path: root/drivers/usb/serial/usb-wwan.h
2015-10-09USB: usb_wwan/option: generalize option_send_setup for other driversDavid Ward
Only the option driver implements the send_setup callback; it uses the SET_CONTROL_LINE_STATE request in CDC ACM to generate DTR/RTS signals on the port. This is not driver-specific though and is needed by other drivers, so move the function to the usb_wwan driver (with formatting tweaks), and replace the callback pointer with a flag that enables the request. Suggested-by: Bjørn Mork <bjorn@mork.no> Suggested-by: Johan Hovold <johan@kernel.org> Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: Johan Hovold <johan@kernel.org>
2014-05-27USB: usb_wwan: do not resume I/O on closing portsJohan Hovold
Use tty-port initialised flag rather than private flag to determine when port is closing down. Since the tty-port flag is set prior to dropping DTR/RTS (when HUPCL is set) this avoid submitting the read urbs when resuming the interface in dtr_rts() only to immediately kill them again in shutdown(). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27USB: usb_wwan: remove bogus function prototypeJohan Hovold
The usb_wwan_send_setup() function has never existed. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27USB: usb_wwan: remove unimplemented set_termiosJohan Hovold
The driver does not implement set_termios so the operation can be left unset (tty will do the tty_termios_copy_hw for us). Note that the send_setup call is bogus as it really only sets DTR/RTS to their current values. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27USB: usb_wwan: fix remote wakeupJohan Hovold
Make sure that needs_remote_wake up is always set when there are open ports. Currently close() would unconditionally set needs_remote_wakeup to 0 even though there might still be open ports. This could lead to blocked input and possibly dropped data on devices that do not support remote wakeup (and which must therefore not be runtime suspended while open). Add an open_ports counter (protected by the susp_lock) and only clear needs_remote_wakeup when the last port is closed. Note that there are currently no multi-port drivers using the usb_wwan implementation. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25USB: usb-wwan: fix multiple memory leaks in error pathsJohan Hovold
Fix port-data memory leak in usb-serial probe error path by moving port data allocation to port_probe. Since commit a1028f0abf ("usb: usb_wwan: replace release and disconnect with a port_remove hook") port data is deallocated in port_remove. This leaves a possibility for memory leaks if usb-serial probe fails after attach but before the port in question has been successfully registered. Note that this patch also fixes two additional memory leaks in the error path of attach should port initialisation fail for any port as the urbs were never freed and neither was the data of any of the successfully initialised ports. Compile-only tested. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: usb_wwan: replace release and disconnect with a port_remove hookBjørn Mork
Doing port specific cleanup in the .port_remove hook is a lot simpler and safer than doing it in the USB driver .release or .disconnect methods. The removal of the port from the usb-serial bus will happen before the USB driver cleanup, so we must be careful about accessing port specific driver data from any USB driver functions. This problem surfaced after the commit 0998d0631 device-core: Ensure drvdata = NULL when no driver is bound which turned the previous unsafe access into a reliable NULL pointer dereference. Fixes the following Oops: [ 243.148471] BUG: unable to handle kernel NULL pointer dereference at (null) [ 243.148508] IP: [<ffffffffa0468527>] stop_read_write_urbs+0x37/0x80 [usb_wwan] [ 243.148556] PGD 79d60067 PUD 79d61067 PMD 0 [ 243.148590] Oops: 0000 [#1] SMP [ 243.148617] Modules linked in: sr_mod cdrom qmi_wwan usbnet option cdc_wdm usb_wwan usbserial usb_storage uas fuse af_packet ip6table_filter ip6_tables iptable_filter ip_tables x_tables tun edd cpufreq_conservative cpufreq_userspace cpufreq_powersave snd_pcm_oss snd_mixer_oss acpi_cpufreq snd_seq mperf snd_seq_device coretemp arc4 sg hp_wmi sparse_keymap uvcvideo videobuf2_core videodev videobuf2_vmalloc videobuf2_memops rtl8192ce rtl8192c_common rtlwifi joydev pcspkr microcode mac80211 i2c_i801 lpc_ich r8169 snd_hda_codec_idt cfg80211 snd_hda_intel snd_hda_codec rfkill snd_hwdep snd_pcm wmi snd_timer ac snd soundcore snd_page_alloc battery uhci_hcd i915 drm_kms_helper drm i2c_algo_bit ehci_hcd thermal usbcore video usb_common button processor thermal_sys [ 243.149007] CPU 1 [ 243.149027] Pid: 135, comm: khubd Not tainted 3.5.0-rc7-next-20120720-1-vanilla #1 Hewlett-Packard HP Mini 110-3700 /1584 [ 243.149072] RIP: 0010:[<ffffffffa0468527>] [<ffffffffa0468527>] stop_read_write_urbs+0x37/0x80 [usb_wwan] [ 243.149118] RSP: 0018:ffff880037e75b30 EFLAGS: 00010286 [ 243.149133] RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88005912aa28 [ 243.149150] RDX: ffff88005e95f028 RSI: 0000000000000000 RDI: ffff88005f7c1a10 [ 243.149166] RBP: ffff880037e75b60 R08: 0000000000000000 R09: ffffffff812cea90 [ 243.149182] R10: 0000000000000000 R11: 0000000000000001 R12: ffff88006539b440 [ 243.149198] R13: ffff88006539b440 R14: 0000000000000000 R15: 0000000000000000 [ 243.149216] FS: 0000000000000000(0000) GS:ffff88007ee80000(0000) knlGS:0000000000000000 [ 243.149233] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 243.149248] CR2: 0000000000000000 CR3: 0000000079fe0000 CR4: 00000000000007e0 [ 243.149264] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 243.149280] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 243.149298] Process khubd (pid: 135, threadinfo ffff880037e74000, task ffff880037d40600) [ 243.149313] Stack: [ 243.149323] ffff880037e75b40 ffff88006539b440 ffff8800799bc830 ffff88005f7c1800 [ 243.149348] 0000000000000001 ffff88006539b448 ffff880037e75b70 ffffffffa04685e9 [ 243.149371] ffff880037e75bc0 ffffffffa0473765 ffff880037354988 ffff88007b594800 [ 243.149395] Call Trace: [ 243.149419] [<ffffffffa04685e9>] usb_wwan_disconnect+0x9/0x10 [usb_wwan] [ 243.149447] [<ffffffffa0473765>] usb_serial_disconnect+0xd5/0x120 [usbserial] [ 243.149511] [<ffffffffa0046b48>] usb_unbind_interface+0x58/0x1a0 [usbcore] [ 243.149545] [<ffffffff8139ebd7>] __device_release_driver+0x77/0xe0 [ 243.149567] [<ffffffff8139ec67>] device_release_driver+0x27/0x40 [ 243.149587] [<ffffffff8139e5cf>] bus_remove_device+0xdf/0x150 [ 243.149608] [<ffffffff8139bc78>] device_del+0x118/0x1a0 [ 243.149661] [<ffffffffa0044590>] usb_disable_device+0xb0/0x280 [usbcore] [ 243.149718] [<ffffffffa003c6fd>] usb_disconnect+0x9d/0x140 [usbcore] [ 243.149770] [<ffffffffa003da7d>] hub_port_connect_change+0xad/0x8a0 [usbcore] [ 243.149825] [<ffffffffa0043bf5>] ? usb_control_msg+0xe5/0x110 [usbcore] [ 243.149878] [<ffffffffa003e6e3>] hub_events+0x473/0x760 [usbcore] [ 243.149931] [<ffffffffa003ea05>] hub_thread+0x35/0x1d0 [usbcore] [ 243.149955] [<ffffffff81061960>] ? add_wait_queue+0x60/0x60 [ 243.150004] [<ffffffffa003e9d0>] ? hub_events+0x760/0x760 [usbcore] [ 243.150026] [<ffffffff8106133e>] kthread+0x8e/0xa0 [ 243.150047] [<ffffffff8157ec04>] kernel_thread_helper+0x4/0x10 [ 243.150068] [<ffffffff810612b0>] ? flush_kthread_work+0x120/0x120 [ 243.150088] [<ffffffff8157ec00>] ? gs_change+0xb/0xb [ 243.150101] Code: fd 41 54 53 48 83 ec 08 80 7f 1a 00 74 57 49 89 fc 31 db 90 49 8b 7c 24 20 45 31 f6 48 81 c7 10 02 00 00 e8 bc 64 f3 e0 49 89 c7 <4b> 8b 3c 37 49 83 c6 08 e8 4c a5 bd ff 49 83 fe 20 75 ed 45 30 [ 243.150257] RIP [<ffffffffa0468527>] stop_read_write_urbs+0x37/0x80 [usb_wwan] [ 243.150282] RSP <ffff880037e75b30> [ 243.150294] CR2: 0000000000000000 [ 243.177170] ---[ end trace fba433d9015ffb8c ]--- Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reported-by: Thomas Schäfer <tschaefer@t-online.de> Suggested-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-02-17tty: remove filp from the USB tty ioctlsAlan Cox
We don't use it so we can trim it from here as we try and stamp the file object dependencies out of the serial code. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-30usb-wwan: implement TIOCGSERIAL and TIOCSSERIAL to avoid blocking close(2)Dan Williams
Some devices (ex ZTE 2726) simply don't respond at all when data is sent to some of their USB interfaces. The data gets stuck in the TTYs queue and sits there until close(2), which them blocks because closing_wait defaults to 30 seconds (even though the fd is O_NONBLOCK). This is rarely desired. Implement the standard mechanism to adjust closing_wait and let applications handle it how they want to. Signed-off-by: Dan Williams <dcbw@redhat.com>
2010-05-20usb serial: Add generic USB wwan supportMatthew Garrett
The generic USB serial code is ill-suited for high-speed USB wwan devices, resulting in the option driver. However, other non-option devices may also gain similar benefits from not using the generic code. Factorise out the non-option specific code from the option driver and make it available to other users. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
