path: root/drivers/usb/serial/usb-wwan.h
2011-02-17tty: remove filp from the USB tty ioctlsAlan Cox
We don't use it so we can trim it from here as we try and stamp the file object dependencies out of the serial code. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-30usb-wwan: implement TIOCGSERIAL and TIOCSSERIAL to avoid blocking close(2)Dan Williams
Some devices (ex ZTE 2726) simply don't respond at all when data is sent to some of their USB interfaces. The data gets stuck in the TTYs queue and sits there until close(2), which them blocks because closing_wait defaults to 30 seconds (even though the fd is O_NONBLOCK). This is rarely desired. Implement the standard mechanism to adjust closing_wait and let applications handle it how they want to. Signed-off-by: Dan Williams <dcbw@redhat.com>
2010-05-20usb serial: Add generic USB wwan supportMatthew Garrett
The generic USB serial code is ill-suited for high-speed USB wwan devices, resulting in the option driver. However, other non-option devices may also gain similar benefits from not using the generic code. Factorise out the non-option specific code from the option driver and make it available to other users. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
