path: root/drivers/usb/serial/pl2303.h
2008-12-17USB: pl2303: add id for Hewlett-Packard LD220-HP POS pole displayMike Provencher
Add id for the Hewlett-Packard LD220-HP POS pole display. Bus 002 Device 002: ID 03f0:3524 Hewlett-Packard Signed-off-by: Mike Provencher <mike.provencher@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17USB: add 5372:2303 to pl2303Matthew Arnold
This patch adds the "Superial" USB-Serial converter to pl2303 so that it is detected, by the correct driver. Adds the relevant vendor:product (5372:2303) to the device tables in pl2303.c & pl2303.h. The patch has been tested against 2.6.24-22-generic. Signed-off-by: Matthew D Arnold <matthew.arnold-1@uts.edu.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: pl2023: Remove USB id (4348:5523) handled by ch341Tollef Fog Heen
USB ID 4348:5523 is handled by the ch341 driver. Remove it from the pl2023 driver. Reverts 002e8f2c80c6be76bb312940bc278fc10b2b2487. Signed-off-by: Tollef Fog Heen <tfheen@err.no> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: add a pl2303 device idGreg Kroah-Hartman
As reported by Ken A Scott <kscott9@sent.com> Cc: Ken A Scott <kscott9@sent.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: pl2303: another product IDSteve Murphy
I've just got a USB GPRS/EDGE modem branded Manufacturer Micromax Model MMX610U (see http://www.airtel.in/level2_t3data.aspx?path=1/106/179) working by adding another product ID to pl2303. Modem info reports same module as Max Arnold's i.e.SIMCOM SIM600 but with product ID 0x0612 (cf Ox0611). From: Steve Murphy <steve@gnusis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20usb-serial: Use ftdi_sio driver for RATOC REX-USB60FAtsushi Nemoto
This patch reverts 57833ea6b95a3995149f1f6d1a8d8862ab7a0ba2 ("usb-serial: pl2303: add support for RATOC REX-USB60F") and adds support for the device to ftdi_sio driver. Cc: Akira Tsukamoto <akirat@rd.scei.sony.co.jp> Cc: stable <stable@kernel.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: pl2303: another product IDMax Arnold
Device like this http://aldiga.com/english/A-100-USB-EDGE10.htm contains Prolific 2303 chip. Actually their site a bit outdated - I have AlDiga AL-11U GSM/GPRS/EDGE modem and it works with pl2303 module after adding corresponding product ID. By default modem uses baud rate 460800. GSM chipset - SIMCom SIM600, quad band 850/900/1800/1900 MHz Device info: T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1 P: Vendor=067b ProdID=0611 Rev= 0.00 C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303 E: Ad=81(I) Atr=03(Int.) MxPS= 10 Ivl=1ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms From: Max Arnold <lwarxx@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: pl2303: add support for RATOC REX-USB60FAkira Tsukamoto
pl2303: add support for RATOC REX-USB60F This patch adds support for RATOC REX-USB60F Serial Adapters, which is widely used in Japan recently. Cc: stable <stable@kernel.org> Signed-off-by: Akira Tsukamoto <akirat@rd.scei.sony.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: remove duplicate entry in Option driver and Pl2303 driver for Huawei modemDaniel Kozák
Remove entry for Huawei E620 UMTS/HSDPA card (ID: 12d1:1001) in pl2303 driver Option driver is use instead Cc: stable <stable@kernel.org> Signed-off-by: Daniel Kozák <kozzi11@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Adding YC Cable USB Serial device to pl2303Damien Stuart
This simply adds the "YC Cable" as a vendor and its pl2303-based USB<->Serial adapter as a product. This particular adapter is sold by Radio Shack. I've done limited testing on a few different systems with no issues. Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add support for 4348:5523 WinChipHead USB->RS 232 adapterPiotr Roszatycki
add support for: 4348:5523 WinChipHead USB->RS 232 adapter with Prolifec PL 2303 chipset [ mingo@elte.hu: merged it and nursed it upstream ] Cc: stable <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: pl2303: add support for Corega CG-USBRS232RMagnus Damm
pl2303: add support for Corega CG-USBRS232R This patch adds support for Corega CG-USBRS232R Serial Adapters. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-25usb: serial/pl2303: support for IO Data Device RSAQ5Masakazu Mokuno
This patch adds support for the IO Data Device USB-RSAQ5, PL2303 based USB-serial converter, to pl2303 driver Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usb: serial/pl2303: support for BenQ Siemens Mobile Phone EF81Andreas Loibl
This patch adds support for the BenQ Mobile Phone EF81 to pl2303 Signed-off-by: Andreas Loibl <andreas@andreas-loibl.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: PL2303: Willcom WS002IN Support.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28USB: Add vendor / product ID to pl2303Wesley PA4WDH
2006-09-27usb serial: support Alcor Micro Corp. USB 2.0 TO RS-232 through pl2303 driverJohannes Steingraeber
Patch to add support for Alcor Micro Corp. USB 2.0 TO RS-232 converter. This patch adds VID and PID to pl2303.[ch], adds it to the "HORRIBLE HACK FOR PL2303" in usb-serial.c and also prevents cdc-acm to claim driving this device by blacklisting it in hid-core. Signed-off-by: Johannes Steingraeber <Jo_Stein@web.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-26[PATCH] USB: pl2303: removed support for OTi's DKU-5 clone cableTomasz Kazmierczak
This patch removes support for a clone of Nokia DKU-5 cable made by Ours Technology Inc, as it turned out that the cable does not use the pl2303 chip, but OTI-6858 chip which is not compatible with the pl2303. Signed-off-by: Tomasz Kazmierczak <tomek.fizyk@op.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: New USB ID for Belkin Serial AdapterKim Oldfield
Can you add the USB IDs for the Belkin USB Serial adapter (P/N F5U257) to the pl2303 driver in the Linux Kernel? Are you the appropriate person to approach for this? I recently purchased a Belkin USB Serial adapter (P/N F5U257) and found that it didn't work. After a bit of experimentation I found that it works with the pl2303 driver once the ID has been added. See attached patch to fix this. Also attached is the output from lsusb -v just in case you require any information from there. From: Kim Oldfield <luv@oldfield.wattle.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: Support for Susteen Datapilot Universal-2 cable in pl2303Matthew Meno
The Susteen Datapilot cable (http://www.susteen.com/productdetail/71/producthl/Notempty) has an internal pl2303 to communicate with a set of dummy connector-ends that connect to a variety of cell phones. I've found that it works right out of the box by simply adding the product/vendor id to the pl2303 driver. Signed-off-by: Matt Meno <mmeno@idealcorp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: Addition of vendor/product id pair for pl2303 driverPeter Moulder
Text from the back of the box, for your information/amusement: USB DATA CABLE FOR K700 Series The USB Cable is an ideal link between your mobile phone and PC. Employing the user-friendiy [sic] USB standard,its capacity for rapid data transfer enables functions such as synchronization of phone book and calendar,as well as Internet browsing via a modem-enabled phone.Autual [sic] connection speed is dependent on phone capacity. MADE IN CHINA From: Peter Moulder <Peter.Moulder@infotech.monash.edu.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-27[PATCH] USB: add new iTegno usb CDMA 1x card support for pl2303Wang Jun
Add new iTegno usb CDMA 1x card (usbid '0eba:2080') support to pl2303 driver Signed-off-by: Wang Jun <wangjun1974@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] USB: pl2303: added support for OTi's DKU-5 clone cableTomasz Kazmierczak
This patch adds support for a clone of Nokia DKU-5 cable made by Ours Technology Inc for Nokia phones with PopPort (Nokia 3100 and others). The cable uses PL2303 USB-to-serial converter from Prolific Technology Inc. Signed-off-by: Tomasz Kazmierczak <tomek.fizyk@op.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: support for USB-to-serial cable from Speed Dragon MultimediaDick Streefland
The USB data cable for my Samsung GSM phone contains the USB-to-serial converter chip MS3303H from Speed Dragon Multimedia, Inc. that appears to be compatible with the PL2303 chip. The following patch adds support for this chip to the pl2303 driver. Signed-off-by: Dick Streefland <dick@streefland.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-13[PATCH] USB: PL2303: Leadtek 9531 GPS-MouseChristian Lindner
The patch adds the USB ID (0413:2101) for the Leadtek GPS-Mouse 9531 to the driver pl2303. Signed-off-by: Christian Lindner <christian.lindner@gmx.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: add new pl2303 device idsDenis MONTERRAT
Signed-off-by: FALIPOU F Developer <fred.falipou@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: pl2303: Added support for CA-42 clone cableMartin Gingras
Added support for CA-42 clone cable (www.ca-42.com) Signed-off-by: Martin Gingras <martin.gingras@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: pl2303: adds new IDs.Luiz Fernando Capitulino
This patch adds two new Siemens mobiles IDs for the pl2303 driver. Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] USB: PL2303: CA-42 Phone cableRobert Spanton
This patch adds the product ID and vendor ID for a Nokia CA-42 USB cable to the list of devices handled by the pl2303 driver. The patch is against 2.6.13. Signed-off-by: Robert Spanton <rds204@zepler.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] USB: pl2303 new vendor/model idsPeter Favrholdt
Please accept the attached patch which adds the vendorid 0x0745 and modelid 0x0001 (ID 0745:0001) "Syntech Information Co., Ltd." The device is an USB IR cradle for a barcode scanner (CPT-8001C) from Cipherlab. From: Peter Favrholdt <pfavr@mip.sdu.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -u kernel-source-2.6.11/drivers/usb/serial/pl2303.c ../kernel-source-2.6.11/drivers/usb/serial/pl2303.c
