commit 46fe895e22ab3845515ec06b01eaf1282b342e29 upstream.
Add new Motorola Tetra (simple) driver for Motorola Solutions TETRA PEI
devices.
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0cad ProdID=9011 Rev=24.16
S: Manufacturer=Motorola Solutions Inc.
S: Product=Motorola Solutions TETRA PEI interface
C: #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
Note that these devices do not support the CDC SET_CONTROL_LINE_STATE
request (for any interface).
Reported-by: Max Schulze <max.schulze@posteo.de>
Tested-by: Max Schulze <max.schulze@posteo.de>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit c7b8f77872c73f69a16528a9eb87afefcccdc18b upstream.
According to drivers/usb/serial/io_edgeport.c, the driver may sleep
under a spinlock.
The function call path is:
edge_bulk_in_callback (acquire the spinlock)
process_rcvd_data
process_rcvd_status
change_port_settings
send_iosp_ext_cmd
write_cmd_usb
usb_kill_urb --> may sleep
To fix it, the redundant usb_kill_urb() is removed from the error path
after usb_submit_urb() fails.
This possible bug is found by my static analysis tool (DSAC) and checked
by my code review.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit d08dd3f3dd2ae351b793fc5b76abdbf0fd317b12 upstream.
This adds a new device id for Chilitag devices to the pl2303 driver.
Reported-by: "Chu.Mike [朱堅宜]" <Mike-Chu@prolific.com.tw>
Acked-by: Johan Hovold <johan@kernel.org>
commit 69341bd15018da0a662847e210f9b2380c71e623 upstream.
FS040U modem is manufactured by omega, and sold by Fujisoft. This patch
adds ID of the modem to use option1 driver. Interface 3 is used as
qmi_wwan, so the interface is ignored.
Signed-off-by: Yoshiaki Okamoto <yokamoto@allied-telesis.co.jp>
Signed-off-by: Hiroyuki Yamamoto <hyamamo@allied-telesis.co.jp>
commit d14ac576d10f865970bb1324d337e5e24d79aaf4 upstream.
This adds the ELV ALC 8xxx Battery Charging device
to the list of USB IDs of drivers/usb/serial/cp210x.c
Signed-off-by: Christian Holl <cyborgx1@gmail.com>
commit 4307413256ac1e09b8f53e8715af3df9e49beec3 upstream.
Add IDs for the OneTouch Verio IQ that comes with an embedded
USB-to-serial converter.
Signed-off-by: Diego Elio Pettenò <flameeyes@flameeyes.eu>
commit 3920bb713038810f25770e7545b79f204685c8f2 upstream.
This patch adds support for YUGA CLM920-NC5 PID 0x9625 USB modem to option
driver.
Interface layout:
0: QCDM/DIAG
1: ADB
2: MODEM
3: AT
4: RMNET
Signed-off-by: Taiyi Wu <taiyity.wu@moxa.com>
Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com>
commit 08933099e6404f588f81c2050bfec7313e06eeaf upstream.
This patch adds support for PID 0x1101 of Telit ME910.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
commit 92a18a657fb2e2ffbfa0659af32cc18fd2346516 upstream.
Sierra Wireless EM7565 devices use the QCSERIAL_SWI layout for their
serial ports
T: Bus=01 Lev=03 Prnt=29 Port=01 Cnt=02 Dev#= 31 Spd=480 MxCh= 0
P: Vendor=1199 ProdID=9091 Rev= 0.06
S: Manufacturer=Sierra Wireless, Incorporated
S: Product=Sierra Wireless EM7565 Qualcomm Snapdragon X16 LTE-A
S: SerialNumber=xxxxxxxx
C:* #Ifs= 4 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=qcserial
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=qcserial
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=qcserial
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 8 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=86(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=8e(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0f(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
but need sendsetup = true for the NMEA port to make it work properly.
Simplify the patch compared to v1 as suggested by Bjørn Mork by taking
advantage of the fact that existing devices work with sendsetup = true
too.
Use sendsetup = true for the NMEA interface of QCSERIAL_SWI and add
DEVICE_SWI entries for the EM7565 PID 0x9091 and the EM7565 QDL PID
0x9090.
Tests with several MC73xx/MC74xx/MC77xx devices have been performed in
order to verify backward compatibility.
Signed-off-by: Reinhard Speyerer <rspmn@arcor.de>
commit c6a36ad383559a60a249aa6016cebf3cb8b6c485 upstream.
Add AIRBUS_DS_P8GR device IDs to ftdi_sio driver.
Signed-off-by: Max Schulze <max.schulze@posteo.de>
commit c654b21ede93845863597de9ad774fd30db5f2ab upstream.
Quectel BG96 is an Qualcomm MDM9206 based IoT modem, supporting both
CAT-M and NB-IoT. Tested hardware is BG96 mounted on Quectel
development board (EVB). The USB id is added to option.c to allow
DIAG,GPS,AT and modem communication with the BG96.
Signed-off-by: Sebastian Sjoholm <ssjoholm@mac.com>
commit 74d471b598444b7f2d964930f7234779c80960a0 upstream.
Make sure to free the port private data before returning after a failed
probe attempt.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 19a565d9af6e0d828bd0d521d3bafd5017f4ce52 upstream.
Make sure to stop any submitted interrupt and bulk-out URBs before
returning after failed probe and when the port is being unbound to avoid
later NULL-pointer dereferences in the completion callbacks.
Also fix up the related and broken I/O cancellation on failed open and
on close. (Note that port->write_urb was never submitted.)
commit 771394a54148f18926ca86414e51c69eda27d0cd upstream.
Add USB PID/VID for Sierra Wireless EM7355 LTE modem QDL firmware update
mode.
Signed-off-by: Douglas Fischer <douglas.fischer@outlook.com>
commit 31dc3f819bac28a0990b36510197560258ab7421 upstream.
Add device-id entry for (Honeywell) Metrologic MS7820 bar code scanner.
The device has two interfaces (in this mode?); a vendor-specific
interface with two interrupt endpoints and a second HID interface, which
we do not bind to.
Reported-by: Ladislav Dobrovsky <ladislav.dobrovsky@gmail.com>
Tested-by: Ladislav Dobrovsky <ladislav.dobrovsky@gmail.com>
commit 299d7572e46f98534033a9e65973f13ad1ce9047 upstream.
Make sure to reset the USB-console port pointer when console setup fails
in order to avoid having the struct usb_serial be prematurely freed by
the console code when the device is later disconnected.
Fixes: 73e487fdb75f ("[PATCH] USB console: fix disconnection issues")
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit f5d9644c5fca7d8e8972268598bb516a7eae17f9 upstream.
Dell Wireless 5819/5818 devices are re-branded Sierra Wireless MC74
series which will by default boot with vid 0x413c and pid's 0x81cf,
0x81d0, 0x81d1, 0x81d2.
Signed-off-by: Shrirang Bagul <shrirang.bagul@canonical.com>
commit 837ddc4793a69b256ac5e781a5e729b448a8d983 upstream.
This commit adds support for TP-Link LTE mPCIe module is used
in in TP-Link MR200v1, MR6400v1 and v2 routers.
Signed-off-by: Henryk Heisig <hyniu@o2.pl>
commit c496ad835c31ad639b6865714270b3003df031f6 upstream.
Add the USB device id for the ELV TFD500 data logger.
Signed-off-by: Andreas Engel <anen-nospam@gmx.net>
commit a6c215e21b0dc5fe9416dce90f9acc2ea53c4502 upstream.
Add CYPRESS_VID vid and CYPRESS_WICED_BT_USB and CYPRESS_WICED_WL_USB
Signed-off-by: Jeffrey Chu <jeffrey.chu@cypress.com>
[ Upstream commit cd8db057e93ddaacbec025b567490555d2bca280 ]
Make sure to detect short transfers when reading a device register.
The modem-status handling had sufficient error checks in place, but move
handling of short transfers into the register accessor function itself
for consistency.
[ Upstream commit 0d130367abf582e7cbf60075c2a7ab53817b1d14 ]
Make sure to log an error on short transfers when reading a device
register.
Also clear the provided buffer (which if often an uninitialised
automatic variable) on errors as the driver currently does not bother to
check for errors.
commit 169e86546f5712179709de23cd64bbb15f199fab upstream.
This commit adds support (an ID, really) for D-Link DWM-157 hardware
version C1 USB modem to option driver.
According to manufacturer-provided Windows INF file the device has four
serial ports:
"D-Link HSPA+DataCard Diagnostics Interface" (interface 2; modem port),
"D-Link HSPA+DataCard NMEA Device" (interface 3),
"D-Link HSPA+DataCard Speech Port" (interface 4),
"D-Link HSPA+DataCard Debug Port" (interface 5).
usb-devices output:
T: Bus=05 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2001 ProdID=7d0e Rev=03.00
S: Manufacturer=D-Link,Inc
S: Product=D-Link DWM-157
C: #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=0e Prot=00 Driver=cdc_mbim
I: If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=option
I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 6 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
commit 3b6bcd3d093c698d32e93d4da57679b8fbc5e01e upstream.
This adds a new ATEN device id for a new pl2303-based device.
Reported-by: Peter Kuo <PeterKuo@aten.com.tw>
Cc: Johan Hovold <johan@kernel.org>
commit 9585e340db9f6cc1c0928d82c3a23cc4460f0a3f upstream.
The German Telekom offers a ZigBee USB Stick under the brand name Qivicon
for their SmartHome Home Base in its 1. Generation. The productId is not
known by the according kernel module, this patch adds support for it.
Signed-off-by: Stefan Triller <github@stefantriller.de>
Reviewed-by: Frans Klaver <fransklaver@gmail.com>
commit fd1b8668af59a11bb754a6c9b0051c6c5ce73b74 upstream.
Add device id for D-Link DWM-222.
Signed-off-by: Hector Martin <marcan@marcan.st>
commit 996fab55d864ed604158f71724ff52db1c2454a3 upstream.
A new Sierra Wireless EM7305 device ID used in a Toshiba laptop.
Reported-by: Petr Kloc <petr_kloc@yahoo.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 8fb060da715ad10fe956d7c0077b2fb0c12bb9d7 upstream.
Add two Longcheer device-id entries which specifically enables a
Telewell TW-3G HSPA+ branded modem (0x9801).
Reported-by: Teemu Likonen <tlikonen@iki.fi>
Reported-by: Bjørn Mork <bjorn@mork.no>
Reported-by: Lars Melin <larsm17@gmail.com>
Tested-by: Teemu Likonen <tlikonen@iki.fi>
commit fd90f73a9925f248d696bde1cfc836d9fda5570d upstream.
Added the USB serial device ID for the CEL ZigBee EM3588
radio stick.
Signed-off-by: Jeremie Rapin <rapinj@gmail.com>
commit 6aeb75e6adfaed16e58780309613a578fe1ee90b upstream.
Fix a division-by-zero in set_termios when debugging is enabled and a
high-enough speed has been requested so that the divisor value becomes
zero.
Instead of just fixing the offending debug statement, cap the baud rate
at the base as a zero divisor value also appears to crash the firmware.
commit 26cede343656c0bc2c33cdc783771282405c7fb2 upstream.
Drop erroneous cpu_to_le32 when setting the baud rate, something which
corrupted the divisor on big-endian hosts.
Found using sparse:
warning: incorrect type in argument 1 (different base types)
expected unsigned int [unsigned] [usertype] val
got restricted __le32 [usertype] <noident>
Fixes: af2ac1a091bc ("USB: serial mct_usb232: move DMA buffers to heap")
Acked-By: Pete Zaitcev <zaitcev@yahoo.com>
commit 8d7a10dd323993cc40bd37bce8bc570133b0c396 upstream.
In their infinite wisdom, and never ending quest for end user frustration,
Lenovo has decided to use new USB device IDs for the wwan modules in
their 2017 laptops. The actual hardware is still the Sierra Wireless
EM7455 or EM7430, depending on region.
commit 40dd46048c155b8f0683f468c950a1c107f77a7c upstream.
This patch adds support for Telit ME910 PID 0x1100.
commit 5f63424ab7daac840df2b12dd5bcc5b38d50f779 upstream.
This patch adds support for recognition of ARM-USB-TINY(H) devices which
are almost identical to ARM-USB-OCD(H) but lacking separate barrel jack
and serial console.
By suggestion from Johan Hovold it is possible to replace
ftdi_jtag_quirk with a bit more generic construction. Since all
Olimex-ARM debuggers has exactly two ports, we could safely always use
only second port within the debugger family.
Signed-off-by: Andrey Korolyov <andrey@xdel.ru>
commit bb246681b3ed0967489a7401ad528c1aaa1a4c2e upstream.
Commit 557aaa7ffab6 ("ft232: support the ASYNC_LOW_LATENCY
flag") enables unprivileged users to set the FTDI latency timer,
but there was a logic flaw that skipped sending the corresponding
USB control message to the device.
Specifically, the device latency timer would not be updated until next
open, something which was later also inadvertently broken by commit
c19db4c9e49a ("USB: ftdi_sio: set device latency timeout at port
probe").
A recent commit c6dce2626606 ("USB: serial: ftdi_sio: fix extreme
low-latency setting") disabled the low-latency mode by default so we now
need this fix to allow unprivileged users to again enable it.
Signed-off-by: Anthony Mallet <anthony.mallet@laas.fr>
[johan: amend commit message]
Fixes: 557aaa7ffab6 ("ft232: support the ASYNC_LOW_LATENCY flag")
Fixes: c19db4c9e49a ("USB: ftdi_sio: set device latency timeout at port probe").
commit 31c5d1922b90ddc1da6a6ddecef7cd31f17aa32b upstream.
This development kit has an FT4232 on it with a custom USB VID/PID.
The FT4232 provides four UARTs, but only two are used. The UART 0
is used by the FlashPro5 programmer and UART 2 is connected to the
SmartFusion2 CortexM3 SoC UART port.
Note that the USB VID is registered to Actel according to Linux USB
VID database, but that was acquired by Microsemi.
commit 3c0e25d883d06a1fbd1ad35257e8abaa57befb37 upstream.
Make sure to detect short control-message transfers and log an error
when reading incomplete manufacturer and boot descriptors.
Note that the default all-zero descriptors will now be used after a
short transfer is detected instead of partially initialised ones.
commit 36356a669eddb32917fc4b5c2b9b8bf80ede69de upstream.
Make sure to detect short control-message transfers so that errors are
logged when reading the modem status at open.
Note that while this also avoids initialising the modem status using
uninitialised heap data, these bits could not leak to user space as they
are currently not used.
commit 8c34cb8ddfe808d557b51da983ff10c02793beb2 upstream.
Make sure to detect short control-message transfers when fetching
modem and line state in open and when retrieving registers.
This specifically makes sure that an errno is returned to user space on
errors in TIOCMGET instead of a zero bitmask.
Also drop the unused getdevice function which also lacked appropriate
error handling.
Fixes: f7a33e608d9a ("USB: serial: add quatech2 usb to serial driver")
commit e3e574ad85a208cb179f33720bb5f12b453de33c upstream.
Make sure to detect short responses when reading the latency timer to
avoid using stale buffer data.
Note that no heap data would currently leak through sysfs as
ASYNC_LOW_LATENCY is set by default.
commit b631433b175f1002a31020e09bbfc2e5caecf290 upstream.
Fix open error handling which failed to detect errors when reading the
MSR and LSR registers, something which could lead to the shadow
registers being initialised from errnos.
Note that calling the generic close implementation is sufficient in the
error paths as the interrupt urb has not yet been submitted and the
register updates have not been made.
Fixes: f4c1e8d597d1 ("USB: ark3116: Make existing functions 16450-aware
and add close and release functions.")
commit 39712e8bfa8d3aa6ce1e60fc9d62c9b076c17a30 upstream.
Make sure to detect and return an error on zero-length control-message
transfers when reading from the device.
This addresses a potential failure to detect an empty transmit buffer
during close.
Also remove a redundant check for short transfer when sending a command.
commit e4457d9798adb96272468e93da663de9bd0a4198 upstream.
Use a dedicated buffer for the DMA transfer and make sure to detect
short transfers to avoid parsing a corrupt descriptor.
Fixes: 6e8cf7751f9f ("USB: add EPIC support to the io_edgeport driver")
commit 1eac5c244f705182d1552a53e2f74e2775ed95d6 upstream.
Make sure to detect short control-message transfers rather than continue
with zero-initialised data when retrieving modem status and during
device initialisation.
Fixes: 52af95459939 ("USB: add USB serial ssu100 driver")
commit 1b0aed2b1600f6e5c7b9acfbd610a4e351ef5232 upstream.
Make sure the received data has the required headers before parsing it.
Also drop the redundant urb-status check, which has already been handled
by the caller.
commit c528fcb116e61afc379a2e0a0f70906b937f1e2c upstream.
Make sure to check for short transfers before parsing the receive buffer
to avoid acting on stale data.
commit 436ecf5519d892397af133a79ccd38a17c25fa51 upstream.
This is a Dell branded Sierra Wireless EM7455.
commit 6e9f44eaaef0df7b846e9316fa9ca72a02025d44 upstream.
Add Quectel UC15, UC20, EC21, and EC25. The EC20 is handled by
qcserial due to a USB VID/PID conflict with an existing Acer
device.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit 654b404f2a222f918af9b0cd18ad469d0c941a8e upstream.
Add missing sanity check to the bulk-in completion handler to avoid an
integer underflow that can be triggered by a malicious device.
This avoids leaking 128 kB of memory content from after the URB transfer
buffer to user space.
Fixes: 8c209e6782ca ("USB: make actual_length in struct urb field u32")
commit 0b1d250afb8eb9d65afb568bac9b9f9253a82b49 upstream.
Fix a NULL-pointer dereference in the interrupt callback should a
malicious device send data containing a bad port number by adding the
missing sanity check.
