path: root/drivers/vhost
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21vhost: handle wrap around in # of bufs mathShirley Ma
The meth for calculating the # of outstanding buffers gives incorrect results when vq->upend_idx wraps around zero. Fix that. Signed-off-by: Shirley Ma <xma@us.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-21vhost-net: update used ring on backend changeMichael S. Tsirkin
On backend change, we flushed out outstanding skbs but forgot to update the used ring, so that done entries were left in the ubuf_info ring. As a result we lose heads or complete incorrect ones, crashing the guest or leaking memory. Fix by updating the used ring. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-19vhost: optimize interrupt enable/disableMichael S. Tsirkin
As we now only update used ring after enabling the backend, we can write flags with __put_user: as that's done on data path, it matters. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-19vhost: fix zcopy reference countingMichael S. Tsirkin
Fix get/put refcount imbalance with zero copy, which caused qemu to hang forever on guest driver unload. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-19vhost: set log when updating used flags or avail eventJason Wang
We need to log writes when updating used flags and avail event fields. Otherwise the guest may see a stale value after migration and miss notifying the host. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-19vhost: init used ring after backend was setJason Wang
Move the used ring initialization after backend was set. This makes it possible to disable the backend and tweak the used ring, then restart. This will also make it possible to log the used ring write correctly. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-18vhost: vhost TX zero-copy supportMichael S. Tsirkin
>From: Shirley Ma <mashirle@us.ibm.com> This adds experimental zero copy support in vhost-net, disabled by default. To enable, set experimental_zcopytx module option to 1. This patch maintains the outstanding userspace buffers in the sequence it is delivered to vhost. The outstanding userspace buffers will be marked as done once the lower device buffers DMA has finished. This is monitored through last reference of kfree_skb callback. Two buffer indices are used for this purpose. The vhost-net device passes the userspace buffers info to lower device skb through message control. DMA done status check and guest notification are handled by handle_tx: in the worst case is all buffers in the vq are in pending/done status, so we need to notify guest to release DMA done buffers first before we get any new buffers from the vq. One known problem is that if the guest stops submitting buffers, buffers might never get used until some further action, e.g. device reset. This does not seem to affect linux guests. Signed-off-by: Shirley <xma@us.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-30vhost: support event indexMichael S. Tsirkin
Support the new event index feature. When acked, utilize it to reduce the # of interrupts sent to the guest. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-06Correct occurrences ofRob Landley
- Documentation/kvm/ to Documentation/virtual/kvm - Documentation/uml/ to Documentation/virtual/uml - Documentation/lguest/ to Documentation/virtual/lguest throughout the kernel source tree. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-03-13vhost-net: remove unlocked use of receive_queueMichael S. Tsirkin
Use of skb_queue_empty(&sock->sk->sk_receive_queue) without taking the sk_receive_queue.lock is unsafe or useless. Take it out. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-03-13vhost: lock receive queue, not the socketJason Wang
vhost takes a sock lock to try and prevent the skb from being pulled from the receive queue after skb_peek. However this is not the right lock to use for that, sk_receive_queue.lock is. Fix that up. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-03-13vhost-net: Unify the code of mergeable and big buffer handlingJason Wang
Codes duplication were found between the handling of mergeable and big buffers, so this patch tries to unify them. This could be easily done by adding a quota to the get_rx_bufs() which is used to limit the number of buffers it returns (for mergeable buffer, the quota is simply UIO_MAXIOV, for big buffers, the quota is just 1), and then the previous handle_rx_mergeable() could be resued also for big buffers. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-03-13vhost-net: check the support of mergeable buffer outside the receive loopJason Wang
No need to check the support of mergeable buffer inside the recevie loop as the whole handle_rx()_xx is in the read critical region. So this patch move it ahead of the receiving loop. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-03-08vhost: copy_from_user -> __copy_from_userMichael S. Tsirkin
copy_from_user is pretty high on perf top profile, replacing it with __copy_from_user helps. It's also safe because we do access_ok checks during setup. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-03-08vhost: Cleanup vhost.c and net.cKrishna Kumar
Minor cleanup of vhost.c and net.c to match coding style. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-02-01vhost: rcu annotation fixupMichael S. Tsirkin
When built with rcu checks enabled, vhost triggers bogus warnings as vhost features are read without dev->mutex sometimes, and private pointer is read with our kind of rcu where work serves as a read side critical section. Fixing it properly is not trivial. Disable the warnings by stubbing out the checks for now. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-01-10vhost: fix signed/unsigned comparisonMichael S. Tsirkin
To detect that a sequence number is done, we are doing math on unsigned integers so the result is unsigned too. Not what was intended for the <= comparison. The result is user stuck forever in flush call. Convert to int to fix this. Further, get rid of ({}) to make code clearer. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-12-14Merge branch 'vhost-net-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
2010-12-09vhost test moduleMichael S. Tsirkin
This adds a test module for vhost infrastructure. Intentionally not tied to kbuild to prevent people from installing and loading it accidentally. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-12-09vhost: better variable name in loggingMichael S. Tsirkin
We really store a page offset in write_address, so rename it write_page to avoid confusion. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-12-09vhost: correctly set bits of dirty pagesMichael S. Tsirkin
Fix two bugs in dirty page logging: When counting pages we should increase address by 1 instead of VHOST_PAGE_SIZE. Make log_write() correctly process requests that cross pages with write_address not starting at page boundary. Reported-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-12-09vhost: fix typos in commentJason Wang
2010-12-09vhost: remove unused includeMichael S. Tsirkin
vhost.c does not need to know about sockets, don't include sock.h Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-11-25vhost/net: fix rcu check usageMichael S. Tsirkin
Incorrect rcu check was used as rcu isn't done under mutex here. Force check to 1 for now, to stop it from complaining. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-11-04vhost: get/put_user -> __get/__put_userMichael S. Tsirkin
We do access_ok checks on all ring values on an ioctl, so we don't need to redo them on each access. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-11-04vhost: copy_to_user -> __copy_to_userMichael S. Tsirkin
We do access_ok checks at setup time, so we don't need to redo them on each access. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-11-04vhost-net: batch use/unuse mmMichael S. Tsirkin
Move use/unuse mm to vhost.c which makes it possible to batch these operations. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-11-04vhost: put mm after thread stopMichael S. Tsirkin
makes it possible to batch use/unuse mm Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-10-26drivers/vhost/vhost.c: delete double assignmentJulia Lawall
Delete successive assignments to the same location. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression i; @@ *i = ...; i = ...; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-12vhost: fix return code for log_access_ok()Dan Carpenter
access_ok() returns 1 if it's OK otherwise it should return 0. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-10-07Merge commit 'v2.6.36-rc7' into core/rcuIngo Molnar
Merge reason: Update from -rc3 to -rc7. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-10-05vhost: max s/g to match qemuJason Wang
Qemu supports up to UIO_MAXIOV s/g so we have to match that because guest drivers may rely on this. Allocate indirect and log arrays dynamically to avoid using too much contigious memory and make the length of hdr array to match the header length since each iovec entry has a least one byte. Test with copying large files w/ and w/o migration in both linux and windows guests. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-09-22vhost: fix log ctx signallingMichael S. Tsirkin
The log eventfd signalling got put in dead code. We didn't notice because qemu currently does polling instead of eventfd select. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-09-14vhost-net: fix range checking in mrg bufs caseMichael S. Tsirkin
In mergeable buffer case, we use headcount, log_num and seg as indexes in same-size arrays, and we know that headcount <= seg and log_num equals either 0 or seg. Therefore, the right thing to do is range-check seg, not headcount as we do now: these will be different if guest chains s/g descriptors (this does not happen now, but we can not trust the guest). Long term, we should add BUG_ON checks to verify two other indexes are what we think they should be. Reported-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-09-06vhost: error handling fixMichael S. Tsirkin
vhost should set worker to NULL on cgroups attach failure, so that we won't try to destroy the worker again on close. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-09-06vhost: fix attach to cgroups regressionMichael S. Tsirkin
Since 2.6.36-rc1, non-root users of vhost-net fail to attach if they are in any cgroups. The reason is that when qemu uses vhost, vhost wants to attach its thread to all cgroups that qemu has. But we got the API backwards, so a non-priveledged process (Qemu) tried to control the priveledged one (vhost), which fails. Fix this by switching to the new cgroup_attach_task_all, and running it from the vhost thread. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-09-01vhost: stop worker only if createdEric Dumazet
Its currently illegal to call kthread_stop(NULL) Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21vhost: add __rcu annotationsArnd Bergmann
Also add rcu_dereference_protected() for code paths where locks are held. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: "Michael S. Tsirkin" <mst@redhat.com>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-28vhost-net: mergeable buffers supportDavid Stevens
This adds support for mergeable buffers in vhost-net: this is needed for older guests without indirect buffer support, as well as for zero copy with some devices. Includes changes by Michael S. Tsirkin to make the patch as low risk as possible (i.e., close to no changes when feature is disabled). Signed-off-by: David Stevens <dlstevens@us.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2010-07-28vhost: apply cgroup to vhost workersMichael S. Tsirkin
Apply the cgroup of the owner task to the created vhost worker. Based on patches from Sridhar Samudrala's and Tejun Heo. Later we'll need to also apply cpumask and probably priority of the owner process. Discussion on the best way to do this is still ongoing. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Sridhar Samudrala <samudrala.sridhar@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com>
2010-07-28vhost: replace vhost_workqueue with per-vhost kthreadTejun Heo
Replace vhost_workqueue with per-vhost kthread. Other than callback argument change from struct work_struct * to struct vhost_work *, there's no visible change to vhost_poll_*() interface. This conversion is to make each vhost use a dedicated kthread so that resource control via cgroup can be applied. Partially based on Sridhar Samudrala's patch. * Updated to use sub structure vhost_work instead of directly using vhost_poll at Michael's suggestion. * Added flusher wake_up() optimization at Michael's suggestion. Changes by MST: * Converted atomics/barrier use to a spinlock. * Create thread on SET_OWNER * Fix flushing Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Cc: Sridhar Samudrala <samudrala.sridhar@gmail.com>
2010-07-21vhost net: Fix warning.David S. Miller
Reported by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/vhost/net.c net/bridge/br_device.c Fix merge conflict in drivers/vhost/net.c with guidance from Stephen Rothwell. Revert the effects of net-2.6 commit 573201f36fd9c7c6d5218cdcd9948cee700b277d since net-next-2.6 has fixes that make bridge netpoll work properly thus we don't need it disabled. Signed-off-by: David S. Miller <davem@davemloft.net>
