commit 31dc3f819bac28a0990b36510197560258ab7421 upstream.
Add device-id entry for (Honeywell) Metrologic MS7820 bar code scanner.
The device has two interfaces (in this mode?); a vendor-specific
interface with two interrupt endpoints and a second HID interface, which
we do not bind to.
Reported-by: Ladislav Dobrovsky <ladislav.dobrovsky@gmail.com>
Tested-by: Ladislav Dobrovsky <ladislav.dobrovsky@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Declare device-id tables as const where possible.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Mark function metrousb_is_unidirectional_mode() in serial/metro-usb.c
because it is not used outside this file.
This eliminates the following warning in serial/metro-usb.c:
drivers/usb/serial/metro-usb.c:57:12: warning: no previous prototype for ‘metrousb_is_unidirectional_mode’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The usb_serial_port structure had the number field, which was the minor
number for the port, which almost no one really cared about. They
really wanted the number of the port within the device, which you had to
subtract from the minor of the parent usb_serial_device structure. To
clean this up, provide the real minor number of the port, and the number
of the port within the serial device separately, as these numbers might
not be related in the future.
Bonus is that this cleans up a lot of logic in the drivers, and saves
lines overall.
Tested-by: Tobias Winter <tobias@linuxdingsda.de>
Reviewed-by: Johan Hovold <jhovold@gmail.com>
drivers/staging/serqt_usb2/serqt_usb2.c | 21 +++--------
drivers/usb/serial/ark3116.c | 2 -
drivers/usb/serial/bus.c | 6 +--
drivers/usb/serial/console.c | 2 -
drivers/usb/serial/cp210x.c | 2 -
drivers/usb/serial/cypress_m8.c | 4 +-
drivers/usb/serial/digi_acceleport.c | 6 ---
drivers/usb/serial/f81232.c | 5 +-
drivers/usb/serial/garmin_gps.c | 6 +--
drivers/usb/serial/io_edgeport.c | 58 ++++++++++++--------------------
drivers/usb/serial/io_ti.c | 21 ++++-------
drivers/usb/serial/keyspan.c | 29 +++++++---------
drivers/usb/serial/metro-usb.c | 4 +-
drivers/usb/serial/mos7720.c | 37 +++++++++-----------
drivers/usb/serial/mos7840.c | 52 +++++++++-------------------
drivers/usb/serial/opticon.c | 2 -
drivers/usb/serial/pl2303.c | 2 -
drivers/usb/serial/quatech2.c | 7 +--
drivers/usb/serial/sierra.c | 2 -
drivers/usb/serial/ti_usb_3410_5052.c | 10 ++---
drivers/usb/serial/usb-serial.c | 7 ++-
drivers/usb/serial/usb_wwan.c | 2 -
drivers/usb/serial/whiteheat.c | 20 +++++------
include/linux/usb/serial.h | 6 ++-
24 files changed, 133 insertions(+), 180 deletions(-)
Always try to disable the uart on close.
Since the switch to tty ports, close will be called as part of shutdown
before disconnect returns. Hence there is no need to check the
disconnected flag, and we can put devices in disabled states also on
driver unbind.
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
tty_insert_flip_string this time.
Remove all MODULE_VERSION macros and driver-version information (except
for garmin_gps which uses it in a status reply).
It is the kernel version that matters and not some private version
scheme which rarely even gets updated.
Make sure no control urb is submitted during close after a disconnect by
checking the disconnected flag.
Cc: <stable@vger.kernel.org>
Fix port-data memory leak by moving port data allocation and
deallocation to port_probe and port_remove.
Since commit 0998d0631001288 (device-core: Ensure drvdata = NULL when no
driver is bound) the port private data is no longer freed at release as
it is no longer accessible.
Note that the call to metrousb_clean (close) in shutdown was redundant.
Compile-only tested.
Pull USB changes from Greg Kroah-Hartman:
"Here is the big USB pull request for 3.7-rc1
There are lots of gadget driver changes (including copying a bunch of
files into the drivers/staging/ccg/ directory so that the other gadget
drivers can be fixed up properly without breaking that driver), and we
remove the old obsolete ub.c driver from the tree.
There are also the usual XHCI set of updates, and other various driver
changes and updates. We also are trying hard to remove the old dbg()
macro, but the final bits of that removal will be coming in through
the networking tree before we can delete it for good.
All of these patches have been in the linux-next tree.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fix up several annoying - but fairly mindless - conflicts due to the
termios structure having moved into the tty device, and often clashing
with dbg -> dev_dbg conversion.
* tag 'usb-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (339 commits)
USB: ezusb: move ezusb.c from drivers/usb/serial to drivers/usb/misc
USB: uas: fix gcc warning
USB: uas: fix locking
USB: Fix race condition when removing host controllers
USB: uas: add locking
USB: uas: fix abort
USB: uas: remove aborted field, replace with status bit.
USB: uas: fix task management
USB: uas: keep track of command urbs
xhci: Intel Panther Point BEI quirk.
powerpc/usb: remove checking PHY_CLK_VALID for UTMI PHY
USB: ftdi_sio: add TIAO USB Multi-Protocol Adapter (TUMPA) support
Revert "usb : Add sysfs files to control port power."
USB: serial: remove vizzini driver
usb: host: xhci: Fix Null pointer dereferencing with 71c731a for non-x86 systems
Increase XHCI suspend timeout to 16ms
USB: ohci-at91: fix null pointer in ohci_hcd_at91_overcurrent_irq
USB: sierra_ms: don't keep unused variable
fsl/usb: Add support for USB controller version 2.4
USB: qcaux: add Pantech vendor class match
Now that the dbg() macro is no longer being used in the driver,
the debug module parameter doesn't do anything at all. So remove
it so as to not confuse people.
CC: Aleksey Babahin <tamerlan311@gmail.com>
Fixes the leak of a tty kref that Jiri pointed out.
Signed-off-by: Alan Cox <alan@linux.intel.com>
This is to sync up on Linus's branch to get the other tty and core changes.
Bits noticed doing the termios conversion
Do not set low_latency flag at open as tty_flip_buffer_push must not be
called in IRQ context with low_latency set.
Cc: stable@vger.kernel.org
This reworks the usb_serial_register_drivers() and
usb_serial_deregister_drivers() to not need a pointer to a struct
usb_driver anymore. The usb_driver structure is now created dynamically
and registered and unregistered as needed.
This saves lines of code in each usb-serial driver. All in-kernel users
of these functions were also fixed up at this time. The pl2303 driver
was tested that everything worked properly.
Thanks for the idea to do this from Alan Stern.
Cc: Adhir Ramjiawan <adhirramjiawan0@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Al Borchers <alborchers@steinerpoint.com>
Cc: Aleksey Babahin <tamerlan311@gmail.com>
Cc: Andrew Worsley <amworsley@gmail.com>
Cc: Bart Hartgers <bart.hartgers@gmail.com>
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Dan Carpenter <error27@gmail.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Donald Lee <donald@asix.com.tw>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Gary Brubaker <xavyer@ix.netcom.com>
Cc: Jesper Juhl <jj@chaosbits.net>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Julia Lawall <julia@diku.dk>
Cc: Kautuk Consul <consul.kautuk@gmail.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Lonnie Mendez <dignome@gmail.com>
Cc: Matthias Bruestle and Harald Welte <support@reiner-sct.com>
Cc: Matthias Urlichs <smurf@smurf.noris.de>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Michal Sroczynski <msroczyn@gmail.com>
Cc: "Michał Wróbel" <michal.wrobel@flytronic.pl>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Peter Berger <pberger@brimson.com>
Cc: Preston Fick <preston.fick@silabs.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Rigbert Hamisch <rigbert@gmx.de>
Cc: Simon Arlott <simon@fire.lp0.eu>
Cc: Support Department <support@connecttech.com>
Cc: Thomas Tuttle <ttuttle@chromium.org>
Cc: Uwe Bonnes <bon@elektron.ikp.physik.tu-darmstadt.de>
Cc: Wang YanQing <Udknight@gmail.com>
Cc: William Greathouse <wgreathouse@smva.com>
This is now set by the usb-serial core, no need for the driver to
individually set it.
Thanks to Alan Stern for the idea to get rid of it.
Message in kernel log:
"metro-usb ttyUSB0: Metrologic USB to Serial converter now disconnected from ttyUSB0"
bit more likely than:
"metro-usb ttyUSB0: Metrologic USB to serial converter. converter now disconnected from ttyUSB0"
Signed-off-by: Aleksey Babahin <tamerlan311@gmail.com>
In this place result value is always zero. Use urb->status instead.
We should send special control command to tell device start or stop
transmitting a data.
In Bi-Directional mode that cmd`s are not required.
This function is never called now. Because we don`t send much data
to the device, only one byte via usb_interrupt_msg(). That doesn't require
callback function. But without declaration of write_int_callback inside
the struct usb_serial_driver, the usb_serial_probe doesn't initialize
endpoint address for the interrupt out pipe(interrupt_out_endpointAddress).
This endpoint is necessary for sending data via usb_interrupt_msg()
function.
The right idProduct for Metrologic Bar Code Scanner
in Uni-Directional Serial Emulation mode is 0x0700.
Also rename idProduct for Bi-Directional mode to be a bit more informative.
This properly ties the driver into the dynamic debug system and provides
the needed device identification when the messages are printed out.
It also removes a ton of checkpatch warnings as well, which is always a
nice validation that it's the correct thing to do.
We should use kzalloc() instead of kmalloc() and memset(), and remove an
unneeded void * cast as well.
They aren't needed, make the checkpatch tool unhappy, and in some
places, aren't even correct. So just remove them, they get in the way
and are messy.
By rearranging the functions a bit, we can remove all function
prototypes.
Note, this also deleted the _close function, as it wasn't needed, it was
doing the same thing the cleanup function did, so just call that
instead.
This fixes up all of the coding style errors, and removes the initial,
unneeded comments on how to load the module and the old changelog which
are no longer needed.
There are still a number of coding style warnings left, I'll get to them
later.
A driver doesn't need a .h file just for simple things like vendor ids
and a private structure. So move it into the .c file instead, saving
some overall lines.
Now that we aren't doing anything special in the init function, move to
use the easier module_usb_serial_driver() call instead, saving a lot of
lines of unnecessary code.
All new usb serial drivers should be using the dynamic id function, not
having module parameters for this type of thing. So remove them before
anyone gets used to them being there.
The usb serial core has changed how the driver is to be registered and
unregistered recently. Make these changes to the driver so that it will
properly build and work.
This driver is for the Metrologic barcode scanner.
