Bug 873860
Reviewed-on: http://git-master/r/52135
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Tested-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
(cherry picked from commit 92ec78210ee1526dc2c35b7775674105aa6f729b)
Change-Id: If8b1f7af86574af2158609742bc8e18a2585ad36
Reviewed-on: http://git-master/r/61607
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rc3d4771e2f1c7250e7f8eacedfd7dad1790441b5
The mfd core was updated that removed size_t data_size and
renamed void *platform_data to void *mfd_data in struct mfd_cell.
The new mfd API, mfd_get_data(), was added for mfd device.
It return from struct platform_device to right value of mfd_data
and platform_data.
Change-Id: I9b61d0ac0139be840c328fc0b266752d27815cf5
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/54912
Rebase-Id: Rc0b7b7d376c1bab14eab86a9bdfa4cd5b970bbf8
tegra-pwm-backlight now has a notify function that enables the
brightness to be passed back to the boardfile where it is modified.
Bug 854820
Original-Change-Id: I1425d801f77987485b58c3cbedae464b5db88444
Reviewed-on: http://git-master/r/42639
Rebase-Id: R156ca05e91b04723146628b1b1abcef31a43795a
Set PWM pin to SFIO before it is configured to DC output pin:
Having too early SFIO setting for this pin makes black screen
in display transition from bootloader to kenel and android
since backlight can be turned off.
Bug 858120
Original-Change-Id: I952aa73c50d1df57b1cedf0a5f9ffee0044048ea
Reviewed-on: http://git-master/r/44304
Rebase-Id: R89903c1f14f1b867638834bd1581d8637b079c94
Original-Change-Id: I43036163f62c33f29c915fd4fe37ea10f71dfb55
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Re7c21b8cced25ed6e4038929a0f80892ec91b9a1
Change aat2870_bl suspend and resume event source to backlight driver
from platform driver.
Clean-up codes.
Bug 813111
Change-Id: If04b77bf0c3c3118f05107db6ffeaea7a21cdfac
Reviewed-on: http://git-master/r/35390
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: Rd0d57cb8166b138754e374dbbc47ab011c30d13d
Supporting the dc pwm based backlight control for TEGRA3
SOC.
bug 831073
Original-Change-Id: I21e430e28472285636612b71732a8b94e609bb91
Reviewed-on: http://git-master/r/34734
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Hoang Pham <hopham@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: Re9ee1077cf2c77017472740ac7bc50e4dc7e3ce8
bug 773671
Original-Change-Id: Ib93f0dcb7e22220fe297c81d403c401548f3c649
Reviewed-on: http://git-master/r/18280
Tested-by: Joseph Lehrer <jlehrer@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R3ddd56d2d3df9d9a78b2e8ccbfd0cd64e824ab2f
Since backlight_types[] isn't modified, let's declare it const. That
was probably the intention of the author of commit bb7ca747f8d6
("backlight: add backlight type"), via which the "const char const *"
construct was introduced. The duplicate const was detected by sparse.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
This is an i2c driver, not a platform driver, thus use "i2c" prefix for
the module alias.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
We need a callback to do some things after pwm_enable, pwm_disable
and pwm_config.
Signed-off-by: Dilan Lee <dilee@nvidia.com>
Reviewed-by: Arun Murthy <arun.murthy@stericsson.com>
ep93xx_bl.c uses interfaces from linux/module.h, so it should include
that file. This patch fixes build errors:
CC [M] drivers/video/backlight/ep93xx_bl.o
drivers/video/backlight/ep93xx_bl.c:138: error: 'THIS_MODULE' undeclared here (not in a function)
drivers/video/backlight/ep93xx_bl.c:158: error: expected declaration specifiers or '...' before string constant
drivers/video/backlight/ep93xx_bl.c:158: warning: data definition has no type or storage class
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Ryan Mallon <rmallon@gmail.com>
i386 allmodconfig:
drivers/built-in.o: In function `aat2870_bl_remove':
aat2870_bl.c:(.text+0x414f9): undefined reference to `backlight_device_unregister'
drivers/built-in.o: In function `aat2870_bl_probe':
aat2870_bl.c:(.text+0x418fc): undefined reference to `backlight_device_register'
aat2870_bl.c:(.text+0x41a31): undefined reference to `backlight_device_unregiste
Cc: Jin Park <jinyoungp@nvidia.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Axel Lin <axel.lin@gmail.com>
- Current implementation tests wrong value for setting
aat2870_bl->max_current.
- In the current implementation, we cannot differentiate between 2 cases:
a) if pdata->max_current is not set , or
b) pdata->max_current is set to AAT2870_CURRENT_0_45 (which is also 0).
Fix it by setting AAT2870_CURRENT_0_45 to be 1 and adjust the equation in
aat2870_brightness() accordingly.
Tested-by: Jin Park <jinyoungp@nvidia.com>
backlight_device_register() returns ERR_PTR() on error.
Add backlight driver for AnalogicTech AAT2870.
registered
Since commit a19a6ee "backlight: Allow properties to be passed at
registration" and commit bb7ca74 "backlight: add backlight type", we can
set backlight type and max_brightness before backlights are registered.
Some newly added drivers did not set it properly, let's fix it.
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Donghwa Lee <dh09.lee@samsung.com>
Cc: InKi Dae <inki.dae@samsung.com>
Add the ams369fg06 amoled panel driver. The ams369fg06 amoled panel (480
x 800) driver uses 3-wired SPI inteface. The brightness can be controlled
by gamma setting of amoled panel.
[sfr@canb.auug.org.au: fix build error]
[axel.lin@gmail.com: unregister backlight device when unloading the module]
[axel.lin@gmail.com: staticize ams369fg06_shutdown]
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: anish singh <anish198519851985@gmail.com>
max_brightness
We have set props.max_brightness before registering backlight device.
- Fix checking of wrong return value for backlight_device_register()
- Properly free allocated resources in ld9040_probe() error path and
ld9040_remove().
Cc: Michael Hennerich <michael.hennerich@analog.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
With the addition of a platform device mfd_cell pointer, MFD drivers
can go back to passing platform back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com>
It should check if strict_strtoul() succeeds.
[akpm@linux-foundation.org: don't override strict_strtoul() return value]
Signed-off-by: Liu Yuan <tailai.ly@taobao.com>
Haavard's e-mail address at Atmel is no longer valid.
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Copy 88pm860x platform data into different mfd_data structure for
backlight driver. So move the identification of device node from
backlight driver to mfd driver.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
In systems with multiple framebuffer devices, one of the devices might be
blanked while another is unblanked. In order for the backlight blanking
logic to know whether to turn off the backlight for a particular
framebuffer's blanking notification, it needs to be able to check if a
given framebuffer device corresponds to the backlight.
This plumbs the check_fb hook from core backlight through the
pwm_backlight helper to allow platform code to plug in a check_fb hook.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Cc: Arun Murthy <arun.murthy@stericsson.com>
Cc: Linus Walleij <linus.walleij@stericsson.com>
The following symbols are needlessly defined global: jornada_bl_init,
jornada_bl_exit, jornada_lcd_init, jornada_lcd_exit.
Make them static.
Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
apple_bl uses ACPI interfaces (data & code), so it should depend on ACPI.
drivers/video/backlight/apple_bl.c:142: warning: 'struct acpi_device' declared inside parameter list
drivers/video/backlight/apple_bl.c:142: warning: its scope is only this definition or declaration, which is probably not what you want
drivers/video/backlight/apple_bl.c:201: warning: 'struct acpi_device' declared inside parameter list
drivers/video/backlight/apple_bl.c:215: error: variable 'apple_bl_driver' has initializer but incomplete type
drivers/video/backlight/apple_bl.c:216: error: unknown field 'name' specified in initializer
Acked-by: Matthew Garrett <mjg@redhat.com>
It works on hardware other than Macbook Pros, and it works on GPUs other
than Nvidia. It should even work on iMacs, so change the name to match
reality more precisely and include an alias so existing users don't get
confused.
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Cc: Mourad De Clerck <mourad@aquazul.com>
The SMI-based backlight control functionality may fail to work if the
system is running under EFI rather than BIOS. Check that the hardware
responds as expected, and exit if it doesn't.
This driver only has to deal with two different classes of hardware, but
right now it needs new DMI entries for every new machine. It turns out
that there's an ACPI device that uniquely identifies Apples with backlights,
so this patch reworks the driver into an ACPI one, identifies the hardware
by checking the PCI vendor of the root bridge and strips out all the DMI
code. It also changes the config text to clarify that it works on devices
other than Macbook Pros and GPUs other than nvidia.
There may be multiple ways of controlling the backlight on a given
machine. Allow drivers to expose the type of interface they are
providing, making it possible for userspace to make appropriate policy
decisions.
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Alex Deucher <alexdeucher@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Add a ld9040 amoled panel driver.
Signed-off-by: Donghwa Lee <dh09.lee@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Fix collision with kernel-supplied #define:
drivers/video/backlight/88pm860x_bl.c:24:1: warning: "CURRENT_MASK" redefined
arch/x86/include/asm/page_64_types.h:6:1: warning: this is the location of the previous definition
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: <stable@kernel.org>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
The reset command is part of the init sequence and it take effect
only if the lcd is powered.
The effect of the bug was that the sequence:
set lcd power_state to FB_BLANK_POWERDOWN
set lcd power_state to FB_BLANK_UNBLANK
Did not produced a complete reboot of the LCD which was showing fuzzy
colours.
This was not experienced before implementing correctly all the LCD power
states with the patch [1]. Since before the patch [1] the regulators were
not touched and the LCD shutdown was reached with a register write. After
the patch [1] a complete boot sequence with an initial reset is needed for
the display every time the LCD is powered up.
drivers-video-backlight-l4f00242t03c-full-implement-fb-power-states-for-this-lcd.patch
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
enable/disable
Otherwise a double call to:
$ echo 4 > /sys/class/lcd/l4f00242t03/lcd_power
Will, the first power down the lcd and regulators correctly and the
second produce an unbalanced call to regulator disable.
this lcd
Complete the support of fb power states managing correctly the regulators
bound to this driver.
Fixes sparse warning:
drivers/video/backlight/l4f00242t03.c:28:21: error: dubious one-bit signed bitfield
Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Cc: Thomas Hellstrom <thomas@tungstengraphics.com>
Cc: Alan Hourihane <alanh@tungstengraphics.com>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
According to the comment describing ops_lock in the definition of struct
backlight_device and when comparing with other functions in backlight.c
the mutex must be hold when checking ops to be non-NULL.
Fixes a problem added by c835ee7f4154992e6 ("backlight: Add suspend/resume
support to the backlight core") in Jan 2009.
backlight_device_register has been expecting a const "ops" argument, and using
it as such, since 9905a43b2d563e6f89e4c63c4278ada03f2ebb14. Let's make the
remaining backlight_ops instances const.
Inspired by hunks of the grsecurity patch, updated for newer kernels.
Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr>
Add support for the MacBookAir3,1 and MacBookAir3,2 to the mbp-nvidia-bl
driver.
Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com>
Handle return value, strict_strtoul is declared with attribute
warn_unused_result.
This affects the get/set of the current Ambient Light Zone. Reading
should return an integer between 1..3 (1 = Daylight, 2 = office, 3 =
dark). Writing a value between 1..3 forces the backlight controller to
enter the corresponding Ambient Light Zone. Writing 0 returns to normal
operation.
Fix valid range checking so we don't write invalid values to the
controller, and make sure we subtract 1, since this is what the register
definition (CFGR:BLV) requires. Otherwise the values written don't work
correctly.
The intensity of the backlight can be varied from a range of
max_brightness to zero. Though most, if not all the pwm based backlight
devices start flickering at lower brightness value. And also for each
device there exists a brightness value below which the backlight appears
to be turned off though the value is not equal to zero.
If the range of brightness for a device is from zero to max_brightness. A
graph is plotted for brightness Vs intensity for the pwm based backlight
device has to be a linear graph.
intensity
0 max_brightness
But pratically on measuring the above we note that the intensity of
backlight goes to zero(OFF) when the value in not zero almost nearing to
zero(some x%). so the graph looks like
intensity
0 x max_brightness
In order to overcome this drawback knowing this x% i.e nothing but the low
threshold beyond which the backlight is off and will have no effect, the
brightness value is being offset by the low threshold value(retaining the
linearity of the graph). Now the graph becomes
intensity
0 max_brightness
With this for each and every digit increment in the brightness from zero
there is a change in the intensity of backlight. Devices having this
behaviour can set the low threshold brightness(lth_brightness) and pass
the same as platform data else can have it as zero.
Signed-off-by: Arun Murthy <arun.murthy@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
