Remove fb_save_state() and fb_restore_state operations from frame buffer layer.
They are used only in two drivers:
1. savagefb - and cause bug #11248
2. uvesafb
Usage of these operations is misunderstood in both drivers so kill these
operations, fix the bug #11248 and avoid confusion in the future.
Tested on Savage 3D/MV card and the patch fixes the bug #11248.
The frame buffer layer uses these funtions during switch between graphics
and text mode of the console, but these drivers saves state before
switching of the frame buffer (in the fb_open) and after releasing it (in
the fb_release). This defeats the purpose of these operations.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Reported-by: Jochen Hein <jochen@jochen.org>
Tested-by: Jochen Hein <jochen@jochen.org>
Cc: Michal Januszewski <spock@gentoo.org>
Attempting to unload a framebuffer module calls unregister_framebuffer()
which in turn gets fbcon to release it. If fbcon has no framebuffers
linked to a console, it will also unbind itself from the console driver.
However, if fbcon never registered itself as a console driver, the unbind
will fail causing the framebuffer device entry to persist. In most cases
this failure will result in an oops when attempting to access the now
non-existent device.
This patch ensures that the fbcon unbind request will succeed even if a
bind was never done. It tracks if a successful bind ever occurred & will
only attempt to unbind if needed. If there never was a bind, it simply
returns with no error.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: <stable@kernel.org>
At the moment about half of the framebuffer drivers can return an error
code in fb_set_par. Until now it would be silently ignored by fbmem.c
and fbcon.c. This patch fixes fbmem.c to return the error code and
restore var on error.
But it is not clear in which video mode the device is when fb_set_par
fails. It would be good and reasonable if it were in the old state but
there is no guarantee that this is true for all existing drivers.
Additionally print a message if a failing fb_set_par is detected in
fbmem.c or fbcon.c.
Although most errors should be caught by the previous fb_check_var some
errors can't as they are dynamic (memory allocations, ...) and can only be
detected while performing the operations which is forbidden in
fb_check_var.
This patch shouldn't have a negative impact on normal operation as all
drivers return 0 on success. The impact in case of error depends heavily
on the driver and caller but it's expected to be better than before.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Catalin and kmemleak spotted a leak of a VC screen buffer in
vc_allocate() due to the following chain of events:
vc_allocate()
visual_init(init=1)
vc->vc_sw->con_init(init=1)
fbcon_init()
vc_resize()
vc->screen_buf = kmalloc()
The common way for the VC drivers is to set the screen dimension
parameters manually in the init case and only call vc_resize() for
!init - which allocates a screen buffer according to the new
dimensions.
fbcon instead would do vc_resize() unconditionally and afterwards set
the dimensions manually (again) for !init - i.e. completely upside
down. The vc_resize() allocated buffer would then get lost by
vc_allocate() allocating a fresh one.
Use vc_resize() only for actual resizing to close the leak.
Set the dimensions manually only in initialization mode to remove the
redundant setting in resize mode.
The kmemleak trace from Catalin:
unreferenced object 0xde158000 (size 12288):
comm "Xorg", pid 1439, jiffies 4294961016
hex dump (first 32 bytes):
20 00 20 00 20 00 20 00 20 00 20 00 20 00 20 00 . . . . . . . .
backtrace:
[<c006f74b>] __save_stack_trace+0x17/0x1c
[<c006f81d>] create_object+0xcd/0x188
[<c01f5457>] kmemleak_alloc+0x1b/0x3c
[<c006e303>] __kmalloc+0xdb/0xe8
[<c012cc4b>] vc_do_resize+0x73/0x1e0
[<c012cdf1>] vc_resize+0x15/0x18
[<c011afc1>] fbcon_init+0x1f9/0x2b8
[<c0129e87>] visual_init+0x9f/0xdc
[<c012aff3>] vc_allocate+0x7f/0xfc
[<c012b087>] con_open+0x17/0x80
[<c0120e43>] tty_open+0x1f7/0x2e4
[<c0072fa1>] chrdev_open+0x101/0x118
[<c006ffad>] __dentry_open+0x105/0x1cc
[<c00700fd>] nameidata_to_filp+0x2d/0x38
[<c00788cd>] do_filp_open+0x2c1/0x54c
[<c006fdff>] do_sys_open+0x3b/0xb4
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Tested-by: Dave Young <hidave.darkstar@gmail.com>
fb_notifier_call_chain() is called with info->lock held, i.e. in
do_fb_ioctl() => FBIOPUT_VSCREENINFO => fb_set_var() and the some
notifier callbacks, like fbcon_event_notify(), try to re-acquire
info->lock again.
Remove the lock/unlock_fb_info() in all the framebuffer notifier
callbacks' and be sure to always call fb_notifier_call_chain() with
info->lock held.
Reported-by: Pavel Roskin <proski@gnu.org>
Reported-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Fix a circular locking dependency in the frame buffer console driver
pushing down the mutex fb_info->lock.
Circular locking dependecies occur calling the blocking
fb_notifier_call_chain() with fb_info->lock held. Notifier callbacks can
try to acquire mm->mmap_sem, while fb_mmap() acquires the locks in the
reverse order mm->mmap_sem => fb_info->lock.
Tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Kill the last remaining vblank cursor blinking user
Add missing check for Atari in free_irq() call, which could cause problems on
multi-platform m68k kernels.
Reported-by: Brad Boyer <flar@allandria.com>
Remove the Mac VBL interrupt code as it doesn't work properly and
doesn't bring any benefit when fixed. Also remove unused
DEFAULT_CURSOR_BLINK_RATE macro and irqres variable.
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Add a call to cancel_work_sync() in fbcon_exit() to cancel any pending
work in the fbcon workqueue.
The current implementation of fbcon_exit() sets the fbcon workqueue
function info->queue.func to NULL, but does not assure that there is no
work pending when it does so. On occasion, depending on system timing,
there will still be pending work in the queue when fbcon_exit() is
called. This results in a null pointer deference when run_workqueue()
tries to call the queue's work function.
Fixes errors on shutdown similar to these:
Console: switching to colour dummy device 80x25
Unable to handle kernel paging request for data at address 0x00000000
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
The commit aef7db4bd5a3b6068dfa05919a3d685199eed116 fixed the problem with
recursive locking in fb blanking code if blank is caused by user setting
the /sys/class/graphics/fb*/blank. However this broke the fbcon timeout
blanking.
If you use a driver that defines ->fb_blank operation and at the same time
that driver relies on other driver (e.g. backlight or lcd class) to blank
the screen, when the fbcon times out and tries to blank the fb, it will
call only fb driver blanker and won't notify the other driver. Thus FB
output is disabled, but the screen isn't blanked.
Restore fbcon blanking and at the same time apply the proper fix for the
above problem: if fbcon_blank is called with FBINFO_FLAG_USEREVENT, we are
already called through notification from fb_blank, thus we don't have to
blank the fb again.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Updatescrollmode is marked inline, but it's big and is called only from
non-critical codepaths (fbcon_resize, fbcon_switch, fbcon_modechanged).
Dropping it saves almost 800 bytes of text size.
23859 287 8448 32594 7f52 drivers/video/console/fbcon.o.before
23065 287 8448 31800 7c38 drivers/video/console/fbcon.o.after
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits)
UIO: Fix mapping of logical and virtual memory
UIO: add automata sercos3 pci card support
UIO: Change driver name of uio_pdrv
UIO: Add alignment warnings for uio-mem
Driver core: add bus_sort_breadthfirst() function
NET: convert the phy_device file to use bus_find_device_by_name
kobject: Cleanup kobject_rename and !CONFIG_SYSFS
kobject: Fix kobject_rename and !CONFIG_SYSFS
sysfs: Make dir and name args to sysfs_notify() const
platform: add new device registration helper
sysfs: use ilookup5() instead of ilookup5_nowait()
PNP: create device attributes via default device attributes
Driver core: make bus_find_device_by_name() more robust
usb: turn dev_warn+WARN_ON combos into dev_WARN
debug: use dev_WARN() rather than WARN_ON() in device_pm_add()
debug: Introduce a dev_WARN() function
sysfs: fix deadlock
device model: Do a quickcheck for driver binding before doing an expensive check
Driver core: Fix cleanup in device_create_vargs().
Driver core: Clarify device cleanup.
echo 3 >> /sys/class/graphics/fbcon/rotate_all, then switch to another
console. Result:
BUG: unable to handle kernel paging request at ffffc20005d00000
IP: [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109
PGD 7e228067 PUD 7e229067 PMD 7bc1f067 PTE 0
Oops: 0002 [1] SMP
CPU 1
Modules linked in: [...a lot...]
Pid: 10, comm: events/1 Not tainted 2.6.26.5-45.fc9.x86_64 #1
RIP: 0010:[bitfill_aligned+149/265] [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109
RSP: 0018:ffff81007d811bc8 EFLAGS: 00010216
RAX: ffffc20005d00000 RBX: 0000000000000000 RCX: 0000000000000400
RDX: 0000000000000000 RSI: ffffc20005d00000 RDI: ffffffffffffffff
RBP: ffff81007d811be0 R08: 0000000000000400 R09: 0000000000000040
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000010000
R13: ffffffff811632f0 R14: 0000000000000006 R15: ffff81007cb85400
FS: 0000000000000000(0000) GS:ffff81007e004780(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: ffffc20005d00000 CR3: 0000000000201000 CR4: 00000000000006e0
Process events/1 (pid: 10, threadinfo ffff81007d810000, task ffff81007d808000)
Stack: ffff81007c9d75a0 0000000000000000 0000000000000000 ffff81007d811c80
ffffffff81163a61 ffff810000000000 ffffffff8115f9c8 0000001000000000
0000000100aaaaaa 000000007cd0d4a0 fffffd8a00000800 0001000000000000
Call Trace:
[cfb_fillrect+523/798] cfb_fillrect+0x20b/0x31e
[soft_cursor+416/436] ? soft_cursor+0x1a0/0x1b4
[ccw_clear_margins+205/263] ccw_clear_margins+0xcd/0x107
[fbcon_clear_margins+59/61] fbcon_clear_margins+0x3b/0x3d
[fbcon_switch+1291/1466] fbcon_switch+0x50b/0x5ba
[redraw_screen+261/481] redraw_screen+0x105/0x1e1
[ccw_cursor+0/1869] ? ccw_cursor+0x0/0x74d
[complete_change_console+48/190] complete_change_console+0x30/0xbe
[change_console+115/120] change_console+0x73/0x78
[console_callback+0/292] ? console_callback+0x0/0x124
[console_callback+97/292] console_callback+0x61/0x124
[schedule_delayed_work+25/30] ? schedule_delayed_work+0x19/0x1e
[run_workqueue+139/282] run_workqueue+0x8b/0x11a
[worker_thread+221/238] worker_thread+0xdd/0xee
[autoremove_wake_function+0/56] ? autoremove_wake_function+0x0/0x38
[worker_thread+0/238] ? worker_thread+0x0/0xee
[kthread+73/118] kthread+0x49/0x76
[child_rip+10/18] child_rip+0xa/0x12
[kthread+0/118] ? kthread+0x0/0x76
[child_rip+0/18] ? child_rip+0x0/0x12
Because fbcon_set_all_vcs()->FBCON_SWAP() uses display->rotate == 0 instead
of fbcon_ops->rotate, and vc_resize() has no effect because it is called with
new_cols/rows == ->vc_cols/rows.
Tested on 2.6.26.5-45.fc9.x86_64, but
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git seems to
have the same problem.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: <stable@kernel.org> [2.6.27.x, 2.6.26.x, maybe 2.6.25.x]
Now that device_create() has been audited, rename things back to the
original call to be sane.
This reverts commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b, and the
subsequent commits that fixed it up:
- afa9b649 "fbcon: prevent cursor disappearance after switching to 512
character font"
- d850a2fa "vt/fbcon: fix background color on line feed"
- 7fe3915a "vt/fbcon: update scrl_erase_char after 256/512-glyph font
switch"
by request of Alan Cox. Quoth Alan:
"Unfortunately it's wrong and its been causing breakages because
various apps like ncurses expect our previous (and correct)
behaviour."
Alexander sent out a similar patch.
Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Tested-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexander V. Lukyanov <lav@netis.ru>
Fix infinite recursive notifier in the fbdev layer. This causes recursive
locking. Dmitry Baryshkov found the problem and confirmed that the patch
fixes the bug.
After doing
# echo 1 > /sys/class/graphics/fb0/blank
I got the following in my kernel log:
[ INFO: possible recursive locking detected ]
2.6.27-rc6-00086-gda63874-dirty #97
echo/1564 is trying to acquire lock:
((fb_notifier_list).rwsem){..--}, at: [<c005a384>] __blocking_notifier_call_chain+0x38/0x6c
but task is already holding lock:
2 locks held by echo/1564:
#0: (&buffer->mutex){--..}, at: [<c00ddde0>] sysfs_write_file+0x30/0x80
#1: ((fb_notifier_list).rwsem){..--}, at: [<c005a384>] __blocking_notifier_call_chain+0x38/0x6c
stack backtrace:
[<c0029fe4>] (dump_stack+0x0/0x14) from [<c0060ce0>] (print_deadlock_bug+0xa4/0xd0)
[<c0060c3c>] (print_deadlock_bug+0x0/0xd0) from [<c0060e54>] (check_deadlock+0x148/0x17c)
r6:c397a1e0 r5:c397a530 r4:c04fcf98
[<c0060d0c>] (check_deadlock+0x0/0x17c) from [<c00637e8>] (validate_chain+0x3c4/0x4f0)
[<c0063424>] (validate_chain+0x0/0x4f0) from [<c0063efc>] (__lock_acquire+0x5e8/0x6b4)
[<c0063914>] (__lock_acquire+0x0/0x6b4) from [<c006402c>] (lock_acquire+0x64/0x78)
[<c0063fc8>] (lock_acquire+0x0/0x78) from [<c0316ca8>] (down_read+0x4c/0x60)
r7:00000009 r6:ffffffff r5:c0427a40 r4:c005a384
[<c0316c5c>] (down_read+0x0/0x60) from [<c005a384>] (__blocking_notifier_call_chain+0x38/0x6c)
r5:c0427a40 r4:c0427a74
[<c005a34c>] (__blocking_notifier_call_chain+0x0/0x6c) from [<c005a3d8>] (blocking_notifier_call_chain+0x20/0x28)
r8:00000009 r7:c086d640 r6:c3967940 r5:00000000 r4:c38984b8
[<c005a3b8>] (blocking_notifier_call_chain+0x0/0x28) from [<c014baa0>] (fb_notifier_call_chain+0x1c/0x24)
[<c014ba84>] (fb_notifier_call_chain+0x0/0x24) from [<c014c18c>] (fb_blank+0x64/0x70)
[<c014c128>] (fb_blank+0x0/0x70) from [<c0155978>] (fbcon_blank+0x114/0x1bc)
r5:00000001 r4:c38984b8
[<c0155864>] (fbcon_blank+0x0/0x1bc) from [<c0170ea8>] (do_blank_screen+0x1e0/0x2a0)
[<c0170cc8>] (do_blank_screen+0x0/0x2a0) from [<c0154024>] (fbcon_fb_blanked+0x74/0x94)
r5:c3967940 r4:00000001
[<c0153fb0>] (fbcon_fb_blanked+0x0/0x94) from [<c0154228>] (fbcon_event_notify+0x100/0x12c)
r5:fffffffe r4:c39bc194
[<c0154128>] (fbcon_event_notify+0x0/0x12c) from [<c005a0d4>] (notifier_call_chain+0x38/0x7c)
[<c005a09c>] (notifier_call_chain+0x0/0x7c) from [<c005a3a0>] (__blocking_notifier_call_chain+0x54/0x6c)
r8:c3b51ea0 r7:00000009 r6:ffffffff r5:c0427a40 r4:c0427a74
r8:00000001 r7:c3a7e000 r6:00000000 r5:00000000 r4:c38984b8
[<c014c128>] (fb_blank+0x0/0x70) from [<c014e450>] (store_blank+0x54/0x7c)
r5:c38984b8 r4:c3b51ec4
[<c014e3fc>] (store_blank+0x0/0x7c) from [<c017981c>] (dev_attr_store+0x28/0x2c)
r8:00000001 r7:c042bf80 r6:c39eba10 r5:c3967c30 r4:c38e0140
[<c01797f4>] (dev_attr_store+0x0/0x2c) from [<c00ddaac>] (flush_write_buffer+0x54/0x68)
[<c00dda58>] (flush_write_buffer+0x0/0x68) from [<c00dde08>] (sysfs_write_file+0x58/0x80)
r8:c3b51f78 r7:c3bcb070 r6:c39eba10 r5:00000001 r4:00000001
[<c00dddb0>] (sysfs_write_file+0x0/0x80) from [<c009de04>] (vfs_write+0xb8/0x148)
[<c009dd4c>] (vfs_write+0x0/0x148) from [<c009e384>] (sys_write+0x44/0x70)
r7:00000004 r6:c3bcb070 r5:00000000 r4:00000000
[<c009e340>] (sys_write+0x0/0x70) from [<c0025d00>] (ret_fast_syscall+0x0/0x2c)
r6:4001b000 r5:00000001 r4:401dc658
Reported-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Testted-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Adjust and honor the vc_scrl_erase_char for 256 and 512 character fonts.
It fixes the issue with disappearing cursor during scrolling
(http://bugzilla.kernel.org/show_bug.cgi?id=11258). The issue was
reported and tracked by Peter Hanzel.
Reported-by: Peter Hanzel <hanzelpeter@gmail.com>
If the 'clear' command is used on the frame buffer with a logo the upper
area is filled by few lines but not scrolled anymore.
Fix this by removing the protected area for the logo if any part of the
logo is cleared.
Make logo_height variable local in the only function it is used.
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
The interlaced and double line mode bits should not be copied to new
console when the console is switched. Otherwise, the new console may be
set to incorrect refresh rate.
Also, the x and y offsets does not need to be copied.
Another addendum to commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b
("vt: fix background color on line feed").
fbcon still was not doing the right thing (read: continued to do old
behavior). fbcon_clear() seems to clear the new line (e.g. where your new
prompt appears after doing echo -en "\e[42mfoo\n"), while scr_memsetw clears
the previous one only (where "foo" appears). So just temporarily set the
video_erase_char to the scrl_erase_char so that fbcon_clear does the right
thing.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Addendum to commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b ("vt: fix
vc->vc_scrl_erase_char was not updated when fbcon switches between
256- and 512-glyph fonts.
A command that causes a line feed while a background color is active,
such as
perl -e 'print "x" x 60, "\e[44m", "x" x 40, "\e[0m\n"'
and
perl -e 'print "x" x 40, "\e[44m\n", "x" x 40, "\e[0m\n"'
causes the line that was started as a result of the line feed to be completely
filled with the currently active background color instead of the default
color.
When scrolling, part of the current screen is memcpy'd/memmove'd to the new
region, and the new line(s) that will appear as a result are cleared using
memset. However, the lines are cleared with vc->vc_video_erase_char, causing
them to be colored with the currently active background color. This is
different from X11 terminal emulators which always paint the new lines with
the default background color (e.g. `xterm -bg black`).
The clear operation (\e[1J and \e[2J) also use vc_video_erase_char, so a new
vc->vc_scrl_erase_char is introduced with contains the erase character used
for scrolling, which is built from vc->vc_def_color instead of vc->vc_color.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Antonino A. Daplas <adaplas@gmail.com>
Cc: Antonino Daplas <adaplas@pol.net>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Adrian Bunk <bunk@stusta.de>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Ben Dooks <ben-linux@fluff.org>
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) /
(d)) but is perhaps more readable.
An extract of the semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@haskernel@
#include <linux/kernel.h>
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP((n),d)
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP(n,(d))
+ DIV_ROUND_UP(n,d)
// </smpl>
The current attr_fgcol_ec / attr_bgcol_ec macros do a simple shift of bits
to get the color from vc_video_erase_char. For a monochrome display
however the attribute does not contain any color, only attribute bits.
Furthermore the reverse bit is lost because it is shifted out, the
resulting color is always 0.
This can bee seen on a monochrome console either directly or by setting it
to inverse mode via "setterm -inversescreen on" . Text is written with
correct color, fb_fillrects from a bit_clear / bit_clear_margins will get
wrong colors.
Signed-off-by: Thomas Pfaff <tpfaff@pcs.com>
After the APUS removal, some code can be removed.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Karsten Keil <kkeil@suse.de>
Cc: James Bottomley <James.Bottomley@steeleye.com>
As reported in Bugzilla Bug 9093, upon switching to X, a small rectangular
cursor can still be seen blinking in the upper left part of the screen. It is
fbcon's text cursor. This is caused by a strange ioctl(..., KDSETMODE,
KD_TEXT) call done by something in userspace, perhaps by X itself, while the
tty is still in graphics mode. And when the tty is in KD_TEXT mode, the
cursor timer is restarted.
Although this is a userspace problem, we can work around it by delaying the
restart of the cursor timer until an fbcon_switch() is called. In other
words, the cursor timer will not be restarted even if a KD_TEXT mode switch is
requested.
Regression potential: Present but low
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
Various console drivers are able to resize the screen via the con_resize()
hook. This hook is also visible in userspace via the TIOCWINSZ, VT_RESIZE and
VT_RESIZEX ioctl's. One particular utility, SVGATextMode, expects that
con_resize() of the VGA console will always return success even if the
resulting screen is not compatible with the hardware. However, this
particular behavior of the VGA console, as reported in Kernel Bugzilla Bug
7513, can cause undefined behavior if the user starts with a console size
larger than 80x25.
To work around this problem, add an extra parameter to con_resize(). This
parameter is ignored by drivers except for vgacon. If this parameter is
non-zero, then the resize request came from a VT_RESIZE or VT_RESIZEX ioctl
and vgacon will always return success. If this parameter is zero, vgacon will
return -EINVAL if the requested size is not compatible with the hardware. The
latter is the more correct behavior.
With this change, SVGATextMode should still work correctly while in-kernel and
stty resize calls can expect correct behavior from vgacon.
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the
checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver
does not use it.
Fix compile warning ('map_override unused') if fbcon is compiled as a module
and CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=n.
[akpm@linux-foundation.org: cleanup]
This allows for proper console unregistration via the VT layer, and updates
the FB layer to use it. This makes debugging new console drivers much easier,
since you can properly clean them up before unloading.
[adaplas]
unregister_framebuffer() is typically called as part of the driver's
module_exit(). Doing so otherwise will freeze the machine as the VT layer is
holding reference counts on fbcon, and fbcon on the driver. With this change,
it allows unregister_framebuffer() to be called safely anywhere as needed.
Additions from the original: If multiple drivers are used by fbcon, and if
one of them unregisters, a driver will take over the consoles vacated by the
outgoing one (via set_con2fb_map). Once only the outgoing driver remains,
then fbcon will unbind from the VT layer (if CONFIG_HW_CONSOLE_UNBINDING is
set to y).
It is important that these drivers implement fb_open() and fb_release()
just to ensure that no other process is using the driver. Likewise, these
drivers _must_ check the return value of unregister_framebuffer().
[akpm@linux-foundation.org: make fbcon_unbind() stub inline]
Signed-off-by: Jesse Barnes <jesse.barnes@intel.com>
Use set_con2fb_map() to select the primary display driver instead of using
unbind_con_driver() and bind_con_driver(). Using the former is much simpler
and safer than the current one.
set_con2fb_map() has regressed for some time. Using fbcon=map:01, for
example, works only if there is only 1 working framebuffer. Trying to do a
set_con2fb_map() on a non-allocated vc will freeze the system.
- ensure that succeeding drivers after the first gets mapped to the console
- remove fbcon_preset_display() and modify fbcon_set_display() to include the
former's functionality
- ensure that binding and unbinding succeeds if multiple drivers are mapped to
the console
Allow fbcon to select the primary display adapter using the
fb_is_primary_device() arch-specific helper. If a a primary adapter is
detected, fbcon will unbind the old adapter from the VT layer, then rebind
using the new adapter. This requires that bind_/unbind_con_driver() be made
public.
Because this feature may produce unexpected behavior (from the user's POV),
this must be explicitly enabled in Kconfig.
[akpm@linux-foundation.org: export unbind_con_driver]
Port fbcon.c to use struct device from using struct class_device
Add sysfs attribute to enable or disable cursor blinking. This will also
disable cursor blinking if the VT layer's softcursor is active. These changes
are required to enable some machines to enter low-power states properly.
This patch replaces the current SCROLL_MOVE method with smarter method using
the same logic as the SCROLL_REDRAW method. This brings these two methods
much closer in performance and benefits all framebuffers which uses the
SCROLL_MOVE method.
[adaplas]
- remove unnecessary char attribute checking
- whitespace cleanups and 80-column line fixes
- Check the console-to-fb mapping in fbcon_get_requirement(), otherwise the
value returned may not be valid for the driver.
- Minor cleanup
Check if the mode can properly display the screen. This will be needed by
drivers where the capability is not constant with each mode. The function
fb_set_var() will query fbcon the requirement, then it will query the driver
(via a new hook fb_get_caps()) its capability. If the driver's capability
cannot handle fbcon's requirement, then fb_set_var() will fail.
For example, if a particular driver supports 2 modes where:
mode1 = can only display 8x16 bitmaps
mode2 = can display any bitmap
then if current mode = mode2 and current font = 12x22
fbset <mode1> /* mode1 cannot handle 12x22 */
fbset will fail
Fontmaps can be 256 or 512 in length. The only driver that can do tileblitting
can only handle 256 characters. Check for this when setting the font.
fbcon_set_font() will now check if the new font dimensions can be drawn by the
driver (by checking pixmap.blit_x and blit_y). Similarly, add 2 new
parameters to get_default_font(), font_w and font_h, to further aid in the
font selection process.
If the current framebuffer console is rotated (rotate != 0), doing an
"fbset -a" will corrupt the current console. Fix by updating the current
console only after all non-visible consoles have been updated.
It was always intended for the logo to be drawn only if both fbcon and the
driver that is mapped to it are both compiled statically. Currently, if fbcon
is loaded prior to the driver, the logo is not shown. Reverse the order, and
the code may attempt to draw the logo which is __initdata. By accident, this
bug is rarely seen because this method of loading the modules is not common
and secondly, a code in fb_prepare_logo() that checks the height of the logo
(now a random value) rarely succeeds.
Fix by drawing the logo only if both fbcon and the driver are statically
compiled.
When the cursor and echo are disabled on the current console, pressing a
key will cause a black rectangle to be painted in the cursor's position.
Fix this by not touching the framebuffer in fbcon_cursor() when the
cursor is off.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
fbcon_prepare_logo(): Avoid vertical overflow when making space for the logo
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Acked-By: James Simmons <jsimmons@infradead.org>
