path: root/drivers/usb/misc/yurex.c
2010-11-30USB: yurex: add .llseek fop to file_operationsTomoki Sekiyama
Default llseek operation behavior was changed by the patch named "vfs: make no_llseek the default" after the yurex driver had been merged, so the llseek to yurex is now ignored. This patch add llseek fop with default_llseek to yurex driver to catch up to the change. Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: yurex: fix memory leak and corrupted messagesTomoki Sekiyama
This fixes the memory leak on disconnecting the device. In addition, it fixes some messages corrupted by incorrect encoding. Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: yurex: assign a real minor number to the driverGreg Kroah-Hartman
This assigns the minor number 192 to the yurex driver. We also fix up the previous usb minor number entry, it was wrong. Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: add driver for Meywa-Denki & Kayac YUREXTomoki Sekiyama
Meywa-Denki/Kayac YUREX is a leg-shakes sensor device. See http://bbu.kayac.com/en/about/ for further information. This driver support read/write the leg-shakes counter in the device via a device file /dev/yurex[0-9]*. [minor coding style cleanups fixed by gregkh] Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
