path: root/drivers/uwb/Kconfig
2010-10-25uwb: Remove the WLP subsystem and driversDavid Vrabel
The only Wimedia LLC Protocol (WLP) hardware was an Intel i1480 chip with a beta release of firmware that was never commercially available as a product. This hardware and firmware is no longer available as Intel sold their UWB/WLP IP. I also see little prospect of other WLP capable hardware ever being available. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-09-17uwb: depend on EXPERIMENTALDavid Vrabel
The UWB stack has some sysfs APIs that will change thus it's best marked as EXPERIMENTAL until these APIs are finalized. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add the i1480 WLP driverInaky Perez-Gonzalez
Add the driver for the WLP capability of the Intel i1480 device. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add the i1480 DFU driverInaky Perez-Gonzalez
Add the driver for downloading the firmware to an Intel i1480 device. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add WiMedia LLC Protocol (build system)Greg Kroah-Hartman
Add the WLP build system (Kconfig and Kbuild files). Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add HWA radio controller driverInaky Perez-Gonzalez
Add a driver for USB-connected UWB radio controllers (HWAs). Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add whc-rc radio control driverInaky Perez-Gonzalez
Add the driver for WHCI radio controllers. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add the UWB stack (build system)Greg Kroah-Hartman
The Kbuild and Kconfig files. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Vrabel <david.vrabel@csr.com>
