path: root/drivers/uwb/rsv.c
2009-01-23uwb: lock rc->rsvs_lock with spin_lock_bh()David Vrabel
rc->rsvs_lock may be taken in a timer so lock it with spin_lock_bh(). Signed-off-by: David Vrabel <david.vrabel@csr.com>
2009-01-06uwb: safely remove all reservationsDavid Vrabel
When removing all reservations during shutdown, terminate them first and then wait for any pending timeout work to complete. This prevents the timeout work from running after the reservation has been freed. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-12-12uwb: fix oops when terminating an already terminated reservationDavid Vrabel
Calling uwb_rsv_terminate() on a reservation already in UWB_RSV_STATE_NONE should do nothing. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-12-12uwb: improved MAS allocator and reservation conflict handlingStefano Panella
Greatly enhance the MAS allocator: - Handle row and column reservations. - Permit all the available MAS to be allocated. - Follows the WiMedia rules on MAS selection. Take appropriate action when reservation conflicts are detected. - Correctly identify which reservation wins the conflict. - Protect alien BP reservations. - If an owned reservation loses, resize/move it. - Follow the backoff procedure before requesting additional MAS. When reservations are terminated, move the remaining reservations (if necessary) so they keep following the MAS allocation rules. Signed-off-by: Stefano Panella <stefano.panella@csr.com> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-11-19uwb: add basic radio managerDavid Vrabel
The UWB radio manager coordinates the use of the radio between the PALs that may be using it. PALs request use of the radio with uwb_radio_start() and the radio manager will start beaconing if its not already doing so. When the last PAL has called uwb_radio_stop() beaconing will be stopped. In the future, the radio manager will have a more sophisticated channel selection algorithm, probably following the Channel Selection Policy from the WiMedia Alliance when it is finalized. For now, channel 9 (BG1, TFC1) is selected. The user may override the channel selected by the radio manager and may force the radio to stop beaconing. The WUSB Host Controller PAL makes use of this and there are two new debug PAL commands that can be used for testing. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-11-17uwb: add pal parameter to new reservation callbackDavid Vrabel
The pal parameter allows PALs to retrieve their PAL-specific data structure. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-11-07uwb: don't unbind the radio controller driver when resettingDavid Vrabel
Use pre_reset and post_reset methods to avoid unbinding the radio controller driver after a uwb_rc_reset_all() call. This avoids a deadlock in uwb_rc_rm() when waiting for the uwb event thread to stop. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-10-31uwb: remove unused #include <version.h>Huang Weiyi
The file(s) below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/uwb/drp-ie.c drivers/uwb/hwa-rc.c drivers/uwb/i1480/dfu/usb.c drivers/uwb/i1480/i1480u-wlp/lc.c drivers/uwb/i1480/i1480u-wlp/sysfs.c drivers/uwb/rsv.c drivers/uwb/whc-rc.c This patch removes the said #include <version.h>. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-10-28uwb: reference count reservationsDavid Vrabel
Reference counting the struct uwb_rsv's is safer and easier to get right than the transferring ownership of the structures from the PAL to reservation manager. This fixes an oops in the debug PAL after a reservation timed out. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-10-28uwb: target reservations shouldn't get streamsDavid Vrabel
The reservation owner should decide the stream index to use based on what reservations it's created. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add the UWB stack (reservation manager)David Vrabel
DRP and reservation management. Signed-off-by: David Vrabel <david.vrabel@csr.com>
