This is the 5.4.76 stable release
- drivers/tty/serial/fsl_lpuart.c:
Fix merge conflict of upstream patches [86875e1d6426] and [8febdfb5973d],
which contradicted with patch [cde0cb39c0e8e] from NXP.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit 20914919ad31849ee2b9cfe0428f4a20335c9e2a upstream.
This patch fixes a possible issue when mtu3_gadget_stop()
already assigned NULL to mtu->gadget_driver during mtu_gadget_disconnect().
[<ffffff9008161974>] notifier_call_chain+0xa4/0x128
[<ffffff9008161fd4>] __atomic_notifier_call_chain+0x84/0x138
[<ffffff9008162ec0>] notify_die+0xb0/0x120
[<ffffff900809e340>] die+0x1f8/0x5d0
[<ffffff90080d03b4>] __do_kernel_fault+0x19c/0x280
[<ffffff90080d04dc>] do_bad_area+0x44/0x140
[<ffffff90080d0f9c>] do_translation_fault+0x4c/0x90
[<ffffff9008080a78>] do_mem_abort+0xb8/0x258
[<ffffff90080849d0>] el1_da+0x24/0x3c
[<ffffff9009bde01c>] mtu3_gadget_disconnect+0xac/0x128
[<ffffff9009bd576c>] mtu3_irq+0x34c/0xc18
[<ffffff90082ac03c>] __handle_irq_event_percpu+0x2ac/0xcd0
[<ffffff90082acae0>] handle_irq_event_percpu+0x80/0x138
[<ffffff90082acc44>] handle_irq_event+0xac/0x148
[<ffffff90082b71cc>] handle_fasteoi_irq+0x234/0x568
[<ffffff90082a8708>] generic_handle_irq+0x48/0x68
[<ffffff90082a96ac>] __handle_domain_irq+0x264/0x1740
[<ffffff90080819f4>] gic_handle_irq+0x14c/0x250
[<ffffff9008084cec>] el1_irq+0xec/0x194
[<ffffff90085b985c>] dma_pool_alloc+0x6e4/0xae0
[<ffffff9008d7f890>] cmdq_mbox_pool_alloc_impl+0xb0/0x238
[<ffffff9008d80904>] cmdq_pkt_alloc_buf+0x2dc/0x7c0
[<ffffff9008d80f60>] cmdq_pkt_add_cmd_buffer+0x178/0x270
[<ffffff9008d82320>] cmdq_pkt_perf_begin+0x108/0x148
[<ffffff9008d824d8>] cmdq_pkt_create+0x178/0x1f0
[<ffffff9008f96230>] mtk_crtc_config_default_path+0x328/0x7a0
[<ffffff90090246cc>] mtk_drm_idlemgr_kick+0xa6c/0x1460
[<ffffff9008f9bbb4>] mtk_drm_crtc_atomic_begin+0x1a4/0x1a68
[<ffffff9008e8df9c>] drm_atomic_helper_commit_planes+0x154/0x878
[<ffffff9008f2fb70>] mtk_atomic_complete.isra.16+0xe80/0x19c8
[<ffffff9008f30910>] mtk_atomic_commit+0x258/0x898
[<ffffff9008ef142c>] drm_atomic_commit+0xcc/0x108
[<ffffff9008ef7cf0>] drm_mode_atomic_ioctl+0x1c20/0x2580
[<ffffff9008ebc768>] drm_ioctl_kernel+0x118/0x1b0
[<ffffff9008ebcde8>] drm_ioctl+0x5c0/0x920
[<ffffff900863b030>] do_vfs_ioctl+0x188/0x1820
[<ffffff900863c754>] SyS_ioctl+0x8c/0xa0
Fixes: df2069acb005 ("usb: Add MediaTek USB3 DRD driver")
Signed-off-by: Macpaul Lin <macpaul.lin@mediatek.com>
Acked-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/1604642069-20961-1-git-send-email-macpaul.lin@mediatek.com
commit afaa2e745a246c5ab95103a65b1ed00101e1bc63 upstream.
In Bugzilla #208257, Julien Humbert reports that a 32-GB Kingston
flash drive spontaneously disconnects and reconnects, over and over.
Testing revealed that disabling Link Power Management for the drive
fixed the problem.
This patch adds a quirk entry for that drive to turn off LPM permanently.
CC: Hans de Goede <jwrdegoede@fedoraproject.org>
CC: <stable@vger.kernel.org>
Reported-and-tested-by: Julien Humbert <julroy67@gmail.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Link: https://lore.kernel.org/r/20201102145821.GA1478741@rowland.harvard.edu
commit fa27e2f6c5e674f3f1225f9ca7a7821faaf393bb upstream.
If we want to send a control status on our own time (through
delayed_status), make sure to handle a case where we may queue the
delayed status before the host requesting for it (when XferNotReady
is generated). Otherwise, the driver won't send anything because it's
not EP0_STATUS_PHASE yet. To resolve this, regardless whether
dwc->ep0state is EP0_STATUS_PHASE, make sure to clear the
dwc->delayed_status flag if dwc3_ep0_send_delayed_status() is called.
The control status can be sent when the host requests it later.
Cc: <stable@vger.kernel.org>
Fixes: d97c78a1908e ("usb: dwc3: gadget: END_TRANSFER before CLEAR_STALL command")
Signed-off-by: Thinh Nguyen <Thinh.Nguyen@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit db0362eeb22992502764e825c79b922d7467e0eb upstream.
Add the following Telit FN980 composition:
0x1055: tty, adb, tty, tty, tty, tty
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Link: https://lore.kernel.org/r/20201103124425.12940-1-dnlplm@gmail.com
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 489979b4aab490b6b917c11dc02d81b4b742784a upstream.
Add following Telit LE910Cx compositions:
0x1203: rndis, tty, adb, tty, tty, tty, tty
0x1230: tty, adb, rmnet, audio, tty, tty, tty, tty
0x1231: rndis, tty, adb, audio, tty, tty, tty, tty
Link: https://lore.kernel.org/r/20201031225458.10512-1-dnlplm@gmail.com
[ johan: add comments after entries ]
commit a46b973bced1ba57420752bf38426acd9f6cbfa6 upstream.
Add usb product id of the Quectel EC200T module.
Signed-off-by: Ziyi Cao <kernel@septs.pw>
Link: https://lore.kernel.org/r/17f8a2a3-ce0f-4be7-8544-8fdf286907d0@www.fastmail.com
commit 985616f0457d9f555fff417d0da56174f70cc14f upstream.
The write-URB busy flag was being cleared before the completion handler
was done with the URB, something which could lead to corrupt transfers
due to a racing write request if the URB is resubmitted.
Fixes: 507ca9bc0476 ("[PATCH] USB: add ability for usb-serial drivers to determine if their write urb is currently being used.")
Cc: stable <stable@vger.kernel.org> # 2.6.13
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[ Upstream commit 5fca3f062879f8e5214c56f3e3e2be6727900f5d ]
The code:
trb->length = cpu_to_le32(TRB_BURST_LEN(priv_ep->trb_burst_size)
| TRB_LEN(length));
TRB_BURST_LEN(priv_ep->trb_burst_size) may be overflow for int 32 if
priv_ep->trb_burst_size is equal or larger than 0x80;
Below is the Coverity warning:
sign_extension: Suspicious implicit sign extension: priv_ep->trb_burst_size
with type u8 (8 bits, unsigned) is promoted in priv_ep->trb_burst_size << 24
to type int (32 bits, signed), then sign-extended to type unsigned long
(64 bits, unsigned). If priv_ep->trb_burst_size << 24 is greater than 0x7FFFFFFF,
the upper bits of the result will all be 1.
To fix it, it needs to add an explicit cast to unsigned int type for ((p) << 24).
Reviewed-by: Jun Li <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
This is the 5.4.75 stable release
- drivers/i2c/busses/i2c-imx.c:
Drop NXP changes, which are covered by commit [2c58d5e0c754c] from
upstream.
- drivers/net/can/flexcan.c:
Keep NXP implementation, patch [ca10989632d88] from upstream is covered
in the NXP tree.
- drivers/usb/host/xhci.h:
Fix merge fuzz for upstream commit [2600a131e1f61]
commit 3cd54a618834430a26a648d880dd83d740f2ae30 upstream.
fsl_usb2_device_register() should stop init if dma_set_mask() return
error.
Fixes: cae058610465 ("drivers/usb/host: fsl: Set DMA_MASK of usb platform device")
Reviewed-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Link: https://lore.kernel.org/r/20201010060308.33693-1-ran.wang_1@nxp.com
commit 2d9c6442a9c81f4f8dee678d0b3c183173ab1e2d upstream.
Current tcpm_detach() only reset hard_reset_count if port->attached
is true, this may cause this counter clear is missed if the CC
disconnect event is generated after tcpm_port_reset() is done
by other events, e.g. VBUS off comes first before CC disconect for
a power sink, in that case the first tcpm_detach() will only clear
port->attached flag but leave hard_reset_count there because
tcpm_port_is_disconnected() is still false, then later tcpm_detach()
by CC disconnect will directly return due to port->attached is cleared,
finally this will result tcpm will not try hard reset or error recovery
for later attach.
ChiYuan reported this issue on his platform with below tcpm trace:
After power sink session setup after hard reset 2 times, detach
from the power source and then attach:
[ 4848.046358] VBUS off
[ 4848.046384] state change SNK_READY -> SNK_UNATTACHED
[ 4848.050908] Setting voltage/current limit 0 mV 0 mA
[ 4848.050936] polarity 0
[ 4848.052593] Requesting mux state 0, usb-role 0, orientation 0
[ 4848.053222] Start toggling
[ 4848.086500] state change SNK_UNATTACHED -> TOGGLING
[ 4848.089983] CC1: 0 -> 0, CC2: 3 -> 3 [state TOGGLING, polarity 0, connected]
[ 4848.089993] state change TOGGLING -> SNK_ATTACH_WAIT
[ 4848.090031] pending state change SNK_ATTACH_WAIT -> SNK_DEBOUNCED @200 ms
[ 4848.141162] CC1: 0 -> 0, CC2: 3 -> 0 [state SNK_ATTACH_WAIT, polarity 0, disconnected]
[ 4848.141170] state change SNK_ATTACH_WAIT -> SNK_ATTACH_WAIT
[ 4848.141184] pending state change SNK_ATTACH_WAIT -> SNK_UNATTACHED @20 ms
[ 4848.163156] state change SNK_ATTACH_WAIT -> SNK_UNATTACHED [delayed 20 ms]
[ 4848.163162] Start toggling
[ 4848.216918] CC1: 0 -> 0, CC2: 0 -> 3 [state TOGGLING, polarity 0, connected]
[ 4848.216954] state change TOGGLING -> SNK_ATTACH_WAIT
[ 4848.217080] pending state change SNK_ATTACH_WAIT -> SNK_DEBOUNCED @200 ms
[ 4848.231771] CC1: 0 -> 0, CC2: 3 -> 0 [state SNK_ATTACH_WAIT, polarity 0, disconnected]
[ 4848.231800] state change SNK_ATTACH_WAIT -> SNK_ATTACH_WAIT
[ 4848.231857] pending state change SNK_ATTACH_WAIT -> SNK_UNATTACHED @20 ms
[ 4848.256022] state change SNK_ATTACH_WAIT -> SNK_UNATTACHED [delayed20 ms]
[ 4848.256049] Start toggling
[ 4848.871148] VBUS on
[ 4848.885324] CC1: 0 -> 0, CC2: 0 -> 3 [state TOGGLING, polarity 0, connected]
[ 4848.885372] state change TOGGLING -> SNK_ATTACH_WAIT
[ 4848.885548] pending state change SNK_ATTACH_WAIT -> SNK_DEBOUNCED @200 ms
[ 4849.088240] state change SNK_ATTACH_WAIT -> SNK_DEBOUNCED [delayed200 ms]
[ 4849.088284] state change SNK_DEBOUNCED -> SNK_ATTACHED
[ 4849.088291] polarity 1
[ 4849.088769] Requesting mux state 1, usb-role 2, orientation 2
[ 4849.088895] state change SNK_ATTACHED -> SNK_STARTUP
[ 4849.088907] state change SNK_STARTUP -> SNK_DISCOVERY
[ 4849.088915] Setting voltage/current limit 5000 mV 0 mA
[ 4849.088927] vbus=0 charge:=1
[ 4849.090505] state change SNK_DISCOVERY -> SNK_WAIT_CAPABILITIES
[ 4849.090828] pending state change SNK_WAIT_CAPABILITIES -> SNK_READY @240 ms
[ 4849.335878] state change SNK_WAIT_CAPABILITIES -> SNK_READY [delayed240 ms]
this patch fix this issue by clear hard_reset_count at any cases
of cc disconnect, í.e. don't check port->attached flag.
Fixes: 4b4e02c83167 ("typec: tcpm: Move out of staging")
Reported-and-tested-by: ChiYuan Huang <cy_huang@richtek.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Link: https://lore.kernel.org/r/1602500592-3817-1-git-send-email-jun.li@nxp.com
commit 38203b8385bf6283537162bde7d499f830964711 upstream.
Commit a4e7279cd1d1 ("cdc-acm: introduce a cool down") is causing
regression if there is some USB error, such as -EPROTO.
This has been reported on some samples of the Odroid-N2 using the Combee II
Zibgee USB dongle.
> struct acm *acm = container_of(work, struct acm, work)
is incorrect in case of a delayed work and causes warnings, usually from
the workqueue:
> WARNING: CPU: 0 PID: 0 at kernel/workqueue.c:1474 __queue_work+0x480/0x528.
When this happens, USB eventually stops working completely after a while.
Also the ACM_ERROR_DELAY bit is never set, so the cooldown mechanism
previously introduced cannot be triggered and acm_submit_read_urb() is
never called.
This changes makes the cdc-acm driver use a single delayed work, fixing the
pointer arithmetic in acm_softint() and set the ACM_ERROR_DELAY when the
cooldown mechanism appear to be needed.
Fixes: a4e7279cd1d1 ("cdc-acm: introduce a cool down")
Cc: Oliver Neukum <oneukum@suse.com>
Reported-by: Pascal Vizeli <pascal.vizeli@nabucasa.com>
Acked-by: Oliver Neukum <oneukum@suse.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Link: https://lore.kernel.org/r/20201019170702.150534-1-jbrunet@baylibre.com
commit d97c78a1908e59a1fdbcbece87cd0440b5d7a1f2 upstream.
According the programming guide (for all DWC3 IPs), when the driver
handles ClearFeature(halt) request, it should issue CLEAR_STALL command
_after_ the END_TRANSFER command completes. The END_TRANSFER command may
take some time to complete. So, delay the ClearFeature(halt) request
control status stage and wait for END_TRANSFER command completion
interrupt. Only after END_TRANSFER command completes that the driver
may issue CLEAR_STALL command.
Fixes: cb11ea56f37a ("usb: dwc3: gadget: Properly handle ClearFeature(halt)")
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
commit c503672abe1348f10f5a54a662336358c6e1a297 upstream.
The function driver may queue new requests right after halting the
endpoint (i.e. queue new requests while the endpoint is stalled).
There's no restriction preventing it from doing so. However, dwc3
currently drops those requests after CLEAR_STALL. The driver should only
drop started requests. Keep the pending requests in the pending list to
resume and process them after the host issues ClearFeature(Halt) to the
endpoint.
commit 266d0493900ac5d6a21cdbe6b1624ed2da94d47a upstream.
No need to trigger runtime pm in driver removal, otherwise if user
disable auto suspend via sys file, runtime suspend may be entered,
which will call dwc3_core_exit() again and there will be clock disable
not balance warning:
[ 2026.820154] xhci-hcd xhci-hcd.0.auto: remove, state 4
[ 2026.825268] usb usb2: USB disconnect, device number 1
[ 2026.831017] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
[ 2026.836806] xhci-hcd xhci-hcd.0.auto: remove, state 4
[ 2026.842029] usb usb1: USB disconnect, device number 1
[ 2026.848029] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
[ 2026.865889] ------------[ cut here ]------------
[ 2026.870506] usb2_ctrl_root_clk already disabled
[ 2026.875082] WARNING: CPU: 0 PID: 731 at drivers/clk/clk.c:958
clk_core_disable+0xa0/0xa8
[ 2026.883170] Modules linked in: dwc3(-) phy_fsl_imx8mq_usb [last
unloaded: dwc3]
[ 2026.890488] CPU: 0 PID: 731 Comm: rmmod Not tainted
5.8.0-rc7-00280-g9d08cca-dirty #245
[ 2026.898489] Hardware name: NXP i.MX8MQ EVK (DT)
[ 2026.903020] pstate: 20000085 (nzCv daIf -PAN -UAO BTYPE=--)
[ 2026.908594] pc : clk_core_disable+0xa0/0xa8
[ 2026.912777] lr : clk_core_disable+0xa0/0xa8
[ 2026.916958] sp : ffff8000121b39a0
[ 2026.920271] x29: ffff8000121b39a0 x28: ffff0000b11f3700
[ 2026.925583] x27: 0000000000000000 x26: ffff0000b539c700
[ 2026.930895] x25: 000001d7e44e1232 x24: ffff0000b76fa800
[ 2026.936208] x23: ffff0000b76fa6f8 x22: ffff800008d01040
[ 2026.941520] x21: ffff0000b539ce00 x20: ffff0000b7105000
[ 2026.946832] x19: ffff0000b7105000 x18: 0000000000000010
[ 2026.952144] x17: 0000000000000001 x16: 0000000000000000
[ 2026.957456] x15: ffff0000b11f3b70 x14: ffffffffffffffff
[ 2026.962768] x13: ffff8000921b36f7 x12: ffff8000121b36ff
[ 2026.968080] x11: ffff8000119e1000 x10: ffff800011bf26d0
[ 2026.973392] x9 : 0000000000000000 x8 : ffff800011bf3000
[ 2026.978704] x7 : ffff800010695d68 x6 : 0000000000000252
[ 2026.984016] x5 : ffff0000bb9881f0 x4 : 0000000000000000
[ 2026.989327] x3 : 0000000000000027 x2 : 0000000000000023
[ 2026.994639] x1 : ac2fa471aa7cab00 x0 : 0000000000000000
[ 2026.999951] Call trace:
[ 2027.002401] clk_core_disable+0xa0/0xa8
[ 2027.006238] clk_core_disable_lock+0x20/0x38
[ 2027.010508] clk_disable+0x1c/0x28
[ 2027.013911] clk_bulk_disable+0x34/0x50
[ 2027.017758] dwc3_core_exit+0xec/0x110 [dwc3]
[ 2027.022122] dwc3_suspend_common+0x84/0x188 [dwc3]
[ 2027.026919] dwc3_runtime_suspend+0x74/0x9c [dwc3]
[ 2027.031712] pm_generic_runtime_suspend+0x28/0x40
[ 2027.036419] genpd_runtime_suspend+0xa0/0x258
[ 2027.040777] __rpm_callback+0x88/0x140
[ 2027.044526] rpm_callback+0x20/0x80
[ 2027.048015] rpm_suspend+0xd0/0x418
[ 2027.051503] __pm_runtime_suspend+0x58/0xa0
[ 2027.055693] dwc3_runtime_idle+0x7c/0x90 [dwc3]
[ 2027.060224] __rpm_callback+0x88/0x140
[ 2027.063973] rpm_idle+0x78/0x150
[ 2027.067201] __pm_runtime_idle+0x58/0xa0
[ 2027.071130] dwc3_remove+0x64/0xc0 [dwc3]
[ 2027.075140] platform_drv_remove+0x28/0x48
[ 2027.079239] device_release_driver_internal+0xf4/0x1c0
[ 2027.084377] driver_detach+0x4c/0xd8
[ 2027.087954] bus_remove_driver+0x54/0xa8
[ 2027.091877] driver_unregister+0x2c/0x58
[ 2027.095799] platform_driver_unregister+0x10/0x18
[ 2027.100509] dwc3_driver_exit+0x14/0x1408 [dwc3]
[ 2027.105129] __arm64_sys_delete_module+0x178/0x218
[ 2027.109922] el0_svc_common.constprop.0+0x68/0x160
[ 2027.114714] do_el0_svc+0x20/0x80
[ 2027.118031] el0_sync_handler+0x88/0x190
[ 2027.121953] el0_sync+0x140/0x180
[ 2027.125267] ---[ end trace 027f4f8189958f1f ]---
[ 2027.129976] ------------[ cut here ]------------
Fixes: fc8bb91bc83e ("usb: dwc3: implement runtime PM")
commit 03c1fd622f72c7624c81b64fdba4a567ae5ee9cb upstream.
Add the phy cleanup if dwc3 mode init fail, which is the missing part of
de-init for dwc3 core init.
Fixes: c499ff71ff2a ("usb: dwc3: core: re-factor init and exit paths")
commit ca3df3468eec87f6374662f7de425bc44c3810c1 upstream.
When preparing for SG, not all the entries are prepared at once. When
resume, don't use the remaining request length to calculate for MPS
alignment. Use the entire request->length to do that.
Fixes: 5d187c0454ef ("usb: dwc3: gadget: Don't setup more than requested")
commit 66706077dc89c66a4777a4c6298273816afb848c upstream.
The current ZLP handling for ep0 requests is only for control IN
requests. For OUT direction, DWC3 needs to check and setup for MPS
alignment.
Usually, control OUT requests can indicate its transfer size via the
wLength field of the control message. So usb_request->zero is usually
not needed for OUT direction. To handle ZLP OUT for control endpoint,
make sure the TRB is MPS size.
Fixes: c7fcdeb2627c ("usb: dwc3: ep0: simplify EP0 state machine")
Fixes: d6e5a549cc4d ("usb: dwc3: simplify ZLP handling")
commit a609ce2a13360d639b384b6ca783b38c1247f2db upstream.
Similar to some other IA platforms, Elkhart Lake too depends on the
PMU register write to request transition of Dx power state.
Thus, we add the PCI_DEVICE_ID_INTEL_EHLLP to the list of devices that
shall execute the ACPI _DSM method during D0/D3 sequence.
[heikki.krogerus@linux.intel.com: included Fixes tag]
Fixes: dbb0569de852 ("usb: dwc3: pci: Add Support for Intel Elkhart Lake Devices")
Signed-off-by: Raymond Tan <raymond.tan@intel.com>
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
commit 2a632815683d2d34df52b701a36fe5ac6654e719 upstream.
On some platform of AMD, S3 fails with HCE and SRE errors. To fix this,
need to disable a bit which is enable in sparse controller.
Cc: stable@vger.kernel.org #v4.19+
Signed-off-by: Sanket Goswami <Sanket.Goswami@amd.com>
Signed-off-by: Sandeep Singh <sandeep.singh@amd.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Link: https://lore.kernel.org/r/20201028203124.375344-3-mathias.nyman@linux.intel.com
[ Upstream commit 18a367e8947d72dd91b6fc401e88a2952c6363f7 ]
If the xhci-plat.c is the platform driver, after the runtime pm is
enabled, the xhci_suspend is called if nothing is connected on
the port. When the system goes to suspend, it will call xhci_suspend again
if USB wakeup is enabled.
Since the runtime suspend wakeup setting is not always the same as
system suspend wakeup setting, eg, at runtime suspend we always need
wakeup if the controller is in low power mode; but at system suspend,
we may not need wakeup. So, we move the judgement after changing
wakeup setting.
[commit message rewording -Mathias]
Link: https://lore.kernel.org/r/20200918131752.16488-8-mathias.nyman@linux.intel.com
[ Upstream commit c56150c1bc8da5524831b1dac2eec3c67b89f587 ]
Handling for removal of the controller was missing at one place.
Add it.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Link: https://lore.kernel.org/r/20200917112600.26508-1-oneukum@suse.com
tSwapSourceStart
[ Upstream commit 6bbe2a90a0bb4af8dd99c3565e907fe9b5e7fd88 ]
The patch addresses the compliance test failures while running
TD.PD.CP.E3, TD.PD.CP.E4, TD.PD.CP.E5 of the "Deterministic PD
Compliance MOI" test plan published in https://www.usb.org/usbc.
For a product to be Type-C compliant, it's expected that these tests
are run on usb.org certified Type-C compliance tester as mentioned in
The purpose of the tests TD.PD.CP.E3, TD.PD.CP.E4, TD.PD.CP.E5 is to
verify the PR_SWAP response of the device. While doing so, the test
asserts that Source Capabilities message is NOT received from the test
device within tSwapSourceStart min (20 ms) from the time the last bit
of GoodCRC corresponding to the RS_RDY message sent by the UUT was
sent. If it does then the test fails.
This is in line with the requirements from the USB Power Delivery
Specification Revision 3.0, Version 1.2:
"6.6.8.1 SwapSourceStartTimer
The SwapSourceStartTimer Shall be used by the new Source, after a
Power Role Swap or Fast Role Swap, to ensure that it does not send
Source_Capabilities Message before the new Sink is ready to receive
the
Source_Capabilities Message. The new Source Shall Not send the
Source_Capabilities Message earlier than tSwapSourceStart after the
last bit of the EOP of GoodCRC Message sent in response to the PS_RDY
Message sent by the new Source indicating that its power supply is
ready."
The patch makes sure that TCPM does not send the Source_Capabilities
Message within tSwapSourceStart(20ms) by transitioning into
SRC_STARTUP only after tSwapSourceStart(20ms).
Signed-off-by: Badhri Jagan Sridharan <badhri@google.com>
Link: https://lore.kernel.org/r/20200817183828.1895015-1-badhri@google.com
This is the 5.4.73 stable release
- arch/arm/boot/dts/imx6sl.dtsi:
Commit [a1767c90194e2] in NXP tree is now covered with commit [5c4c2f437cead]
from upstream.
- drivers/gpu/drm/mxsfb/mxsfb_drv.c:
Resolve merge hunk for patch [ed8b90d303cf0] from upstream
- drivers/media/i2c/ov5640.c:
Patch [aa4bb8b8838ff] in NXP tree is now covered by patches [79ec0578c7e0a]
and [b2f8546056b35] from upstream. Changes from NXP patch [99aa4c8c18984] are
covered in upstream version as well.
- drivers/net/ethernet/freescale/fec_main.c:
Fix merge fuzz for patch [9e70485b40c83] from upstream.
- drivers/usb/cdns3/gadget.c:
Keep NXP version of the file, upstream version is not compatible.
- drivers/usb/dwc3/core.c:
- drivers/usb/dwc3/core.h:
Fix merge fuzz of patch [08045050c6bd2] together wth NXP patch [b30e41dc1e494]
- sound/soc/fsl/fsl_sai.c:
- sound/soc/fsl/fsl_sai.h:
Commit [2ea70e51eb72a] in NXP tree is now covered with commit [1ad7f52fe6683]
from upstream.
[ Upstream commit 7974ecd7d3c0f42a98566f281e44ea8573a2ad88 ]
Currently, enabling f_ncm at SuperSpeed Plus speeds results in an
oops in config_ep_by_speed because ncm_set_alt passes in NULL
ssp_descriptors. Fix this by re-using the SuperSpeed descriptors.
This is safe because usb_assign_descriptors calls
usb_copy_descriptors.
Tested: enabled f_ncm on a dwc3 gadget and 10Gbps link, ran iperf
Reviewed-by: Maciej Żenczykowski <maze@google.com>
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
commit 98df91f8840cf750a0bc7c4c5d6b6085bac945b3 upstream.
The interrupt may occur during the gadget deletion, it fixes the
below oops.
[ 2394.974604] configfs-gadget gadget: suspend
[ 2395.042578] configfs-gadget 5b130000.usb: unregistering UDC driver [g1]
[ 2395.382562] irq 229: nobody cared (try booting with the "irqpoll" option)
[ 2395.389362] CPU: 0 PID: 301 Comm: kworker/u12:6 Not tainted 5.8.0-rc3-next-20200703-00060-g2f13b83cbf30-dirty #456
[ 2395.399712] Hardware name: Freescale i.MX8QM MEK (DT)
[ 2395.404782] Workqueue: 2-0051 tcpm_state_machine_work
[ 2395.409832] Call trace:
[ 2395.412289] dump_backtrace+0x0/0x1d0
[ 2395.415950] show_stack+0x1c/0x28
[ 2395.419271] dump_stack+0xbc/0x118
[ 2395.422678] __report_bad_irq+0x50/0xe0
[ 2395.426513] note_interrupt+0x2cc/0x38c
[ 2395.430355] handle_irq_event_percpu+0x88/0x90
[ 2395.434800] handle_irq_event+0x4c/0xe8
[ 2395.438640] handle_fasteoi_irq+0xbc/0x168
[ 2395.442740] generic_handle_irq+0x34/0x48
[ 2395.446752] __handle_domain_irq+0x68/0xc0
[ 2395.450846] gic_handle_irq+0x64/0x150
[ 2395.454596] el1_irq+0xb8/0x180
[ 2395.457733] __do_softirq+0xac/0x3b8
[ 2395.461310] irq_exit+0xc0/0xe0
[ 2395.464448] __handle_domain_irq+0x6c/0xc0
[ 2395.468540] gic_handle_irq+0x64/0x150
[ 2395.472295] el1_irq+0xb8/0x180
[ 2395.475436] _raw_spin_unlock_irqrestore+0x14/0x48
[ 2395.480232] usb_gadget_disconnect+0x120/0x140
[ 2395.484678] usb_gadget_remove_driver+0xb4/0xd0
[ 2395.489208] usb_del_gadget+0x6c/0xc8
[ 2395.492872] cdns3_gadget_exit+0x5c/0x120
[ 2395.496882] cdns3_role_stop+0x60/0x90
[ 2395.500634] cdns3_role_set+0x64/0xd8
[ 2395.504301] usb_role_switch_set_role.part.0+0x3c/0x90
[ 2395.509444] usb_role_switch_set_role+0x20/0x30
[ 2395.513978] tcpm_mux_set+0x60/0xf8
[ 2395.517470] tcpm_reset_port+0xa4/0xf0
[ 2395.521222] tcpm_detach.part.0+0x44/0x50
[ 2395.525227] tcpm_state_machine_work+0x8b0/0x2360
[ 2395.529932] process_one_work+0x1c8/0x470
[ 2395.533939] worker_thread+0x50/0x420
[ 2395.537603] kthread+0x148/0x168
[ 2395.540830] ret_from_fork+0x10/0x18
[ 2395.544399] handlers:
[ 2395.546671] [<000000008dea28da>] cdns3_wakeup_irq
[ 2395.551375] [<000000009fee5c61>] cdns3_drd_irq threaded [<000000005148eaec>] cdns3_drd_thread_irq
[ 2395.560255] Disabling IRQ #229
[ 2395.563454] configfs-gadget gadget: unbind function 'Mass Storage Function'/000000000132f835
[ 2395.563657] configfs-gadget gadget: unbind
[ 2395.563917] udc 5b130000.usb: releasing '5b130000.usb'
Fixes: 7733f6c32e36 ("usb: cdns3: Add Cadence USB3 DRD Driver")
Acked-by: Roger Quadros <rogerq@ti.com>
commit 37d2a36394d954413a495da61da1b2a51ecd28ab upstream.
syzbot is reporting hung task at wdm_flush() [1], for there is a circular
dependency that wdm_flush() from flip_close() for /dev/cdc-wdm0 forever
waits for /dev/raw-gadget to be closed while close() for /dev/raw-gadget
cannot be called unless close() for /dev/cdc-wdm0 completes.
Tetsuo Handa considered that such circular dependency is an usage error [2]
which corresponds to an unresponding broken hardware [3]. But Alan Stern
responded that we should be prepared for such hardware [4]. Therefore,
this patch changes wdm_flush() to use wait_event_interruptible_timeout()
which gives up after 30 seconds, for hardware that remains silent must be
ignored. The 30 seconds are coming out of thin air.
Changing wait_event() to wait_event_interruptible_timeout() makes error
reporting from close() syscall less reliable. To compensate it, this patch
also implements wdm_fsync() which does not use timeout. Those who want to
be very sure that data has gone out to the device are now advised to call
fsync(), with a caveat that fsync() can return -EINVAL when running on
older kernels which do not implement wdm_fsync().
This patch also fixes three more problems (listed below) found during
exhaustive discussion and testing.
Since multiple threads can concurrently call wdm_write()/wdm_flush(),
we need to use wake_up_all() whenever clearing WDM_IN_USE in order to
make sure that all waiters are woken up. Also, error reporting needs
to use fetch-and-clear approach in order not to report same error for
multiple times.
Since wdm_flush() checks WDM_DISCONNECTING, wdm_write() should as well
check WDM_DISCONNECTING.
In wdm_flush(), since locks are not held, it is not safe to dereference
desc->intf after checking that WDM_DISCONNECTING is not set [5]. Thus,
remove dev_err() from wdm_flush().
[1] https://syzkaller.appspot.com/bug?id=e7b761593b23eb50855b9ea31e3be5472b711186
[2] https://lkml.kernel.org/r/27b7545e-8f41-10b8-7c02-e35a08eb1611@i-love.sakura.ne.jp
[3] https://lkml.kernel.org/r/79ba410f-e0ef-2465-b94f-6b9a4a82adf5@i-love.sakura.ne.jp
[4] https://lkml.kernel.org/r/20200530011040.GB12419@rowland.harvard.edu
[5] https://lkml.kernel.org/r/c85331fc-874c-6e46-a77f-0ef1dc075308@i-love.sakura.ne.jp
Reported-by: syzbot <syzbot+854768b99f19e89d7f81@syzkaller.appspotmail.com>
Co-developed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Alan Stern <stern@rowland.harvard.edu>
Link: https://lore.kernel.org/r/20200928141755.3476-1-penguin-kernel@I-love.SAKURA.ne.jp
commit a4f88430af896bf34ec25a7a5f0e053fb3d928e0 upstream.
The ES58X devices has a CDC ACM interface (used for debug
purpose). During probing, the device is thus recognized as USB Modem
(CDC ACM), preventing the etas-es58x module to load:
usbcore: registered new interface driver etas_es58x
usb 1-1.1: new full-speed USB device number 14 using xhci_hcd
usb 1-1.1: New USB device found, idVendor=108c, idProduct=0159, bcdDevice= 1.00
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: ES581.4
usb 1-1.1: Manufacturer: ETAS GmbH
usb 1-1.1: SerialNumber: 2204355
cdc_acm 1-1.1:1.0: No union descriptor, testing for castrated device
cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Thus, these have been added to the ignore list in
drivers/usb/class/cdc-acm.c
N.B. Future firmware release of the ES58X will remove the CDC-ACM
interface.
`lsusb -v` of the three devices variant (ES581.4, ES582.1 and
ES584.1):
Bus 001 Device 011: ID 108c:0159 Robert Bosch GmbH ES581.4
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x108c Robert Bosch GmbH
idProduct 0x0159
bcdDevice 1.00
iManufacturer 1 ETAS GmbH
iProduct 2 ES581.4
iSerial 3 2204355
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0035
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 5 Bus Powered Configuration
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 0
iInterface 4 ACM Control Interface
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x01
call management
bDataInterface 0
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 10
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 012: ID 108c:0168 Robert Bosch GmbH ES582
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idProduct 0x0168
bcdDevice 1.00
iProduct 2 ES582
iSerial 3 0108933
bLength 9
bDescriptorType 2
wTotalLength 0x0043
bNumInterfaces 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 1.10
CDC ACM:
bmCapabilities 0x02
CDC Union:
bMasterInterface 0
bSlaveInterface 1
bmCapabilities 0x03
call management
use DataInterface
bDataInterface 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
Bus 001 Device 013: ID 108c:0169 Robert Bosch GmbH ES584.1
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idProduct 0x0169
bcdDevice 1.00
iProduct 2 ES584.1
iSerial 3 0100320
bLength 9
bDescriptorType 2
wTotalLength 0x0043
bNumInterfaces 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
CDC Header:
bcdCDC 1.10
CDC ACM:
bmCapabilities 0x02
CDC Union:
bMasterInterface 0
bSlaveInterface 1
bmCapabilities 0x03
call management
use DataInterface
bDataInterface 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
Signed-off-by: Vincent Mailhol <mailhol.vincent@wanadoo.fr>
Link: https://lore.kernel.org/r/20201002154219.4887-8-mailhol.vincent@wanadoo.fr
[ Upstream commit fbc299437c06648afcc7891e6e2e6638dd48d4df ]
usb_kill_anchored_urbs() is commonly used to cancel all URBs on an
anchor just before releasing resources which the URBs rely on. By doing
so, users of this function rely on that no completer callbacks will take
place from any URB on the anchor after it returns.
However if this function is called in parallel with __usb_hcd_giveback_urb
processing a URB on the anchor, the latter may call the completer
callback after usb_kill_anchored_urbs() returns. This can lead to a
kernel panic due to use after release of memory in interrupt context.
The race condition is that __usb_hcd_giveback_urb() first unanchors the URB
and then makes the completer callback. Such URB is hence invisible to
usb_kill_anchored_urbs(), allowing it to return before the completer has
been called, since the anchor's urb_list is empty.
Even worse, if the racing completer callback resubmits the URB, it may
remain in the system long after usb_kill_anchored_urbs() returns.
Hence list_empty(&anchor->urb_list), which is used in the existing
while-loop, doesn't reliably ensure that all URBs of the anchor are gone.
A similar problem exists with usb_poison_anchored_urbs() and
usb_scuttle_anchored_urbs().
This patch adds an external do-while loop, which ensures that all URBs
are indeed handled before these three functions return. This change has
no effect at all unless the race condition occurs, in which case the
loop will busy-wait until the racing completer callback has finished.
This is a rare condition, so the CPU waste of this spinning is
negligible.
The additional do-while loop relies on usb_anchor_check_wakeup(), which
returns true iff the anchor list is empty, and there is no
__usb_hcd_giveback_urb() in the system that is in the middle of the
unanchor-before-complete phase. The @suspend_wakeups member of
struct usb_anchor is used for this purpose, which was introduced to solve
another problem which the same race condition causes, in commit
6ec4147e7bdb ("usb-anchor: Delay usb_wait_anchor_empty_timeout wake up
till completion is done").
The surely_empty variable is necessary, because usb_anchor_check_wakeup()
must be called with the lock held to prevent races. However the spinlock
must be released and reacquired if the outer loop spins with an empty
URB list while waiting for the unanchor-before-complete passage to finish:
The completer callback may very well attempt to take the very same lock.
To summarize, using usb_anchor_check_wakeup() means that the patched
functions can return only when the anchor's list is empty, and there is
no invisible URB being processed. Since the inner while loop finishes on
the empty list condition, the new do-while loop will terminate as well,
except for when the said race condition occurs.
Signed-off-by: Eli Billauer <eli.billauer@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Link: https://lore.kernel.org/r/20200731054650.30644-1-eli.billauer@gmail.com
[ Upstream commit b77d2a0a223bc139ee8904991b2922d215d02636 ]
Some integrated OHCI controller hubs do not expose all ports of the hub
to pins on the SoC. In some cases the unconnected ports generate
spurious over-current events. For example the Broadcom 56060/Ranger 2 SoC
contains a nominally 3 port hub but only the first port is wired.
Default behaviour for ohci-platform driver is to use global over-current
protection mode (AKA "ganged"). This leads to the spurious over-current
events affecting all ports in the hub.
We now alter the default to use per-port over-current protection.
This patch results in the following configuration changes depending
on quirks:
- For quirk OHCI_QUIRK_SUPERIO no changes. These systems remain set up
for ganged power switching and no over-current protection.
- For quirk OHCI_QUIRK_AMD756 or OHCI_QUIRK_HUB_POWER power switching
remains at none, while over-current protection is now guaranteed to be
set to per-port rather than the previous behaviour where it was either
none or global over-current protection depending on the value at
function entry.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Hamish Martin <hamish.martin@alliedtelesis.co.nz>
Link: https://lore.kernel.org/r/20200910212512.16670-1-hamish.martin@alliedtelesis.co.nz
[ Upstream commit b68d9251561f33661e53dd618f1cafe7ec9ec3c2 ]
This binding driver is needed for Hikey 970 to work,
as otherwise a Serror is produced:
[ 1.837458] SError Interrupt on CPU0, code 0xbf000002 -- SError
[ 1.837462] CPU: 0 PID: 74 Comm: kworker/0:1 Not tainted 5.8.0+ #205
[ 1.837463] Hardware name: HiKey970 (DT)
[ 1.837465] Workqueue: events deferred_probe_work_func
[ 1.837467] pstate: 20000005 (nzCv daif -PAN -UAO BTYPE=--)
[ 1.837468] pc : _raw_spin_unlock_irqrestore+0x18/0x50
[ 1.837469] lr : regmap_unlock_spinlock+0x14/0x20
[ 1.837470] sp : ffff8000124dba60
[ 1.837471] x29: ffff8000124dba60 x28: 0000000000000000
[ 1.837474] x27: ffff0001b7e854c8 x26: ffff80001204ea18
[ 1.837476] x25: 0000000000000005 x24: ffff800011f918f8
[ 1.837479] x23: ffff800011fbb588 x22: ffff0001b7e40e00
[ 1.837481] x21: 0000000000000100 x20: 0000000000000000
[ 1.837483] x19: ffff0001b767ec00 x18: 00000000ff10c000
[ 1.837485] x17: 0000000000000002 x16: 0000b0740fdb9950
[ 1.837488] x15: ffff8000116c1198 x14: ffffffffffffffff
[ 1.837490] x13: 0000000000000030 x12: 0101010101010101
[ 1.837493] x11: 0000000000000020 x10: ffff0001bf17d130
[ 1.837495] x9 : 0000000000000000 x8 : ffff0001b6938080
[ 1.837497] x7 : 0000000000000000 x6 : 000000000000003f
[ 1.837500] x5 : 0000000000000000 x4 : 0000000000000000
[ 1.837502] x3 : ffff80001096a880 x2 : 0000000000000000
[ 1.837505] x1 : ffff0001b7e40e00 x0 : 0000000100000001
[ 1.837507] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 1.837509] CPU: 0 PID: 74 Comm: kworker/0:1 Not tainted 5.8.0+ #205
[ 1.837510] Hardware name: HiKey970 (DT)
[ 1.837511] Workqueue: events deferred_probe_work_func
[ 1.837513] Call trace:
[ 1.837514] dump_backtrace+0x0/0x1e0
[ 1.837515] show_stack+0x18/0x24
[ 1.837516] dump_stack+0xc0/0x11c
[ 1.837517] panic+0x15c/0x324
[ 1.837518] nmi_panic+0x8c/0x90
[ 1.837519] arm64_serror_panic+0x78/0x84
[ 1.837520] do_serror+0x158/0x15c
[ 1.837521] el1_error+0x84/0x100
[ 1.837522] _raw_spin_unlock_irqrestore+0x18/0x50
[ 1.837523] regmap_write+0x58/0x80
[ 1.837524] hi3660_reset_deassert+0x28/0x34
[ 1.837526] reset_control_deassert+0x50/0x260
[ 1.837527] reset_control_deassert+0xf4/0x260
[ 1.837528] dwc3_probe+0x5dc/0xe6c
[ 1.837529] platform_drv_probe+0x54/0xb0
[ 1.837530] really_probe+0xe0/0x490
[ 1.837531] driver_probe_device+0xf4/0x160
[ 1.837532] __device_attach_driver+0x8c/0x114
[ 1.837533] bus_for_each_drv+0x78/0xcc
[ 1.837534] __device_attach+0x108/0x1a0
[ 1.837535] device_initial_probe+0x14/0x20
[ 1.837537] bus_probe_device+0x98/0xa0
[ 1.837538] deferred_probe_work_func+0x88/0xe0
[ 1.837539] process_one_work+0x1cc/0x350
[ 1.837540] worker_thread+0x2c0/0x470
[ 1.837541] kthread+0x154/0x160
[ 1.837542] ret_from_fork+0x10/0x30
[ 1.837569] SMP: stopping secondary CPUs
[ 1.837570] Kernel Offset: 0x1d0000 from 0xffff800010000000
[ 1.837571] PHYS_OFFSET: 0x0
[ 1.837572] CPU features: 0x240002,20882004
[ 1.837573] Memory Limit: none
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
[ Upstream commit 960c7339de27c6d6fec13b54880501c3576bb08d ]
Handle broken union functional descriptors where the master-interface
doesn't exist or where its class is of neither Communication or Data
type (as required by the specification) by falling back to
"combined-interface" probing.
Note that this still allows for handling union descriptors with switched
interfaces.
This specifically makes the Whistler radio scanners TRX series devices
work with the driver without adding further quirks to the device-id
table.
Reported-by: Daniel Caujolle-Bert <f1rmb.daniel@gmail.com>
Tested-by: Daniel Caujolle-Bert <f1rmb.daniel@gmail.com>
Link: https://lore.kernel.org/r/20200921135951.24045-3-johan@kernel.org
[ Upstream commit e8d5f92b8d30bb4ade76494490c3c065e12411b1 ]
Fix this by increase object reference count.
BUG: KASAN: use-after-free in __lock_acquire+0x3fd4/0x4180
kernel/locking/lockdep.c:3831
Read of size 8 at addr ffff8880683b0018 by task syz-executor.0/3377
CPU: 1 PID: 3377 Comm: syz-executor.0 Not tainted 5.6.11 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xce/0x128 lib/dump_stack.c:118
print_address_description.constprop.4+0x21/0x3c0 mm/kasan/report.c:374
__kasan_report+0x131/0x1b0 mm/kasan/report.c:506
kasan_report+0x12/0x20 mm/kasan/common.c:641
__asan_report_load8_noabort+0x14/0x20 mm/kasan/generic_report.c:135
__lock_acquire+0x3fd4/0x4180 kernel/locking/lockdep.c:3831
lock_acquire+0x127/0x350 kernel/locking/lockdep.c:4488
__raw_spin_lock_irqsave include/linux/spinlock_api_smp.h:110 [inline]
_raw_spin_lock_irqsave+0x35/0x50 kernel/locking/spinlock.c:159
printer_ioctl+0x4a/0x110 drivers/usb/gadget/function/f_printer.c:723
vfs_ioctl fs/ioctl.c:47 [inline]
ksys_ioctl+0xfb/0x130 fs/ioctl.c:763
__do_sys_ioctl fs/ioctl.c:772 [inline]
__se_sys_ioctl fs/ioctl.c:770 [inline]
__x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:770
do_syscall_64+0x9e/0x510 arch/x86/entry/common.c:294
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x4531a9
Code: ed 60 fc ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48
89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d
01 f0 ff ff 0f 83 bb 60 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fd14ad72c78 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 000000000073bfa8 RCX: 00000000004531a9
RDX: fffffffffffffff9 RSI: 000000000000009e RDI: 0000000000000003
RBP: 0000000000000003 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000004bbd61
R13: 00000000004d0a98 R14: 00007fd14ad736d4 R15: 00000000ffffffff
Allocated by task 2393:
save_stack+0x21/0x90 mm/kasan/common.c:72
set_track mm/kasan/common.c:80 [inline]
__kasan_kmalloc.constprop.3+0xa7/0xd0 mm/kasan/common.c:515
kasan_kmalloc+0x9/0x10 mm/kasan/common.c:529
kmem_cache_alloc_trace+0xfa/0x2d0 mm/slub.c:2813
kmalloc include/linux/slab.h:555 [inline]
kzalloc include/linux/slab.h:669 [inline]
gprinter_alloc+0xa1/0x870 drivers/usb/gadget/function/f_printer.c:1416
usb_get_function+0x58/0xc0 drivers/usb/gadget/functions.c:61
config_usb_cfg_link+0x1ed/0x3e0 drivers/usb/gadget/configfs.c:444
configfs_symlink+0x527/0x11d0 fs/configfs/symlink.c:202
vfs_symlink+0x33d/0x5b0 fs/namei.c:4201
do_symlinkat+0x11b/0x1d0 fs/namei.c:4228
__do_sys_symlinkat fs/namei.c:4242 [inline]
__se_sys_symlinkat fs/namei.c:4239 [inline]
__x64_sys_symlinkat+0x73/0xb0 fs/namei.c:4239
Freed by task 3368:
kasan_set_free_info mm/kasan/common.c:337 [inline]
__kasan_slab_free+0x135/0x190 mm/kasan/common.c:476
kasan_slab_free+0xe/0x10 mm/kasan/common.c:485
slab_free_hook mm/slub.c:1444 [inline]
slab_free_freelist_hook mm/slub.c:1477 [inline]
slab_free mm/slub.c:3034 [inline]
kfree+0xf7/0x410 mm/slub.c:3995
gprinter_free+0x49/0xd0 drivers/usb/gadget/function/f_printer.c:1353
usb_put_function+0x38/0x50 drivers/usb/gadget/functions.c:87
config_usb_cfg_unlink+0x2db/0x3b0 drivers/usb/gadget/configfs.c:485
configfs_unlink+0x3b9/0x7f0 fs/configfs/symlink.c:250
vfs_unlink+0x287/0x570 fs/namei.c:4073
do_unlinkat+0x4f9/0x620 fs/namei.c:4137
__do_sys_unlink fs/namei.c:4184 [inline]
__se_sys_unlink fs/namei.c:4182 [inline]
__x64_sys_unlink+0x42/0x50 fs/namei.c:4182
The buggy address belongs to the object at ffff8880683b0000
which belongs to the cache kmalloc-1k of size 1024
The buggy address is located 24 bytes inside of
1024-byte region [ffff8880683b0000, ffff8880683b0400)
The buggy address belongs to the page:
page:ffffea0001a0ec00 refcount:1 mapcount:0 mapping:ffff88806c00e300
index:0xffff8880683b1800 compound_mapcount: 0
flags: 0x100000000010200(slab|head)
raw: 0100000000010200 0000000000000000 0000000600000001 ffff88806c00e300
raw: ffff8880683b1800 000000008010000a 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Reported-by: Kyungtae Kim <kt0755@gmail.com>
Signed-off-by: Zqiang <qiang.zhang@windriver.com>
[ Upstream commit f580170f135af14e287560d94045624d4242d712 ]
SPLIT_BOUNDARY_DISABLE should be set for DesignWare USB3 DRD Core
of Hisilicon Kirin Soc when dwc3 core act as host.
[mchehab: dropped a dev_dbg() as only traces are now allowwed on this driver]
Signed-off-by: Yu Chen <chenyu56@huawei.com>
[ Upstream commit b2c586eb07efab982419f32b7c3bd96829bc8bcd ]
In DDMA mode if INTR OUT transfers mps not multiple of 4 then single packet
corresponds to single descriptor.
Descriptor limit set to mps and desc chain limit set to mps *
MAX_DMA_DESC_NUM_GENERIC. On that descriptors complete, to calculate
transfer size should be considered correction value for each descriptor.
In start request function, if "continue" is true then dma buffer address
should be incremmented by offset for all type of transfers, not only for
Control DATA_OUT transfers.
Fixes: cf77b5fb9b394 ("usb: dwc2: gadget: Transfer length limit checking for DDMA")
Fixes: e02f9aa6119e0 ("usb: dwc2: gadget: EP 0 specific DDMA programming")
Fixes: aa3e8bc81311e ("usb: dwc2: gadget: DDMA transfer start and complete")
Signed-off-by: Minas Harutyunyan <hminas@synopsys.com>
[ Upstream commit 4eea21dc67b0c6ba15ae41b1defa113a680a858e ]
The u_ether driver has a qmult setting that multiplies the
transmit queue length (which by default is 2).
The intent is that it should be enabled at high/super speed, but
because the code does not explicitly check for USB_SUPER_PLUS,
it is disabled at that speed.
Fix this by ensuring that the queue multiplier is enabled for any
wired link at high speed or above. Using >= for USB_SPEED_*
constants seems correct because it is what the gadget_is_xxxspeed
functions do.
The queue multiplier substantially helps performance at higher
speeds. On a direct SuperSpeed Plus link to a Linux laptop,
iperf3 single TCP stream:
Before (qmult=1): 1.3 Gbps
After (qmult=5): 3.2 Gbps
Fixes: 04617db7aa68 ("usb: gadget: add SS descriptors to Ethernet gadget")
[ Upstream commit 986499b1569af980a819817f17238015b27793f6 ]
Currently, SuperSpeed NCM gadgets report a speed of 851 Mbps
in USB_CDC_NOTIFY_SPEED_CHANGE. But the calculation appears to
assume 16 packets per microframe, and USB 3 and above no longer
use microframes.
Maximum speed is actually much higher. On a direct connection,
theoretical throughput is at most 3.86 Gbps for gen1x1 and
9.36 Gbps for gen2x1, and I have seen gadget->host iperf
throughput of >2 Gbps for gen1x1 and >4 Gbps for gen2x1.
Unfortunately the ConnectionSpeedChange defined in the CDC spec
only uses 32-bit values, so we can't report accurate numbers for
10Gbps and above. So, report 3.75Gbps for SuperSpeed (which is
roughly maximum theoretical performance) and 4.25Gbps for
SuperSpeed Plus (which is close to the maximum that we can report
in a 32-bit unsigned integer).
This results in:
[50879.191272] cdc_ncm 2-2:1.0 enx228b127e050c: renamed from usb0
[50879.234778] cdc_ncm 2-2:1.0 enx228b127e050c: 3750 mbit/s downlink 3750 mbit/s uplink
on SuperSpeed and:
[50798.434527] cdc_ncm 8-2:1.0 enx228b127e050c: renamed from usb0
[50798.524278] cdc_ncm 8-2:1.0 enx228b127e050c: 4250 mbit/s downlink 4250 mbit/s uplink
on SuperSpeed Plus.
Fixes: 1650113888fe ("usb: gadget: f_ncm: add SuperSpeed descriptors for CDC NCM")
[ Upstream commit 362b9398c962c9ec563653444e15ef9032ef3a90 ]
When booting up on a Raspberry Pi 4 with Control Flow Integrity checking
enabled, the following warning/panic happens:
[ 1.626435] CFI failure (target: dwc2_set_bcm_params+0x0/0x4):
[ 1.632408] WARNING: CPU: 0 PID: 32 at kernel/cfi.c:30 __cfi_check_fail+0x54/0x5c
[ 1.640021] Modules linked in:
[ 1.643137] CPU: 0 PID: 32 Comm: kworker/0:1 Not tainted 5.8.0-rc6-next-20200724-00051-g89ba619726de #1
[ 1.652693] Hardware name: Raspberry Pi 4 Model B Rev 1.2 (DT)
[ 1.658637] Workqueue: events deferred_probe_work_func
[ 1.663870] pstate: 60000005 (nZCv daif -PAN -UAO BTYPE=--)
[ 1.669542] pc : __cfi_check_fail+0x54/0x5c
[ 1.673798] lr : __cfi_check_fail+0x54/0x5c
[ 1.678050] sp : ffff8000102bbaa0
[ 1.681419] x29: ffff8000102bbaa0 x28: ffffab09e21c7000
[ 1.686829] x27: 0000000000000402 x26: ffff0000f6e7c228
[ 1.692238] x25: 00000000fb7cdb0d x24: 0000000000000005
[ 1.697647] x23: ffffab09e2515000 x22: ffffab09e069a000
[ 1.703055] x21: 4c550309df1cf4c1 x20: ffffab09e2433c60
[ 1.708462] x19: ffffab09e160dc50 x18: ffff0000f6e8cc78
[ 1.713870] x17: 0000000000000041 x16: ffffab09e0bce6f8
[ 1.719278] x15: ffffab09e1c819b7 x14: 0000000000000003
[ 1.724686] x13: 00000000ffffefff x12: 0000000000000000
[ 1.730094] x11: 0000000000000000 x10: 00000000ffffffff
[ 1.735501] x9 : c932f7abfc4bc600 x8 : c932f7abfc4bc600
[ 1.740910] x7 : 077207610770075f x6 : ffff0000f6c38f00
[ 1.746317] x5 : 0000000000000000 x4 : 0000000000000000
[ 1.751723] x3 : 0000000000000000 x2 : 0000000000000000
[ 1.757129] x1 : ffff8000102bb7d8 x0 : 0000000000000032
[ 1.762539] Call trace:
[ 1.765030] __cfi_check_fail+0x54/0x5c
[ 1.768938] __cfi_check+0x5fa6c/0x66afc
[ 1.772932] dwc2_init_params+0xd74/0xd78
[ 1.777012] dwc2_driver_probe+0x484/0x6ec
[ 1.781180] platform_drv_probe+0xb4/0x100
[ 1.785350] really_probe+0x228/0x63c
[ 1.789076] driver_probe_device+0x80/0xc0
[ 1.793247] __device_attach_driver+0x114/0x160
[ 1.797857] bus_for_each_drv+0xa8/0x128
[ 1.801851] __device_attach.llvm.14901095709067289134+0xc0/0x170
[ 1.808050] bus_probe_device+0x44/0x100
[ 1.812044] deferred_probe_work_func+0x78/0xb8
[ 1.816656] process_one_work+0x204/0x3c4
[ 1.820736] worker_thread+0x2f0/0x4c4
[ 1.824552] kthread+0x174/0x184
[ 1.827837] ret_from_fork+0x10/0x18
CFI validates that all indirect calls go to a function with the same
exact function pointer prototype. In this case, dwc2_set_bcm_params
is the target, which has a parameter of type 'struct dwc2_hsotg *',
but it is being implicitly cast to have a parameter of type 'void *'
because that is the set_params function pointer prototype. Make the
function pointer protoype match the definitions so that there is no
more violation.
Fixes: 7de1debcd2de ("usb: dwc2: Remove platform static params")
Link: https://github.com/ClangBuiltLinux/linux/issues/1107
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit 167657a1bb5fcde53ac304ce6c564bd90a2f9185 ]
Make sure xHC completes the configure endpoint command and xhci driver
sets the ring pointers correctly before we create the user readable
debugfs file.
In theory there was a small gap where a user could have read the
debugfs file and cause a NULL pointer dereference error as ring
pointer was not yet set, in practise we want this change to simplify
the upcoming streams debugfs support.
Fixes: 02b6fdc2a153 ("usb: xhci: Add debugfs interface for xHCI driver")
Link: https://lore.kernel.org/r/20200918131752.16488-10-mathias.nyman@linux.intel.com
This is the 5.4.72 stable release
commit 6cf87e5edd9944e1d3b6efd966ea401effc304ee upstream.
There exist many FT2232-based JTAG+UART adapter designs in which
FT2232 Channel A is used for JTAG and Channel B is used for UART.
The best way to handle them in Linux is to have the ftdi_sio driver
create a ttyUSB device only for Channel B and not for Channel A:
a ttyUSB device for Channel A would be bogus and will disappear as
soon as the user runs OpenOCD or other applications that access
Channel A for JTAG from userspace, causing undesirable noise for
users. The ftdi_sio driver already has a dedicated quirk for such
JTAG+UART FT2232 adapters, and it requires assigning custom USB IDs
to such adapters and adding these IDs to the driver with the
ftdi_jtag_quirk applied.
Boutique hardware manufacturer Falconia Partners LLC has created a
couple of JTAG+UART adapter designs (one buffered, one unbuffered)
as part of FreeCalypso project, and this hardware is specifically made
to be used with Linux hosts, with the intent that Channel A will be
accessed only from userspace via appropriate applications, and that
Channel B will be supported by the ftdi_sio kernel driver, presenting
a standard ttyUSB device to userspace. Toward this end the hardware
manufacturer will be programming FT2232 EEPROMs with custom USB IDs,
specifically with the intent that these IDs will be recognized by
the ftdi_sio driver with the ftdi_jtag_quirk applied.
Signed-off-by: Mychaela N. Falconia <falcon@freecalypso.org>
[johan: insert in PID order and drop unused define]
commit 031f9664f8f9356cee662335bc56c93d16e75665 upstream.
This is adds a device id for HP LD381 which is a pl2303GC-base device.
Signed-off-by: Scott Chen <scott@labau.com.tw>
commit 924a9213358fb92fa3c3225d6d042aa058167405 upstream.
This commit adds the following Telit FT980-KS composition:
0x1054: rndis, diag, adb, nmea, modem, modem, aux
AT commands can be sent to /dev/ttyUSB2.
Signed-off-by: Leonid Bloch <lb.workbox@gmail.com>
Link: https://lore.kernel.org/r/ce86bc05-f4e2-b199-0cdc-792715e3f275@asocscloud.com
Link: https://lore.kernel.org/r/20201004155813.2342-1-lb.workbox@gmail.com
commit 3e765cab8abe7f84cb80d4a7a973fc97d5742647 upstream.
Add usb ids of the Cellient MPL200 card.
Signed-off-by: Wilken Gottwalt <wilken.gottwalt@mailbox.org>
Link: https://lore.kernel.org/r/3db5418fe9e516f4b290736c5a199c9796025e3c.1601715478.git.wilken.gottwalt@mailbox.org
This is the 5.4.70 stable release
commit 2b405533c2560d7878199c57d95a39151351df72 upstream.
commit 2b74b0a04d3e ("USB: gadget: f_ncm: add bounds checks to ncm_unwrap_ntb()")
adds important bounds checking however it unfortunately also introduces a
bug with respect to section 3.3.1 of the NCM specification.
wDatagramIndex[1] : "Byte index, in little endian, of the second datagram
described by this NDP16. If zero, then this marks the end of the sequence
of datagrams in this NDP16."
wDatagramLength[1]: "Byte length, in little endian, of the second datagram
wDatagramIndex[1] and wDatagramLength[1] respectively then may be zero but
that does not mean we should throw away the data referenced by
wDatagramIndex[0] and wDatagramLength[0] as is currently the case.
Breaking the loop on (index2 == 0 || dg_len2 == 0) should come at the end
as was previously the case and checks for index2 and dg_len2 should be
removed since zero is valid.
I'm not sure how much testing the above patch received but for me right now
after enumeration ping doesn't work. Reverting the commit restores ping,
scp, etc.
The extra validation associated with wDatagramIndex[0] and
wDatagramLength[0] appears to be valid so, this change removes the incorrect
restriction on wDatagramIndex[1] and wDatagramLength[1] restoring data
processing between host and device.
Fixes: 2b74b0a04d3e ("USB: gadget: f_ncm: add bounds checks to ncm_unwrap_ntb()")
Cc: Ilja Van Sprundel <ivansprundel@ioactive.com>
Cc: Brooke Basile <brookebasile@gmail.com>
Cc: stable <stable@kernel.org>
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Link: https://lore.kernel.org/r/20200920170158.1217068-1-bryan.odonoghue@linaro.org
This is the 5.4.69 stable release
[ Upstream commit 1c0e69ae1b9f9004fd72978612ae3463791edc56 ]
If the SS PHY is in P3, there is no pipe_clk, HW may use suspend_clk
for function, as suspend_clk is slow so EP command need more time to
complete, e.g, imx8M suspend_clk is 32K, set ep configuration will
take about 380us per below trace time stamp(44.286278 - 44.285897
= 0.000381):
configfs_acm.sh-822 [000] d..1 44.285896: dwc3_writel: addr
000000006d59aae1 value 00000401
configfs_acm.sh-822 [000] d..1 44.285897: dwc3_readl: addr
configfs_acm.sh-822 [000] d..1 44.286278: dwc3_readl: addr
000000006d59aae1 value 00000001
configfs_acm.sh-822 [000] d..1 44.286279: dwc3_gadget_ep_cmd:
ep0out: cmd 'Set Endpoint Configuration' [401] params 00001000
00000500 00000000 --> status: Successful
This was originally found on Hisilicon Kirin Soc that need more time
for the device controller to clear the CmdAct of DEPCMD.
Signed-off-by: John Stultz <john.stultz@linaro.org>
[ Upstream commit a7f40c233a6b0540d28743267560df9cfb571ca9 ]
The comparison of hcd->irq to less than zero for an error check will
never be true because hcd->irq is an unsigned int. Fix this by
assigning the int retval to the return of platform_get_irq and checking
this for the -ve error condition and assigning hcd->irq to retval.
Addresses-Coverity: ("Unsigned compared against 0")
Fixes: c856b4b0fdb5 ("USB: EHCI: ehci-mv: fix error handling in mv_ehci_probe()")
Link: https://lore.kernel.org/r/20200515165453.104028-1-colin.king@canonical.com
