path: root/drivers/usb/serial/Makefile
2011-04-13Revert "USB: sam-ba: add driver for Atmel SAM Boot Assistant (SAM-BA)"Johan Hovold
This reverts commit 90593899de83a6e6fdea563d058acd2f4334e3f9. SAM-BA devices identify themselves CDC-ACM devices and should be using the cdc-acm driver. Since commit 5b239f0aebd4dd6f85b13decf5e18e86e35d57f0 (USB: cdc-acm: Add pseudo modem without AT command capabilities) cdc-acm also binds to them. Note that the Atmel SAM-BA tools expect to use a USB-serial driver and thus require a symlink from /dev/ttyACMn to some /dev/ttyUSBm (with m < 30) to be able to select the device. This is simply a UI-issue that should be fixed by Atmel. Tested with the SAM-BA 2.10 tools and an Atmel at91sam9260-ek. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Sven Köhler <sven.koehler@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22usb: makefile cleanupmatt mooney
For all modules, change <module>-objs to <module>-y; remove if-statements and replace with lists using the kbuild idiom; move flags to the top of the file; and fix alignment while trying to maintain the original scheme in each file. None of the dependencies are modified. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: sam-ba: add driver for Atmel SAM Boot Assistant (SAM-BA)Johan Hovold
Add new driver to access the SAM-BA boot application of Atmel AT91SAM devices. The SAM-BA firmware cannot handle merged write requests so we cannot use the generic write implementation (which uses the port write fifo). Tested with the SAM-BA 2.10 tools and an Atmel at91sam9260-ek. Signed-off-by: Johan Hovold <jhovold@gmail.com> Tested-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: add USB serial ssu100 driverBill Pemberton
Add support for the Quatech SSU-100 single port usb to serial device. This driver is based on the ftdi_sio.c driver and the original serqt_usb driver from Quatech. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20usb serial: Add generic USB wwan supportMatthew Garrett
The generic USB serial code is ill-suited for high-speed USB wwan devices, resulting in the option driver. However, other non-option devices may also gain similar benefits from not using the generic code. Factorise out the non-option specific code from the option driver and make it available to other users. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB Serial Driver: ZIO MotherboardVijay Kumar
Add ZIO Motherboard USB serial interface driver. Signed-off-by: Vijay Kumar B. <vijaykumar@zilogic.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: qcaux: driver for auxiliary serial ports on Qualcomm devicesDan Williams
qcaux: add driver for QCDM-capable ports on various devices Many Qualcomm-based devices provide a CDC-ACM port which accepts normal AT commands and PPP connections. But they only provide one which makes status or signal strength requests impossible while PPP is active. They also provide secondary USB interfaces that talk the Qualcomm Diagnostic Monitor (QCDM) protocol which can be used for status and strength. Make those QCDM ports accessible. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: serial: Add support for ViVOtech ViVOpay devices.Forest Bond
Add support for USB serial interface provided by ViVOtech ViVOpay devices via new driver vivopay-serial. Currently only the ViVOpay 8800 device is supported, but support for similar devices can be added by adding the appropriate device IDs to the driver. Signed-off-by: Forest Bond <forest.bond@outpostembedded.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: rename cp2101 driver to cp210xGreg Kroah-Hartman
Lots of users are getting confused about the cp2101 driver. It really does support more than just the cp2101 device, so rename it to cp210x to try to prevent confusion. Cc: Craig Shelley <craig@microtron.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: add qualcomm wireless modem driverGreg Kroah-Hartman
Driver originally written by Qualcomm, but rewritten by me due to the totally different coding style. Cleaned up the probe logic to make a bit more sense, this is one wierd device. They could have prevented all of this by just writing sane firmware for the modem. Cc: Tamm Liu <tamml@qualcomm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: serial: add symbol serial driverGreg Kroah-Hartman
This is for the Symbol 6608 barcode scanner in a fake "HID" mode. Thanks to Dalibor Grgec for working with me to get this to start to work properly. Cc: Dalibor Grgec <dalibor.grgec@zemris.fer.hr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: add siemens_mpi usb-serial "stub" driverGreg Kroah-Hartman
This driver got rescued from a few years ago and was requested to be added. So I cleaned it up, ported it to the latest kernel version and here it is. Cc: Thomas Hergenhahn <thomas.hergenhahn@suse.de> Cc: Emmanuele <iemmav@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: add new opticon serial driverGreg Kroah-Hartman
This is for the serial mode of the Opticon barcode scanner. Cc: Kees Stoop <kees.stoop@opticon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: delete airprime driverGreg Kroah-Hartman
This driver is only for one device id, and the option driver should be used instead for it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: add new moto_modem driver for some Morotola phonesGreg Kroah-Hartman
This should work on a KRZR K1m, and some other Motorola phones that do not use the "standard" cdc ACM protocol to talk to USB hosts. Tested-by: Jeff Garzik <jeff@garzik.org> Cc: Jiang Dejun <a5652c@motorola.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add usb-serial spcp8x5 driverGreg Kroah-Hartman
Original version of the driver done by Linxb, changes by Harald, and lots of cleanups by me in order to get it into a mergable state. Cc: Linxb <xubin.lin@worldplus.com.cn> Cc: Harald Klein <hari@vt100.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add iuu_phoenix driverAlain Degreffe
Signed-off-by: Alain Degreffe <eczema@ecze.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: Driver for CH341 USB-serial adaptorFrank A Kingswood
This patch implements a USB serial port driver for the Winchiphead CH341 USB-RS232 Converter. This chip also implements an IEEE 1284 parallel port, I2C and SPI, but that is not supported by the driver. Signed-off-by: Frank A Kingswood <frank@kingswood-consulting.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: oti6858 usb-serial driver (in Nokia CA-42 cable)Kees Lemmens
Last week I've been searching for a driver for the CA-42 cable (see usb below) that fitted my kernel 2.6.20. I only found an abandoned version for a driver on your website that indeed worked on 2.6.18 but wouldn't even compile with a more recent 2.6.20 kernel. I fiddled 2 evenings with the kernel code and have patched it up now to work with the modifications in the 2.6.20 kernel. The patch is attached hereafter and it works fine (at least for me :-) ). Bus 2 Device 13: ID 0ea0:6858 Ours Technology, Inc. I had to fiddle a little with the settings in .gnokiirc but that also occurred with the older 2.6.18 kernel. Nevertheless, on one system with this cable and my Nokia 6070 I had best results with : model = 6510 connection = dku5 while on an other system with the same kernel, cable and phone it only worked with : model = AT connection = serial serial_write_usleep = 1 From: Kees Lemmens <C.W.J.Lemmens@ewi.tudelft.nl> Cc: <pawel.kot@gmail.com> Cc: <bozo@andrews.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01USB: add driver for the USB debug devicesGreg Kroah-Hartman
It's a simple usb-serial driver that just creates a tty device to read and write from. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17USB: add USB serial mos7720 driverGreg Kroah-Hartman
Add support for Moschip 7720 USB dual port usb to serial device. This driver is originally based on the drivers/usb/io_edgeport.c driver. Cleaned up and forward ported by me. Cc: VijayaKumar <vijaykumar@aspirecom.net> Cc: AjayKumar <ajay@aspirecom.net> Cc: Gurudeva <gurudev@aspirecom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Moschip 7840 USB-Serial DriverPaul B Schroeder
Signed-off-by: Paul B Schroeder <pschroeder@uplogix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27Add AIRcable USB Bluetooth Dongle DriverManuel Francisco Naranjo
Add driver for AIRcable USB Bluetooth dongle. Signed-off-by: Naranjo, Manuel Francisco <naranjo.manuel@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: Let option driver handle Anydata CDMA modems. Remove anydata driver.Matthias Urlichs
Signed-off-by: Jon K Hellan <hellan@acm.org> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: add driver for non-composite Sierra Wireless devicesKevin Lloyd
This patch creates a new driver, sierra.c, that supports the new non-composite Sierra Wireless WWAN devices. The older Sierra Wireless and Airprime devices are supported in airprime.c. Signed-off-by: Kevin Lloyd <linux@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-12[PATCH] USB: add ark3116 usb to serial driverGreg Kroah-Hartman
Based on Simon's original driver, with some minor code cleanups and tidying by me. Cc: Simon Schulz <simon@auctionant.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] USB: add driver for funsoft usb serial deviceGreg Kroah-Hartman
Cc: David Clare <david@funsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB serial: add navman driverGreg Kroah-Hartman
Thanks to Warren Lewis <wlewis@scn.org> for the information needed to write the driver and for testing it out. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: add the anydata usb-serial driverGreg Kroah-Hartman
Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[PATCH] USB: delete the nokia_dku2 driverGreg Kroah-Hartman
It was causing too many problems, and this is not the proper type of driver for this device. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] USB: add nokia_dku2 driverGreg Kroah-Hartman
This driver comes from the gnokii project. Was further cleaned up by me to match recent usb-serial core changes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-03[PATCH] USB: add Option Card driverMatthias Urlichs
This patch adds a new driver for "Option" cards. This is a GSM data card, controlled by three "serial ports" which are connected via an OHCI adapter, all located on an oversized PC-Card. It's sold by several GSM service providers. Traditionally, this card has been accessed via the standard serial driver and appropriate vendor= and product= options. However, testing has revealed several problems with this approach, including hung data transfers and lost data blocks when receiving. Therefore, I've written a separate driver. Signed-off-by: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] USB: add a driver for the AirPrime CDMA Wireless PC card.Greg KH
Easier than trying to use the generic usb-serial driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-22[PATCH] USB: add HP49G+ Calculator USB Serial supportArthur Huillet
