commit a53469a68eb886e84dd8b69a1458a623d3591793 upstream.
power off the phy should be done before populate the phy. Otherwise,
am335x_init() could be called by the phy owner to power on the phy first,
then am335x_phy_probe() turns off the phy again without the caller knowing
it.
Fixes: 2fc711d76352 ("usb: phy: am335x: Enable USB remote wakeup using PHY wakeup")
Cc: stable@vger.kernel.org # v3.18+
Signed-off-by: Bin Liu <b-liu@ti.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Use SIMPLE_DEV_PM_OPS macro and remove DEV_PM_OPS macro, in order
to make the code simpler.
Acked-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
<linux/usb/usb_phy_generic.h>
now that all functions match the driver name,
the only missing piece is to rename the header
file itself.
no functional changes, just renaming the function
in order to make it slightly clearer what it should
be used for, also matching the driver name.
by using SET_SYSTEM_SLEEP_PM_OPS, we will make
sure that we don't use undefined functions.
USB remote wakeup using PHY wakeup is supported only in standby mode.
Enabling the PHY_WKUP will break DS0 mode of system suspend.
If the same is enabled while entering DS0, AM33xx never stays in DS0,
it returns immediately from DS0. By default make the PHY wakeup
disabled, using sysfs entry enable the same manually to get
the remote wakeup working from standby.
echo enabled > /sys/bus/platform/device/<usb phy id>/power/wakeup
This will enable the PHY wakeup while going to standby.
PHY wakeup feature is required to wakeup the system from standby
state. Since AM33xx has a bug in which PHY wakeup should not
be enabled while entering DS0, disable the same by default.
A user wishing to use USB wakeup from standby mode need to enable
the same using the sysfs entries.
Also remove am335x_phy_runtime_(suspend/resume) this driver doesnot really
enable/disable the clocks to the PHY.
Add am335x_phy_(suspend/resume) and use the same for enabling the PHY_WKUP.
Signed-off-by: George Cherian <george.cherian@ti.com>
instead of having each user of generic phy find
out about its own resources and pass it to the
core layer, have th core layer itself figure that
out. It's as simple as moving a piece of code
around. This fixes a big regression caused during
the merge window where am335x-based platforms
wouldn't be able to probe their PHY driver.
Commit [4d175f34: usb: phy: nop: Defer clock prepare until PHY init]
removed a goto reaching behind a “return ret” at the end of the function
thus removing the only possible way that statement could be reached, and
so rendering it a dead code. This commit cleans it up by removing said
dead code.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Modelling the RESET line as a regulator supply wasn't a good idea
as it kind of abuses the regulator framework and also makes adaptation
code more complex.
Instead, manage the RESET gpio line directly in the driver. Update
the device tree binding information.
This also makes us easy to migrate to a dedicated GPIO RESET controller
whenever it becomes available.
Signed-off-by: Roger Quadros <rogerq@ti.com>
The data structure of_match_ptr() protects is always compiled in.
Hence of_match_ptr() is not needed.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
This is based on George Cherian's patch which added power & wakeup
support to am335x and does no longer apply since I took some if the code
apart in favor of the multi instance support.
This compiles and I boots and later it detects a device after I plug it in :)
Could somebody please test it so it does what it should?
Cc: George Cherian <george.cherian@ti.com>
Reviewed-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Since we only enable the PHY clock on init and the PHY init and shutdown
does not occur in atomitc context there is no need to prepare the clock
before it is enabled. Move the clk_prepare() operations to go along
with the enables, allowing the clock to be fully idle when not in use.
Signed-off-by: Mark Brown <broonie@linaro.org>
This driver is a redo of my earlier attempt. It uses parts of the
generic PHY driver and uses the new control driver for the register
the phy needs to power on/off the phy. It also enables easy access for
the wakeup register which is not yet implemented.
The difference between the omap attempt is:
- no static holding variable
- one global visible function which exports a struct with callbacks to
access the "control" registers.
