path: root/drivers/video/cirrusfb.c
2010-05-17m68k: amiga - Zorro bus modalias supportGeert Uytterhoeven
Add Amiga Zorro bus modalias and uevent support Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-13cirrusfb: do not allow unsupported pixel depthKrzysztof Helt
Do not allow modes with unsupported pixel depth. Otherwise, one can hang a computer by setting incorrect value with fbset command. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: fix interlaced modesKrzysztof Helt
Fix calculations of timings for interlaced modes. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: fix threshold register mask for Laguna chipsKrzysztof Helt
Fix threshold register mask for Laguna chips otherwise some 8bpp modes are garbled after selecting a 24bpp mode. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: GD5434 (aka SD64) support fixedKrzysztof Helt
Fix handling of the Cirrus Logic GD5434 chip. Distinguish this chip from the GD5430. It allows detecting memory size for both models correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: set MCLK in one placeKrzysztof Helt
A memory clock (MCLK) is set at various places. Move the setting into one place. Set the MCLK only for Zorro cards as the x86 cards should be initialized by BIOS. Improve handling of the GD5434 (SD64). Kill one annoying debug output "virtual offset: ...". Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: add accelerator constantKrzysztof Helt
Add an accelerator constant so almost all Cirrus are recognized as accelerators by the fbset command. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: fix clock doublingKrzysztof Helt
Cirrus' Alpine and Picasso4 chips uses DAC clock doubling to achieve full range of pixclock frequencies. [akpm@linux-foundation.org: fix spelling, use usual comment layout] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: use 24bpp instead of 32bppKrzysztof Helt
The 32bpp is supported only on the latest Cirrus Logic chips. Use the 24bpp which is supported at least since Alpine chips (GD543x). Change 32bpp mode setting to 24bpp mode. Change acceleration as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: GD5446 fixesKrzysztof Helt
Various fixes to make Cirrus GD5446 chip work. Another Cirrus chip works with the cirrusfb. The gd5446 seems very similar to Alpine chips. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: fix error paths in cirrusfb_xxx_register()Krzysztof Helt
Balance iomap and iounmap and alloc and free calls in case of error druing device register (probing). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: add imageblit functionKrzysztof Helt
Add hardware color expansion (imageblit) function. It roughly doubles scrolling speed of my Alpine card (GD5430). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: acceleration improvementsKrzysztof Helt
- Fix color expansion for 16bpp and 32bpp modes in the cirrusfb_RectFill(). - Make a function with a common blitter code (cirrusfb_set_blitter). - Add fb_sync function to allow a higher layer synchronize with the blitter. - Kill one redundant blitter reset. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: various Laguna fixesKrzysztof Helt
- The Laguna GD5465 (AGP) has one register more than non-AGP chips. Recognize the AGP version and write a tile control register only on the AGP version. Tested only on an AGP card. - Bump up RAMDAC frequencies after X11 code. This allow to drive a flat panel resolution 1680x1050 at 16bpp from the 4MB card. - Fix screen start address overflow bits on Laguna cards (CRT1D register). - Fix exit path in the cirrusfb_pci_register() in case of error. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: check_var improvementsKrzysztof Helt
Break cirrusfb_decode_var() function into two parts: cirrusfb_check_pixclock() which can be called from the cirrusfb_check_var() aand merge rest into the cirrusfb_set_par_foo(). This allows rejecting modes with too high pixclock before before any change to hardware state (and a console is messed up). Also, fix RGB field's lengths for 8bpp modes to correct ones so X11 works with fbdev driver with cirrusfb. Kill some redundant function calls or register loads. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: Laguna chipset 8bpp fixKrzysztof Helt
Fix 8bpp mode by adding handling of the Laguna chipsets to various places and stop trashing a HDR register which probably does not exist on the Laguna. Fix compilation warnings about uninitialized variables also. Finally, all 8bpp, 16bpp and 32bpp modes work on the Laguna chipset. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: various improvementsKrzysztof Helt
Various improvements to the code: - kill a structure with only one field: multiplexing and use the field directly - move the cirrusfb_ops structure down the file to kill forward declarations - move cirrusfb_init() to kill forward declaration - kill register loads done already in the init_vgachip() - kill assigments done by higher layer in the cirrusfb_pan_display() - do not overwrite line pitch bit in the CL_CRT1D register - kill btype variables if they were used only once or twice - add cpu_relax() in the busy waiting loop The fix to the CL_CRT1D register handling makess the 1024x768 32bpp mode work. Previously, only lower resolution modes have worked with 32bpp. Signed-off-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: use 5-6-5 RGB for 16bpp modeKrzysztof Helt
Use the 5-6-5 RGB mode instead of the 5-5-5 mode at 16bpp depth. It fixes colors in the 16bpp modes on Cirrus Laguna chips. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Cc: Arthur Marsh <arthur.marsh@internode.on.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: do not calculate line length twiceKrzysztof Helt
A line length is calculated twice: first in the cirrusfb_decode_var() then in the cirrusfb_set_par_foo(). Use the first calculated value. A nice side effect is that 32bpp mode works now. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Cc: Arthur Marsh <arthur.marsh@internode.on.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: add mmio registers for Laguna chipsetsKrzysztof Helt
The Laguna chipsets use special registers which are available through the mmio area. The cirrusfb driver does not use memory mapped registers for the PCI cards. Add the memory mapped area for Laguna chipsets and add basic usage of the special Laguna registers after SVGALIB code. This gives readable console at 16bpp on the GD-5465 (Laguna AGP). The 8bpp and 32bpp depths are still broken. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: add Laguna additional overflow registerKrzysztof Helt
Add additional overflow register setting for Laguna chips. Also, simplify some code in the cirrusfb_pan_display() and cirrusfb_blank(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: fix Laguna chipset memory detection and clock settingKrzysztof Helt
Fix memory detection and clock setting for Cirrus Laguna chipsets (GD5464/GD5465). The changes are done after the Xorg code. The driver still does not display anything on the GD5465 but it switches resolutions correctly at least. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: convert printks to dev_fooKrzysztof Helt
Convert all printks to dev_dbg, dev_info or dev_err. Kill some excessive debug information and code in the process. [akpm@linux-foundation.org: printk fixes] [akpm@linux-foundation.org: cleanups] Signed-off-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19cirrusfb: remove unused variablesVlada Peric
After commit a1d35a7a (cirrusfb: use modedb and add mode_option parameter), these variables are no longer used, so remove them to fix compilation warning. Signed-off-by: Vlada Periæ <vlada.peric@gmail.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-01section fixes for cirrusfbAl Viro
cirrusfb_zorro_unmap() may be called both from __devexit and (on cleanup path) from __devinit. So it needs to be a normal function, same as for cirrusfb_pci_unmap() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: do not change MCLK for Alpine chipsKrzysztof Helt
A memory clock value (MCLK) is changed to a minimum required by a current mode bandwidth. This usually lowers the MCLK to its minimum (50 MHz) thus decreasing the card performance. Just leave the MCLK value set by card BIOS. The CL-GD5446 Technical Reference Manual point 9.9.1.3 states that if a pixclock value is close (~1%) to the MCLK or MCLK/2 this may result in a jitter on the screen. A countermeasure is to use the MCLK as pixclock source instead of a VCLK. The patch implements this as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: fix 16bpp modesKrzysztof Helt
The 16bpp mode did not work on the Cirrus cards as the visual type was set to DIRECTCOLOR instead of TRUECOLOR. The Alpine family used one incorrect register setting so this 16bpp modes generated wrong horizontal frequency. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: add noaccel module parameterKrzysztof Helt
The noaccel parameter is already handled if the driver is not built as module. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: drop clock fields from cirrusfb_regs structureKrzysztof Helt
Move call to pixclock calculation into the cirrusfb_set_par_foo(). It makes copy of clock registers redundant. Simplify clock calculations further. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: eliminate CRT registers from global structureKrzysztof Helt
Move calculations of CRT register values into the cirrusfb_set_par_foo() where the values are used. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: add __devinit attribute to probing functionsKrzysztof Helt
Add __devinit attribute to probing functions. This fixed section mismatch warning from my previous patch. Kill one redundant forward declaration. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: use modedb and add mode_option parameterKrzysztof Helt
Use modedb for initial mode instead of table of few predefined modes. Add mode_option module parameter as a step toward unification of frame buffers' parameters. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: drop device pointers from cirrusfb_infoKrzysztof Helt
The device pointer can be easily obtained from fb_info->device if needed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: remove 24 bpp modeKrzysztof Helt
The 24 bpp mode is not implemented. Disallow it in the cirrusfb_check_var() and remove it from checks. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: simplify clock calculationKrzysztof Helt
Simplify clock calculation. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16cirrusfb: remove information about memory size during mode changeKrzysztof Helt
Remove information about memory size displayed twice each time a display mode change. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02cirrusfb: check_par fixesKrzysztof Helt
1. Check if virtual resolution fits into memory. Otherwise, Linux hangs during panning. 2. When selected use all available memory to maximize yres_virtual to speed up panning (previously also xres_virtual was increased). 3. Simplify memory restriction calculations. Signed-off-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12drivers/video/cirrusfb: fix RAM address printkPhilippe De Muyter
In the cirrusfb driver, the RAM address printk has a superfluous 'x' that could be interpreted as "don't care", while it is actually a typo. Fix that. [akpm@linux-foundation.org: join the two printk strings to make it atomic] Signed-off-by: Philippe De Muyter <phdm@macqel.be> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: use DIV_ROUND_UP or roundupJulia Lawall
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) / (d)) but is perhaps more readable. An extract of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression n,d; @@ ( - (n + d - 1) / d + DIV_ROUND_UP(n,d) | - (n + (d - 1)) / d + DIV_ROUND_UP(n,d) ) @depends on haskernel@ expression n,d; @@ - DIV_ROUND_UP((n),d) + DIV_ROUND_UP(n,d) @depends on haskernel@ expression n,d; @@ - DIV_ROUND_UP(n,(d)) + DIV_ROUND_UP(n,d) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-27cirrusfb nonsenseAl Viro
(pointer > 0) is deeply weird; (pointer >= 0) is even dumber... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fix cirrusfb breakageAl Viro
2007-10-16cirrusfb: code improvement 2nd partKrzysztof Helt
This patch removes: - redundant fields from the cirrusfb_regs structure - one redundant header - fixes two includes ("" to <>) Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16cirrusfb: code improvementsKrzysztof Helt
This patch does some "short-range" code improvements like merging identical switch clauses, replacing conditional branches with calculation of values, merging only once-used functions into place they are called from. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16cirrusfb: remove fields from cirrusfb_infoKrzysztof Helt
This patch removes unused or redundant fields from cirrusfb_info structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16cirrusfb: remove typedefsKrzysztof Helt
This patch replaces "typedef enum" with "enum type" constructs. Using the typedef is error for the checkpatch.pl script. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16cirrusfb: checkpatch.pl cleanupKrzysztof Helt
This patch fixes over 850 errors and warnings pointed out by the checkpatch.pl script. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08cirrusfb: convert to generic booleanRichard Knutsson
Convert to generic boolean. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ioremap balanced with iounmap for drivers/video/cirrusfbAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
