Set wake enable only if remote wakeup is supported
by the platform
Bug 1039143
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: I805dd773cdbb5639f59b2f5ba4bcb2e14be74d5b
Reviewed-on: http://git-master/r/147462
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Adding the check for vbus before setting the
run bit.
Bug 1046443
Change-Id: If71748f0fe9c942061ca871034ad4298a58efc23
Signed-off-by: Rohith Seelaboyina <rseelaboyina@nvidia.com>
Reviewed-on: http://git-master/r/131733
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Notify USB connection events to otg core. These
notifications will be used by drivers (e.g. otg wakelock
driver) who registered for the events.
Bug 1031034
Bug 976849
Change-Id: I3655071af9226e3aef385681fcabc94b9def4233
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/127137
Reviewed-by: Alex Courbot <acourbot@nvidia.com>
GVS: Gerrit_Virtual_Submit
Sometimes USB connect and disconnect events is not detected properly. The
OTG irq handler is using a workqueue which has no protection for multiple
incoming event handling.
This patch adds mutex to protect the workqueue for USB connection
handling.
BUG 968345
Change-Id: If1c6fec4231dd0dc918f7f278e0a1d7667782917
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/122308
Current Tegra UDC driver share same IRQ with OTG driver, and it will call
bus_resume() even if there is no UDC IRQ pending.
This patch will check UDC IRQ source and will not cause bus resume if no
IRQ pending for UDC driver.
BUG 1015685
Change-Id: Ifc5634ae5d1f7f1435c64bc527ab2e9fb8d0e36b
Reviewed-on: http://git-master/r/121896
Reviewed-by: Simone Willett <swillett@nvidia.com>
Enable the USB charging based on the USB charging spec 1.2. Now we can
detect:
1. SDP (stanardard downstream port)
2. CDP (charging downstream port)
3. DCP (dedicated charging port)
4. None (no cable connected)
5. Non-standard charger
For some non-standard charger, we cannot detect it as DCP device.
If we find a charger detected as USB device but no EP0 packet recieved
with 1s, we then decided this is 1A charger.
bug 968345
Change-Id: I804f90ea6e4794da8f52b1c3ebd694828d99f40e
Reviewed-on: http://git-master/r/120218
Increase max packet size and clean up timing logic so we can better
recover from not getting an interrupt in time for a SOF.
Bug 1026047
Signed-off-by: Mike Lockwood <lockwood@google.com>
(cherry picked from commit 3d2096a7959d023bc31a3cf934c3d425de01c94f)
Change-Id: I0a0a6f448e71e4a0c478bb44cadc54fa021e13e4
Reviewed-on: http://git-master/r/123344
This driver presents a standard USB audio class interface to the host
and an ALSA PCM device to userspace
Bug 1026047
(cherry picked from commit a23ff394752015a233dd3b27b05c9d913cbf5536)
Change-Id: I4054e09888f17d9cdfcfd4a3d430ca5cfb3fd9fa
Reviewed-on: http://git-master/r/123343
Bug 1026047
(cherry picked from commit 7a3d01af4f04950a86a18f5a439f1802d8093650)
drivers/usb/gadget/f_accessory.c
Change-Id: I30bc02a1bcf636967d56370db83578f49f0e7514
Reviewed-on: http://git-master/r/123342
The control request will be used by the host to enable/disable USB audio
and the ioctl will be used by userspace to read the audio mode
Bug 1026047
(cherry picked from commit 3e1ff6142761eef148c667e540381d1fbc437d4f)
Change-Id: I5f449de230ca8f44e2dae30a0f87772310b68f20
Reviewed-on: http://git-master/r/123341
Currently dr_controller_run() is called only during otg state
change.
When we unload a gadget driver, for example g_mass_storage
gadget driver, dr_controller_stop() is called but when it is
loaded back dr_controller_run() won't get called becasue of the
if condition failure. i.e
if (!udc->transceiver) {
dr_controller_run(udc);
So when the gadget driver is loaded for the second time
without removing the cable (i.e without otg state change),
the device won't get enumerated on the host because DR
IRQs are not enabled.
This CL fixes the above issue.
Bug 1012787
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ia127630e24dbe4c1e418163c2b858efb3baa8e45
Reviewed-on: http://git-master/r/114592
Give ownership of the DMA buffer back to the processor first and
then free the buffer. Otherwise processor won't be able to
access the dma mapped buffers and this would lead to slab
corruption.
When the DMA buffer is freed without a call to dma_sync_single_for_cpu(),
the kernel won't be able to set the buffer as POISON FREE and when we
acquire this memory back again the kernel will start printing slab
corruption output as the memory is not set to POISON FREE
Bug 1017884
Bug 1018161
Reviewed-on: http://git-master/r/#change,122151
Change-Id: I00d6cb185cd2314cccb56f968eb0a05288588c13
Reviewed-on: http://git-master/r/122390
usb_put_hcd calls hcd_release which frees up memory allocated
for hcd. As iounmap is called after usb_put_hcd and it is trying
to access hcd->regs, getting warning messages during unload of
USB. Hence fixing it.
bug 1023362
Change-Id: Ic339395edad9a76a9eeae290eff3517d2c714477
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/122088
Tested-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Device disconnect during resume might fail if notification
clients for this device removal are not ready.
Disconnecting device after the resume is complete.
Bug 1024496
Change-Id: Ia806e177d2dd2b1b43d3fea7a4af45f0d4a93cd4
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/122079
Fixing the potential compilation this is
currently masked as CONFIG_USB_OTG_UTILS
is enabled.
Change-Id: Ie10e5fc252156b8b904d387d87a11136fcc3f4c1
Reviewed-on: http://git-master/r/122043
Werror flag is enabled now. Fixing the compilations
errors when DEBUG is enabled.
Change-Id: I909dd177eedfd72f1f71d1a546fc40c301bd1aa7
Reviewed-on: http://git-master/r/122033
This config option only builds on PPC platforms.
Change-Id: Ibe7ebdc2dd5b9aa46e8f887570481a11a373c417
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/95475
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Changing prototype of create_bluk_endpoints since
function can called during runtime.
Bug 1026235
Change-Id: I9a39abb4de4548f18e6c6482e56a9126fe4122a3
Reviewed-on: http://git-master/r/120277
-enable warnings as errors compilation flag
-handle errors of missing semicolon and mismatched argument type
bug 949219
Change-Id: I29b1c08c590c94fa1aa43a9e37abf0385e3597d5
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/118235
bug 949219
Change-Id: If76cece9a5c929216024b165f48f37c4046faffc
Reviewed-on: http://git-master/r/118037
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Value of WAKEUP register is not updated
properly. Correcting it to take appropriate
value.
Bug 1008660
Change-Id: Ic1dcfed6639c8e8c686bc6931216fd268e4521ed
Read the RUN bit and update it properly.
Remove unused variable.
Change-Id: I1df5dc99ce40e2ca15f0ade28d156a7262467519
Signed-off-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-on: http://git-master/r/117958
When EHCI host controller driver examines qh/qtd descriptors, driver
might see stale data in cache on some ARM CPU. This patch introduces
two helper functions, ehci_sync_qh() and ehci_sync_qtd(), to
invalidate cached descriptors so that driver can always read
up-to-date descriptors from memory.
Bug 1005403
Change-Id: I2345bda7dfe29c5fe7f9550066b518cd6624d263
Signed-off-by: JC Kuo <jckuo@nvidia.com>
Reviewed-on: http://git-master/r/116406
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Reviewed-by: ChihMin Cheng <ccheng@nvidia.com>
Reviewed-by: Joy Wang <joyw@nvidia.com>
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
SW WAR implementation for h/w issue observed on all tegra platforms
Adding a dTD to a Primed Endpoint May Not Get Recognized
TD freeing will be delayed until next TD is completed
Bug 1002166
Reviewed-on: http://git-master/r/109562
(cherry picked from commit 8603480606af20444ed91e3010a22cc02edacb78)
Change-Id: I875d06eb2db78a18858590645df631478f3201bb
Reviewed-on: http://git-master/r/116972
There is race between acm_suspend and acm_read_bulk_callback. Host may
receive bulk transfer right before suspend. The packet will be discarded
if this urb is killed in acm_suspend. This patch checks the actual length
of urb and processes it in this case.
Bug 996268
Signed-off-by: Steve Lin <stlin@nvidia.com>
Change-Id: Ief2b42708160b67903f976ec60da825d46c4720b
Reviewed-on: http://git-master/r/117135
(cherry picked from commit af3e96c987fbae8a135d1ff18872b9c32e09b67f)
Reviewed-on: http://git-master/r/118105
Tested-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
1) Returning in irq after remote wakeup resume handled
in ehci irq function.
2) Removed the unused variables.
Bug 889618
Change-Id: I9a1fd25c753a53462bf7742065fa618caae501ab
Signed-off-by: Vinod Atyam <vatyam@nvidia.com>
Reviewed-on: http://git-master/r/111192
Make sure phy is turned ON before reading USB
registers.
Bug 993380
Bug 1006579
Reviewed-on: http://git-master/r/116045
(cherry picked from commit a1a6db7dc88880fb3d4bca0036ce421e4032adae)
Change-Id: If94e691bf9b5b46dd8f8562f27cf86e59a4d6353
Reviewed-on: http://git-master/r/117257
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
The usb transaction buffers are allocated in module init.
In device open, close and disconnect the buffers will not be
freed. Instead they will be reused to avoid allocation failure
in low-mem conditions.
The usb driver register moved to init so that rmmod and
insmod is not required.
Bug 956211
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/109935
(cherry picked from commit a4e8219a86f80fd06aaaae2c40a657098d5dcfa5)
Change-Id: Id88cfe3b0a75cb2e6f39176b5297f81f4f9e978b
Reviewed-on: http://git-master/r/115609
Tested-by: Vinayak Pane <vpane@nvidia.com>
Wake sources usb VBUS or ID detect enabled
bug 980993
bug 936982
Change-Id: Iea36d308c1a118abdb7815212d749bd058d0054f
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103141
Previously the callback was added to control USB VBUS.
The standard way is to use regulator.
Bug 997805
Change-Id: I88b15befaf4e162478da19ead50695978b2c5f4b
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/112901
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Addressed below items with this patch:
1. Using devm_kzalloc in place of kzalloc.
2. Correcting platform_get_irq return value check
Change-Id: I68225fe40adbb4be98e16ee2e0a4fccefadd8626
Reviewed-on: http://git-master/r/105843
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Turn off regulators along with clocks during suspend
Bug 991262
Reviewed-on: http://git-master/r/108820
(cherry picked from commit 41ae7ac21a2c08da0e4312b8395b380a704fa16c)
Change-Id: Ib49eec5d91571d75881f4d252d956dece1d37d60
Reviewed-on: http://git-master/r/105364
Include pm_qos_params header file to avail pm_qos
apis.
Bug 923594
Change-Id: Icbaad45e83a688b537159eea22ddd7356565fabf
Reviewed-on: http://git-master/r/113438
Add support for another XMM modem.
Bug 996038
Change-Id: I392a18284b372fbc80c581b31b21af3c072bf4d3
Signed-off-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-on: http://git-master/r/110193
(cherry picked from commit bdad2e9c1b195c8f7fcc3216f2bf27ea99dfd597)
Reviewed-on: http://git-master/r/110941
Becasue of a previous workaround, suspend/resume pair is implemented as
suspend/complete pair in the driver's dev_pm_ops field.
If any driver suspend routine (which is called before otg suspend)
failed, then tegra_otg_resume() will be called even tegra_otg_suspend()
is not called. This will cause disable the OTG clock, and OTG will not
generate any more IRQ.
Ideal fix would be use suspend/resume pair to implement the dev_pm_ops,
but this might break previous workaround. This patch check suspend()
routine is called or not in the resume routine; even we use suspend/
resume pair in the future, it will not cause bad behaviour.
BUG 999759
Change-Id: I88f9c28bb76c5ff9e32917904017f291456cb933
Reviewed-on: http://git-master/r/108444
(cherry picked from commit c751aeea65f126d8e2df7f8a9ba02a631f958dc1)
Reviewed-on: http://git-master/r/108945
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Host support should be disabled only when there is platform
data specifying proper setting.
Bug 998001
Change-Id: I99ff534074dd7ebbf12b53dcf53d6286925965d2
Reviewed-on: http://git-master/r/108760
Two threads race for two resources when baseband_usb_close()
get called from a user process
Bug 988188
Change-Id: Ic962640b6414e576d34b7ff6870b21b644837434
Signed-off-by: pyu <pyu@nvidia.com>
Reviewed-on: http://git-master/r/107088
Corrected wIndex in the hub control to call the bus reset sequence properly.
Change-Id: I7d410262d55ad4ad5acfe72e8725616238f863ac
(cherry picked from commit fee4a582584e24e93b9c43446a0d223664d70e6b)
(cherry picked from commit f8b775561696979ad08f53ea3b3c571bc07734bb)
Reviewed-on: http://git-master/r/107593
Tested-by: Vinod Atyam <vatyam@nvidia.com>
This is not merged properly reverting the change.
This reverts commit 3b080222a7b37c31fe73be90c3e681096f8b82dd.
Change-Id: Icb07c67bdff69a41685f7f8b038cf38306566789
Reviewed-on: http://git-master/r/107001
bug 947300
Change-Id: Ib9f1b796faa94d8424cfca41c7ec29d5360ef60c
Reviewed-on: http://git-master/r/106983
HSIC device enumeration is broken after usb common
phy changes. Setting correct hsic config in port_power
and repairing wIndex in hub_control.
Bug 991485
Change-Id: Ic2873879070cba8a06fb2cadc40d6c46158f71e9
Reviewed-on: http://git-master/r/105513
Disabling the ID_WAKEUP in the suspend causing the
otg state to change to host, so disabling it in otg
suspend. Also, renaming the readl calls to otg_readl
call.
Bug 993390
Change-Id: I2789ea31fefe4425eb63b6be3e70d794bddcfd83
Reviewed-on: http://git-master/r/106177
Replaced kstrtoul with sscanf.
Change-Id: I1c82e92bf43d2ceba6ac3a7c0090394ba3497f13
Reviewed-on: http://git-master/r/105888
Fixing the UTMIP auto suspend issues.
Bug 992463
Bug 989400
Change-Id: Ia0d536cd66081b263f7f2bde5debcc600dcef22a
Reviewed-on: http://git-master/r/105692
Enable pmu vbus interrupt for Enterprise and Whistler
to save power by turning off controller clock
Change-Id: I691bdd76ca71d63d98f83e2a3a18bbfcfc16a473
Reviewed-on: http://git-master/r/105150
This change fixes remote wakeup issues
when usb line is in suspend state.
Bug 989441
Bug 989400
Change-Id: I97982943d5521470b83ed87b83ab8703c4e9c260
Reviewed-on: http://git-master/r/104746
Problem description:
- tegra_udc_irq uses udc->lock
- Some functions running in the process context was not disabling
interrupts when locking udc->lock
- If a function gets interrupted by tegra_udc_irq after locking
udc->lock, a deadlock occurs, as tegra_udc_irq would also try to
lock
Fix description:
- Use an interruption disabling variant of spin_lock
Bug 983958
Change-Id: Ib774847212da64f1f727a207a4821860ffa7b4a8
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/102693
Following enhancements are done:
a. Removed unnecessary apis.
b. Update the new platform data structures.
c. Removed unnecessary function call overheads.
Bug 887361
Change-Id: I148f2c0adb617c6f3100b84854bbd4ed1e953ecd
Reviewed-on: http://git-master/r/103601
Update the udc driver to use common phy.
Bug 887361
Change-Id: I013c3df22fd7d41718debb96dc8db78f56d73bd1
Reviewed-on: http://git-master/r/103600
a. Update driver with common phy interface
b. Make host driver independent of phy type and
remove unnecessary CONFIG variables.
Bug 887361
Change-Id: Ibafa37a048df4377b73029039b04d04a53020bd4
Reviewed-on: http://git-master/r/103599
