path: root/drivers/usb/misc/phidgetmotorcontrol.c
2009-03-24USB: remove phidget drivers from kernel tree.Greg Kroah-Hartman
These devices are better controlled with the LGPL userspace library found at: http://www.phidgets.com/downloads.php?os_id=3 and full documentation at: http://www.phidgets.com/documentation/web/cdoc/index.html Cc: Chester Fitchett <fitchett@phidgets.com> Acked-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16device create: usb: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: Phidget: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). It fixes all 3 phidget drivers, which all have the same problem. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19USB: misc: phidgetmotorcontrol: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-01usb: phidgetmotorcontrol free urb cleanupMariusz Kozlowski
- usb_free_urb() cleanup Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01USB: phidgetmotorcontrol: Use usb_endpoint_* functionsLuiz Fernando N. Capitulino
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: Phidgets should check create_device_file() return valueSean Young
device_create_file() could fail, add proper error paths for this condition. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Put phidgets driver in a sysfs classSean Young
This patch creates a device class phidget and add the phidget drivers to them. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Add driver for PhidgetMotorControlSean Young
This driver add support for the Phidgets Inc., MotorControl via sysfs. Also some minor fixes for the InterfaceKit. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
