Add device ids to pl2303 for the Hewlett-Packard HP POS pole displays:
LD960: 03f0:0B39
LCM220: 03f0:3139
LCM960: 03f0:3239
[ Johan: fix indentation and sort PIDs numerically ]
Signed-off-by: Aaron Sanders <aaron.sanders@hp.com>
Cc: stable@vger.kernel.org
Signed-off-by: Johan Hovold <jhovold@gmail.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Switch to the generic TIOCMIWAIT implementation which does not suffer
from the races involved when using the deprecated sleep_on functions.
Only wake up MSR wait queue on actual modem-status changes.
Clean up line-status handling somewhat.
Get tty-reference only when actually needed.
Declare constant device-type data as const.
Use the new C_CMSPAR macro for consistency.
Use direct baud-rate encoding rather than divisors for supported baud
rates.
This restores the way baud rates were set prior to commit 8d48fdf689fe
("USB: PL2303: correctly handle baudrates above 115200") which added
divisor encoding, but also switched to the new encoding method for all
baudrates above 115200.
As noted by Frank Schäfer <fschaefer.oss@googlemail.com>, baud rate 500k
was later errounously added to the supported baud-rate table although
it can only be set using divisors.
Note that the current implementation could easily be extended to support
arbitrary non-standard baud rates using divisors (e.g. by falling back
to divisors when the table lookup fails).
Cc: Frank Schäfer <fschaefer.oss@googlemail.com>
Add helper function for direct baud-rate encoding.
Refactor baud-rate divisor handling.
Enforce any baud-rate limits before doing table lookup.
Refactor supported baud-rate table lookup.
Rename baud-rate encoding function to match tty naming.
Encode all device-type specifics in a struct rather than testing for
device type and spreading such information throughout the driver.
Add quirk for legacy devices (type 0 and 1) rather than testing on
device type throughout the driver.
Merge types 0 and 1, whose differences are unknown and have always been
treated the same.
Add TYPE_-prefix to both types.
Test for TYPE_01 (rather than !TYPE_HX) for legacy device quirks.
Use speed_t for baud rates throughout.
Implement line-status handling for Siemens phones as a quirk rather than
spreading such information all over the driver by matching on vendor and
and product ids.
Note that the SIEMENS_PRODUCT_ID_EF81, which was added after the
line-status handling for the other Siemens phones was fixed, might also
need this quirk.
Remove redundant get_line_request (the read back settings are never
used).
Refactor and add error handling to line requests.
Add error handling to set_control_lines.
Add error handling and clean up vendor read and write functions.
Use u16 rather than __u16.
Fix multi-line comment style.
Remove some comments.
Remove unnecessary whitespace and add some where appropriate.
Drop DRIVER_DESC define.
Merge and simplify multi-line error message.
Remove bogus MSR wait-queue wake up from process_read_urb which never
updates the MSR flags.
Remove redundant error messages on allocation failures, which have
already been logged.
Cc: Joe Perches <joe@perches.com>
Remove redundant ioctl debugging from subdrivers. The ioctl request code
has already been logged by usb-serial core.
Some PL2303 devices are known to lose bytes if you change serial
settings even to the same values as before. Avoid this by comparing the
encoded settings with the previsouly used ones before configuring the
device.
The common case was fixed by commit bf5e5834bffc6 ("pl2303: Fix mode
switching regression"), but this problem was still possible to trigger,
for instance, by using the TCSETS2-interface to repeatedly request
115201 baud, which gets mapped to 115200 and thus always triggers a
settings update.
This patch fixes the CS5 setting on the PL2303 USB-to-serial devices. CS5 has a
value of 0 and the CSIZE setting has been skipped altogether by the enclosing
if. Tested on 3.11.6 and the scope shows the correct output after the fix has
been applied.
Tagged to be added to stable, because it fixes a user visible driver bug and is
simple enough to backport easily.
Signed-off-by: Colin Leitner <colin.leitner@gmail.com>
Cc: stable <stable@vger.kernel.org>
the "HX" chip type"
This reverts commit b8bdad608213caffa081a97d2e937e5fe08c4046.
Revert all of the pl2303 changes that went into 3.12-rc1 and -rc2 as
they cause regressions on some versions of the chip. This will all be
revisited for later kernel versions when we can figure out how to handle
this in a way that does not break working devices.
Reported-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Johan Hovold <jhovold@gmail.com>
This reverts commit 57ce61aad748ceaa08c859da04043ad7dae7c15e.
the divisor based baud rate encoding method"
This reverts commit 75417d9f99f89ab241de69d7db15af5842b488c4.
This reverts commit b9208c721ce736125fe58d398319513a27850fd8.
functions"
This reverts commit e917ba01d69ad705a4cd6a6c77538f55d84f5907.
based encoding method"
This reverts commit b5c16c6a031c52cc4b7dda6c3de46462fbc92eab.
for baud rates < 115200 with HX chips"
This reverts commit 61fa8d694b8547894b57ea0d99d0120a58f6ebf8.
with HX chips"
This reverts commit c23bda365dfbf56aa4d6d4a97f83136c36050e01.
pl2303_startup()"
This reverts commit 73b583af597542329e6adae44524da6f27afed62.
This reverts commit a77a8c23e4db9fb1f776147eda0d85117359c700.
This reverts commit 034d1527adebd302115c87ef343497a889638275.
This reverts commit 7d26a78f62ff4fb08bc5ba740a8af4aa7ac67da4.
According to Prolific, several (unauthorized) cheap and less functional
clones of the PL2303HX chip are in circulation. [1]
I've had the chance to test such a cloned device and it turned out that
it doesn't support any baud rates above 115200 baud (original: 6 Mbaud)
It also doesn't support the divisior based baud rate encoding method,
so no continuous baud rate adjustment is possible.
Nevertheless, these devices have been working (unintentionally) with
the driver up to commit 61fa8d694b ("pl2303: also use the divisor based
baud rate encoding method for baud rates < 115200 with HX chips"), and
this commit broke support for them.
Fortunately, it is pretty simple to distinguish between the original
and the cloned HX chips, so I've added a check and an extra chip type
to keep the clones working.
The same check is used by the latest Prolific Windows driver, so it
should be solid.
[1] http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41
Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com>
The driver currently knows about 3 different PL2303 chip types:
The two legacy chip types type_0 and type_1 (PL2303H ?) and the HX
type.
The device distinction is currently completely based on the examination
of the USB descriptors.
During the last years, Prolific has introduced further PL2303 chips,
such as the HXD (HX rev. D), TA (which replaced the X/HX chips), SA,
RA, EA and TB variants.
Unfortunately, all these new chips are currently detected as HX chips,
because they are all using the same bMaxPacketSize0 = 0x40 value in the
USB device descriptor.
At this point it is not clear if these chips are really working with
the driver, there are just some positive indicators (like device
manufacturers claiming Linux support for these devices or commit
8d48fdf689 "correctly handle baudrates above 115200" which should only
be necessary for newer devices, ...)
For a complete support of all devices, we need to distinguish between
them, because they differ in several functional aspects, such as the
maximum supported baud rate (HXD, TB, EA: 12Mbps, HX, TA: 6Mbps,
RA: 1Mbps, SA: 115.2kbps), handshaking line support, RS422/485 and
GPIO ports support (currently not supported by the driver).
And there might be further differences that we don't know yet.
This patch improves the chip type detection by evaluating the bcdDevice
value of the device descriptor. The values are taken from the
datasheets and are safe to use because manufacturers can't change them:
3.00: X/HX, TA
4.00: HXD, EA, RA, SA
5.00: TB
The rest of the device descriptors is completely identical, so no
further distinction is possible this way.
Anyway, Prolifics "checkChipVersion.exe"-tool is definitely able to
distinguish for example between the X/HX and the TA chips, so there
must be a possibility to improve the distinction further...
The chip type distinction is getting more and more relevant and
complicating, so always print the chip type.
Printing a name string is also much better than just printing an
internal index number.
There is no need for two else-if constructs for the type_1 chip
detection in pl2303_startup(), so merge them.
I've found some new datasheets which describe some additionally
supported standard baud rates and I've verified them with my HX
(rev. 3A) device. But adding support for individual (chip type
specific) baud rates would add a good amount of extra code (especially
when support for further chips will be added to the driver one day),
which makes no sense as long as we are not using the direct baud rate
encoding method for newer chips.
So for now, just drop a comment about these additionally supported baud
rates.
The second comment is about the baud rate differences between the two
encoding methods. In theory, we could optimize the code a bit by
comparing the resulting baud rates of both methods and selecting the
one which is closer to the requested baud rate. But that seems to be a
bit overkill, because the differences are very small and the device
likely uses the same baud rate generator for both methods so that the
resulting baud rate would be the same.
Now that the divisor based baud rate encoding method has been fixed and
extended, it can also be used for baud rates < 115200 baud with HX
chips.
This makes it possible to adjust the baud rate almost continuously
instead of just beeing able to select between 16 fixed standard values.
Tested with a PL2303HX 04463A (week 46, 2004, rev 3A).
encoding method
Reinhard Max has done some tests with a PL2303HX (rev A) and a logic
analyzer and it seems, that although the PL2303HX is specified for baud
rates from 75 to 6M baud, the full divisor range can be used with the
divisor based baud rate encoding method. This corresponds to baud rates
from 46 to 24M baud.
Baud rates down to 46 baud (max. divisor) have been confirmed to work
even under heavy/permanent load, so remove the lower limit.
Baud rates up to 24M baud should really be tested carefully in "real
life" scenarios before removing the upper limit completely.
Anyway, the Windows driver allows maximum baud rates of 110% of the
specified limit, so for now, increase the upper limit to this value.
Signed-off-by: Reinhard Max <max@suse.de>
Commit 0c967e7e "USB: serial: pl2303 works at 500kbps" added 500000
baud to the list of supported standard baud rates.
But the reason why the driver works with this baud rate is, that since
commit 8d48fdf6 "USB: PL2303: correctly handle baudrates above 115200"
a second (divisor based) baud rate encoding method is used for values
above 115200 baud, which is not limited to a fixed set of standard baud
rates.
Remove the 500000 baud value from the list of standard baud rates
again, because this list is only used with the direct baud rate
encoding method and 500000 baud is not supported with this method.
In opposition to the direct baud rate encoding method, the divisor
based method is not limited to a fixed set of standard baud rates.
Hence, there is no need to round to the next nearest standard value.
Reported-by: Mastro Gippo <gipmad@gmail.com>
