commit 1097ccebe630170080c41df0edcf88e0626e9c75 upstream.
This changes the max length for the usb seven segment delcom device to 8
from 6. Delcom has both 6 and 8 variants and having 8 works fine with
devices which are only 6.
Signed-off-by: Harrison Metzger <harrisonmetz@gmail.com>
Signed-off-by: Stuart Pook <stuart@acm.org>
Change-Id: I9badf4f45734ff63d0f9abdcd348a89e6761d05e
Reviewed-on: http://git-master/r/79679
commit 59bf5cf94f0fa3b08fb1258b52649077b7d0914d upstream.
We were sending data on the stack when uploading firmware, which causes
some machines fits, and is not allowed. Fix this by using the buffer we
already had around for this very purpose.
Reported-by: Wouter M. Koolen <wmkoolen@cwi.nl>
Tested-by: Wouter M. Koolen <wmkoolen@cwi.nl>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Just spelling fixes.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits)
USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h
USB: UHCI: Support big endian GRUSBHC HC
sparc: add {read,write}*_be routines
USB: UHCI: Add support for big endian descriptors
USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier
USB: UHCI: Add support for big endian mmio
usb-storage: Correct adjust_quirks to include latest flags
usb/isp1760: Fix possible unlink problems
usb/isp1760: Move function isp1760_endpoint_disable() within file.
USB: remove remaining usages of hcd->state from usbcore and fix regression
usb: musb: ux500: add configuration and build options for ux500 dma
usb: musb: ux500: add dma glue layer for ux500
usb: musb: ux500: add dma name for ux500
usb: musb: ux500: add ux500 specific code for gadget side
usb: musb: fix compile error
usb-storage: fix up the unusual_realtek device list
USB: gadget: f_audio: Fix invalid dereference of initdata
EHCI: don't rescan interrupt QHs needlessly
OHCI: fix regression caused by nVidia shutdown workaround
USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage
On amd64 unsigned is not as wide as pointer and this causes a compiler
warning. Switching to unsigned long corrects the problem.
Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu>
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
Added several new devices to ldusb and excluded them from the HID driver.
Signed-off-by: Michael Hund <mhund@ld-didactic.de>
dummy_hcd + g_zero:
|./testusb -a -s 1024 -v 1024 -t 10
| usbtest 2-1:3.0: subtest 14 error, status 0
with patch:
./testusb -a -t 10
|unknown speed /proc/bus/usb/001/002
| dummy_udc dummy_udc: disabled ep-a
| dummy_udc dummy_udc: disabled ep-b
| dummy_udc dummy_udc: enabled ep-a (ep1in-bulk) maxpacket 1024
| dummy_udc dummy_udc: enabled ep-b (ep2out-bulk) maxpacket 1024
| zero gadget: source/sink enabled
| usbtest 1-1:3.0: TEST 10: queue 32 control calls, 1000 times
| dummy_hcd dummy_hcd: timer fired with no URBs pending?
|/proc/bus/usb/001/002 test 10, 0.022370 secs
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reviewed-by: Felipe Balbi <balbi@ti.com>
This patch (as1452b) adds a new test case to the usbtest driver. Test
24 exercises the unlink-from-queue pathways in the host. It queues a
user-specified number of bulk-OUT URBs of user-specified size, unlinks
the fourth- and second-from-last URBs in the queue, and then waits to
see if all the URBs complete in the expected way (except of course
that the unlinked URBs might complete normally, if they weren't
unlinked soon enough).
This new test has confirmed the existence of a bug in the ehci-hcd
driver, to be fixed by a separate patch.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The kernel already prints its build timestamp during boot, no need to
repeat it in random drivers and produce different object files each
time.
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: linux-usb@vger.kernel.org
My testprog do a lot of bitbang - after hours i got following warning and my machine lockups:
WARNING: at /build/buildd/linux-2.6.38/lib/kref.c:34
After debugging uss720 driver i discovered that the completion callback was called before
usb_submit_urb returns. The callback frees the request structure that is krefed on return by
usb_submit_urb.
Signed-off-by: Peter Holik <peter@holik.at>
Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
Cc: stable <stable@kernel.org>
There may be multiple ways of controlling the backlight on a given
machine. Allow drivers to expose the type of interface they are
providing, making it possible for userspace to make appropriate policy
decisions.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Alex Deucher <alexdeucher@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
This is needed to resolve some merge conflicts that were found
in the USB host controller patches, and reported by Stephen Rothwell.
Add a set of new tests similar to the existing ones but using
transfer buffers at an "odd" address [ie offset of +1 from
the buffer obtained by kmalloc() or usb_alloc_coherent()]
The new tests are:
#17 : bulk out (like #1) using kmalloc and DMA mapping by USB core.
#18 : bulk in (like #2) using kmalloc and DMA mapping by USB core.
#19 : bulk out (like #1) using usb_alloc_coherent()
#20 : bulk in (like #2) using usb_alloc_coherent()
#21 : control write (like #14)
#22 : isochonous out (like #15)
#23 : isochonous in (like #16)
Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com>
Commit ecc1624a2fff45780959efbcb73ace18fdb3c58d (USB: misc: uss720.c: add
another vendor/product ID) duplicated entry in the driver's USB device ID
table. Remove the duplicate.
If case of an unknown usb_device_id->driver_info (which could only
occur if the info got corrupted somewhere outside the usbled driver),
a debug message depended on an uninitialized value. This was harmless,
but ugly, and gets fixed with this patch.
Signed-off-by: Melchior FRANZ <mfranz@aon.at>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
This is to resolve the conflict in the file,
drivers/usb/gadget/composite.c that was due to a revert in Linus's tree
needed for the 2.6.37 release.
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
So far the USBLED driver only supports Delcom's "USB Visual Signal
Indicator" (http://www.delcomproducts.com/products_USBLMP.asp). The
driver generates virtual files "red", "green", and "blue" under the
device's /sys/ directory, where color values can be read from and
written to.
This patch adds support for Dream Cheeky's "DL100B Webmail Notifier"
(http://www.dreamcheeky.com/webmail-notifier -- available from several
shops, such as http://www.conrad.at/ce/de/product/777048/USB-WEBMAIL).
This device isn't as pretty as Delcom's, but it's *far* cheaper, and
its 3 LEDs can be set in 32 brightness steps each. The grey envelope
contour can easily be removed, leaving a rather neutral white box (with
a few small holes), which is useful for generic signalling purposes.
Of course, the small circuit board can easily be put into a prettier
case.
The DL100B device pretends to be a HID, but the HID descriptor shows
that it's not overly useful as such (see below). The patch therefore
removes the "HID-ness" (hid-core.c, hid-ids.h), and adds the necessary
commands to usbled.c. The protocol info comes from the developer's
manual that Dream Cheeky kindly provided (815DeveloperManual.pdf).
HID descriptor:
0: 05 01 Usage Page 'Generic Desktop Controls'
2: 09 10 Usage 'Reserved'
4: a1 01 Collection 'Application (mouse, keyboard)'
6: 05 00 Usage Page 'Undefined'
8: 19 10 Usage Minimum = 16
10: 29 11 Usage Maximum = 17
12: 15 00 Logical Minimum = 0
14: 25 0f Logical Maximum = 15
16: 75 08 Report Size = 8
18: 95 08 Report Count = 8
20: 91 02 Output data *var abs lin pref-state null-pos non-vol bit-field
22: 19 10 Usage Minimum = 16
24: 29 11 Usage Maximum = 17
26: 15 00 Logical Minimum = 0
28: 25 0f Logical Maximum = 15
30: 75 08 Report Size = 8
32: 95 08 Report Count = 8
34: 81 00 Input data array abs lin pref-state null-pos non-vol bit-field
36: c0 End Collection
Fabio Battaglia report that he has another cable that works with this
driver, so this patch adds its vendor/product ID.
Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
Default llseek operation behavior was changed by the patch named
"vfs: make no_llseek the default" after the yurex driver had been merged,
so the llseek to yurex is now ignored.
This patch add llseek fop with default_llseek to yurex driver
to catch up to the change.
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com>
They should not be writable by any user.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Harrison Metzger <harrisonmetz@gmail.com>
It should not be writable by any user.
Cc: Sam Hocevar <sam@zoy.org>
Cc: Oliver Bock <bock@tfh-berlin.de>
Structure iowarrior_info is copied to userland with padding byted
between "serial" and "revision" fields uninitialized. It leads to
leaking of contents of kernel stack memory.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Acked-by: Kees Cook <kees.cook@canonical.com>
Structure sisusb_info is copied to userland with "sisusb_reserved" field
uninitialized. It leads to leaking of contents of kernel stack memory.
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits)
USB: mct_u232: fix broken close
USB: gadget: amd5536udc.c: fix error path
USB: imx21-hcd - fix off by one resource size calculation
usb: gadget: fix Kconfig warning
usb: r8a66597-udc: Add processing when USB was removed.
mxc_udc: add workaround for ENGcm09152 for i.MX35
USB: ftdi_sio: add device ids for ScienceScope
USB: musb: AM35x: Workaround for fifo read issue
USB: musb: add musb support for AM35x
USB: AM35x: Add musb support
usb: Fix linker errors with CONFIG_PM=n
USB: ohci-sh - use resource_size instead of defining its own resource_len macro
USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro
USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro
USB: xhci: Fix compile error when CONFIG_PM=n
USB: accept some invalid ep0-maxpacket values
USB: xHCI: PCI power management implementation
USB: xHCI: bus power management implementation
USB: xHCI: port remote wakeup implementation
USB: xHCI: port power management implementation
Manually fix up (non-data) conflict: the SCSI merge gad renamed the
'hw_sector_size' member to 'physical_block_size', and the USB tree
brought a new use of it.
If the iowarrior devices in this case statement support more than 8 bytes
per report, it is possible to write past the end of a kernel heap allocation.
This will probably never be possible, but change the allocation to be more
defensive anyway.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
For all modules, change <module>-objs to <module>-y; remove
if-statements and replace with lists using the kbuild idiom; move
flags to the top of the file; and fix alignment while trying to
maintain the original scheme in each file.
None of the dependencies are modified.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Felipe Balbi <balbi@ti.com>
Check the data length of isochronous transfers is
as expected.
With this test #16 will now fail if the device side
sends no data.
Cc: David Brownell <david-b@pacbell.net>
Replace EXTRA_CFLAGS with ccflags-y.
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
This fixes the memory leak on disconnecting the device.
In addition, it fixes some messages corrupted by incorrect encoding.
This assigns the minor number 192 to the yurex driver.
We also fix up the previous usb minor number entry, it was wrong.
Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com>
Meywa-Denki/Kayac YUREX is a leg-shakes sensor device.
See http://bbu.kayac.com/en/about/ for further information.
This driver support read/write the leg-shakes counter in the device
via a device file /dev/yurex[0-9]*.
[minor coding style cleanups fixed by gregkh]
Cc: Jiri Kosina <jkosina@suse.cz>
The "mutex" ftdi->sw_lock is used as a lock and a completion. Convert
it to a real semaphore which allows both.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
copy_to_user() returns number of not copied bytes, not error code.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
fs/exofs/inode.c
It is very common that one altsetting may include only one iso-in or iso-out
single endpoint, especially for high bandwidth endpoint, so support it.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
This patch fixes the warning below:
[30753.755998] ------------[ cut here ]------------
[30753.755998] WARNING: at /home/tom/git/linux-2.6/linux-2.6-next/arch/x86/include/asm/dma-mapping.h:155 hcd_buffer_free+0xb1/0xd4 [usbcore]()
[30753.755998] Hardware name: 6475EK2
[30753.755998] Modules linked in: uvcvideo ehci_hcd usbtest cdc_ether usbnet vfat fat usb_storage nfsd lockd nfs_acl auth_rpcgss exportfs mii tun videodev v4l1_compat v4l2_compat_ioctl32 fuse bridge stp llc sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf kvm_intel kvm arc4 ecb ath5k usbhid mac80211 snd_hda_codec_conexant ch341 usbserial ath cfg80211 thinkpad_acpi snd_hda_intel pcspkr wmi hwmon yenta_socket iTCO_wdt iTCO_vendor_support i2c_i801 e1000e snd_hda_codec snd_hwdep snd_pcm snd_timer snd soundcore snd_page_alloc pata_acpi uhci_hcd ohci_hcd usbcore i915 drm_kms_helper drm i2c_algo_bit i2c_core video output [last unloaded: uvcvideo]
[30753.755998] Pid: 0, comm: swapper Tainted: G W 2.6.35-rc6-gkh-wl+ #49
[30753.755998] Call Trace:
[30753.755998] <IRQ> [<ffffffff8104478a>] warn_slowpath_common+0x80/0x98
[30753.755998] [<ffffffff810447b7>] warn_slowpath_null+0x15/0x17
[30753.755998] [<ffffffffa00ce02d>] hcd_buffer_free+0xb1/0xd4 [usbcore]
[30753.755998] [<ffffffffa00c1345>] usb_free_coherent+0x1c/0x1e [usbcore]
[30753.755998] [<ffffffffa00b13e4>] simple_free_urb+0x23/0x2f [usbtest]
[30753.755998] [<ffffffffa00b210b>] iso_callback+0xbb/0x10f [usbtest]
[30753.755998] [<ffffffffa00c7390>] usb_hcd_giveback_urb+0x8c/0xc0 [usbcore]
[30753.755998] [<ffffffffa0449b35>] ehci_urb_done+0x84/0x95 [ehci_hcd]
[30753.755998] [<ffffffffa044b5a5>] ehci_work+0x41a/0x7dd [ehci_hcd]
[30753.755998] [<ffffffffa044e298>] ehci_irq+0x33b/0x370 [ehci_hcd]
[30753.755998] [<ffffffff8100fb05>] ? sched_clock+0x9/0xd
[30753.755998] [<ffffffff8105e641>] ? sched_clock_local+0x1c/0x82
[30753.755998] [<ffffffff8105e76a>] ? sched_clock_cpu+0xc3/0xce
[30753.755998] [<ffffffff81067c7e>] ? trace_hardirqs_off+0xd/0xf
[30753.755998] [<ffffffff8105e7b8>] ? cpu_clock+0x43/0x5e
[30753.755998] [<ffffffffa00c6999>] usb_hcd_irq+0x45/0xa1 [usbcore]
[30753.755998] [<ffffffff81092e02>] handle_IRQ_event+0x20/0xa5
[30753.755998] [<ffffffff81094cea>] handle_fasteoi_irq+0x92/0xd2
[30753.755998] [<ffffffff8100c0ed>] handle_irq+0x1f/0x2a
[30753.755998] [<ffffffff8100b75d>] do_IRQ+0x57/0xbe
[30753.755998] [<ffffffff8136a693>] ret_from_intr+0x0/0x16
[30753.755998] <EOI> [<ffffffff81223baa>] ? acpi_idle_enter_bm+0x231/0x269
[30753.755998] [<ffffffff81223ba3>] ? acpi_idle_enter_bm+0x22a/0x269
[30753.755998] [<ffffffff812c4b6b>] cpuidle_idle_call+0x99/0xce
[30753.755998] [<ffffffff81008dd5>] cpu_idle+0x61/0xaa
[30753.755998] [<ffffffff8136374b>] start_secondary+0x1c2/0x1c6
[30753.755998] ---[ end trace 904cfaf7ab4cb1a2 ]---
