path: root/drivers/usb/serial/pl2303.c
2009-10-09USB: pl2303: fix error characters not being reported to ldiscJohan Hovold
Fix regression introduced by commit d4fc4a7bfc2dee626f4fec1e209e58eaa4312de6 (tty: Fix the PL2303 private methods for sysrq). Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB-serial: pl2303: use 1.5 instead of 2 stop bits with 5 data bitsFrank Schaefer
This is how "real" UARTs (e.g. 16550) work and AFAIK what RS232 specifies, too. Make the driver more compliant. Signed-off-by: Frank Schaefer <schaefer.frank@gmx.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB-serial: pl2303: add space/mark parityFrank Schaefer
The device supports it, so why not use it ? Works fine ! Signed-off-by: Frank Schaefer <schaefer.frank@gmx.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB-serial: pl2303: fix baud rate handling in case of unsupported valuesFrank Schaefer
According to the datasheets, the PL2303 supports a set of 25 baudrates. The baudrate is set as a 4 byte value directly. During my experiments with device 067b:2303 (PL2303X), I noticed that - the bridge-controller always uses 9600 baud if invalid/unsupported baud rate values are set - the baud rate value returned by usb_control_msg(..., GET_LINE_REQUEST, ...) does not reflect the actually used baudrate. Always the last set value is returned, even if it was invalid and not used by the controller. This patch fixes the following issues with the current code: 1.) make sure that only supported baudrates are set (are there any buggy chip revisions out there which don't "like" other values... ?). 2.) always set the baudrate to the next nearest supported baudrate. 3.) applications can now read back the resulting baudrate properly, because tty_encode_baud_rate(...) is now fed with the actually used baudrate. Signed-off-by: Frank Schaefer <schaefer.frank@gmx.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: serial: pl2303: new hardware support - sanwa multimeterPawel Ludwikow
I'd like to present my small patch enabling to use Sanwa PC5000 mulitimeter with linux. Signed-off-by: Pawel Ludwikow <pludwiko@rab.ict.pwr.wroc.pl> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19tty: USB does not need the filp argument in the driversAlan Cox
And indeed none of them use it. Clean this up as it will make moving to a standard open method rather easier. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07USB: pl2303: New vendor and product idKhanh-Dang Nguyen Thu Lam
I am submitting a patch for the pl2303 driver. This patch adds support for the "Sony QN-3USB" cable (vendor=0x054c, product=0x0437). This USB cable is a so-called data cable used to connect a Sony mobile phone to a computer. Supported models are Sony CMD-J5, J6, J7, J16, J26, J70 and Z7. I have used this patch with my Sony CMD-J70 for several days and I haven't encountered any kernel/hardware issue. From: Khanh-Dang Nguyen Thu Lam <kdntl@yahoo.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: pl2303: New vendor and product id for the prolific driverGianpaolo Cugola
I recently bought a PC interface for the Cressi Edy dive computer (www.cressi.it) and discovered that it uses the pl2303 chip, albeit with ad-hoc vendor and product ids (04b8, 0521 respectively). Being in the process of writing a linux software for such device (cressi only provides a windows software), I patched the pl2303 linux driver to have the interface recognized. I am submitting you the patch (very basic) for inclusion in next kernel version. From: Gianpaolo Cugola <gianpaoloc@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-10tty: Fix the PL2303 private methods for sysrqAlan Cox
PL2303 has private data shovelling methods that also have no fast path. Fix them to work the same way as the default handler. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10tty: Fix USB kref leakAlan Cox
The sysrq code acquired a kref leak. Fix it by passing the tty separately from the caller (thus effectively using the callers kref which all the callers hold anyway) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15USB: usb-serial: replace shutdown with disconnect, releaseAlan Stern
This patch (as1254) splits up the shutdown method of usb_serial_driver into a disconnect and a release method. The problem is that the usb-serial core was calling shutdown during disconnect handling, but drivers didn't expect it to be called until after all the open file references had been closed. The result was an oops when the close method tried to use memory that had been deallocated by shutdown. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: pl2303 usb_serial: implement sysrq handling on breakJason Wessel
Add callbacks to process the sysrq when using a pl2303 usb device as a console. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11tty: Bring the usb tty port structure into more useAlan Cox
This allows us to clean stuff up, but is probably also going to cause some app breakage with buggy apps as we now implement proper POSIX behaviour for USB ports matching all the other ports. This does also mean other apps that break on USB will now work properly. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06tty: pl2303 needs identifiers for Siemens S81 as well as EF81Alan Cox
Closes bug 9065 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-17USB: pl2303: add id for Hewlett-Packard LD220-HP POS pole displayMike Provencher
Add id for the Hewlett-Packard LD220-HP POS pole display. Bus 002 Device 002: ID 03f0:3524 Hewlett-Packard Signed-off-by: Mike Provencher <mike.provencher@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17USB: add 5372:2303 to pl2303Matthew Arnold
This patch adds the "Superial" USB-Serial converter to pl2303 so that it is detected, by the correct driver. Adds the relevant vendor:product (5372:2303) to the device tables in pl2303.c & pl2303.h. The patch has been tested against 2.6.24-22-generic. Signed-off-by: Matthew D Arnold <matthew.arnold-1@uts.edu.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: remove info() macro from usb/serial driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13tty: usb-serial krefsAlan Cox
Use kref in the USB serial drivers so that we don't free tty structures from under the URB receive handlers as has historically been the case if you were unlucky. This also gives us a framework for general tty drivers to use tty_port objects and refcount. Contains two err->dev_err changes merged together to fix clashes in the -next tree. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13usb: fix pl2303 initializationJason Wessel
This patch removes the private check for the termios_initialized for the pl2303 usb driver. It forced the baud to 9600 on the first call to pl2303_set_termios() Based on the tty changes in the 2.6.27 kernel, the termios passed to the *_set_termios functions is always populated the first time. This means there is no need to privately initialize the settings the first time, and doing so will not allow the use of the kernel parameter "console=ttyUSB0,115200" as an example. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-13USB: pl2023: Remove USB id (4348:5523) handled by ch341Tollef Fog Heen
USB ID 4348:5523 is handled by the ch341 driver. Remove it from the pl2023 driver. Reverts 002e8f2c80c6be76bb312940bc278fc10b2b2487. Signed-off-by: Tollef Fog Heen <tfheen@err.no> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-22tty-usb-pl2303: Coding styleAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22usb_serial: API all changeAlan Cox
USB serial likes to use port->tty back pointers for the real work it does and to do so without any actual locking. Unfortunately when you consider hangup events, hangup/parallel reopen or even worse hangup followed by parallel close events the tty->port and port->tty pointers are not guaranteed to be the same as port->tty is the active tty while tty->port is the port the tty may or may not still be attached to. So rework the entire API to pass the tty struct. For console cases we need to pass both for now. This shows up multiple drivers that immediately crash with USB console some of which have been fixed in the process. Longer term we need a proper tty as console abstraction Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03USB: add a pl2303 device idGreg Kroah-Hartman
As reported by Ken A Scott <kscott9@sent.com> Cc: Ken A Scott <kscott9@sent.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: pl2303: another product IDSteve Murphy
I've just got a USB GPRS/EDGE modem branded Manufacturer Micromax Model MMX610U (see http://www.airtel.in/level2_t3data.aspx?path=1/106/179) working by adding another product ID to pl2303. Modem info reports same module as Max Arnold's i.e.SIMCOM SIM600 but with product ID 0x0612 (cf Ox0611). From: Steve Murphy <steve@gnusis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20usb-serial: Use ftdi_sio driver for RATOC REX-USB60FAtsushi Nemoto
This patch reverts 57833ea6b95a3995149f1f6d1a8d8862ab7a0ba2 ("usb-serial: pl2303: add support for RATOC REX-USB60F") and adds support for the device to ftdi_sio driver. Cc: Akira Tsukamoto <akirat@rd.scei.sony.co.jp> Cc: stable <stable@kernel.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove unnecessary type casting of urb->contextMing Lei
urb->context code cleanup Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24usb serial: more fixes and groundwork for tty changesAlan Cox
- If a termios change fails due to lack of memory we should copy the old settings back over as the device has not changed - Note various locking problems - kl5kusb105 had various remaining tty flag handling problems - Make safe_serial use tty_insert_flip_string not open coded loops - set termios speed properly in usb_serial Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: serial: remove unneeded number endpoints settingsGreg Kroah-Hartman
The usb-serial core no longer checks these fields so remove them from all of the individual drivers. They will be removed from the usb-serial core in a patch later in the series. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: pl2303: another product IDMax Arnold
Device like this http://aldiga.com/english/A-100-USB-EDGE10.htm contains Prolific 2303 chip. Actually their site a bit outdated - I have AlDiga AL-11U GSM/GPRS/EDGE modem and it works with pl2303 module after adding corresponding product ID. By default modem uses baud rate 460800. GSM chipset - SIMCom SIM600, quad band 850/900/1800/1900 MHz Device info: T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1 P: Vendor=067b ProdID=0611 Rev= 0.00 C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303 E: Ad=81(I) Atr=03(Int.) MxPS= 10 Ivl=1ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms From: Max Arnold <lwarxx@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: last abuses of intfdata in close for usb-serial driversOliver Neukum
these drivers abused intfdata in close() as flags for binding. That races with reprobing of those devices. This patch fixes that by using the flag and the locks introduced with the patch against mos7720. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: pl2303: Add autosuspend support to pl2303 usb serial converter.Sarah Sharp
Signed-off-by: Sarah Sharp <saharabeara@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: pl2303: Move pl2303 vendor specific init to probe function.Sarah Sharp
Without this fix, the pl2303 usb-serial adapter would not suspend properly unless it had been opened first. A pl2303 type_1 chip will still break if the system is hibernated while the RS-232 connector is powered by another system. This was broken before, and a reset resume does not fix it. All other suspend and autosuspend scenarios work with ATEN pl2303 adaptors with HX and type_1 chips. Signed-off-by: Sarah Sharp <saharabeara@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: pl2303: Cleanup FISH and SOUP macros in pl2303 driver.Sarah Sharp
Replace the FISH and SOUP macros that violated the macro guidelines in CodingStyle. Turn them into function calls with clearer variable names. Signed-off-by: Sarah Sharp <saharabeara@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: pl2303: add support for RATOC REX-USB60FAkira Tsukamoto
pl2303: add support for RATOC REX-USB60F This patch adds support for RATOC REX-USB60F Serial Adapters, which is widely used in Japan recently. Cc: stable <stable@kernel.org> Signed-off-by: Akira Tsukamoto <akirat@rd.scei.sony.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: remove duplicate entry in Option driver and Pl2303 driver for Huawei modemDaniel Kozák
Remove entry for Huawei E620 UMTS/HSDPA card (ID: 12d1:1001) in pl2303 driver Option driver is use instead Cc: stable <stable@kernel.org> Signed-off-by: Daniel Kozák <kozzi11@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Adding YC Cable USB Serial device to pl2303Damien Stuart
This simply adds the "YC Cable" as a vendor and its pl2303-based USB<->Serial adapter as a product. This particular adapter is sold by Radio Shack. I've done limited testing on a few different systems with no issues. Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add support for 4348:5523 WinChipHead USB->RS 232 adapterPiotr Roszatycki
add support for: 4348:5523 WinChipHead USB->RS 232 adapter with Prolifec PL 2303 chipset [ mingo@elte.hu: merged it and nursed it upstream ] Cc: stable <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-08pl2303: Fix mode switching regressionAlan Cox
Cleaning out all the incorrect 'no change made' checks for termios settings showed up a problem with the PL2303. The hardware here seems to lose sync and bits if you tell it to make no changes. This shows up with a real world application. To fix this the driver check for meaningful hardware changes is restored but doing the tests correctly and as a tty layer function so it doesn't get duplicated wrongly everywhere if other drivers turn out to need it. Signed-off-by: Alan Cox <alan@redhat.com> Tested-by: Mirko Parthey <mirko.parthey@informatik.tu-chemnitz.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-28USB: pl2303: add support for Corega CG-USBRS232RMagnus Damm
pl2303: add support for Corega CG-USBRS232R This patch adds support for Corega CG-USBRS232R Serial Adapters. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-25usb: serial/pl2303: support for IO Data Device RSAQ5Masakazu Mokuno
This patch adds support for the IO Data Device USB-RSAQ5, PL2303 based USB-serial converter, to pl2303 driver Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-25USB: pl2303: remove can't happen checks, set speed properly and report baud rateAlan Cox
2007-10-12usb: serial/pl2303: support for BenQ Siemens Mobile Phone EF81Andreas Loibl
This patch adds support for the BenQ Mobile Phone EF81 to pl2303 Signed-off-by: Andreas Loibl <andreas@andreas-loibl.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: pl2303: remove bogus checks and fix speed support to use ↵Alan Cox
tty_get_baud_rate() Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: serial: pl2303: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Cc: <linux-usb-devel@lists.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: fix up license wording on some of my usb-serial driversGreg Kroah-Hartman
Also update the copyright date on the pl2303 driver, as it was out of date. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: flow control fix for pl2303t.sefzick
in order to be able to switch back to 'flow-control none' after having activated 'flow-control rts/cts', I made a small change to 'pl2303.c'. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: PL2303: Willcom WS002IN Support.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB serial: add driver pointer to all usb-serial driversJohannes Hölzl
Every usb serial driver should have a pointer to the corresponding usb driver. So the usb serial core can add a new id not only to the usb serial driver, but also to the usb driver. Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag no_dynamic_id=1. This is added now. Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
