path: root/drivers/usb/misc/phidgetservo.c
2009-03-24USB: remove phidget drivers from kernel tree.Greg Kroah-Hartman
These devices are better controlled with the LGPL userspace library found at: http://www.phidgets.com/downloads.php?os_id=3 and full documentation at: http://www.phidgets.com/documentation/web/cdoc/index.html Cc: Chester Fitchett <fitchett@phidgets.com> Acked-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16device create: usb: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: Phidget: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). It fixes all 3 phidget drivers, which all have the same problem. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: Fix oops in PhidgetServoSean Young
The PhidgetServo causes an Oops when any of its sysfs attributes are read or written too, making the driver useless. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Phidgets should check create_device_file() return valueSean Young
device_create_file() could fail, add proper error paths for this condition. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Put phidgets driver in a sysfs classSean Young
This patch creates a device class phidget and add the phidget drivers to them. Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: kzalloc in PhidgetServoOliver Neukum
another for kzalloc. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: move CONFIG_USB_DEBUG checks into the MakefileGreg Kroah-Hartman
This lets us remove a lot of code in the drivers that were all checking the same thing. It also found some bugs in a few of the drivers, which has been fixed up. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/usb/input/aiptek.c - ↵Yani Ioannou
drivers/zorro/zorro-sysfs.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
