[ Upstream commit db04264fe9bc0f2b62e036629f9afb530324b693 ]
The SR-IOV spec requires that VFs must report zero for the INTx pin
register as VFs are precluded from INTx support. It's much easier for
the host kernel to understand whether a device is a VF and therefore
whether a non-zero pin register value is bogus than it is to do the
same in userspace. Override the INTx count for such devices and
virtualize the pin register to provide a consistent view of the device
to the user.
As this is clearly a spec violation, warn about it to support hardware
validation, but also provide a known whitelist as it doesn't do much
good to continue complaining if the hardware vendor doesn't plan to
fix it.
Known devices with this issue: 8086:270c
Tested-by: Gage Eads <gage.eads@intel.com>
Reviewed-by: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 30ea32ab1951c80c6113f300fce2c70cd12659e4 ]
Free allocated vdev->msi_perm in error path.
Signed-off-by: Li Qiang <liq3ea@gmail.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
commit cf0d53ba4947aad6e471491d5b20a567cbe92e56 upstream.
MRRS defines the maximum read request size a device is allowed to
make. Drivers will often increase this to allow more data transfer
with a single request. Completions to this request are bound by the
MPS setting for the bus. Aside from device quirks (none known), it
doesn't seem to make sense to set an MRRS value less than MPS, yet
this is a likely scenario given that user drivers do not have a
system-wide view of the PCI topology. Virtualize MRRS such that the
user can set MRRS >= MPS, but use MPS as the floor value that we'll
write to hardware.
[ Upstream commit 523184972b282cd9ca17a76f6ca4742394856818 ]
With virtual PCI-Express chipsets, we now see userspace/guest drivers
trying to match the physical MPS setting to a virtual downstream port.
Of course a lone physical device surrounded by virtual interconnects
cannot make a correct decision for a proper MPS setting. Instead,
let's virtualize the MPS control register so that writes through to
hardware are disallowed. Userspace drivers like QEMU assume they can
write anything to the device and we'll filter out anything dangerous.
Since mismatched MPS can lead to AER and other faults, let's add it
to the kernel side rather than relying on userspace virtualization to
handle it.
Root complex integrated endpoints do not have a link and therefore may
use a smaller PCIe capability in config space than we expect when
building our config map. Add a case for these to avoid reporting an
erroneous overlap.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes:
- add support for PCI on ARM64 boxes with ACPI. We already had this
for theoretical spec-compliant hardware; now we're adding quirks
for the actual hardware (Cavium, HiSilicon, Qualcomm, X-Gene)
- add runtime PM support for hotplug ports
- enable runtime suspend for Intel UHCI that uses platform-specific
wakeup signaling
- add yet another host bridge registration interface. We hope this is
extensible enough to subsume the others
- expose device revision in sysfs for DRM
- to avoid device conflicts, make sure any VF BAR updates are done
before enabling the VF
- avoid unnecessary link retrains for ASPM
- allow INTx masking on Mellanox devices that support it
- allow access to non-standard VPD for Chelsio devices
- update Broadcom iProc support for PAXB v2, PAXC v2, inbound DMA,
etc
- update Rockchip support for max-link-speed
- add NVIDIA Tegra210 support
- add Layerscape LS1046a support
- update R-Car compatibility strings
- add Qualcomm MSM8996 support
- remove some uninformative bootup messages"
* tag 'pci-v4.10-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (115 commits)
PCI: Enable access to non-standard VPD for Chelsio devices (cxgb3)
PCI: Expand "VPD access disabled" quirk message
PCI: pciehp: Remove loading message
PCI: hotplug: Remove hotplug core message
PCI: Remove service driver load/unload messages
PCI/AER: Log AER IRQ when claiming Root Port
PCI/AER: Log errors with PCI device, not PCIe service device
PCI/AER: Remove unused version macros
PCI/PME: Log PME IRQ when claiming Root Port
PCI/PME: Drop unused support for PMEs from Root Complex Event Collectors
PCI: Move config space size macros to pci_regs.h
x86/platform/intel-mid: Constify mid_pci_platform_pm
PCI/ASPM: Don't retrain link if ASPM not possible
PCI: iproc: Skip check for legacy IRQ on PAXC buses
PCI: pciehp: Leave power indicator on when enabling already-enabled slot
PCI: pciehp: Prioritize data-link event over presence detect
PCI: rcar: Add gen3 fallback compatibility string for pcie-rcar
PCI: rcar: Use gen2 fallback compatibility last
PCI: rcar-gen2: Use gen2 fallback compatibility last
PCI: rockchip: Move the deassert of pm/aclk/pclk after phy_init()
Move PCI configuration space size macros (PCI_CFG_SPACE_SIZE and
PCI_CFG_SPACE_EXP_SIZE) from drivers/pci/pci.h to
include/uapi/linux/pci_regs.h so they can be used by more drivers and
eliminate duplicate definitions.
[bhelgaas: Expand comment to include PCI-X details]
Signed-off-by: Wang Sheng-Hui <shhuiw@foxmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
As of commit d97ffe236894 ("PCI: Fix return value from
pci_user_{read,write}_config_*()") it's unnecessary to call
pcibios_err_to_errno() to fixup the return value from these functions.
pcibios_err_to_errno() already does simple passthrough of -errno values,
therefore no functional change is expected.
[aw: changelog]
Signed-off-by: Cao jin <caoj.fnst@cn.fujitsu.com>
We use a BAR restore trick to try to detect when a user has performed
a device reset, possibly through FLR or other backdoors, to put things
back into a working state. This is important for backdoor resets, but
we can actually just virtualize the "front door" resets provided via
PCIe and AF FLR. Set these bits as virtualized + writable, allowing
the default write to set them in vconfig, then we can simply check the
bit, perform an FLR of our own, and clear the bit. We don't actually
have the granularity in PCI to specify the type of reset we want to
do, but generally devices don't implement both PCIe and AF FLR and
we'll favor these over other types of reset, so we should generally
lineup. We do test whether the device provides the requested FLR type
to stay consistent with hardware capabilities though.
This seems to fix several instance of devices getting into bad states
with userspace drivers, like dpdk, running inside a VM.
Reviewed-by: Greg Rose <grose@lightfleet.com>
Signed-off-by: Wei Jiangang <weijg.fnst@cn.fujitsu.com>
The size of the VPD area is not necessarily 4-byte aligned, so a
pci_vpd_read() might return less than 4 bytes. Zero our buffer and
accept anything other than an error. Intel X710 NICs exercise this.
Fixes: 4e1a635552d3 ("vfio/pci: Use kernel VPD access functions")
PCI-Express spec says that reading 4 bytes at offset 100h should return
zero if there is no extended capability so VFIO reads this dword to
know if there are extended capabilities.
However it is not always possible to access the extended space so
generic PCI code in pci_cfg_space_size_ext() checks if
pci_read_config_dword() can read beyond 100h and if the check fails,
it sets the config space size to 100h.
VFIO does its own extended capabilities check by reading at offset 100h
which may produce 0xffffffff which VFIO treats as the extended config
space presense and calls vfio_ecap_init() which fails to parse
capabilities (which is expected) but right before the exit, it writes
zero at offset 100h which is beyond the buffer allocated for
vdev->vconfig (which is 256 bytes) which leads to random memory
corruption.
This makes VFIO only check for the extended capabilities if
the discovered config size is more than 256 bytes.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
If a device is reset without the memory or i/o bits enabled in the
command register we may not detect it, potentially leaving the device
without valid BAR programming. Add an additional test to check the
BARs on each write to the command register.
INTx masking has two components, the first is that we need the ability
to prevent the device from continuing to assert INTx. This is
provided via the DisINTx bit in the command register and is the only
thing we can really probe for when testing if INTx masking is
supported. The second component is that the device needs to indicate
if INTx is asserted via the interrupt status bit in the device status
register. With these two features we can generically determine if one
of the devices we own is asserting INTx, signal the user, and mask the
interrupt while the user services the device.
Generally if one or both of these components is broken we resort to
APIC level interrupt masking, which requires an exclusive interrupt
since we have no way to determine the source of the interrupt in a
shared configuration. This often makes it difficult or impossible to
configure the system for userspace use of the device, for an interrupt
mode that the user may not need.
One possible configuration of broken INTx masking is that the DisINTx
support is fully functional, but the interrupt status bit never
signals interrupt assertion. In this case we do have the ability to
prevent the device from asserting INTx, but lack the ability to
identify the interrupt source. For this case we can simply pretend
that the device lacks INTx support entirely, keeping DisINTx set on
the physical device, virtualizing this bit for the user, and
virtualizing the interrupt pin register to indicate no INTx support.
We already support virtualization of the DisINTx bit and already
virtualize the interrupt pin for platforms without INTx support. By
tying these components together, setting DisINTx on open and reset,
and identifying devices broken in this particular way, we can provide
support for them w/o the handicap of APIC level INTx masking.
Intel i40e (XL710/X710) 10/20/40GbE NICs have been identified as being
broken in this specific way. We leave the vfio-pci.nointxmask option
as a mechanism to bypass this support, enabling INTx on the device
with all the requirements of APIC level masking.
Cc: John Ronciak <john.ronciak@intel.com>
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
Integrated graphics may have their ROM shadowed at 0xc0000 rather than
implement a PCI option ROM. Make this ROM appear to the user using
the ROM BAR.
Typically config space for a device is mapped out into capability
specific handlers and unassigned space. The latter allows direct
read/write access to config space. Sometimes we know about registers
living in this void space and would like an easy way to virtualize
them, similar to how BAR registers are managed. To do this, create
one more pseudo (fake) PCI capability to be handled as purely virtual
space. Reads and writes are serviced entirely from virtual config
space.
Smatch complains about a possible out of bounds error:
drivers/vfio/pci/vfio_pci_config.c:1241 vfio_cap_init()
error: buffer overflow 'pci_cap_length' 20 <= 20
The problem is that pci_cap_length[] was defined as large enough to
hold "PCI_CAP_ID_AF + 1" elements. The code in vfio_cap_init() assumes
it has PCI_CAP_ID_MAX + 1 elements. Originally, PCI_CAP_ID_AF and
PCI_CAP_ID_MAX were the same but then we introduced PCI_CAP_ID_EA in
commit f80b0ba95964 ("PCI: Add Enhanced Allocation register entries")
so now the array is too small.
Let's fix this by making the array size PCI_CAP_ID_MAX + 1. And let's
make a similar change to pci_ext_cap_length[] for consistency. Also
both these arrays can be made const.
The PCI VPD capability operates on a set of window registers in PCI
config space. Writing to the address register triggers either a read
or write, depending on the setting of the PCI_VPD_ADDR_F bit within
the address register. The data register provides either the source
for writes or the target for reads.
This model is susceptible to being broken by concurrent access, for
which the kernel has adopted a set of access functions to serialize
these registers. Additionally, commits like 932c435caba8 ("PCI: Add
dev_flags bit to access VPD through function 0") and 7aa6ca4d39ed
("PCI: Add VPD function 0 quirk for Intel Ethernet devices") indicate
that VPD registers can be shared between functions on multifunction
devices creating dependencies between otherwise independent devices.
Fortunately it's quite easy to emulate the VPD registers, simply
storing copies of the address and data registers in memory and
triggering a VPD read or write on writes to the address register.
This allows vfio users to avoid seeing spurious register changes from
accesses on other devices and enables the use of shared quirks in the
host kernel. We can theoretically still race with access through
sysfs, but the window of opportunity is much smaller.
Acked-by: Mark Rustad <mark.d.rustad@intel.com>
add Kconfig switch to hide INTx
add Kconfig switch to let vfio announce PCI BARs are not mapable
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
In PCIe r1.0, sec 5.10.2, bit 0 of the Uncorrectable Error Status, Mask,
and Severity Registers was for "Training Error." In PCIe r1.1, sec 7.10.2,
bit 0 was redefined to be "Undefined."
Rename PCI_ERR_UNC_TRAIN to PCI_ERR_UNC_UND to reflect this change.
No functional change.
[bhelgaas: changelog]
Signed-off-by: Chen, Gong <gong.chen@linux.intel.com>
When sizing the TPH capability we store the register containing the
table size into the 'dword' variable, but then use the uninitialized
'byte' variable to analyze the size. The table size is also actually
reported as an N-1 value, so correct sizing to account for this.
The round_up() for both TPH and DPA is unnecessary, remove it.
Detected by Coverity: CID 714665 & 715156
These are set of two capability registers, it's pretty much given that
they're registers, so reflect their purpose in the name.
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
Having PCIe/PCI-X capability isn't enough to assume that there are
extended capabilities. Both specs define that the first capability
header is all zero if there are no extended capabilities. Testing
for this avoids an erroneous message about hiding capability 0x0 at
offset 0x100.
Pull vfio updates from Alex Williamson:
"Changes include extension to support PCI AER notification to
userspace, byte granularity of PCI config space and access to
unarchitected PCI config space, better protection around IOMMU driver
accesses, default file mode fix, and a few misc cleanups."
* tag 'vfio-for-v3.10' of git://github.com/awilliam/linux-vfio:
vfio: Set container device mode
vfio: Use down_reads to protect iommu disconnects
vfio: Convert container->group_lock to rwsem
PCI/VFIO: use pcie_flags_reg instead of access PCI-E Capabilities Register
vfio-pci: Enable raw access to unassigned config space
vfio-pci: Use byte granularity in config map
vfio: make local function vfio_pci_intx_unmask_handler() static
VFIO-AER: Vfio-pci driver changes for supporting AER
VFIO: Wrapper for getting reference to vfio_device
Currently, we use pcie_flags_reg to cache PCI-E Capabilities Register,
because PCI-E Capabilities Register bits are almost read-only. This patch
use pcie_caps_reg() instead of another access PCI-E Capabilities Register.
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Devices like be2net hide registers between the gaps in capabilities
and architected regions of PCI config space. Our choices to support
such devices is to either build an ever growing and unmanageable white
list or rely on hardware isolation to protect us. These registers are
really no different than MMIO or I/O port space registers, which we
don't attempt to regulate, so treat PCI config space in the same way.
Reported-by: Gavin Shan <shangw@linux.vnet.ibm.com>
Tested-by: Gavin Shan <shangw@linux.vnet.ibm.com>
The config map previously used a byte per dword to map regions of
config space to capabilities. Modulo a bug where we round the length
of capabilities down instead of up, this theoretically works well and
saves space so long as devices don't try to hide registers in the gaps
between capabilities. Unfortunately they do exactly that so we need
byte granularity on our config space map. Increase the allocation of
the config map and split accesses at capability region boundaries.
The vfio drivers call kmalloc or kzalloc, but do not
include <linux/slab.h>, which causes build errors on
ARM.
Cc: kvm@vger.kernel.org
We give the user access to change the power state of the device but
certain transitions result in an uninitialized state which the user
cannot resolve. To fix this we need to mark the PowerState field of
the PMCSR register read-only and effect the requested change on behalf
of the user. This has the added benefit that pdev->current_state
remains accurate while controlled by the user.
The primary example of this bug is a QEMU guest doing a reboot where
the device it put into D3 on shutdown and becomes unusable on the next
boot because the device did a soft reset on D3->D0 (NoSoftRst-).
We can actually handle MMIO and I/O port from the same access function
since PCI already does abstraction of this. The ROM BAR only requires
a minor difference, so it gets included too. vfio_pci_config_readwrite
gets renamed for consistency.
Even PCIe 1.x had extended config space.
Add PCI device support for VFIO. PCI devices expose regions
for accessing config space, I/O port space, and MMIO areas
of the device. PCI config access is virtualized in the kernel,
allowing us to ensure the integrity of the system, by preventing
various accesses while reducing duplicate support across various
userspace drivers. I/O port supports read/write access while
MMIO also supports mmap of sufficiently sized regions. Support
for INTx, MSI, and MSI-X interrupts are provided using eventfds to
userspace.
