path: root/drivers/video/cobalt_lcdfb.c
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-03cocbalt_lcdfb: correct sectionsHenrik Kretzschmar
Since the drivers probe call was changed from .init.text to .devinit.text in commit c2e13037e6794bd0d9de3f9ecabf5615f15c160b the fb_fix_screeninfo structure must be changed from .init.data to .devinit.data, too. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Tested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-07platform-drivers: move probe to .devinit.text in drivers/videoUwe Kleine-König
A pointer to a probe callback is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Adrian Bunk <bunk@stusta.de> Cc: Alberto Mardegan <mardy@users.sourceforge.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andriy Skulysh <askulysh@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Frans Pop <elendil@planet.nl> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Helge Deller <deller@gmx.de> Cc: Huang Ying <ying.huang@intel.com> Cc: Ian Molton <spyro@f2s.com> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Kaj-Michael Lang <milang@tal.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Magnus Damm <damm@igel.co.jp> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Roland Stigge <stigge@antcom.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Vincent Sanders <vince@simtec.co.uk> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: James Simmons <jsimmons@infradead.org> Acked-by: Peter Jones <pjones@redhat.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-03Update Yoichi Yuasa's e-mail addressYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-24fbdev: add new Cobalt LCD framebuffer driverYoichi Yuasa
Add new Cobalt LCD framebuffer driver. [akpm@linux-foundation.org: fix build] Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
