git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (79 commits)
powerpc/8xx: Add support for the MPC8xx based boards from TQC
powerpc/85xx: Introduce support for the Freescale P1022DS reference board
powerpc/85xx: Adding DTS for the STx GP3-SSA MPC8555 board
powerpc/85xx: Change deprecated binding for 85xx-based boards
powerpc/tqm85xx: add a quirk for ti1520 PCMCIA bridge
powerpc/tqm85xx: update PCI interrupt-map attribute
powerpc/mpc8308rdb: support for MPC8308RDB board from Freescale
powerpc/fsl_pci: add quirk for mpc8308 pcie bridge
powerpc/85xx: Cleanup QE initialization for MPC85xxMDS boards
powerpc/85xx: Fix booting for P1021MDS boards
powerpc/85xx: Fix SWIOTLB initalization for MPC85xxMDS boards
powerpc/85xx: kexec for SMP 85xx BookE systems
powerpc/5200/i2c: improve i2c bus error recovery
of/xilinxfb: update tft compatible versions
powerpc/fsl-diu-fb: Support setting display mode using EDID
powerpc/5121: doc/dts-bindings: update doc of FSL DIU bindings
powerpc/5121: shared DIU framebuffer support
powerpc/5121: move fsl-diu-fb.h to include/linux
powerpc/5121: fsl-diu-fb: fix issue with re-enabling DIU area descriptor
powerpc/512x: add clock structure for Video-IN (VIU) unit
Add support for the LCD controller on JZ4740 SoCs.
Cc: linux-fbdev@vger.kernel.org
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1470/
Some SH-Mobile SoCs have an HDMI controller and a PHY, attached to one of their
LCDC interfaces. This patch adds a preliminary static support for such
controllers, this means, that only the 720p mode is handled ATM. Support for
more modes and a dynamic switching between them will be added by a follow up
patch.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Adds support for encoding display mode information
in the device tree using verbatim EDID block.
If the EDID entry in the DIU node is present, the
driver will build mode database using EDID data
and allow setting the display modes from this database.
Otherwise display mode will be set using mode
entries from driver's internal database as usual.
This patch also updates device tree bindings.
Acked-by: Timur Tabi <timur@freescale.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
include/linux/serial_sci.h
Commit f601441916d1e19291d0b4f044b4a7551e2924d0 ("imxfb: add support for
i.MX25:) has inserted the symbol HAVE_FB_IMX, which does not depend on FB
after the menuconfig FB. This breaks the menu, presenting most of the
drivers outside of it, when using menuconfig.
Moving the symbol to the start of the file, just like HAVE_FB_ATMEL, fixes
the problem without breaking it for iMX25 configurations (tested with
ARCH=arm, no build).
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Baruch Siach <baruch@tkos.co.il>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Some SH-mobile SoCs have a MIPI DSI controller, that can be used to connect
MIPI displays to LCDC. This patch adds a platform driver for SH-mobile MIPI DSI
unit. It uses existing hooks in the sh_mobile_lcdcfb.c driver for display
activation and deactivation.
Tested-by: Damian Hobson-Garcia <dhobsong@igel.co.jp>
* 'msm-video' of git://codeaurora.org/quic/kernel/dwalker/linux-msm:
drivers: video: msm: add include msm_mdp.h
drivers: video: msm: default to no
viafb: make procfs entries optional
This patch adds a config option to enable procfs entries for direct
hardware access. This was the old behaviour but the option defaults
to no as this is really ugly and should not be needed if the driver
works correct (and if it doesn't, it needs to be fixed).
That stuff is really something that should
- not be needed at all (the driver should be capable of doing it)
- not be there (debugfs would be better for such things)
So add this option just for backwards compatiblity.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
This is a simple gpiolib driver giving access to the GPIO lines in the
VIA framebuffer system. A simple mechanism exists for switching lines
between GPIO and I2C, but it's only compile-time for now.
Cc: ScottFang@viatech.com.cn
Cc: JosephChan@via.com.tw
Cc: Harald Welte <laforge@gnumonks.org>
Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
It doesn't cure cancer ..
Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
* master.kernel.org:/home/rmk/linux-2.6-arm: (23 commits)
ARM: Fix RiscPC decompressor build errors
ARM: Fix sorting of platform group config options and includes
ARM: 5991/1: Fix regression in restore_user_regs macro
ARM: 5989/1: ARM: KGDB: add support for SMP platforms
ARM: 5990/1: ARM: use __armv5tej_mmu_cache_flush for V5TEJ instead of __armv4_mmu_cache_flush
ARM: Add final piece to fix XIP decompressor in read-only memory
video: enable sh_mobile_lcdc on SH-Mobile ARM
ARM: mach-shmobile: ap4evb SDHI0 platform data V2
ARM: mach-shmobile: sh7372 SDHI vector merge
ARM: mach-shmobile: sh7377 SDHI vector merge
ARM: mach-shmobile: sh7367 SDHI vector merge
ARM: mach-shmobile: G4EVM KEYSC platform data
mtd: enable sh_flctl on SH-Mobile ARM
ARM: mach-shmobile: G3EVM FLCTL platform data
ARM: mach-shmobile: G3EVM KEYSC platform data
Video: ARM CLCD: Better fix for swapped IENB and CNTL registers
ARM: Add L2 cache handling to smp boot support
ARM: 5960/1: ARM: perf-events: fix v7 event selection mask
ARM: 5959/1: ARM: perf-events: request PMU interrupts with IRQF_NOBALANCING
ARM: 5988/1: pgprot_dmacoherent() for non-mmu builds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sunxvr1000: Add missing FB=y depenency.
MAINTAINERS: Add entry for sparc serial drivers.
drivers/serial/sunsab.c: adjust the constant used to initialize the interrupt_mask0 fields
This patch enables the sh_mobile_lcdc driver on
SH-Mobile ARM.
Signed-off-by: Magnus Damm <damm@opensource.se>
sparc64: Add very basic XVR-1000 framebuffer driver.
qlogicpti: Remove slash in QlogicPTI irq name
Acked-by: Frans van Berckel <fberckel@xs4all.nl>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (370 commits)
ARM: S3C2443: Add set_rate and round_rate calls for armdiv clock
ARM: S3C2443: Remove #if 0 for clk_mpll
ARM: S3C2443: Update notes on MPLLREF clock
ARM: S3C2443: Further clksrc-clk conversions
ARM: S3C2443: Change to using plat-samsung clksrc-clk implementation
USB: Fix s3c-hsotg build following Samsung platform header moves
ARM: S3C64XX: Reintroduce unconditional build of audio device
ARM: 5961/1: ux500: fix CLKRST addresses
ARM: 5977/1: arm: Enable backtrace printing on oops when PC is corrupted
ASoC: Fix S3C64xx IIS driver for Samsung header reorg
ARM: S3C2440: Fix plat-s3c24xx move of s3c2440/s3c2442 support
[ARM] pxa: fix typo in mxm8x10.h
[ARM] pxa/raumfeld: set GPIO drive bits for LED pins
[ARM] pxa/zeus: Add support for mcp2515 CAN bus
[ARM] pxa/zeus: Add support for onboard max6369 watchdog
[ARM] pxa/zeus: Add Eurotech as the manufacturer
[ARM] pxa/zeus: Correct the USB host initialisation flags
[ARM] pxa/zeus: Allow usage of 8250-compatible UART in uncompress
[ARM] pxa: refactor uncompress.h for non-PXA uarts
[ARM] mmp2: fix incorrect calling of chip->mask_ack() for 2nd level cascaded IRQs
An LCD controller driver for nuc900s. The Linux LOGO is just fine and the
FB-Test application was ok, too.
Signed-off-by: Wang Qiang <rurality.linux@gmail.com>
Cc: Wang Zongshun <mcuos.com@gmail.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
The config Option FB_SOFT_BUFFER was removed in
c465e05a03209651078b95686158648fd7ed84c5 ("fbcon/fbdev: Move softcursor
out of fbdev to fbcon").
While moving to fbcon this single driver has it left as a select in
KConfig / #ifdef in source. This last occurence is removed here so the
option is really gone
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
The commit also introduces the HAVE_FB_IMX config that is to be selected from
the MX25 platform config. Once this commit gets merged, the two other i.MX
archs, ARCH_MX1 and ARCH_MX2, should follow this one.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Framebuffer driver for the Landscape LCD EZ-Extender (ADZS-BFLLCD-EZEXT)
http://docs.blackfin.uclinux.org/doku.php?id=hw:cards:landscape_lcd_ez-extender
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
* 'for-linus' of git://codeaurora.org/quic/kernel/dwalker/linux-msm:
HTC Dream: mmc compilation fixes
video: Allow selecting MSM framebuffer in Kconfig
Add arm msm maintainer entry
msm: Add memory map for HTC Dream
msm: add minimal board file for HTC Dream device
msm: make debugging UART (for DEBUG_LL) configurable
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux:
MAINTAINERS: Add OMAP2/3 DSS and OMAPFB maintainer
OMAP: SDP: Enable DSS2 for OMAP3 SDP board
OMAP: DSS2: Taal DSI command mode panel driver
OMAP: DSS2: Add generic and Sharp panel drivers
OMAP: DSS2: omapfb driver
OMAP: DSS2: DSI driver
OMAP: DSS2: SDI driver
OMAP: DSS2: RFBI driver
OMAP: DSS2: Video encoder driver
OMAP: DSS2: DPI driver
OMAP: DSS2: DISPC
OMAP: DSS2: Add more core files
OMAP: DSS2: Display Subsystem Driver core
OMAP: DSS2: Documentation for DSS2
OMAP: Add support for VRFB rotation engine
OMAP: Add VRAM manager
OMAP: OMAPFB: add omapdss device
OMAP: OMAPFB: split omapfb.h
OMAP2: Add funcs for writing SMS_ROT_* registers
Allow user to select MSM framebuffer support in Kconfig.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'xen/fbdev' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen pvfb: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers.
fb-defio: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers.
fb-defio: If FBINFO_VIRTFB is defined, do not set VM_IO flag.
Fix toogle whether xenbus driver should be built as module or part of kernel.
Add a Video RAM manager for OMAP 2 and 3 platforms. VRAM manager is used
to allocate large continuous blocks of SDRAM or SRAM. The features VRAM
manager has that are missing from dma_alloc_* functions are:
- Support for OMAP2's SRAM
- Allocate without ioremapping
- Allocate at defined physical addresses
- Allows larger VRAM area and larger allocations
The upcoming DSS2 uses VRAM manager.
VRAM area size can be defined in kernel config, board file or with
kernel boot parameters. Board file definition overrides kernel config,
and boot parameter overrides kernel config and board file.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
Many Atmel SOC are embedding a LCD controller. This patch removes the long
dependency line for this Atmel LCD framebuffer driver configuration entry.
The HAVE_FB_ATMEL configuration option is located in the video Kconfig file
as it may be setup by ARM/AT91 and AVR32 chips.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
The config FB_PRE_INIT_FB entry in drivers/video/Kconfig pushes all entries
below it out of the menuconfig selection. Fix this.
The "select" statement in the Kconfig ensures that all other users
of the xenbus will have the same dependency.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
I would like to get rid of option CONFIG_FB_MATROX_MULTIHEAD and just
always enable it. There are many reasons for doing this:
* CONFIG_FB_MATROX_MULTIHEAD=y is what all x86 distributions do, so it
definitely works or we would know by now.
* Building the matroxfb driver with CONFIG_FB_MATROX_MULTIHEAD not set
results in the following build warning:
drivers/video/matrox/matroxfb_crtc2.c: In function 'matroxfb_dh_open':
drivers/video/matrox/matroxfb_crtc2.c:265: warning: the address of 'matroxfb_global_mxinfo' will always evaluate as 'true'
drivers/video/matrox/matroxfb_crtc2.c: In function 'matroxfb_dh_release':
drivers/video/matrox/matroxfb_crtc2.c:285: warning: the address of 'matroxfb_global_mxinfo' will always evaluate as 'true'
This is nothing to be worried about, the driver will work fine, but build
warnings are still annoying.
* The trick to get multihead support without CONFIG_FB_MATROX_MULTIHEAD,
which is described in the config help text, no longer works: you can't
load the same kernel module more than once.
* I fail to see how CONFIG_FB_MATROX_MULTIHEAD=y would make the code
significantly slower, contrary to what the help text says. A few extra
parameters on the stack here and there can't really slow things down in
comaprison to the rest of the code, and register access.
* The driver built without CONFIG_FB_MATROX_MULTIHEAD is larger than the
driver build with CONFIG_FB_MATROX_MULTIHEAD=y by 8%.
* One less configuration option makes things simpler. We add options
all the time, being able to remove one for once is nice. It improves
testing coverage. And I don't think the Matrox adapters are still
popular enough to warrant overdetailed configuration settings.
* We should be able to unobfuscate the driver code quite a bit after
this change (patches follow.)
Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz>
EP93xx video driver plus documentation.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Daniele Venzano <linux@brownhat.org>
Add LCD controller (LCDC) driver for TI's DA8xx/OMAP-L1xx architecture.
LCDC specifications can be found at http://www.ti.com/litv/pdf/sprufm0a.
LCDC on DA8xx consists of two independent controllers, the Raster
Controller and the LCD Interface Display Driver (LIDD) controller. LIDD
further supports character and graphic displays.
This patch adds support for the graphic display (Sharp LQ035Q3DG01) found
on the DA830 based EVM. The EVM details can be found at:
http://support.spectrumdigital.com/boards/dskda830/revc/.
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Signed-off-by: Pavel Kiryukhin <pkiryukhin@ru.mvista.com>
Signed-off-by: Steve Chen <schen@mvista.com>
Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
DESC
davinci-fb-frame-buffer-driver-for-ti-da8xx-omap-l1xx-fix
EDESC
fix kconfig indenting
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Pavel Kiryukhin <pkiryukhin@ru.mvista.com>
Cc: Steve Chen <schen@mvista.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Add a framebuffer driver for Qualcomm MSM/QSD SoCs, tested on HTC Dream
smartphone (aka T-Mobile G1, aka ADP1).
Brian said:
I did the original quick and dirty version for bringup. Rebecca took
over and (re)wrote the bulk of the driver, getting things stable for
production ship of Dream and Sapphire, and Dima is currently adding
support for later Qualcomm chipsets (QSD8x50, etc).
Cc: Brian Swetland <swetland@google.com>
Cc: Rebecca Schultz Zavin <rebecca@android.com>
Cc: Dima Zavin <dima@android.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (262 commits)
sh: mach-ecovec24: Add user debug switch support
sh: Kill off unused se_skipped in alignment trap notification code.
sh: Wire up HAVE_SYSCALL_TRACEPOINTS.
video: sh_mobile_lcdcfb: use both register sets for display panning
video: sh_mobile_lcdcfb: implement display panning
sh: Fix up sh7705 flush_dcache_page() build.
sh: kfr2r09: document the PLL/FLL <-> RF relationship.
sh: mach-ecovec24: need asm/clock.h.
sh: mach-ecovec24: deassert usb irq on boot.
sh: Add KEYSC support for EcoVec24
sh: add kycr2_delay for sh_keysc
sh: cpufreq: Include CPU id in info messages.
sh: multi-evt support for SH-X3 proto CPU.
sh: clkfwk: remove bogus set_bus_parent() from SH7709.
sh: Fix the indication point of the liquid crystal of AP-325RXA(AP3300)
sh: Add EcoVec24 romImage defconfig
sh: USB disable process is needed if romImage boot for EcoVec24
sh: EcoVec24: add HIZA setting for LED
sh: EcoVec24: write MAC address in boot
sh: Add romImage support for EcoVec24
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits)
PCI hotplug: clean up acpi_run_hpp()
PCI hotplug: acpiphp: use generic pci_configure_slot()
PCI hotplug: shpchp: use generic pci_configure_slot()
PCI hotplug: pciehp: use generic pci_configure_slot()
PCI hotplug: add pci_configure_slot()
PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface
PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge
PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation
PCI: Clear saved_state after the state has been restored
PCI PM: Return error codes from pci_pm_resume()
PCI: use dev_printk in quirk messages
PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset()
PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle
PCI Hotplug: acpiphp: find bridges the easy way
PCI: pcie portdrv: remove unused variable
PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support
ACPI PM: Replace wakeup.prepared with reference counter
PCI PM: Introduce device flag wakeup_prepared
PCI / ACPI PM: Rework some debug messages
PCI PM: Simplify PCI wake-up code
Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree
scanning having been moved and merged for the 32- and 64-bit cases. The
'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support
PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
arch/sh/kernel/vmlinux.lds.S
MAINTAINERS
arch/arm/mm/fault.c
'w90x900' into devel
Background:
Graphic devices are accessed through ranges in I/O or memory space. While most
modern devices allow relocation of such ranges, some "Legacy" VGA devices
implemented on PCI will typically have the same "hard-decoded" addresses as
they did on ISA. For more details see "PCI Bus Binding to IEEE Std 1275-1994
Standard for Boot (Initialization Configuration) Firmware Revision 2.1"
Section 7, Legacy Devices.
The Resource Access Control (RAC) module inside the X server currently does
the task of arbitration when more than one legacy device co-exists on the same
machine. But the problem happens when these devices are trying to be accessed
by different userspace clients (e.g. two server in parallel). Their address
assignments conflict. Therefore an arbitration scheme _outside_ of the X
server is needed to control the sharing of these resources. This document
introduces the operation of the VGA arbiter implemented for Linux kernel.
Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Modify atmel LCD driver: atmel_lcdfb for at91sam9g10. This add a clock
management equivalent to at91sam9261.
Signed-off-by: Hong Xu <hong.xu@atmel.com>
Users get confused by this driver. It's really a special purpose
embedded driver, and causes a lot of problems if enabled. So hide it
under EMBEDDED by default, and make sure it doesn't get enabled with
the i915 DRM driver.
Dave, I'm hoping you can feed this to Linus through your tree. It's
appropriate for 2.6.31 I think.
Signed-off-by: Dave Airlie <airlied@linux.ie>
This deifdefs the driver and adds an explicit HAVE_CLK dependency. Given
that all SH platforms provide it, there is no reason to keep this as an
ifdef. Other architectures that implement support for this driver will
already have to provide clock framework support for timers and so on
already, so adding this as an additional dependency is not terribly
probematic.
Fix this build error when CONFIG_STI_CONSOLE is not set
drivers/video/stifb.c:1337: undefined reference to `sti_get_rom'
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Here are the at91 specific files dedicated to the at91sam9g45 series. They
mimic the traditional at91 way of managing chips & boards.
The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. In
the future, the main board for this 9g45 series will be the
AT91SAM9M10G45-EK (I choose this last name for the board file).
Simple drivers are enabled in _devices and board- files. Newer peripheral
support will be added in future patches.
Incuded peripherals support (for now):
- USART
- SPI
- Ethernet
- NAND flash
- LCD
- gpio/joystick/buttons
- leds and pwm
Do not accept VESA modes by the "vga=" kernel parameter if there is no
frame buffer driver compiled-in to handle it.
Also, there is a comment added to the Kconfig description after Werner
Lemberg's suggestion
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13249
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Reported-by: Werner Lemberg <wl@gnu.org>
Cc: Michal Januszewski <spock@gentoo.org>
The OpenFirmware part of this driver is uncompilable on SPARC due to it's
dependance on several PPC specific functions.
Restricting this to PPC to prevent these build errors:
CC drivers/video/mb862xx/mb862xxfb.o
drivers/video/mb862xx/mb862xxfb.c: In function 'of_platform_mb862xx_probe':
drivers/video/mb862xx/mb862xxfb.c:559: error: implicit declaration of function 'of_address_to_resource'
drivers/video/mb862xx/mb862xxfb.c:575: error: 'NO_IRQ' undeclared (first use in this function)
drivers/video/mb862xx/mb862xxfb.c:575: error: (Each undeclared identifier is reported only once
drivers/video/mb862xx/mb862xxfb.c:575: error: for each function it appears in.)
This was found using randconfig builds.
Signed-off-by: Julian Calaby <julian.calaby@gmail.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (417 commits)
MAINTAINERS: EB110ATX is not ebsa110
MAINTAINERS: update Eric Miao's email address and status
fb: add support of LCD display controller on pxa168/910 (base layer)
[ARM] 5552/1: ep93xx get_uart_rate(): use EP93XX_SYSCON_PWRCNT and EP93XX_SYSCON_PWRCN
[ARM] pxa/sharpsl_pm: zaurus needs generic pxa suspend/resume routines
[ARM] 5544/1: Trust PrimeCell resource sizes
[ARM] pxa/sharpsl_pm: cleanup of gpio-related code.
[ARM] pxa/sharpsl_pm: drop set_irq_type calls
[ARM] pxa/sharpsl_pm: merge pxa-specific code into generic one
[ARM] pxa/sharpsl_pm: merge the two sharpsl_pm.c since it's now pxa specific
[ARM] sa1100: remove unused collie_pm.c
[ARM] pxa: fix the conflicting non-static declarations of global_gpios[]
[ARM] 5550/1: Add default configure file for w90p910 platform
[ARM] 5549/1: Add clock api for w90p910 platform.
[ARM] 5548/1: Add gpio api for w90p910 platform
[ARM] 5551/1: Add multi-function pin api for w90p910 platform.
[ARM] Make ARM_VIC_NR depend on ARM_VIC
[ARM] 5546/1: ARM PL022 SSP/SPI driver v3
ARM: OMAP4: SMP: Update defconfig for OMAP4430
ARM: OMAP4: SMP: Enable SMP support for OMAP4430
