Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
Signed-off-by: Alan Cox <alan@linux.intel.com>
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
Alan's commit 335f8514f200e63d689113d29cb7253a5c282967 introduced
.carrier_raised function in several drivers. That also means
tty_port_block_til_ready can now suspend the process trying to open the serial
port when Carrier Detect is low and put it into tty_port.open_wait queue. We
need to wake up the process when Carrier Detect goes high and trigger TTY
hangup when CD goes low.
Some of the devices do not report modem status line changes, or at least we
don't understand the status message, so for those we remove .carrier_raised
again.
Signed-off-by: Libor Pechacek <lpechacek@suse.cz>
Cc: stable <stable@kernel.org>
This now refcounts but doesn't actually check the reference was obtained in
all the places it should.
If port is NULL, then the call to dev_err will dereference a value that is
a small offset from NULL.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression E,E1;
identifier f;
statement S1,S2,S3;
if ((E == NULL && ...) || ...)
... when != if (...) S1 else S2
when != E = E1
* E->f
... when any
return ...;
else S3
// </smpl>
Fix regression introduced by commit
a108bfcb372d8c4452701039308fb95747911c59 (USB: tty: Prune uses of
tty_request_room in the USB layer) which broke three drivers
(cypress_m8, digi_acceleport and spcp8x5) through incorrect use of
tty_insert_flip_string_fixed_flag.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: stable <stable@kernel.org> [.34]
This patch (as1344) removes references to port->port.count from the
USB serial drivers. Now that serial ports are properly reference
counted, port.count checking is unnecessary and incorrect. Drivers
should assume that the port is in use from the time the open method
runs until the close method is called.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
We have lots of callers that do not need to do this in the first place.
Remove the calls as they both cost CPU and for big buffers can mess up the
multi-page allocation avoidance.
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
Cc: cocci@diku.dk
This patch fixes a regression introduced in
39892da44b21b5362eb848ca424d73a25ccc488f.
Acked-by: Oliver Neukum <oliver@neukum.org>
And indeed none of them use it. Clean this up as it will make moving to a
standard open method rather easier.
This patch (as1254) splits up the shutdown method of usb_serial_driver
into a disconnect and a release method.
The problem is that the usb-serial core was calling shutdown during
disconnect handling, but drivers didn't expect it to be called until
after all the open file references had been closed. The result was an
oops when the close method tried to use memory that had been
deallocated by shutdown.
This allows us to clean stuff up, but is probably also going to cause
some app breakage with buggy apps as we now implement proper POSIX behaviour
for USB ports matching all the other ports. This does also mean other apps
that break on USB will now work properly.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Some of the usb-serial drivers are starting to use urb->status in ways
they should not be doing. This fixes up some of them to prevent that.
err() is going away, so switch to dev_err() or printk() if it's really
needed.
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Use kref in the USB serial drivers so that we don't free tty structures
from under the URB receive handlers as has historically been the case if
you were unlucky. This also gives us a framework for general tty drivers to
use tty_port objects and refcount.
Contains two err->dev_err changes merged together to fix clashes in the
-next tree.
Signed-off-by: Alan Cox <alan@redhat.com>
Code tidy
USB serial likes to use port->tty back pointers for the real work it does and
to do so without any actual locking. Unfortunately when you consider hangup
events, hangup/parallel reopen or even worse hangup followed by parallel close
events the tty->port and port->tty pointers are not guaranteed to be the same
as port->tty is the active tty while tty->port is the port the tty may or
may not still be attached to.
So rework the entire API to pass the tty struct. For console cases we need
to pass both for now. This shows up multiple drivers that immediately crash
with USB console some of which have been fixed in the process.
Longer term we need a proper tty as console abstraction
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
- Operations are now a shared const function block as with most other Linux
objects
- Introduce wrappers for some optional functions to get consistent behaviour
- Wrap put_char which used to be patched by the tty layer
- Document which functions are needed/optional
- Make put_char report success/fail
- Cache the driver->ops pointer in the tty as tty->ops
- Remove various surplus lock calls we no longer need
- Remove proc_write method as noted by Alexey Dobriyan
- Introduce some missing sanity checks where certain driver/ldisc
combinations would oops as they didn't check needed methods were present
[akpm@linux-foundation.org: fix fs/compat_ioctl.c build]
[akpm@linux-foundation.org: fix isicom]
[akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build]
[akpm@linux-foundation.org: fix kgdb]
Cc: Jason Wessel <jason.wessel@windriver.com>
urb->context code cleanup
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
The usb-serial core no longer checks these fields so remove them from
all of the individual drivers. They will be removed from the usb-serial
core in a patch later in the series.
these drivers abused intfdata in close() as flags for binding.
That races with reprobing of those devices. This patch fixes that by using
the flag and the locks introduced with the patch against mos7720.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
- Expand some x&y to x & y so I could read it when checking
- Clear CMSPAR bit in the termios (as the driver does not support it)
- Encode the speed using the new tty_encode_baud_rate facility
- The outbreak of acute bracketitus has been cured
- The belief that brackets should have spaces everywhere likewise
- Various other coding style tweaks
- Use baud rates not Bfoo in the speed setup switch
This done in anticipation of removal of urb->status, which will make
that patch easier to review and apply in the future.
Cc: <linux-usb-devel@lists.sourceforge.net>
Cc: Peter Berger <pberger@brimson.com>
Cc: Al Borchers <borchers@steinerpoint.com>
Some further cleanup after Oliver's patch to update the tty
buffering. The input buffer is not used at all anymore, so
I removed it.
Signed-off-by: Al Borchers <alborchers@steinerpoint.com>
this fixes the flushing trouble due to its own buffering for this driver.
Cc: Al Borchers <alborchers@steinerpoint.com>
tty_wakeup cleanup
- remove wake_up_interruptible(&tty->write_wait) surrounding
tty_wakup(tty);
- substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty);
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Acked-by: Tilman Schmidt <tilman@imap.cc>
Every usb serial driver should have a pointer to the corresponding usb driver.
So the usb serial core can add a new id not only to the usb serial driver, but
also to the usb driver.
Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag
no_dynamic_id=1. This is added now.
Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de>
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
This is the grungy swap all the occurrences in the right places patch that
goes with the updates. At this point we have the same functionality as
before (except that sgttyb() returns speeds not zero) and are ready to
begin turning new stuff on providing nobody reports lots of bugs
If you are a tty driver author converting an out of tree driver the only
impact should be termios->ktermios name changes for the speed/property
setting functions from your upper layers.
If you are implementing your own TCGETS function before then your driver
was broken already and its about to get a whole lot more painful for you so
please fix it 8)
Also fill in c_ispeed/ospeed on init for most devices, although the current
code will do this for you anyway but I'd like eventually to lose that extra
paranoia
[akpm@osdl.org: bluetooth fix]
[mp3@de.ibm.com: sclp fix]
[mp3@de.ibm.com: warning fix for tty3270]
[hugh@veritas.com: fix tty_ioctl powerpc build]
[jdike@addtoit.com: uml: fix ->set_termios declaration]
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
Acked-by: Peter Oberparleiter <oberpar@de.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/infiniband/core/iwcm.c
drivers/net/chelsio/cxgb2.c
drivers/net/wireless/bcm43xx/bcm43xx_main.c
drivers/net/wireless/prism54/islpci_eth.c
drivers/usb/core/hub.h
drivers/usb/input/hid-core.c
net/core/netpoll.c
Fix up merge failures with Linus's head and fix new compilation failures.
Signed-Off-By: David Howells <dhowells@redhat.com>
Fix various .c/.h typos in comments (no code changes).
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Fix up for make allyesconfig.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
USB serial outside of the kernel tree can not build properly due to
usb-serial.h being buried down in the source tree. This patch moves the
location of the file to include/linux/usb and fixes up all of the usb
serial drivers to handle the move properly.
Cc: Sergei Organov <osv@javad.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The API and code have been through various bits of initial review by
serial driver people but they definitely need to live somewhere for a
while so the unconverted drivers can get knocked into shape, existing
drivers that have been updated can be better tuned and bugs whacked out.
This replaces the tty flip buffers with kmalloc objects in rings. In the
normal situation for an IRQ driven serial port at typical speeds the
behaviour is pretty much the same, two buffers end up allocated and the
kernel cycles between them as before.
When there are delays or at high speed we now behave far better as the
buffer pool can grow a bit rather than lose characters. This also means
that we can operate at higher speeds reliably.
For drivers that receive characters in blocks (DMA based, USB and
especially virtualisation) the layer allows a lot of driver specific
code that works around the tty layer with private secondary queues to be
removed. The IBM folks need this sort of layer, the smart serial port
people do, the virtualisers do (because a virtualised tty typically
operates at infinite speed rather than emulating 9600 baud).
Finally many drivers had invalid and unsafe attempts to avoid buffer
overflows by directly invoking tty methods extracted out of the innards
of work queue structs. These are no longer needed and all go away. That
fixes various random hangs with serial ports on overflow.
The other change in here is to optimise the receive_room path that is
used by some callers. It turns out that only one ldisc uses receive room
except asa constant and it updates it far far less than the value is
read. We thus make it a variable not a function call.
I expect the code to contain bugs due to the size alone but I'll be
watching and squashing them and feeding out new patches as it goes.
Because the buffers now dynamically expand you should only run out of
buffering when the kernel runs out of memory for real. That means a lot of
the horrible hacks high performance drivers used to do just aren't needed any
more.
Description:
tty_insert_flip_char is an old API and continues to work as before, as does
tty_flip_buffer_push() [this is why many drivers dont need modification]. It
does now also return the number of chars inserted
There are also
tty_buffer_request_room(tty, len)
which asks for a buffer block of the length requested and returns the space
found. This improves efficiency with hardware that knows how much to
transfer.
and tty_insert_flip_string_flags(tty, str, flags, len)
to insert a string of characters and flags
For a smart interface the usual code is
len = tty_request_buffer_room(tty, amount_hardware_says);
tty_insert_flip_string(tty, buffer_from_card, len);
More description!
At the moment tty buffers are attached directly to the tty. This is causing a
lot of the problems related to tty layer locking, also problems at high speed
and also with bursty data (such as occurs in virtualised environments)
I'm working on ripping out the flip buffers and replacing them with a pool of
dynamically allocated buffers. This allows both for old style "byte I/O"
devices and also helps virtualisation and smart devices where large blocks of
data suddenely materialise and need storing.
So far so good. Lots of drivers reference tty->flip.*. Several of them also
call directly and unsafely into function pointers it provides. This will all
break. Most drivers can use tty_insert_flip_char which can be kept as an API
but others need more.
At the moment I've added the following interfaces, if people think more will
be needed now is a good time to say
int tty_buffer_request_room(tty, size)
Try and ensure at least size bytes are available, returns actual room (may be
zero). At the moment it just uses the flipbuf space but that will change.
Repeated calls without characters being added are not cumulative. (ie if you
call it with 1, 1, 1, and then 4 you'll have four characters of space. The
other functions will also try and grow buffers in future but this will be a
more efficient way when you know block sizes.
int tty_insert_flip_char(tty, ch, flag)
As before insert a character if there is room. Now returns 1 for success, 0
for failure.
int tty_insert_flip_string(tty, str, len)
Insert a block of non error characters. Returns the number inserted.
int tty_prepare_flip_string(tty, strptr, len)
Adjust the buffer to allow len characters to be added. Returns a buffer
pointer in strptr and the length available. This allows for hardware that
needs to use functions like insl or mencpy_fromio.
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
It is no longer needed, so let's remove it, saving a bit of memory.
This lets drivers, like the usb-serial ones, disable the ability to add
ids from sysfs.
The usb-serial drivers are "odd" in that they are really usb-serial bus
drivers, not usb bus drivers, so the dynamic id logic will have to go
into the usb-serial bus core for those drivers to get that ability.
This fixes up a lot of problems in sysfs with some of the usb serial
drivers, they had incorrect driver names. Also saves a tiny ammount
of memory.
Don't duplicate something that's already in struct driver.
I'm tired of trying to explain why a "device_type" is really a driver.
This better describes exactly what this structure is.
First patch incorrectly changed state of the wait-queue usage to
TASK_UNINTERRUPTIBLE. Reverted to TASK_INTERRUPTIBLE.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
infrastructure for it.
Let it rip!
