[ Upstream commit 88f6bf3846ee90bf33aa1ce848cd3bfb3229f4a4 ]
A recent info-leak bug manifested itself along with warning about a
negative buffer overflow:
ldusb 1-1:0.28: Read buffer overflow, -131383859965943 bytes dropped
when it was really a rather large positive one.
A sanity check that prevents this has now been put in place, but let's
fix up the size format specifiers, which should all be unsigned.
Signed-off-by: Johan Hovold <johan@kernel.org>
Link: https://lore.kernel.org/r/20191022143203.5260-3-johan@kernel.org
commit 52403cfbc635d28195167618690595013776ebde upstream.
USB control-message timeouts are specified in milliseconds, not jiffies.
Waiting 83 minutes for a transfer to complete is a bit excessive.
Fixes: 2824bd250f0b ("[PATCH] USB: add ldusb driver")
Cc: stable <stable@vger.kernel.org> # 2.6.13
Reported-by: syzbot+a4fbb3bb76cda0ea4e58@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20191022153127.22295-1-johan@kernel.org
commit d98ee2a19c3334e9343df3ce254b496f1fc428eb upstream.
The custom ring-buffer implementation was merged without any locking or
explicit memory barriers, but a spinlock was later added by commit
9d33efd9a791 ("USB: ldusb bugfix").
The lock did not cover the update of the tail index once the entry had
been processed, something which could lead to memory corruption on
weakly ordered architectures or due to compiler optimisations.
Specifically, a completion handler running on another CPU might observe
the incremented tail index and update the entry before ld_usb_read() is
done with it.
Fixes: 9d33efd9a791 ("USB: ldusb bugfix")
Link: https://lore.kernel.org/r/20191022143203.5260-2-johan@kernel.org
commit 7a6f22d7479b7a0b68eadd308a997dd64dda7dae upstream.
Fix broken read implementation, which could be used to trigger slab info
leaks.
The driver failed to check if the custom ring buffer was still empty
when waking up after having waited for more data. This would happen on
every interrupt-in completion, even if no data had been added to the
ring buffer (e.g. on disconnect events).
Due to missing sanity checks and uninitialised (kmalloced) ring-buffer
entries, this meant that huge slab info leaks could easily be triggered.
Note that the empty-buffer check after wakeup is enough to fix the info
leak on disconnect, but let's clear the buffer on allocation and add a
sanity check to read() to prevent further leaks.
Reported-by: syzbot+6fe95b826644f7f12b0b@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20191018151955.25135-2-johan@kernel.org
commit b14a39048c1156cfee76228bf449852da2f14df8 upstream.
If disconnect() races with release() after a process has been
interrupted, release() could end up returning early and the driver would
fail to free its driver data.
Link: https://lore.kernel.org/r/20191010125835.27031-2-johan@kernel.org
commit 58ecf131e74620305175a7aa103f81350bb37570 upstream.
The driver was using its struct usb_interface pointer as an inverted
disconnected flag, but was setting it to NULL before making sure all
completion handlers had run. This could lead to a NULL-pointer
dereference in a number of dev_dbg, dev_warn and dev_err statements in
the completion handlers which relies on said pointer.
Fix this by unconditionally stopping all I/O and preventing
resubmissions by poisoning the interrupt URBs at disconnect and using a
dedicated disconnected flag.
This also makes sure that all I/O has completed by the time the
disconnect callback returns.
Link: https://lore.kernel.org/r/20191009153848.8664-4-johan@kernel.org
commit 52ad2bd8918158266fc88a05f95429b56b6a33c5 upstream.
This patch adds support for new CASSY devices to the ldusb driver. The
PIDs are also added to the ignore list in hid-quirks.
Signed-off-by: Karsten Koop <kkoop@ld-didactic.de>
MODULE_VERSION is useless for in-kernel drivers, so just remove all
usage of it in the USB misc drivers. Along with this, some
DRIVER_VERSION macros were removed as they are also pointless.
Cc: Keith Packard <keithp@keithp.com>
Cc: Juergen Stuber <starblue@users.sourceforge.net>
Cc: Cesar Miquel <miquel@df.uba.ar>
Acked-by: Richard Leitner <richard.leitner@skidata.com>
Use the new endpoint helpers to lookup the required interrupt-in
endpoint and optional interrupt-out endpoint.
Note that the descriptors are searched in reverse order to avoid any
regressions.
Changed the location of '*' to fit the current coding style and easy
readability.
Signed-of-by: Milian Reichardt <mreichardt95@gmail.com>
Added a Space after ',' to get rid of an error message in checkpatch.pl
and improve readability
Fixed ERROR: Use 4 digit octal (0777) not decimal permissions to fulfill
the current coding-style.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
All kmalloc-based functions print enough information on failures.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
kmalloc will print enough information in case of failure.
Removes Vernier Software & Technology devices from the ldusb
driver and the hid_ignore_list table of the usbhid driver in the
Linux tree. These devices will now be supported via the hidraw
driver.
A user space driver for these devices will be found in the
Go! Software Development Kit from Vernier at
http://www.vernier.com/downloads/software-development-kits/go-sdk/.
These devices are also be supported by the LabQuest2 standalone
interface shown at http://www.vernier.com/products/interfaces/labq2/
and the LoggerPro for Linux software shown at
http://www.vernier.com/downloads/logger-pro-linux/.
Signed-off-by: Dennis O'Brien <dennis.obrien@eqware.net>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
We want to get rid of CONFIG_USB_DEBUG, so remove the reliance of the
ldusb driver on it. Don't use the custom macro, or a special module
parameter, instead, rely on the in-kernel dynamic debugging
infrastructure, which is much easier to use, and consistant across the
whole kernel.
err() was a very old USB-specific macro that I thought had
gone away. This patch removes it from being used in the
driver and uses dev_err() instead.
CC: Michael Hund <mhund@ld-didactic.de>
CC: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
CC: Felipe Balbi <balbi@ti.com>
This converts the drivers in drivers/usb/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Simon Arlott <cxacru@fire.lp0.eu>
Cc: Duncan Sands <duncan.sands@free.fr>
Cc: Matthieu CASTET <castet.matthieu@free.fr>
Cc: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Michael Hund <mhund@ld-didactic.de>
Cc: Zack Parsons <k3bacon@gmail.com>
Cc: Melchior FRANZ <mfranz@aon.at>
Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com>
Cc: Dan Carpenter <error27@gmail.com>
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: David Kubicek <dave@awk.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Added several new devices to ldusb and excluded them from the HID driver.
Signed-off-by: Michael Hund <mhund@ld-didactic.de>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Reduces string space a bit
Neaten a macro redefine of dbg
BKL was not needed at all. Removed without replacement.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Straightforward push into the drivers to allow
auditing individual drivers separately
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: cocci@diku.dk
poll() should test for a disconnection of the device.
Labpro device is in both ldusb and vstusb device tables.
Should only be a vstusb device.
Signed-off-by: stephen ware <stephen.ware@eqware.net>
Microchip has changed the PICDEM FS USB demo device (0x04d8:000c)
to use bulk transfer and not interrupt transfer. So I've updated the libusb
based program here (Post #31).
http://forum.microchip.com/tm.aspx?m=106426&mpage=2
So I believe that the in-kernel ldusb driver will no longer work with the
demo firmware. It should be removed.
Signed-off-by: Xiaofan Chen <xiaofanc@gmail.com>
Cc: Michael Hund <MHund@LD-Didactic.de>
Cc: stable <stable@kernel.org>
Signed-off-by: Daniel Walker <dwalker@mvista.com>
Acked-by: Matthew Wilcox <willy@linux.intel.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
I have a new ldusb device to go into the device table. Jiri has merged
the change for hiddev quirks already.
This done in anticipation of removal of urb->status, which will make
that patch easier to review and apply in the future.
This patch (as908) adds central protection in usbcore for the
prototypical race between opening and unregistering a char device.
The spinlock used to protect the minor-numbers array is replaced with
an rwsem, which can remain locked across a call to a driver's open()
method. This guarantees that open() and deregister() will be mutually
exclusive.
The private locks currently used in several individual drivers for
this purpose are no longer necessary, and the patch removes them. The
following USB drivers are affected: usblcd, idmouse, auerswald,
legousbtower, sisusbvga/sisusb, ldusb, adutux, iowarrior, and
usb-skeleton.
As a side effect of this change, usb_deregister_dev() must not be
called while holding a lock that is acquired by open(). Unfortunately
a number of drivers do this, but luckily the solution is simple: call
usb_deregister_dev() before acquiring the lock.
In addition to these changes (and their consequent code
simplifications), the patch fixes a use-after-free bug in adutux and a
race between open() and release() in iowarrior.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch fixes a problem reported with consecutive reads in the ldusb
driver.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Hi Greg:
I have found that /drivers/usb/misc/ldusb.c works with the "PICDEM Full
Speed USB"
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en021940
Signed-off-by: Joey S Goncalves <jgoncalves@peragrin.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Making structs const prevents accidental bugs and with the proper debug
options they're protected against corruption.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
the patch below converts a bunch of semaphores-used-as-mutex in the USB
code to mutexes
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
another one for kzalloc
Signed-off-by: Oliver Neukum <oliver@neukum.name>
drivers
As there is no more usb devfs support, these bits would just confuse
people.
It is no longer needed, so let's remove it, saving a bit of memory.
Fix
drivers/usb/misc/ldusb.c: In function `ld_usb_read':
drivers/usb/misc/ldusb.c:467: warning: int format, different type arg (arg 4)
drivers/usb/misc/ldusb.c: In function `ld_usb_write':
drivers/usb/misc/ldusb.c:531: warning: int format, different type arg (arg 4)
drivers/usb/misc/ldusb.c:532: warning: int format, different type arg (arg 5)
drivers/usb/misc/ldusb.c:532: warning: int format, different type arg (arg 6)
below you will find the forgotten kmalloc check (sorry).
The following driver provides complete interrupt-in and interrupt-out
reports (raw data) to a user program. Until now it uses the
HIDIOCGDEVINFO ioctl call, because I don't know better :-(. Perhaps, it
will be ok for you - and I will be happy, if you assign 8 minor numbers.
I have tested it in several environments and it works very well for me.
However, it has a problem with two or more devices at the same hub, if
the two or more devices need 1 ms interrupt-in transfers. Unfortunately
more than one interrupt-in transfer every ms isn't possible (ehci
driver?). This is why the min_interrupt_in_interval and
min_interrupt_out_interval are increased to 2 ms (see the corresponding
module parameters). This way, I can use two devices simultaneously at
the same hub.
