path: root/drivers/usb/serial/empeg.c
2010-05-20USB: empeg: reimplement using generic frameworkJohan Hovold
Kill custom read and write implementations (static 16*4k write-urb pool shared among all ports in system). Also remove old changelog entries in header (code is now gone, and these entries can still be retrieved through git). Compile-only tested. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: tty: Prune uses of tty_request_room in the USB layerAlan Cox
We have lots of callers that do not need to do this in the first place. Remove the calls as they both cost CPU and for big buffers can mess up the multi-page allocation avoidance. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB serial: make USB device id constantNémeth Márton
The id_table field of the struct usb_device_id is constant in <linux/usb.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Németh Márton <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-09USB: serial: fix assumption that throttle/unthrottle cannot sleepOliver Neukum
many serial subdrivers are clearly written as if throttle/unthrottle cannot sleep. This leads to unneeded atomic submissions. This patch converts affected drivers in a way to makes very clear that throttle/unthrottle can sleep. Thus future misdesigns can be avoided and efficiency and reliability improved. This removes any such assumption using GFP_KERNEL and spin_lock_irq() Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19tty: USB serial termios bitsAlan Cox
Various drivers have hacks to mangle termios structures. This stems from the fact there is no nice setup hook for configuring the termios settings when the port is created Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19tty: USB does not need the filp argument in the driversAlan Cox
And indeed none of them use it. Clean this up as it will make moving to a standard open method rather easier. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: usb-serial: replace shutdown with disconnect, releaseAlan Stern
This patch (as1254) splits up the shutdown method of usb_serial_driver into a disconnect and a release method. The problem is that the usb-serial core was calling shutdown during disconnect handling, but drivers didn't expect it to be called until after all the open file references had been closed. The result was an oops when the close method tried to use memory that had been deallocated by shutdown. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11tty: Bring the usb tty port structure into more useAlan Cox
This allows us to clean stuff up, but is probably also going to cause some app breakage with buggy apps as we now implement proper POSIX behaviour for USB ports matching all the other ports. This does also mean other apps that break on USB will now work properly. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-23USB: removal of tty->low_latency hack dating back to the old serial codeOliver Neukum
This removes tty->low_latency from all USB serial drivers that push data into the tty layer at hard interrupt context. It's no longer needed and actually harmful. Signed-off-by: Oliver Neukum <oliver@neukum.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove use of err() in drivers/usb/serialGreg Kroah-Hartman
err() is going away, so switch to dev_err() or printk() if it's really needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove info() macro from usb/serial driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13tty: usb-serial krefsAlan Cox
Use kref in the USB serial drivers so that we don't free tty structures from under the URB receive handlers as has historically been the case if you were unlucky. This also gives us a framework for general tty drivers to use tty_port objects and refcount. Contains two err->dev_err changes merged together to fix clashes in the -next tree. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22empeg: Coding styleAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22usb_serial: API all changeAlan Cox
USB serial likes to use port->tty back pointers for the real work it does and to do so without any actual locking. Unfortunately when you consider hangup events, hangup/parallel reopen or even worse hangup followed by parallel close events the tty->port and port->tty pointers are not guaranteed to be the same as port->tty is the active tty while tty->port is the port the tty may or may not still be attached to. So rework the entire API to pass the tty struct. For console cases we need to pass both for now. This shows up multiple drivers that immediately crash with USB console some of which have been fixed in the process. Longer term we need a proper tty as console abstraction Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24USB: remove unnecessary type casting of urb->contextMing Lei
urb->context code cleanup Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: serial: remove unneeded number endpoints settingsGreg Kroah-Hartman
The usb-serial core no longer checks these fields so remove them from all of the individual drivers. They will be removed from the usb-serial core in a patch later in the series. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-25USB: empeg: clean up and handle speedsAlan Cox
The empeg is pretty fixed. Tidy up the long foo->bar->baz stuff and encode the fixed speed properly. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: serial: empeg: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Cc: <linux-usb-devel@lists.sourceforge.net> Cc: Gary Brubaker <xavyer@ix.netcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB serial: add driver pointer to all usb-serial driversJohannes Hölzl
Every usb serial driver should have a pointer to the corresponding usb driver. So the usb serial core can add a new id not only to the usb serial driver, but also to the usb driver. Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag no_dynamic_id=1. This is added now. Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[PATCH] USB: move usb-serial.h to include/linux/usb/Greg Kroah-Hartman
USB serial outside of the kernel tree can not build properly due to usb-serial.h being buried down in the source tree. This patch moves the location of the file to include/linux/usb and fixes up all of the usb serial drivers to handle the move properly. Cc: Sergei Organov <osv@javad.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB serial: encapsulate schedule_work, remove double-callingPete Zaitcev
I'm going to throw schedule_work away, it's retarded. But for starters, let's have it encapsulated. Also, generic and whiteheat were both calling usb_serial_port_softint and scheduled work. Only one was necessary. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: allow usb drivers to disable dynamic idsGreg Kroah-Hartman
This lets drivers, like the usb-serial ones, disable the ability to add ids from sysfs. The usb-serial drivers are "odd" in that they are really usb-serial bus drivers, not usb bus drivers, so the dynamic id logic will have to go into the usb-serial bus core for those drivers to get that ability. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: move name to driver structureGreg Kroah-Hartman
This fixes up a lot of problems in sysfs with some of the usb serial drivers, they had incorrect driver names. Also saves a tiny ammount of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: get rid of the .owner field in usb_serial_driverGreg Kroah-Hartman
Don't duplicate something that's already in struct driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: rename usb_serial_device_type to usb_serial_driverGreg Kroah-Hartman
I'm tired of trying to explain why a "device_type" is really a driver. This better describes exactly what this structure is. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] USB: kfree cleanup for drivers/usb/* - no need to check for NULLJesper Juhl
Get rid of a bunch of redundant NULL pointer checks in drivers/usb/*, there's no need to check a pointer for NULL before calling kfree() on it. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/drivers/usb/class/audio.c ===================================================================
