This converts the io_edgeport.c driver to use the module_usb_serial_driver() call
instead of having to have a module_init/module_exit function, saving a lot
of duplicated code.
CC: Johan Hovold <jhovold@gmail.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Huzaifa Sidhpurwala <huzaifas@redhat.com>
CC: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
This patch (as1525) modifies the following usb-serial drivers to
utilize the new usb_serial_{de}register_drivers() routines:
io_edgeport, io_ti, ipaq, ipw, ir-usb, and iuu_phoenix.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Use dev_err_console in write paths for devices which can be used as a
console but do not use the generic write implementation.
Compile-only tested.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Remove unnecessary reinitialisations of urb->dev before each submission,
which were based on the (no longer valid) assumption that serial->dev
will be set to NULL on close.
Cc: Matthias Bruestle and Harald Welte <support@reiner-sct.com>
Cc: Lonnie Mendez <dignome@gmail.com>
Cc: Peter Berger <pberger@brimson.com>
Cc: Al Borchers <alborchers@steinerpoint.com>
Cc: Support Department <support@connecttech.com>
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: David Kubicek <dave@awk.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits)
pch_uart: reference clock on CM-iTC
pch_phub: add new device ML7213
n_gsm: fix UIH control byte : P bit should be 0
n_gsm: add a documentation
serial: msm_serial_hs: Add MSM high speed UART driver
tty_audit: fix tty_audit_add_data live lock on audit disabled
tty: move cd1865.h to drivers/staging/tty/
Staging: tty: fix build with epca.c driver
pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()
Staging: generic_serial: fix double locking bug
nozomi: don't use flush_scheduled_work()
tty/serial: Relax the device_type restriction from of_serial
MAINTAINERS: Update HVC file patterns
tty: phase out of ioctl file pointer for tty3270 as well
tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile
pch_uart: Fix DMA channel miss-setting issue.
pch_uart: fix exclusive access issue
pch_uart: fix auto flow control miss-setting issue
pch_uart: fix uart clock setting issue
pch_uart : Use dev_xxx not pr_xxx
Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied
twice, then changes to the same area in one branch)
timeout variable is not used anywhere in int write_cmd_usb, remove it
Signed-off-by: Huzaifa Sidhpurwala <huzaifas@redhat.com>
This was to resolve a merge issue with drivers/char/Makefile and
drivers/tty/serial/68328serial.c
We don't use it so we can trim it from here as we try and stamp the file
object dependencies out of the serial code.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
The major and minor number saved in the product_info structure
were copied from the address instead of the data, causing an
inconsistency in the reported versions during firmware loading:
usb 4-1: firmware: requesting edgeport/down.fw
/usr/src/linux/drivers/usb/serial/io_edgeport.c: downloading firmware version (930) 1.16.4
/usr/src/linux/drivers/usb/serial/io_edgeport.c: edge_startup - time 3 4328191260
/usr/src/linux/drivers/usb/serial/io_edgeport.c: FirmwareMajorVersion 0.0.4
This can cause some confusion whether firmware loaded successfully
or not.
Cc: stable@kernel.org
Signed-off-by: Bjørn Mork <bjorn@mork.no>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Simple pasting job using the new ops function. Also fix a couple of devices
directly returning the internal struct (which happens at this point to match
for the fields that matter but isn't correct or futureproof)
Greg prefers this to go through the trivial tree.
http://lkml.org/lkml/2010/6/24/1
There are about 2500 void functions in drivers/usb
Only a few used return; at end of function.
Standardize them a bit.
Moved a statement down a line in drivers/usb/host/u132-hcd.c
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
We have lots of callers that do not need to do this in the first place.
Remove the calls as they both cost CPU and for big buffers can mess up the
multi-page allocation avoidance.
#define dbg adds the newline, messages shouldn't.
Converted dbg("%s", "some string") to dbg("some string")
Johan Hovold points out that get_string() is basically just a
re-implimentation of usb_string(). It is also buggy. It does DMA on
the stack and it doesn't handle negative returns from
usb_get_descriptor(). Plus unicode_to_ascii() is a rubbish function and
moving to usb_string() avoids using it.
Let's eliminate get_string() entirely.
Reported-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Johan Hovold <jhovold@gmail.com>
The original code was passing a stack variable as a dma buffer, so I
made it an allocated variable. Instead of adding a bunch of kfree()
calls, I changed all the error return paths to gotos.
Also I noticed that the error checking wasn't correct because
usb_get_descriptor() can return negative values.
While I was at it, I made an unrelated white space change by moving
the unicode_to_ascii() on to one line.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
And indeed none of them use it. Clean this up as it will make moving to a
standard open method rather easier.
This patch (as1254) splits up the shutdown method of usb_serial_driver
into a disconnect and a release method.
The problem is that the usb-serial core was calling shutdown during
disconnect handling, but drivers didn't expect it to be called until
after all the open file references had been closed. The result was an
oops when the close method tried to use memory that had been
deallocated by shutdown.
This allows us to clean stuff up, but is probably also going to cause
some app breakage with buggy apps as we now implement proper POSIX behaviour
for USB ports matching all the other ports. This does also mean other apps
that break on USB will now work properly.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This removes tty->low_latency from all USB serial drivers that push
data into the tty layer at hard interrupt context. It's no longer needed
and actually harmful.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
err() is going away, so switch to dev_err() or printk() if it's really
needed.
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Use kref in the USB serial drivers so that we don't free tty structures
from under the URB receive handlers as has historically been the case if
you were unlucky. This also gives us a framework for general tty drivers to
use tty_port objects and refcount.
Contains two err->dev_err changes merged together to fix clashes in the
-next tree.
Signed-off-by: Alan Cox <alan@redhat.com>
The edgeport reports negative error codes to functions that do not
expect them. This can cause ports to jam forever
USB serial likes to use port->tty back pointers for the real work it does and
to do so without any actual locking. Unfortunately when you consider hangup
events, hangup/parallel reopen or even worse hangup followed by parallel close
events the tty->port and port->tty pointers are not guaranteed to be the same
as port->tty is the active tty while tty->port is the port the tty may or
may not still be attached to.
So rework the entire API to pass the tty struct. For console cases we need
to pass both for now. This shows up multiple drivers that immediately crash
with USB console some of which have been fixed in the process.
Longer term we need a proper tty as console abstraction
Version number provided in first HEX record.
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org>
* endianness annotations
* endianness fixes
* missing get_unaligned/put_unaligned
It's pretty much all over the place, changes to different files are independent.
Serial-parts-Acked-by: Alan Cox <alan@redhat.com>
urb->context code cleanup
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Found these while looking at printk uses.
Add missing newlines to dev_<level> uses
Add missing KERN_<level> prefixes to multiline dev_<level>s
Fixed a wierd->weird spelling typo
Added a newline to a printk
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Greg KH <greg@kroah.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: James Smart <James.Smart@Emulex.Com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Fix serious regression on non-EPiC edgeport usb-serial devices. Baud
rate and MCR/LCR registers are not being written on these models due
to apparent copy-n-paste errors introduced with EPiC support.
Failure reported by Nick Pasich <Nick@NickAndBarb.net>.
Signed-off-by: Adam Kropelin <akropel1@rochester.rr.com>
Cc: stable <stable@kernel.org>
This done in anticipation of removal of urb->status, which will make
that patch easier to review and apply in the future.
Cc: <linux-usb-devel@lists.sourceforge.net>
usb_unlink_urb() is asynchronous, therefore an URB's buffer may not
be freed without waiting for the completion handler. This patch switches
to usb_kill_urb(), which is synchronous.
Thanks to Alan for making me look at the remaining users of usb_unlink_urb()
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Al Borchers <alborchers@steinerpoint.com>
Fix the misspellings of "propogate", "writting" and (oh, the shame
:-) "kenrel" in the source tree.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
io_edgeport is using a global variable without locking.
This is _the_ classical race condition. This patch switches to atomic_t.
Every usb serial driver should have a pointer to the corresponding usb driver.
So the usb serial core can add a new id not only to the usb serial driver, but
also to the usb driver.
Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag
no_dynamic_id=1. This is added now.
Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de>
This patch adds EPiC support to the io_edgeport driver which adds
support for a number of NCR printers:
- NCR (Axiohm) 7401-K580 printer
- NCR (TEC) 7401-K590 printer, 7402-K592
- NCR (TEC) 7167, 7168 printers
- NCR (TEC) 7197, 7198, F306, F307, F309 printers
- NCR (Axiohm) 7194 printer
- NCR (Axiohm) 7158 printer
and a few more.
It is based on the 2.6.19 kernel.
Signed-off-by: Greg Kroah-Hartman <greg@kroah.com>
This is the grungy swap all the occurrences in the right places patch that
goes with the updates. At this point we have the same functionality as
before (except that sgttyb() returns speeds not zero) and are ready to
begin turning new stuff on providing nobody reports lots of bugs
If you are a tty driver author converting an out of tree driver the only
impact should be termios->ktermios name changes for the speed/property
setting functions from your upper layers.
If you are implementing your own TCGETS function before then your driver
was broken already and its about to get a whole lot more painful for you so
please fix it 8)
Also fill in c_ispeed/ospeed on init for most devices, although the current
code will do this for you anyway but I'd like eventually to lose that extra
paranoia
[akpm@osdl.org: bluetooth fix]
[mp3@de.ibm.com: sclp fix]
[mp3@de.ibm.com: warning fix for tty3270]
[hugh@veritas.com: fix tty_ioctl powerpc build]
[jdike@addtoit.com: uml: fix ->set_termios declaration]
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
Acked-by: Peter Oberparleiter <oberpar@de.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
