commit 29f86e66428ee083aec106cca1748dc63d98ce23 upstream.
Device stucks on filesystem writes, unless following quirk is passed:
echo 04e8:5136:m > /sys/module/usb_storage/parameters/quirks
Add corresponding entry to unusual_devs.h
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
commit ab4b71644a26d1ab92b987b2fd30e17c25e89f85 upstream.
This reverts commit 200e0d99 ("USB: storage: optimize to match the
Huawei USB storage devices and support new switch command" and the
followup bugfix commit cd060956 ("USB: storage: properly handle
the endian issues of idProduct").
The commit effectively added a large number of Huawei devices to
the deprecated usb-storage mode switching logic. Many of these
devices have been in use and supported by the userspace
usb_modeswitch utility for years. Forcing the switching inside
the kernel causes a number of regressions as a result of ignoring
existing onfigurations, and also completely takes away the ability
to configure mode switching per device/system/user.
Known regressions caused by this:
- Some of the devices support multiple modes, using different
switching commands. There are existing configurations taking
advantage of this.
- There is a real use case for disabling mode switching and
instead mounting the exposed storage device. This becomes
impossible with switching logic inside the usb-storage driver.
- At least on device fail as a result of the usb-storage switching
command, becoming completely unswitchable. This is possibly a
firmware bug, but still a regression because the device work as
expected using usb_modeswitch defaults.
In-kernel mode switching was deprecated years ago with the
development of the more user friendly userspace alternatives. The
existing list of devices in usb-storage was only kept to prevent
breaking already working systems. The long term plan is to remove
the list, not to add to it. Ref:
http://permalink.gmane.org/gmane.linux.usb.general/28543
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: <fangxiaozhi@huawei.com>
new switch command
commit 200e0d994d9d1919b28c87f1a5fb99a8e13b8a0f upstream.
1. Optimize the match rules with new macro for Huawei USB storage devices,
to avoid to load USB storage driver for the modem interface
with Huawei devices.
2. Add to support new switch command for new Huawei USB dongles.
Signed-off-by: fangxiaozhi <huananhu@huawei.com>
commit d7870af7e2e3a91b462075ec1ca669b482215187 upstream.
This commit sets removable subclass for Casio EX-N1 digital camera.
The patch has been tested within an ALT Linux kernel:
http://git.altlinux.org/people/led/packages/?p=kernel-image-3.0.git;a=commitdiff;h=c0fd891836e89fe0c93a4d536a59216d90e4e3e7
See also https://bugzilla.kernel.org/show_bug.cgi?id=49221
Signed-off-by: Oleksandr Chumachenko <ledest@gmail.com>
Signed-off-by: Michael Shigorin <mike@osdn.org.ua>
commit 0070513b5e005161a7a7fd9a3f48f982b41eb094 upstream.
This patch (as1560) reverts commit
afff07e61a5243e14ee3f0a272a0380cd744a8a3 (usb-storage: Add 090c:1000
to unusal-devs). It is no longer needed, because usb-storage now
tells the sd driver to try READ CAPACITY(10) before READ CAPACITY(16)
for every USB mass-storage device.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Hans de Goede <hdegoede@redhat.com>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
commit afff07e61a5243e14ee3f0a272a0380cd744a8a3 upstream.
This device gives a bogus answer to get_capacity(16):
[ 8628.278614] scsi 8:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 4
[ 8628.279452] sd 8:0:0:0: Attached scsi generic sg4 type 0
[ 8628.280338] sd 8:0:0:0: [sdd] 35747322042253313 512-byte logical blocks: (18.3 EB/15.8 EiB)
So set the quirk flag to avoid using get_capacity(16) with it:
[11731.386014] usb-storage 2-1.6:1.0: Quirks match for vid 090c pid 1000: 80000
[11731.386075] scsi9 : usb-storage 2-1.6:1.0
[11731.386172] usbcore: registered new interface driver usb-storage
[11731.386175] USB Mass Storage support registered.
[11732.387394] scsi 9:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 4
[11732.388462] sd 9:0:0:0: Attached scsi generic sg3 type 0
[11732.389432] sd 9:0:0:0: [sdc] 7975296 512-byte logical blocks: (4.08 GB/3.80 GiB)
Which makes the capacity look a lot more sane :)
Tested-by: Simon Raffeiner <sturmflut@lieberbiber.de>
commit df767b71e5816692134d59c0c17e0f77cd73333d upstream.
This patch (as1553) adds an unusual_dev entrie for the Yarvik PMP400
MP4 music player.
Reported-by: Jesse Feddema <jdfeddema@gmail.com>
Tested-by: Jesse Feddema <jdfeddema@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
Kingston DT 101 G2 replies a wrong tag while transporting, add an
unusal_devs entry to ignore the tag validation.
Signed-off-by: Qinglin Ye <yestyle@gmail.com>
Cc: stable <stable@vger.kernel.org>
Connecting the V2M to a Linux host results in a constant stream of
errors spammed to the console, all of the form
sd 1:0:0:0: ioctl_internal_command return code = 8070000
: Sense Key : 0x4 [current]
: ASC=0x0 ASCQ=0x0
The errors appear to be otherwise harmless. Add an unusual_devs entry
which eliminates all of the error messages.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@kernel.org>
Some USB mass-storage devices have bugs that cause them not to handle
the first READ(10) command they receive correctly. The Corsair
Padlock v2 returns completely bogus data for its first read (possibly
it returns the data in encrypted form even though the device is
supposed to be unlocked). The Feiya SD/SDHC card reader fails to
complete the first READ(10) command after it is plugged in or after a
new card is inserted, returning a status code that indicates it thinks
the command was invalid, which prevents the kernel from retrying the
read.
Since the first read of a new device or a new medium is for the
partition sector, the kernel is unable to retrieve the device's
partition table. Users have to manually issue an "hdparm -z" or
"blockdev --rereadpt" command before they can access the device.
This patch (as1470) works around the problem. It adds a new quirk
flag, US_FL_INVALID_READ10, indicating that the first READ(10) should
always be retried immediately, as should any failing READ(10) commands
(provided the preceding READ(10) command succeeded, to avoid getting
stuck in a loop). The patch also adds appropriate unusual_devs
entries containing the new flag.
Tested-by: Sven Geggus <sven-usbst@geggus.net>
Tested-by: Paul Hartman <paul.hartman+linux@gmail.com>
CC: <stable@kernel.org>
This patch (as1444) adds an unusual_devs entry for an MP3 player from
Coby electronics. The device has two nasty bugs.
Tested-by: Jasper Mackenzie <scarletpimpernal@hotmail.com>
This device suffers from the off-by-one error when reporting the capacity,
so add entry with US_FL_FIX_CAPACITY.
Signed-off-by: Nick Holloway <Nick.Holloway@pyrites.org.uk>
This patch (as1438) adds an unusual_devs entry for the MagicPixel
FW_Omega2 chip, used in the CamSport Evo camera. The firmware
incorrectly reports a vendor-specific bDeviceClass.
Reported-by: <ttkspam@free.fr>
external hard drive enclosure
The TrekStor DataStation maxi g.u external hard drive enclosure uses a
JMicron USB to SATA chip which needs the US_FL_IGNORE_RESIDUE flag to work
properly.
Signed-off-by: Richard Schütz <r.schtz@t-online.de>
Add an unusual_devs entry for the Samsung YP-CP3 MP4 player.
User was getting the following errors in dmesg:
usb 2-6: reset high speed USB device using ehci_hcd and address 2
usb 2-6: USB disconnect, address 2
sd 3:0:0:0: [sdb] Assuming drive cache: write through
sdb:<2>ldm_validate_partition_table(): Disk read failed.
Dev sdb: unable to read RDB block 0
unable to read partition table
Signed-off-by: Vitaly Kuznetsov <vitty@altlinux.ru>
CC: stable@kernel.org
Some Rockbox based mp4 players will crash when ever they see a
read_capacity_16 scsi command. So add a new US_FL which tells the scsi sd
driver to not issue any read_capacity_16 scsi commands.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Appotech ax3003 (the larger brother of the ax203) based devices are even
more buggy then the ax203. They will go of into lala land when ever they
see a READ_DISC_INFO scsi command. So add a new US_FL which tells the
scsi sr driver to not issue any READ_DISC_INFO scsi commands.
[akpm@linux-foundation.org: fix build]
This commit changes prefix for some of the USB mass storage
class related macros (ie. USB_SC_ for subclass and USB_PR_
for class).
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
These Appotech controllers are found in Picture Frames, they provide a
(buggy) emulation of a cdrom drive which contains the windows software
Uploading of pictures happens over the corresponding /dev/sg device.
It seems unlikely that this entry is needed anymore since the kernel
has logic to handle devices that poorly respond to INQUIRY. Since we
now have another entry with the same VID/PID but different flags, it's
a good time to attempt to clean this up.
The original submitter's email no longer works, so we'll keep an eye
out for any regression reports.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
One last bit was missed while removing the USB_BERRY_CHARGE config
option in a8d4211f33a9573f7b1bdcfd9c9c48631d1515ee which gets dropped
by this patch.
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
SL11R-IDE 2.6c (at least) reports wrong capacity (one sector more).
Reading that last sector causes the device not to work anymore (and looks
like HAL or something does that automatically after plugging in):
sd 5:0:0:0: [sdc] Device not ready
sd 5:0:0:0: [sdc] Result: hostbyte=0x00 driverbyte=0x08
sd 5:0:0:0: [sdc] Sense Key : 0x2 [current]
sd 5:0:0:0: [sdc] ASC=0x0 ASCQ=0x0
sd 5:0:0:0: [sdc] CDB: cdb[0]=0x28: 28 00 04 a8 b5 70 00 00 01 00
Add unusual_devs entry to fix the capacity.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Enable the SD-Card interface on multiple Option 3G sticks.
The unusual_devs.h entry is necessary because the device descriptor is
vendor-specific. That prevents usb-storage from binding to it as an interface
driver.
Signed-off-by: Jan Dumon <j.dumon@option.com>
This patch removes the subclass and protocol entries from a Microtech
entry in unusual_devs.h. This was reported by <ryck@pacbell.net>.
Greg, please apply.
Resolves kernel.org bug 14914.
Remove entry for 2770:915d (usb digital camera with mass storage
support) from unusual_devs.h. The fix triggered by the entry causes
the file system on the camera to be completely inaccessible (no
partition table, the device is not mountable).
The patch works, but let me clarify a few things about it. All the
patch does is remove the entry for this device from the
drivers/usb/storage/unusual_devs.h, which is supposed to help with a
problem with the device's reported size (I think). I'm pretty sure it
was originally added for a reason, so I'm not sure removing it won't
cause other problems to reappear. Also, I should note that this
unusual_devs.h entry was present (and activating workarounds) in
2.6.29, but in that version everything works fine. Starting with
2.6.30, things no longer work.
Signed-off-by: Ryan May <rmay31@gmail.com>
Cc: Rohan Hart <rohan.hart17@gmail.com>
This patch (as1311) fixes a problem in usb-storage: Some devices are
pretty broken when it comes to reporting sense data. The information
they send back indicates that they have more than 18 bytes of sense
data available, but when the system asks for more than 18 they fail or
hang. The symptom is that probing fails with multiple resets.
The patch adds a new BAD_SENSE flag to indicate that usb-storage
should never ask for more than 18 bytes of sense data. The flag can
be set in an unusual_devs entry or via the "quirks=" module parameter,
and it is set automatically whenever a REQUEST SENSE command for more
than 18 bytes fails or times out.
An unusual_devs entry is added for the Agfa photo frame, which uses a
Prolific chip having this bug.
Tested-by: Daniel Kukula <daniel.kuku@gmail.com>
We set pdt_1f_for_no_lun for UFI devices, so most floppy entiries should
be unnecessary. This patch removes three entries which I'm certain are.
- For Mitsumi I have a customer with RHEL 5 (bz#514296)
- For SMSC I accessed Novell's Bugzilla and verified the entry
- For Y-E I tested the patch with the actual device
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
Add a quirk entry for the Leading Driver UD-11 usb flash drive.
As Alan Stern told me, the device doesn't deal correctly with the
locking media feature of the device, and this patch incorporates it.
Compiled, tested, working.
Signed-off-by: Rogerio Brito <rbrito@ime.usp.br>
Cc: Phil Dibowitz <phil@ipom.com>
Cc: Robert Hancock <hancockrwd@gmail.com>
D-Link DWN-652 in Modem mode exposes 3 interfaces
- First one is the USB storage one
- Second one is for both control and connection
- Third one is unknown
This patch avoids usb-storage trying to switch again when already in
modem mode, and exposes only 2 ttyUSB instead of 3 by not attaching
to the storage interface
Signed-off-by: Pascal Terjan <pterjan@mandriva.com>
This patch was originaly submitted by Phillip Potter
<phillipinda@hotmail.com> but was re-diffed to conform with
SubmittingPatches and to rebase on a newer tree by me.
Reported by Alessio Treglia on
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/125250
[ 2158.139386] sd 5:0:0:1: ioctl_internal_command return code = 8000002
[ 2158.139390] : Current: sense key: No Sense
[ 2158.139393] Additional sense: No additional sense information
Adds unusual device support.
modified: drivers/usb/storage/unusual_devs.h
Signed-off-by: Chuck Short <zulcss@ubuntu.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
This patch (as1227) adds the MAX_SECTORS_64 flag to the unusual_devs
entry for the Simple Tech/Datafab controller. This fixes Bugzilla
#12882.
Reported-and-tested-by: binbin <binbinsh@gmail.com>
This patch allows D-Link DWM-652 3.5G modem to work.
It is an express card but was only tested with the provided usb adapter as I
don't have machines with express card connector.
/dev/ttyUSB{0,1,2} get created, and using comgt on ttyUSB1 works fine :
[root@plop tmp]# comgt -d /dev/ttyUSB1 -e
Enter PIN number: XXXX
Waiting for Registration..(120 sec max).
Registered on Home network: "Orange France",2
Signal Quality: 15,99
This patch (as1217) converts usb-storage's onetouch subdriver into a
separate module.
This patch (as1216) converts usb-storage's karma subdriver into a
separate module.
This patch (as1215) converts usb-storage's alauda subdriver into a
separate module.
This patch (as1214) converts usb-storage's jumpshot subdriver into a
separate module.
This patch (as1213) converts usb-storage's datafab subdriver into a
separate module.
This patch (as1212) converts usb-storage's freecom subdriver into a
separate module.
This patch (as1211) converts usb-storage's shuttle_usbat subdriver
into a separate module.
This patch (as1210) converts usb-storage's cypress_atacb subdriver
This patch (as1209) converts usb-storage's sddr55 subdriver into a
separate module.
This patch (as1208) converts usb-storage's isd200 subdriver into a
separate module.
This patch (as1207) converts usb-storage's sddr09 subdriver into a
separate module.
An unexpected complication arises because of DPCM devices, in which
one LUN uses the sddr09 transport and one uses the standard CB
transport. Since these devices can be used even when
USB_STORAGE_SDDR09 isn't configured, their entries in unusual_devs.h
require special treatment. If SDDR09 isn't configured then the
entries remain in unusual_devs.h; if it is then the entries are
present in unusual_sddr09.h instead.
The "c-enter" USB to Toshiba 1.8" IDE enclosure needs special treatment
to work flawlessly. This patch is absolutely trivial, as the integrated
USB-IDE bridge is already identified to be an "unusual" device, only the
bcdDevice is different (lower) to the bcdDeviceMin already included in
the kernel.
It is a Prolific 2507 bridge.
T: Bus=02 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=067b ProdID=2507 Rev= 0.01
S: Manufacturer=Prolific Technology Inc.
S: Product=ATAPI-6 Bridge Controller
S: SerialNumber=00000272
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Signed-off-by: Thomas Bartosik <tbartdev@gmx-topmail.de>
Current firmware revision 5.60 still behaves the same,
so update the quirk up a (non-existing) 99.99 revision.
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=493415
Signed-off-by: Moritz Muehlenhoff <jmm@debian.org>
Tested-by: Jan Heitkoetter <devnull@heitkoetter.net>
Enable the SD-Card interface on the GI 0431 HSUPA stick from Option.
interface driver.
T: Bus=07 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 15 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs= 1
P: Vendor=0af0 ProdID=7501 Rev= 0.00
S: Manufacturer=Option N.V.
S: Product=Globetrotter HSUPA Modem
C:* #Ifs=11 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 7 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=89(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=09(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 9 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=8a(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0a(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#=10 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=0b(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=8c(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
