Optics. The driver provides both IOCTL and read()/write() methods for sending raw data to spectrometers across the bulk channel. Each method allows for a configured timeout. From: Stephen Ware <stephen.ware@eqware.net> Signed-off-by: Dennis O'Brien <dennis.obrien@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Added driver for a Delcom USB 7-segment LED DisplayHarrison Metzger
Added basic support for a Delcom USB 7-segment LED Display Signed-off by: Harrison Metzger <harrisonmetz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13usb: auerswald: remove driver (obsolete)Wolfgang Mües
This patch removes the auerswald USB driver from the linux kernel 2.6.26. This driver was included into the kernel mainly to connect to the ISDN framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile and moving ISDN support, this connection was never realized, and the only use of this driver was for device configuration. In the age of DSL, the demand of ISDN support is getting very low. Meanwhile, with the advent of libusb, an userspace driver was done for the device configuration which works fine for linux and mac. (Thanks to the libusb developers!). The userspace driver is downloadable from the auerswald web site. So this driver is obsolete now and has to be removed. Many thanks to all developers which helped me to bring this driver up and working. Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: Firmware loader driver for USB Apple iSight cameraMatthew Garrett
Uninitialised Apple iSight drivers present with a distinctive USB ID. Once firmware has been uploaded, they disconnect and reconnect with a new ID. At this point they can be driven by the uvcvideo driver. As this is unique to the Apple cameras and not functionality shared by any other UVC devices, it makes sense to provide the firmware loading functionality in a separate driver. This driver will read an isight.fw file extracted from the Apple driver using the tools at http://bersace03.free.fr/ift/ and upload it to the camera. It will also handle the case where the device loses its firmware during hibernation and must have it reloaded. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23USB: add driver for iowarrior devices.Greg Kroah-Hartman
The ioctl is commented out for now, until we verify some userspace application issues. Cc: Christian Lucht <lucht@codemercs.com> Cc: Robert Marquardt <marquardt@codemercs.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: Driver to charge USB blackberry devicesGreg Kroah-Hartman
A simple driver to turn on the charging capability of a USB BlackBerry device when it is plugged into the machine. It does not bind to the device, so all userspace programs can still sync properly with it. Note, if CONFIG_USB_SUSPEND is enabled, it can play havoc with this device as the power to the port will be shut down. This device id will have to be added to the global blacklist table when it is created. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01USB: build the appledisplay driverAdrian Bunk
We do already have both the code and a config option, so why not build this driver? ;-) Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17USB: move trancevibrator.c to the proper usb directoryGreg Kroah-Hartman
It's not a input driver, so it doesn't belong in the input directory. Cc: Sam Hocevar <sam@zoy.org> Cc: Dmitry Torokhov <dtor@insightbb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: ftdi-elan: client driver for ELAN Uxxx adaptersTony Olech
This "ftdi-elan" module is one half of the "driver" for ELAN's Uxxx series adapters which are USB to PCMCIA CardBus adapters. Currently only the U132 adapter is available and it's module is called "u132-hcd". When the USB hot plug subsystem detects a Uxxx series adapter it should load this module. Upon a successful device probe() the jtag device file interface is created and the status workqueue started up. The jtag device file interface exists for the purpose of updating the firmware in the Uxxx series adapter, but as yet it had never been used. The status workqueue initializes the Uxxx and then sits there polling the Uxxx until a supported PCMCIA CardBus device is detected it will start the command and respond workqueues and then load the module that handles the device. This will initially be only the u132-hcd module. The status workqueue then just polls the Uxxx looking for card ejects. The command and respond workqueues implement a command sequencer for communicating with the firmware on the other side of the FTDI chip in the Uxxx. This "ftdi-elan" module exports some functions to interface with the sequencer. Note that this module is a USB client driver. Note that the "u132-hcd" module is a (cut-down OHCI) host controller. Thus we have a topology with the parent of a host controller being a USB client! This really stresses the USB subsystem semaphore/mutex handling in the module removal. Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Add ADU support for Ontrak ADU devicesSteven Haigh
This patch adds support for Ontrak ADU USB devices. Fixed for printk issues by Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Steven Haigh <netwiz@crc.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Put phidgets driver in a sysfs classSean Young
This patch creates a device class phidget and add the phidget drivers to them. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Add driver for PhidgetMotorControlSean Young
This driver add support for the Phidgets Inc., MotorControl via sysfs. Also some minor fixes for the InterfaceKit. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: rename Cypress CY7C63xxx driver to proper name and fix up some ↵Oliver Bock
tiny things This is a new driver for the Cypress CY7C63xxx mirco controller series. It currently supports the pre-programmed CYC63001A-PC by AK Modul-Bus GmbH. It's based on a kernel 2.4 driver (cyport) by Marcus Maul which I ported to kernel 2.6 using sysfs. I intend to support more controllers of this family (and more features) as soon as I get hold of the required IDs etc. Please see the source code's header for more information. Signed-off-by: Oliver Bock <o.bock@fh-wolfenbuettel.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: new driver for Cypress CY7C63xxx mirco controllersOliver Bock
2006-06-21[PATCH] Driver for Apple Cinema Displayakpm@osdl.org
This is a driver to control the brightness of an Apple Cinema Display over USB. It updates the local brightness value if the user presses a button on the display. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Cc: Oliver Neukum <oliver@neukum.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: move CONFIG_USB_DEBUG checks into the MakefileGreg Kroah-Hartman
This lets us remove a lot of code in the drivers that were all checking the same thing. It also found some bugs in a few of the drivers, which has been fixed up. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] USB: add ldusb driverMichael Hund
The following driver provides complete interrupt-in and interrupt-out reports (raw data) to a user program. Until now it uses the HIDIOCGDEVINFO ioctl call, because I don't know better :-(. Perhaps, it will be ok for you - and I will be happy, if you assign 8 minor numbers. I have tested it in several environments and it works very well for me. However, it has a problem with two or more devices at the same hub, if the two or more devices need 1 ms interrupt-in transfers. Unfortunately more than one interrupt-in transfer every ms isn't possible (ehci driver?). This is why the min_interrupt_in_interval and min_interrupt_out_interval are increased to 2 ms (see the corresponding module parameters). This way, I can use two devices simultaneously at the same hub. Signed-off-by: Michael Hund <mhund@ld-didactic.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
