commit c1a1f273d0825774c80896b8deb1c9ea1d0b91e3 upstream.
This device presents itself as a USB hub with three attached devices:
- An ACM serial port connected to the GPS module (not affected by this
commit)
- An FTDI serial port connected to the GPS module (1546:0502)
- Another FTDI serial port connected to the ODIN-W2 radio module
(1546:0503)
This commit registers U-Blox's VID and the PIDs of the second and third
devices.
Datasheet: https://www.u-blox.com/sites/default/files/C099-F9P-AppBoard-Mbed-OS3-FW_UserGuide_%28UBX-18063024%29.pdf
Signed-off-by: Fabio D'Urso <fabiodurso@hotmail.it>
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 357f16d9e0194cdbc36531ff88b453481560b76a upstream.
Both devices added here have a FTDI chip inside. The device from Echelon
is called 'Network Interface' it is actually a LON network gateway.
ID 0403:8348 Future Technology Devices International, Ltd
https://www.eltako.com/fileadmin/downloads/de/datenblatt/Datenblatt_PL-SW-PROF.pdf
ID 0920:7500 Network Interface
https://www.echelon.com/products/u20-usb-network-interface
Signed-off-by: Beni Mahler <beni.mahler@gmx.net>
commit f8377eff548170e8ea8022c067a1fbdf9e1c46a8 upstream.
This adds the vid:pid of the isodebug v1 isolated JTAG/SWD+UART. Only the
second channel is available for use as a serial port.
Signed-off-by: Andreas Fritiofson <andreas.fritiofson@unjo.com>
commit 422c2537ba9d42320f8ab6573940269f87095320 upstream.
Add PIDs for the NovaTech OrionLX+ and Orion I/O so they can be
automatically detected.
Signed-off-by: George McCollister <george.mccollister@gmail.com>
commit 8d7fa3d4ea3f0ca69554215e87411494e6346fdc upstream.
This adds the USB ID of the Hjelmslund Electronics USB485 Iso stick.
Signed-off-by: Mans Rullgard <mans@mansr.com>
commit 470b5d6f0cf4674be2d1ec94e54283a1770b6a1a upstream.
Arrow USB Blaster integrated on MAX1000 board uses the same vendor ID
(0x0403) and product ID (0x6010) as the "original" FTDI device.
This patch avoids picking up by ftdi_sio of the first interface of this
USB device. After that this device can be used by Arrow user-space JTAG
driver.
Signed-off-by: Vasyl Vavrychuk <vvavrychuk@gmail.com>
commit 6555ad13a01952c16485c82a52ad1f3e07e34b3a upstream.
Add device id for Harman FirmwareHubEmulator to make the device
auto-detectable by the driver.
Signed-off-by: Clemens Werther <clemens.werther@gmail.com>
commit 9608e5c0f079390473b484ef92334dfd3431bb89 upstream.
This patch adds a device ID for the RT Systems cable used to
program Yaesu VX-8R/VX-8DR handheld radios. It uses the main
FTDI VID instead of the common RT Systems VID.
Signed-off-by: Major Hayden <major@mhtx.net>
commit c6a36ad383559a60a249aa6016cebf3cb8b6c485 upstream.
Add AIRBUS_DS_P8GR device IDs to ftdi_sio driver.
Signed-off-by: Max Schulze <max.schulze@posteo.de>
Add CYPRESS_VID vid and CYPRESS_WICED_BT_USB and CYPRESS_WICED_WL_USB
Signed-off-by: Jeffrey Chu <jeffrey.chu@cypress.com>
Remove the broken alt_speed code, and warn when trying to set the line
speed using TIOCSSERIAL and SPD flags.
The use of SPD flags to set the line speed has been deprecated since
v2.1.69 and support for alt_speed (e.g. "warp") has even been removed
from TTY core in v3.10 by commit 6865ff222cca ("TTY: do not warn about
setting speed via SPD_*"), effectively breaking all driver
implementations of this except for serial core.
Also remove the verbose and outdated comment on how to set baud rates.
Note that setting a custom divisor will continue to work with the
caveat that 38400 must again be selected every time the divisor is
changed since v2.6.24 and commit 669a6db1037e ("USB: ftd_sio: cleanups
and updates for new termios work") which started reporting back the
actual baud rate used.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Reviewed-by: Alan Cox <alan@linux.intel.com>
Simplify TIOCSSERIAL flag logic somewhat.
This patch adds support for recognition of ARM-USB-TINY(H) devices which
are almost identical to ARM-USB-OCD(H) but lacking separate barrel jack
and serial console.
By suggestion from Johan Hovold it is possible to replace
ftdi_jtag_quirk with a bit more generic construction. Since all
Olimex-ARM debuggers has exactly two ports, we could safely always use
only second port within the debugger family.
Signed-off-by: Andrey Korolyov <andrey@xdel.ru>
Commit 557aaa7ffab6 ("ft232: support the ASYNC_LOW_LATENCY
flag") enables unprivileged users to set the FTDI latency timer,
but there was a logic flaw that skipped sending the corresponding
USB control message to the device.
Specifically, the device latency timer would not be updated until next
open, something which was later also inadvertently broken by commit
c19db4c9e49a ("USB: ftdi_sio: set device latency timeout at port
probe").
A recent commit c6dce2626606 ("USB: serial: ftdi_sio: fix extreme
low-latency setting") disabled the low-latency mode by default so we now
need this fix to allow unprivileged users to again enable it.
Signed-off-by: Anthony Mallet <anthony.mallet@laas.fr>
[johan: amend commit message]
Fixes: 557aaa7ffab6 ("ft232: support the ASYNC_LOW_LATENCY flag")
Fixes: c19db4c9e49a ("USB: ftdi_sio: set device latency timeout at port probe").
Cc: stable <stable@vger.kernel.org> # 2.6.31
This development kit has an FT4232 on it with a custom USB VID/PID.
The FT4232 provides four UARTs, but only two are used. The UART 0
is used by the FlashPro5 programmer and UART 2 is connected to the
SmartFusion2 CortexM3 SoC UART port.
Note that the USB VID is registered to Actel according to Linux USB
VID database, but that was acquired by Microsemi.
The 'store' function for the "event_char" device attribute currently
expects a base 10 value. The value is composed of an enable bit in bit
8 and an 8-bit "event character" code in bits 7 to 0. It seems
reasonable to allow hexadecimal and octal numbers to be written to the
device attribute in addition to decimal. Make it so.
Change the debug message to show the value in hexadecimal, rather than
decimal.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
The "event_char" device attribute value, when written, is interpreted as
an enable bit in bit 8, and an "event character" in bits 7 to 0.
Return an error -EINVAL for out-of-range values. Use kstrtouint() to
parse the integer instead of the obsolete simple_strtoul().
Valid latency timer values are between 1 ms and 255 ms in 1 ms steps.
The store function for the "latency_timer" device attribute currently
allows any value, although only the lower 16 bits will be sent to the
device, and the device only stores the lower 8 bits. The hardware
appears to accept the (invalid) value 0 and treats it the same as 1
(resulting in a latency of 1 ms).
Change the latency_timer_store() function to accept only the values 0 to
255, returning an error -EINVAL for out-of-range values. Call
kstrtou8() to parse the integer instead of the obsolete
simple_strtoul().
If a BM type chip has iSerialNumber set to 0 in its EEPROM, an incorrect
value is read from the bcdDevice field of the USB descriptor, making it
look like an AM type chip. Attempt to correct this in
ftdi_determine_type() by attempting to read the latency timer for an AM
type chip if it has iSerialNumber set to 0. If that succeeds, assume it
is a BM type chip.
Currently, read_latency_timer() bails out without reading the latency
timer for an AM type chip, so factor out the guts of
read_latency_timer() into a new function _read_latency_timer() that
attempts to read the latency timer regardless of chip type, and returns
either the latency timer value or a negative error number.
The latency timer was introduced with the FT232BM and FT245BM chips. Do
not bother attempting to read or write it for older chip versions.
FTDI devices use a receive latency timer to periodically empty the
receive buffer and report modem and line status (also when the buffer is
empty).
When a break or error condition is detected the corresponding status
flags will be set on a packet with nonzero data payload and the flags
are not updated until the break is over or further characters are
received.
In order to avoid over-reporting break and error conditions, these flags
must therefore only be processed for packets with payload.
This specifically fixes the case where after an overrun, the error
condition is continuously reported and NULL-characters inserted until
further data is received.
Reported-by: Michael Walle <michael@walle.cc>
Fixes: 72fda3ca6fc1 ("USB: serial: ftd_sio: implement sysrq handling on
break")
Fixes: 166ceb690750 ("USB: ftdi_sio: clean up line-status handling")
Cc: stable <stable@vger.kernel.org> # v2.6.35
Clean up the ioctl handler and make sure to pass an unsigned-int rather
than serial_struct pointer to the TIOCSERGETLSR helper as this it what
the user argument really is.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Since commit 557aaa7ffab6 ("ft232: support the ASYNC_LOW_LATENCY
flag") the FTDI driver has been using a receive latency-timer value of
1 ms instead of the device default of 16 ms.
The latency timer is used to periodically empty a non-full receive
buffer, but a status header is always sent when the timer expires
including when the buffer is empty. This means that a two-byte bulk
message is received every millisecond also for an otherwise idle port as
long as it is open.
Let's restore the pre-2009 behaviour which reduces the rate of the
status messages to 1/16th (e.g. interrupt frequency drops from 1 kHz to
62.5 Hz) by not setting ASYNC_LOW_LATENCY by default.
Anyone willing to pay the price for the minimum-latency behaviour should
set the flag explicitly instead using the TIOCSSERIAL ioctl or a tool
such as setserial (e.g. setserial /dev/ttyUSB0 low_latency).
Note that since commit 0cbd81a9f6ba ("USB: ftdi_sio: remove
tty->low_latency") the ASYNC_LOW_LATENCY flag has no other effects but
to set a minimal latency timer.
Reported-by: Antoine Aubert <a.aubert@overkiz.com>
Cc: stable@vger.kernel.org # v2.6.31: e3e574ad85a2
Make sure to detect short responses when reading the latency timer to
avoid using stale buffer data.
Note that no heap data would currently leak through sysfs as
ASYNC_LOW_LATENCY is set by default.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Make sure to detect short responses when fetching the modem status in
order to avoid parsing uninitialised buffer data and having bits of it
leak to user space.
Note that we still allow for short 1-byte responses.
git://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-next
Johan writes:
USB-serial updates for v4.10-rc1
These updates include a new driver for Fintek F8153x devices, support
for the GPIO functionality on CP2105 devices, and improved support for
CH34X devices.
Included are also some clean ups and fixes for various minor issues.
Drop invalid user-pointer checks from ioctl handlers.
A NULL-pointer can be valid in user space and copy_to_user() takes care
of sanity checking.
This patch adds support for the TI CC3200 LaunchPad board, which uses a
custom USB vendor ID and product ID. Channel A is used for JTAG, and
channel B is used for a UART.
Signed-off-by: Doug Brown <doug@schmorgal.com>
This adds support to ftdi_sio for the Infineon TriBoard TC2X7
engineering board for first-generation Aurix SoCs with Tricore CPUs.
Mere addition of the device IDs does the job.
Signed-off-by: Stefan Tauner <stefan.tauner@technikum-wien.at>
BCM20706V2_EVAL is a WICED dev board designed with FT2232H USB 2.0
UART/FIFO IC.
To support BCM920706V2_EVAL dev board for WICED development on Linux.
Add the VID(0a5c) and PID(6422) to ftdi_sio driver to allow loading
ftdi_sio for this board.
Signed-off-by: Sheng-Hui J. Chu <s.jeffrey.chu@gmail.com>
Ivium Technologies uses the FTDI VID with custom PIDs for their line of
electrochemical interfaces and the PalmSens they developed for PalmSens
BV.
Signed-off-by: Robert Delien <robert@delien.nl>
The ftdi_sio_quirk structures are never modified, so declare them as
const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
A Fedora user reports that the ftdi_sio driver works properly for the
ICP DAS I-7561U device. Further, the user manual for these devices
instructs users to load the driver and add the ids using the sysfs
interface.
Add support for these in the driver directly so that the devices work
out of the box instead of needing manual configuration.
Reported-by: <thesource@mail.ru>
CC: stable <stable@vger.kernel.org>
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
Move constants to the right of binary operators where it increases
readability.
Generated by: scripts/coccinelle/misc/compare_const_fl.cocci
Signed-off-by: Mathieu OTHACEHE <m.othacehe@gmail.com>
[johan: drop some chunks and fix others, amend commit message ]
Harald Linden reports that the ftdi_sio driver works properly for the
Yaesu SCU-18 cable if the device ids are added to the driver. So let's
add them.
Reported-by: Harald Linden <harald.linden@7183.org>
CustomWare uses the FTDI VID with custom PIDs for their ShipModul MiniPlex
products.
Signed-off-by: Matthijs Kooijman <matthijs@stdin.nl>
This adds support for new Xsens device, Motion Tracker Development Board,
using Xsens' own Vendor ID
Signed-off-by: Patrick Riphagen <patrick.riphagen@xsens.com>
This patch uses the existing CALAO Systems ftdi_8u2232c_probe in order
to avoid attaching a TTY to the JTAG port as this board is based on the
CALAO Systems reference design and needs the same fix up.
Signed-off-by: Doug Goldstein <cardoe@cardoe.com>
[johan: clean up probe logic ]
Synapse Wireless uses the FTDI VID with a custom PID of 0x9090 for their
SNAP Stick 200 product.
This patch integrates Cyber Cortex AV boards with the existing
ftdi_jtag_quirk in order to use serial port 0 with JTAG which is
required by the manufacturers' software.
Steps: 2
[ftdi_sio_ids.h]
1. Defined the device PID
[ftdi_sio.c]
2. Added a macro declaration to the ids array, in order to enable the
jtag quirk for the device.
Signed-off-by: Max Mansfield <max.m.mansfield@gmail.com>
These product identifiers (PID) all deal with marine NMEA format data
used on motor boats and yachts. We supply the programmed devices to
Chetco, for use inside their equipment. The PIDs are a direct copy of
our Windows device drivers (FTDI drivers with altered PIDs).
Signed-off-by: Mark Glover <mark@actisense.com>
[johan: edit commit message slightly ]
Add PIDs for new Matrix Orbital GTT series products.
Signed-off-by: Troy Clark <tclark@matrixorbital.ca>
[johan: shorten commit message ]
An official recent Windows driver from FTDI detects counterfeit devices
and reprograms the internal EEPROM containing the USB PID to 0, effectively
bricking the device.
Add support for this VID/PID pair to correctly bind the driver on these
devices.
See:
http://hackaday.com/2014/10/22/watch-that-windows-update-ftdi-drivers-are-killing-fake-chips/
Signed-off-by: Perry Hung <iperry@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Add new IDs for the Xsens Awinda Station and Awinda Dongle.
While at it, order the definitions by PID and add a logical separation
between devices using Xsens' VID and those using FTDI's VID.
Cc: <stable@vger.kernel.org>
Signed-off-by: Frans Klaver <frans.klaver@xsens.com>
Signed-off-by: Taylor Braun-Jones <taylor.braun-jones@ge.com>
Cc: Johan Hovold <johan@kernel.org>
Add device id for NOVITUS Bono E thermal printer.
Reported-by: Emanuel Koczwara <poczta@emanuelkoczwara.pl>
Added support to the ftdi_sio driver for ekey Converter USB which
uses an FT232BM chip.
Signed-off-by: Jaša Bartelj <jasa.bartelj@gmail.com>
Add device id for Basic Micro ATOM Nano USB2Serial adapters.
Reported-by: Nicolas Alt <n.alt@mytum.de>
Tested-by: Nicolas Alt <n.alt@mytum.de>
This adds support for new Xsens devices, using Xsens' own Vendor ID.
Johan writes:
USB-serial updates for v3.17-rc1
Here are some minor fixes and clean-ups to the ftdi_sio, mos7840 and kl5kusb105
drivers for v3.17-rc1.
