Paolo asked to enable the mmap. I kept it off because I'm do not
entirely understand how it workse these days after ->nopage etc.
But it seems like working somewhat at least.
Signed-Off-By: Pete Zaitcev <zaitcev@gmail.com>
Cc: Paolo Abeni <paolo.abeni@email.it>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Convert USB mon driver from nopage to fault.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
- make the needlessly global struct mon_fops_binary static
- #if 0 the unused mon_bin_mmap() and related code
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Greg KH <greg@kroah.com>
Cc: Pete Zaitcev <zaitcev@redhat.com>
This patch (as978) reorganizes the way usbmon uses urb->status. It
now accepts the status value as an argument.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Setup packet must be visible in virtual space. There's absolutely no
good reason to implement any kind of zero-copy transfer of 8 bytes, and
the documentation in usb.h is explicit about it. So, drop DMA remapping.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
This is a set of small updates to Alan's work to make the code more to
my liking. Mostly premature optimizations, but also direction of control
transfers in the binary interface was always out.
This patch (as949) changes the usbmon driver to use the new urb->ep
field rather than urb->pipe.
Add a class which allows for an easier integration with udev.
This code was originally written by Paolo Abeni, and arrived to my tree
as a part of big patch to add binary API on December 18. As I understand,
Paolo always meant the class to be a part of the whole thing. This is his
udev rule to go along with the patch:
KERNEL=="usbmon[0-9]*", NAME="usbmon%n", MODE="0440",OWNER="root",GROUP="bin"
Add the "bus zero" feature to the usbmon. If a user process specifies bus
with number zero, it receives events from all buses. This is useful when
we wish to see initial enumeration when a bus is created, typically after
a modprobe. Until now, an application had to loop until a new bus could
be open, then start capturing on it. This procedure was cumbersome and
could lose initial events. Also, often it's too bothersome to find exactly
to which bus a specific device is attached.
Paolo Albeni provided the original concept implementation. I added the
handling of "bus->monitored" flag and generally fixed it up.
mon_bin_exit() and mon_text_exit() are called from __init code, so don't mark
them as __exit.
This patch adds a new, "binary" API in addition to the old, text API usbmon
had before. The new API allows for less CPU use, and it allows to capture
all data from a packet where old API only captured 32 bytes at most. There
are some limitations and conditions to this, e.g. in case someone constructs
a URB with 1GB of data, it's not likely to be captured, because even the
huge buffers of the new reader are finite. Nonetheless, I expect this new
capability to capture all data for all real life scenarios.
The downside is, a special user mode application is required where cat(1)
worked before. I have sample code at http://people.redhat.com/zaitcev/linux/
and Paolo Abeni is working on patching libpcap.
This patch was initially written by Paolo and later I tweaked it, and
we had a little back-and-forth. So this is a jointly authored patch, but
I am submitting this I am responsible for the bugs.
Signed-off-by: Paolo Abeni <paolo.abeni@email.it>
