This patch limits the amount of outstanding 'write' data that can be
queued up for the ftdi_sio driver, to prevent userspace DoS attacks (or
simple accidents) that use up all the system memory by writing lots of
data to the serial port.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
This patch adds a bunch of new device IDs to the ftdi_sio driver for
various devices from microHAM using FTDI chips.
Micheal Studer supplied the PID for the USB-Y9 device. I examined the
INF file in microHAM's Windows driver package for the USB-KW, USB-YS,
USB-IC, USB-DB9 and USB-RS232 devices.
Documentation: Specify grayscale specification on ATIK-ATK16
and ATIK-ATK16HR comments.
New: Add ProductID and VendorID for devices ATIK-ATK16C and
ATIK-ATK16HRC. These devices are also USB Astronomical CCD
cameras that work through an FTDI 245BM chip, share the
same base hardware but, it has a colour CCD chip instead
of a grayscale one.
Signed-off-by: Rui Santos <rsantos@grupopie.com>
The attached patch adds a new PID for the ftdi_sio driver. It will
enable support for PC-DJ's DAC-2 controller module
(more information on http://www.pcdjhardware.com/DAC2.asp)
Signed-off-by: Wouter Paesen <wouter@kangaroot.net>
This patch adds two new devices to the ftdi_sio driver's device ID
table. The device IDs were supplied by Cory Lee to support two POS
printers made by Westrex International (Model 777 and Model 8900F).
this patch includes the Vendor Id for a optic fiber to USB device named
TTUSB from thought Technology. It's just add the vendor Id to
ftdi_sio.h and add the Vendor ID and model Id to table_combined.
Signed-off-by: Louis Nyffenegger <louis.nyffenegger@gmail.com>
The API and code have been through various bits of initial review by
serial driver people but they definitely need to live somewhere for a
while so the unconverted drivers can get knocked into shape, existing
drivers that have been updated can be better tuned and bugs whacked out.
This replaces the tty flip buffers with kmalloc objects in rings. In the
normal situation for an IRQ driven serial port at typical speeds the
behaviour is pretty much the same, two buffers end up allocated and the
kernel cycles between them as before.
When there are delays or at high speed we now behave far better as the
buffer pool can grow a bit rather than lose characters. This also means
that we can operate at higher speeds reliably.
For drivers that receive characters in blocks (DMA based, USB and
especially virtualisation) the layer allows a lot of driver specific
code that works around the tty layer with private secondary queues to be
removed. The IBM folks need this sort of layer, the smart serial port
people do, the virtualisers do (because a virtualised tty typically
operates at infinite speed rather than emulating 9600 baud).
Finally many drivers had invalid and unsafe attempts to avoid buffer
overflows by directly invoking tty methods extracted out of the innards
of work queue structs. These are no longer needed and all go away. That
fixes various random hangs with serial ports on overflow.
The other change in here is to optimise the receive_room path that is
used by some callers. It turns out that only one ldisc uses receive room
except asa constant and it updates it far far less than the value is
read. We thus make it a variable not a function call.
I expect the code to contain bugs due to the size alone but I'll be
watching and squashing them and feeding out new patches as it goes.
Because the buffers now dynamically expand you should only run out of
buffering when the kernel runs out of memory for real. That means a lot of
the horrible hacks high performance drivers used to do just aren't needed any
more.
Description:
tty_insert_flip_char is an old API and continues to work as before, as does
tty_flip_buffer_push() [this is why many drivers dont need modification]. It
does now also return the number of chars inserted
There are also
tty_buffer_request_room(tty, len)
which asks for a buffer block of the length requested and returns the space
found. This improves efficiency with hardware that knows how much to
transfer.
and tty_insert_flip_string_flags(tty, str, flags, len)
to insert a string of characters and flags
For a smart interface the usual code is
len = tty_request_buffer_room(tty, amount_hardware_says);
tty_insert_flip_string(tty, buffer_from_card, len);
More description!
At the moment tty buffers are attached directly to the tty. This is causing a
lot of the problems related to tty layer locking, also problems at high speed
and also with bursty data (such as occurs in virtualised environments)
I'm working on ripping out the flip buffers and replacing them with a pool of
dynamically allocated buffers. This allows both for old style "byte I/O"
devices and also helps virtualisation and smart devices where large blocks of
data suddenely materialise and need storing.
So far so good. Lots of drivers reference tty->flip.*. Several of them also
call directly and unsafely into function pointers it provides. This will all
break. Most drivers can use tty_insert_flip_char which can be kept as an API
but others need more.
At the moment I've added the following interfaces, if people think more will
be needed now is a good time to say
int tty_buffer_request_room(tty, size)
Try and ensure at least size bytes are available, returns actual room (may be
zero). At the moment it just uses the flipbuf space but that will change.
Repeated calls without characters being added are not cumulative. (ie if you
call it with 1, 1, 1, and then 4 you'll have four characters of space. The
other functions will also try and grow buffers in future but this will be a
more efficient way when you know block sizes.
int tty_insert_flip_char(tty, ch, flag)
As before insert a character if there is room. Now returns 1 for success, 0
for failure.
int tty_insert_flip_string(tty, str, len)
Insert a block of non error characters. Returns the number inserted.
int tty_prepare_flip_string(tty, strptr, len)
Adjust the buffer to allow len characters to be added. Returns a buffer
pointer in strptr and the length available. This allows for hardware that
needs to use functions like insl or mencpy_fromio.
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
This patch adds vendor and product IDs to the ftdi_sio driver's device
ID table for two devices from teratronik.de. The device IDs were
submitted by O. Wölfelschneider of Teratronik Elektronische Systeme
GmbH.
The charset of the patch is latin-1, same as the original files.
Please apply, thanks! (I've tried to avoid a clash with Andrew Morton's
patch to add support for Posiflex PP-7700 printer to the same driver.)
This little patch adds recognition of Posiflex PP-7000 retail printer to
ftdo_sio module. The printer uses FT232BM bridge programmed with custom
VID/PID. The patch posted to lkml and sf.net was for 2.6.11.1 kernel,
here is one reworked for 2.6.12.
patch below marks various USB tables and variables as const so that they
end up in .rodata section and don't cacheline share with things that get
written to. For the non-array variables it also allows gcc to optimize
more.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
This lets drivers, like the usb-serial ones, disable the ability to add
ids from sysfs.
The usb-serial drivers are "odd" in that they are really usb-serial bus
drivers, not usb bus drivers, so the dynamic id logic will have to go
into the usb-serial bus core for those drivers to get that ability.
table. The device IDs were supplied by Stefan Nies of KOBIL Systems for
two of their devices using the FTDI chip.
This is a patch to get the ELV FHZ1000 Home Automation control device to
work with Linux. The patch adds a new device ID to the ftdi_sio driver.
It is for kernel version 2.6.13.4.
Signed-off-by: Martin Hagelin <martin.hagelin@home.se>
This fixes up a lot of problems in sysfs with some of the usb serial
drivers, they had incorrect driver names. Also saves a tiny ammount
of memory.
Don't duplicate something that's already in struct driver.
I'm tired of trying to explain why a "device_type" is really a driver.
This better describes exactly what this structure is.
We would like to add a PID for the Pyramid Appliance Display, which works
on USB via FTDI_SIO.
Signed-off-by: Thomas Riewe <thomasr@pyramid.de>
drivers/usb/serial/ftdi_sio.c | 1 +
drivers/usb/serial/ftdi_sio.h | 3 +++
2 files changed, 4 insertions(+)
This patch enables direct kernel support for the Artemis
and ATIK astronomical based USB CCD cameras.
Since all communications with this camera are done via an
FTDI 245BM chip, it was only needed to specify the
ProductID and VendorID of all three devices.
In what tests are concerned, data was transfered from and
to the FTDI at the chips Top speed (360KB/s).
drivers/usb/serial/ftdi_sio.c | 3 +++
drivers/usb/serial/ftdi_sio.h | 13 +++++++++++++
2 files changed, 16 insertions(+)
I'm using a 2 port USB RS232 dongle to connect to a serial-IR cradle for
a bar code reader). Detecting the baudrate of the serial-IR involves
keeping DTR low while changing baudrate.
This works using normal 16550A serial ports as well as the FTDI driver
version 1.4.0 (Linux 2.6.8) but stopped working with the change to
"ensure RTS and DTR are raised when changing baudrate" introduced in
version 1.4.1 (Linux 2.6.9).
The attached patch fixes this, so RTS and DTR is only raised when
changing baudrate iff the previous baudrate was B0.
Signed-off-by: Peter Favrholdt <pfavr@how.dk>
ftdi_sio: I messed up the baud_base for custom baud rate support in
2.6.13. The attached one-liner patch fixes it.
This patch for the ftdi_sio driver adds a bunch of new devices and fixes
an incorrect PID:
o Fix PID for ELV UO100 (the PID was in fact for ELV UR100).
o Add PID ELV UR100 (see above) and ELV ALC 8500 Expert.
o Add a whole bunch of other PIDs for ELV USB devices, commented out for
now as they may be used by other drivers eventually. (Christian Abt
of ELV.de submitted a full list of devices including an indication of
which set of drivers are used by default in the MS Windows world. We
decided to comment out the devices that use FTDI's D2XX Windows
drivers by default.)
o Add PIDs for eight devices from Xsens Technologies BV (submitted in a
patch against 2.6.12.2 by Patrick Riphagen).
o Add PID for Falcom Samba GPRS modem (submitted by Sebastian Schubert).
ftdi_sio: Support one user specified vendor and product ID via a couple
of new module parameters.
ftdi_sio: Fix timeouts in a couple of usb_control_msg() calls due to
change of units from jiffies to milliseconds in 2.6.12.
ftdi_sio: Update RTS and DTR simultaneously, using a single control URB
instead of separate control URBs for RTS and DTR. Reinhard Bergmann
observed time differences of up to 680 ms with his application on a
2.4.22 kernel when RTS and DTR were updated using separate control
URBs, which is unacceptable.
The attached patch adds the following new devices to the ftdi_sio driver:
* microHAM USB-Y6 and USB-Y8 devices submitted by Justin Burket (KL1RL).
* Evolution Robotics ER1 Control Module submitted by Shawn M. Lavelle.
ftdi_sio: Remove redundant handling of TIOCMBIS and TIOCMBIC ioctls
as they are handled in the tty layer and never reach this driver.
ftdi_sio: Use a single usb_device_id table and detect the type of chip
programatically. The table also flags devices requiring special
initialization. The patch makes the driver about 10K smaller and makes
it easier to add new device IDs.
drivers/zorro/zorro-sysfs.c: update device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
ftdi_sio: Avoid losing bytes at tty-ldisc.
This patch was originally developed by Daniel Smertnig. I
(Ian Abbott) made a few changes. It has been tested by both
Daniel and I, at least for raw, non-canonical receive data
processing.
Here is Daniel's original description of the patch:
During a project in which I was using a FTDI 232BM to
transmit data at relative high speeds (625kBit/s), I
noticed a problem where data was lost even if flow
control was enabled: The FTDI-Driver receives 512 Bytes
of data over USB at a time, which consists of 8 64-Byte
packets. Subtracting the 2 bytes of status information
included in each packet this gives 496 "real" data
bytes per read.
This data is passed (indirectly, via the flip buffers)
to the tty line discipline which takes care of
throttling when there the free buffer space reaches
TTY_THRESHOLD_THROTTLE (128). Because the FTDI driver
processes up to 496 bytes at a time, throttling won't
happen in time and the line discipline will discard the
remaining bytes.
To avoid this the patch passes data in 62-byte blocks
to the tty layer and checks the available space in the
ldisc-buffers. If there isn't enough free space,
processing the rest of the data is delayed using a
workqueue.
Note: The original problem should be easily
reproducible with a userspace program which does slow &
small reads.
Signed-off-by: Daniel Smertnig <daniel.smertnig@gmail.com>
ftdi_sio: Add PID for "ELV USB Module UM100".
PID sent by Armin Laugher.
Here are some spelling corrections for drivers/usb.
cancelation -> cancellation
succesful -> successful
decriptor -> descriptor
Initalize -> Initialize
wierd -> weird
Protocoll -> Protocol
occured -> occurred
successfull -> successful
Procesing -> Processing
devide -> divide
Isochronuous -> Isochronous
noticable -> noticeable
Basicly -> Basically
transfering -> transferring
intialize -> initialize
Incomming -> Incoming
additionnal -> additional
asume -> assume
Unfortunatly -> Unfortunately
retreive -> retrieve
tranceiver -> transceiver
Compatiblity -> Compatibility
Incorprated -> Incorporated
existance -> existence
Ununsual -> Unusual
Signed-off-by: Steven Cole <elenstev@mesatop.com>
[ftdi_sio] Replaced redundant INTERFACE_A and INTERFACE_B macros with
the equivalent PIT_SIOA and PIT_SIOB macros.
Some VID/PID updates for the ftdi_sio driver:
* The "Gude Analog- und Digitalsysteme GmbH" entries were missing from
the "combined" table.
* Replaced FTDI_8U232AM_ALT_ALT_PID with 3 PIDs for devices from
4n-galaxy.de.
* Removed redundant FTDI_RM_VID and renamed FTDI_RMCANVIEW_PID to
FTDI_RM_CANVIEW_PID.
* Added VID/PID for serial converter in Mobility Electronics EasiDock
USB 200 (mentioned by Gregory Schmitt).
* Added PID for Active Robots USB comms board (mentioned by John Koch).
diff -ur a/drivers/usb/serial/ftdi_sio.c b/drivers/usb/serial/ftdi_sio.c
Get rid of a bunch of redundant NULL pointer checks in drivers/usb/*,
there's no need to check a pointer for NULL before calling kfree() on it.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
Index: gregkh-2.6/drivers/usb/class/audio.c
infrastructure for it.
Let it rip!
