path: root/drivers/uwb
2015-03-18uwb: Remove umc bus legacy suspend/resume supportLars-Peter Clausen
There are currently no umc drivers implementing suspend/resume, so remove the legacy suspend/resume support from the framework. If a umc driver ever wants to implement suspend/resume they can use dev_pm_ops, which works out of the box without any additional support necessary from the bus itself. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18uwb/whci: Delete an unnecessary check before the function call ↵Markus Elfring
"umc_device_unregister" The umc_device_unregister() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-15Merge tag 'usb-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg KH: "Here's the big pull request for the USB driver tree for 3.20-rc1. Nothing major happening here, just lots of gadget driver updates, new device ids, and a bunch of cleanups. All of these have been in linux-next for a while with no reported issues" * tag 'usb-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (299 commits) usb: musb: fix device hotplug behind hub usb: dwc2: Fix a bug in reading the endpoint directions from reg. staging: emxx_udc: fix the build error usb: Retry port status check on resume to work around RH bugs Revert "usb: Reset USB-3 devices on USB-3 link bounce" uhci-hub: use HUB_CHAR_* usb: kconfig: replace PPC_OF with PPC ehci-pci: disable for Intel MID platforms (update) usb: gadget: Kconfig: use bool instead of boolean usb: musb: blackfin: remove incorrect __exit_p() USB: fix use-after-free bug in usb_hcd_unlink_urb() ehci-pci: disable for Intel MID platforms usb: host: pci_quirks: joing string literals USB: add flag for HCDs that can't receive wakeup requests (isp1760-hcd) USB: usbfs: allow URBs to be reaped after disconnection cdc-acm: kill unnecessary messages cdc-acm: add sanity checks usb: phy: phy-generic: Fix USB PHY gpio reset usb: dwc2: fix USB core dependencies usb: renesas_usbhs: fix NULL pointer dereference in dma_release_channel() ...
2015-02-13usb: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. * drivers/uwb/drp.c::uwb_drp_handle_alien_drp() was formatting mas.bm into a buffer but never used it. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-25uwb: lc-dev: Remove unused functionRickard Strandqvist
Remove the function uwb_dev_addr_bcast() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-03uwb: Remove bogus colon after newline from debug messageGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-23uwb: add an ASIE sysfs attribute to uwb_rc devicesThomas Pugliese
Allow user mode to add and remove application specific information elements (ASIEs) to the beacon of a uwb_rc device. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-23uwb: create a uwb bus type and add in-range peer devices to itThomas Pugliese
Documentation/usb/WUSB-Design-overview.txt states that UWB devices seen by a UWB radio controller are added to /sys/bus/uwb/devices, but this was not actually being done. This functionality is needed in order for UWB peer devices to be enumerated by user mode tools. This patch creates a uwb bus type and adds UWB peer devices to it as they are discovered by the radio controller. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-23uwb: remove UWB build dependency on PCIThomas Pugliese
UWB does not require PCI to be enabled so remove build dependency. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-23uwb: update uwb device prints to be more usefulThomas Pugliese
Print info about the radio controller device instead of the its parent when UWB devices connect and disconnect. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-23uwb: line length cleanupThomas Pugliese
Fix line length in uwb-internal.h Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-08uwb: init beacon cache entry before registering uwb deviceThomas Pugliese
Make sure the uwb_dev->bce entry is set before calling uwb_dev_add in uwbd_dev_onair so that usermode will only see the device after it is properly initialized. This fixes a kernel panic that can occur if usermode tries to access the IEs sysfs attribute of a UWB device before the driver has had a chance to set the beacon cache entry. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-01uwb/whci: use correct structure type name in sizeofJulia Lawall
Correct typo in the name of the type given to sizeof. Because it is the size of a pointer that is wanted, the typo has no impact on compilation or execution. This problem was found using Coccinelle (http://coccinelle.lip6.fr/). The semantic patch used can be found in message 0 of this patch series. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uwb: fix variable set but not used warningsThomas Pugliese
Fix variable set but not used warnings in UWB. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uwb: comment typo fixThomas Pugliese
Comment typo fix. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uwb: whitespace and line length cleanupsThomas Pugliese
Fix whitespace and line length issues reported by checkpatch. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uwb: add error messages when reservation establish failsThomas Pugliese
Add better error messages during the channel change/reservation establish process. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uwb: fix channel change failureThomas Pugliese
Make the transition to the UWB_RSV_STATE_NONE state synchronous so that there is not a race between uwb_rsv_terminate and uwb_rsv_establish. uwb_rsv_terminate would set the rsv->state to UWB_RSV_STATE_NONE but did not release the stream resource until a 320ms timeout had expired. If a user called uwb_rsv_establish during that time, it could fail to establish the reservation because no stream resources were available. This patch removes the timer from the uwb_rsv_terminate process since it is not needed when transitioning to UWB_RSV_STATE_NONE. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-24uwb: don't call spin_unlock_irq in a USB completion handlerThomas Pugliese
This patch converts the use of spin_lock_irq/spin_unlock_irq to spin_lock_irqsave/spin_unlock_irqrestore in uwb_rc_set_drp_cmd_done which is called from a USB completion handler. There are also whitespace cleanups to make checkpatch.pl happy. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16uwb: adds missing error handlingDaeseok Youn
There is checking NULL before dereferncing but it need to add "return". Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20uwb: move mutex_lock to error case in uwbd_evt_handle_rc_bp_slot_changeThomas Pugliese
Only acquire rc->uwb_dev.mutex in the error case in uwbd_evt_handle_rc_bp_slot_change. This fixes a bug where establishing a reservation on a new channel will fail if we were unable to establish a reservation on the previous channel due to DRP conflict. If rc->uwb_dev.mutex is acquired in the non-error case when the uwb system is attempting to start beaconing, it will block because the start beaconing code is holding this mutex. This prevents any other notifications from the URC from being processed. In particular, the DRP_AVAILABILITY notification will not be processed during the start beaconing process which can result in a failure to establish a reservation. It is safe to not hold the mutex in the non-error case since the only other place rc->uwb_dev.beacon_slot is accessed is in the same worker thread that uwbd_evt_handle_rc_bp_slot_change executes in. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20uwb: use uwb_rsv_callback instead of calling rsv->callback directlyThomas Pugliese
Use uwb_rsv_callback wrapper instead of calling rsv->callback directly. uwb_rsv_callback checks for NULL and is used by other callers of the callback routine. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20uwb: whitespace and comment cleanupsThomas Pugliese
various whitespace and comment cleanups Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20uwb: add debug prints during channel change and beacon actionsThomas Pugliese
Add debug prints during channel change and beacon actions. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-19uwb: umc-dev: add missing put_device callLevente Kurusa
This is required so that we give up the last reference to the device. Signed-off-by: Levente Kurusa <levex@linux.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08uwb: Use dev_is_pci() to check whether it is pci deviceYijing Wang
Use PCI standard marco dev_is_pci() instead of directly compare pci_bus_type to check whether it is pci device. Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-07Merge tag 'driver-core-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core / sysfs patches from Greg KH: "Here's the big driver core / sysfs update for 3.13-rc1. There's lots of dev_groups updates for different subsystems, as they all get slowly migrated over to the safe versions of the attribute groups (removing userspace races with the creation of the sysfs files.) Also in here are some kobject updates, devres expansions, and the first round of Tejun's sysfs reworking to enable it to be used by other subsystems as a backend for an in-kernel filesystem. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (83 commits) sysfs: rename sysfs_assoc_lock and explain what it's about sysfs: use generic_file_llseek() for sysfs_file_operations sysfs: return correct error code on unimplemented mmap() mdio_bus: convert bus code to use dev_groups device: Make dev_WARN/dev_WARN_ONCE print device as well as driver name sysfs: separate out dup filename warning into a separate function sysfs: move sysfs_hash_and_remove() to fs/sysfs/dir.c sysfs: remove unused sysfs_get_dentry() prototype sysfs: honor bin_attr.attr.ignore_lockdep sysfs: merge sysfs_elem_bin_attr into sysfs_elem_attr devres: restore zeroing behavior of devres_alloc() sysfs: fix sysfs_write_file for bin file input: gameport: convert bus code to use dev_groups input: serio: remove bus usage of dev_attrs input: serio: use DEVICE_ATTR_RO() i2o: convert bus code to use dev_groups memstick: convert bus code to use dev_groups tifm: convert bus code to use dev_groups virtio: convert bus code to use dev_groups ipack: convert bus code to use dev_groups ...
2013-10-29UWB: clean up attribute use by using ATTRIBUTE_GROUPS()Greg Kroah-Hartman
The ATTRIBUTE_GROUPS() macro can be used in the uwb code to reduce the number of lines of code. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16uwb: convert bus code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct bus_type is going away soon, dev_groups should be used instead. This converts the uwb bus code to use the correct field. Cc: Bruno Morelli <bruno@evidence.eu.com> Cc: <linux-usb@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-19uwb: Staticize local symbolsJingoo Han
These local symbols are used only in this file. Fix the following sparse warnings: drivers/uwb/drp-ie.c:30:5: warning: symbol 'uwb_rsv_reason_code' was not declared. Should it be static? drivers/uwb/drp-ie.c:58:5: warning: symbol 'uwb_rsv_companion_reason_code' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12UWB: fix sysfs warning on HWA device unplug.Thomas Pugliese
In the disconnect routine for the hwa_hc interface, it calls uwb_pal_unregister to unregister itself from the UWB subsystem. This function attempts to clean up the link to the host controller directory in the device's UWB radio control interface directory. If the disconnect routine for the radio control interface has already run, the uwb directory will be gone so the call to sysfs_remove_link generates a warning. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12HWA RC: fix a kernel panic when unplugging the HWA dongleThomas Pugliese
This patch fixes a kernel panic that can occur when unplugging the HWA dongle while a downstream device is in the process of disconnecting. This involved 2 changes. First, call usb_lock_device_for_reset before usb_reset_device to synchronize the HWA's post_rest and disconnect routines. Second, set the hwarc->neep_urb and hwarc->rd_buffer to NULL when they are freed in the error path in the post_reset routine. This prevents a double free when the disconnect routine is called and attempts to free those resources again. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03drivers: avoid format string in dev_set_nameKees Cook
Calling dev_set_name with a single paramter causes it to be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents, including wrappers like device_create*() and bdi_register(). Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-24USB: HWA: fix device probe failureThomas Pugliese
This patch fixes a race condition that caused the HWA_HC interface probe function to occasionally fail. The HWA_HC would attempt to register itself with the HWA_RC by searching for a uwb_rc class device with the same parent device ptr. If the probe function for the HWA_RC interface had yet to run, the uwb_rc class device would not have been created causing the look up to fail and the HWA_HC probe function to return an error causing the device to be unusable. The fix is for the HWA to delay registering with the HWA_RC until receiving the command from userspace to start the wireless channel. It is the responsibility of userspace to ensure that the uwb_rc class device has been created before starting the HWA channel. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-06UWB: HWA: add support for Alereon 5310 and 5611 devicesThomas Pugliese
This patch adds support for the Alereon 5310 and 5611 devices to the HWA-rc driver. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03uwb: use %*ph specifier to dump bufferAndy Shevchenko
In kernel we have nice specifier %*ph to dump small buffers. Let's use it. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-21usb: uwb: use correct locking calls for rc datatpugliese
The rc object's members can be accessed from both a timer and URB callback. Use spin_*_irq instead of spin_*_bh. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-21uwb/whci: Use module_pci_driver to register driverPeter Huewe
Removing some boilerplate by using module_pci_driver instead of calling register and unregister in the otherwise empty init/exit functions. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-29uwb: rename random32() to prandom_u32()Akinobu Mita
Use preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-06driver-core: constify data for class_find_device()Michał Mirosław
All in-kernel users of class_find_device() don't really need mutable data for match callback. In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c) this patch changes match callbacks to use const search data. The const is propagated to rtc_class_open() and power_supply_get_by_name() parameters. Note that there's a dev reference leak in suspend_test.c that's not touched in this patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26uwb: fix uwb_dev_unlock() missed at an error path in uwb_rc_cmd_async()Alexey Khoroshilov
There is the only path in uwb_rc_cmd_async() where rc->uwb_dev is left unlocked. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15drivers/uwb: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25umc-bus.c: fix usage of device_trylockClaudio Scordino
Fix usage of device_trylock. It has the same semantics of mutex_trylock, so it returns 1 if the lock has been acquired successfully. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Bruno Morelli <bruno@evidence.eu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18uwb: fix error handlingOliver Neukum
Fatal errors such as a device disconnect must not trigger error handling. The error returns must be checked. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18uwb: fix use of del_timer_sync() in interruptOliver Neukum
del_timer_sync() cannot be used in interrupt. Replace it with del_timer() and a flag Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23uwb: use for_each_clear_bit()Akinobu Mita
Use for_each_clear_bit() to iterate over all the cleared bit in a memory region. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Stefano Panella <stefano.panella@csr.com> Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-09Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits) USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c xhci: Clean up 32-bit build warnings. USB: update documentation for usbmon usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops drivers/usb/class/cdc-acm.c: clear dangling pointer drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree drivers/usb/host/isp1760-if.c: introduce missing kfree usb: option: add ZD Incorporated HSPA modem usb: ch9: fix up MaxStreams helper USB: usb-skeleton.c: cleanup open_count USB: usb-skeleton.c: fix open/disconnect race xhci: Properly handle COMP_2ND_BW_ERR USB: remove dead code from suspend/resume path USB: add quirk for another camera drivers: usb: wusbcore: Fix dependency for USB_WUSB xhci: Better debugging for critical host errors. xhci: Be less verbose during URB cancellation. xhci: Remove debugging about ring structure allocation. xhci: Remove debugging about toggling cycle bits. xhci: Remove debugging for individual transfers. ...
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-12-09uwb: Use kcalloc instead of kzalloc to allocate arrayThomas Meyer
The advantage of kcalloc is, that will prevent integer overflows which could result from the multiplication of number of elements and size and it is also a bit nicer to read. The semantic patch that makes this change is available in https://lkml.org/lkml/2011/11/25/107 Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
