Correct spelling typo in debug messages and comments
within drivers/video.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
If CONFIG_FB_ATY_BACKLIGHT=y but CONFIG_PCI=n:
drivers/video/aty/atyfb_base.c:2272: warning: ‘aty_bl_exit’ defined but not used
If CONFIG_ATARI=y for a modular build:
drivers/video/aty/atyfb_base.c:2794: warning: ‘store_video_par’ defined but not
used
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
There may be multiple ways of controlling the backlight on a given
machine. Allow drivers to expose the type of interface they are
providing, making it possible for userspace to make appropriate policy
decisions.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Alex Deucher <alexdeucher@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
Cc: Greg KH <gregkh@suse.de>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
After commit 25edd6946a1d74e5e77813c2324a0908c68bcf9e ("sparc64: Get
rid of indirect p1275 PROM call buffer.") we can't pass virtual
addresses >4GB to PROM calls.
Largely this is never necessary in drivers because we have a copy of
the entire PROM device tree in the kernel and a set of of_*()
interfaces to access it.
Unfortunately there were some lingering prom calls in the atyfb
driver, in particular prom_finddevice() was being called with an
on-stack address which could be anywhere.
This code is actually probing for information we already have, the
PROM choosen console output device is stored in of_console_device so
all of this nasty code consolidates into a one-line comparison.
Next we have some prom_getintdefault() calls which are trivially
transformed into the equivalent of_getintprop_default().
Special thanks to Fabio, who figured out exactly where the bootup
was hanging. That made this bug trivial to fix.
Reported-by: Fabio M. Di NItto <fabbione@fabbione.net>
Reported-by: Sam Ravnborg <sam@ravnborg.org>
Reported-by: Frans van Berckel <fberckel@xs4all.nl>
Signed-off-by: Fabio M. Di NItto <fabbione@fabbione.net>
backlight_device_register has been expecting a const "ops" argument, and using
it as such, since 9905a43b2d563e6f89e4c63c4278ada03f2ebb14. Let's make the
remaining backlight_ops instances const.
Inspired by hunks of the grsecurity patch, updated for newer kernels.
Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr>
Rather than passing around ints everywhere, use the
phandle type where appropriate for the various functions
that talk to the PROM.
Signed-off-by: Andres Salomon <dilinger@queued.net>
FBIO_WAITFORVSYNC is currently implemented by matroxfb, atyfb, intelfb and
more. All of them keep redefining the same FBIO_WAITFORVSYNC macro over
and over again, so move it to linux/fb.h and clean up those duplicate
defines.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Cc: Ville Syrjala <syrjala@sci.fi>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Maik Broemme <mbroemme@plusserver.de>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: "Hiremath, Vaibhav" <hvaibhav@ti.com>
Values such as max_brightness should be set before backlights are
registered, but the current API doesn't allow that. Add a parameter to
backlight_device_register and update drivers to ensure that they
set this correctly.
Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
machine is compatible is an OF-specific call. It should have
the of_ prefix to protect the global namespace.
Acked-by: Michal Simek <monstr@monstr.eu>
In struct device_node, the phandle is named 'linux_phandle' for PowerPC
and MicroBlaze, and 'node' for SPARC. There is no good reason for the
difference, it is just an artifact of the code diverging over a couple
of years. This patch renames both to simply .phandle.
Note: the .node also existed in PowerPC/MicroBlaze, but the only user
seems to be arch/powerpc/platforms/powermac/pfunc_core.c. It doesn't
look like the assignment between .linux_phandle and .node is
significantly different enough to warrant the separate code paths
unless ibm,phandle properties actually appear in Apple device trees.
I think it is safe to eliminate the old .node property and use
phandle everywhere.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Fix a bunch of coding style problems in atyfb_base.c.
Signed-off-by: Ville Syrjala <syrjala@sci.fi>
Cc: "H Hartley Sweeten" <hartleys@visionengravers.com>
Block writes require 64 byte alignment. Since block writes could be used
with SGRAM or WRAM also refine the memory type detection to check for
either type before deciding to use the 64 byte alignment.
Tested-by: Mikulas Patocka <mpatocka@redhat.com>
Apparently HP OmniBook 500's BIOS doesn't like the way atyfb reprograms
the hardware. The BIOS will simply hang after a reboot. Fix the problem
by restoring the hardware to it's original state on reboot.
Cc: Mikulas Patocka <mpatocka@redhat.com>
This fixes atyfb to properly save the PCI config space -before- it
potentially switches the PM state of the chip. This avoids a
warning with the new PM core and is the right thing to do anyway.
I also slightly cleaned up the code that checks whether we are
running on a PowerMac to do a runtime check instead of a compile
check only, and replaced a deprecated number with the proper
symbolic constant.
Finally, I removed the useless switch to D0 from resume since
the core does it for us.
Fix namespace violations by changing non-kconfig CONFIG_ names to CNFG_*.
Fixes breakage in staging/, which adds a real CONFIG_PANEL.
drivers/video/aty/atyfb_base.c:2663: warning: 'aty_resume_chip' defined
but not used
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Cc: Antonino A. Daplas <adaplas@pol.net>
Cc: Mark Asselstine <asselsm@gmail.com>
The argument to iounmap() is void __iomem *. Fix the cast.
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Properly propagate errors to the probe function.
Convert atyfb to use a PCI device ID table.
Atari probe code relies on correct_chipset() failing if the device is not
a mach64 GX/CX. aty_chips[] array would be indexed with -1 in that case.
Remove dead code. This will slightly change the behaviour of the driver
on systems that support backlight control. Previously they would just
turn the backlight off using the backlight control but now the generic LCD
code will also turn off the LCD using the POWER_MANAGEMENT register.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
drivers/video/aty/atyfb_base.c:3359:26: warning: Using plain integer as NULL pointer
drivers/video/aty/radeon_base.c:2280:32: warning: Using plain integer as NULL pointer
drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer
drivers/video/sis/sis_main.c:5790:44: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Free buffer when the framebuffer can't be registered
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the
checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver
does not use it.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
atyfb: Move the pseudo palette into the card-specific atyfb_par, so it's no
longer shared among multiple cards
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight:
leds: cr_bllcd.c: build fix
backlight: Convert from struct class_device to struct device
backlight: Fix order of Kconfig entries
The current scheme works on static interpretation of text names, which
is wrong.
The output-device setting, for example, must be resolved via an alias
or similar to a full path name to the console device.
Paths also contain an optional set of 'options', which starts with a
colon at the end of the path. The option area is used to specify
which of two serial ports ('a' or 'b') the path refers to when a
device node drives multiple ports. 'a' is assumed if the option
specification is missing.
This was caught by the UltraSPARC-T1 simulator. The 'output-device'
property was set to 'ttya' and we didn't pick upon the fact that this
is an OBP alias set to '/virtual-devices/console'. Instead we saw it
as the first serial console device, instead of the hypervisor console.
The infrastructure is now there to take advantage of this to resolve
the console correctly even in multi-head situations in fbcon too.
Thanks to Greg Onufer for the bug report.
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
The pseudo_palette is only 16 elements long.
Convert the backlight and LCD classes from struct class_device
to struct device since class_device is scheduled for removal.
One nasty API break is the backlight power attribute has had to be
renamed to bl_power and the LCD power attribute has had to be renamed
to lcd_power since the original names clash with the core. I can't see
a way around this.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Fix a regression on Apple iBook1. Changes in the clock init code caused an
incorrect XCLK frequency to be used leading to a corrupted display.
Cc: Olaf Hering <olaf@aepfle.de>
Cc: Antonino Daplas <adaplas@gmail.com>
No need to use asm/pbm.h here.
Laptops with Rage Mobility and 32bit memory interface seem to require halved
XCLK to operate correctly.
Reorganize atyfb clock init code so command line clock overrides are effective
for all chips. The old code would silently ignore some of the command line
clock overrides with some chips.
Coverity Bug 68, kill dead code.
backlight: Allow enable/disable of fb backlights, fixing regressions
backlight: Fix nvidia backlight initial brightness
Fix the following compile error:
MODPOST 327 modules
WARNING: "aty_st_lcd" [drivers/video/aty/atyfb.ko] undefined!
WARNING: "aty_ld_lcd" [drivers/video/aty/atyfb.ko] undefined!
make[1]: *** [__modpost] Error 1
make: *** [modules] Error 2
Enabling the backlight by default appears to cause problems for many
users. This patch disables backlight controls unless explicitly
enabled by users via a module parameter. Since PMAC users are known
to work, default to enabled in that case.
Per device data such as brightness belongs to the indivdual device
and should therefore be separate from the the backlight operation
function pointers. This patch splits the two types of data and
allows simplifcation of some code.
