commit e6637d5427d2af9f3f33b95447bfc5347e5ccd85 upstream.
commit ae1287865f5361fa138d4d3b1b6277908b54eac9
Author: Dave Airlie <airlied@redhat.com>
Date: Thu Jan 24 16:12:41 2013 +1000
fbcon: don't lose the console font across generic->chip driver switch
uses a pointer in vc->vc_font.data to load font into the new driver.
However if the font is actually freed, we need to clear the data
so that we don't reload font from dangling pointer.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=892340
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
commit 054430e773c9a1e26f38e30156eff02dedfffc17 upstream.
Okay so Alan's patch handled the case where there was no registered fbcon,
however the other path entered in set_con2fb_map pit.
In there we called fbcon_takeover, but we also took the console lock in a couple
of places. So push the console lock out to the callers of set_con2fb_map,
this means fbmem and switcheroo needed to take the lock around the fb notifier
entry points that lead to this.
This should fix the efifb regression seen by Maarten.
Tested-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Tested-by: Lu Hua <huax.lu@intel.com>
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream.
I've still got lockdep warnings even after Alan's patch, and it seems that
yet more band aids are required to paper over similar paths for
unbind_con_driver() and unregister_con_driver(). After this hack, lockdep
warnings are finally gone.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream.
Adjust the console layer to allow a take over call where the caller
already holds the locks. Make the fb layer lock in order.
This is partly a band aid, the fb layer is terminally confused about the
locking rules it uses for its notifiers it seems.
[akpm@linux-foundation.org: remove stray non-ascii char, tidy comment]
[akpm@linux-foundation.org: export do_take_over_console()]
[airlied: cleanup another non-ascii char]
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit ae1287865f5361fa138d4d3b1b6277908b54eac9 upstream.
If grub2 loads efifb/vesafb, then when systemd starts it can set the console
font on that framebuffer device, however when we then load the native KMS
driver, the first thing it does is tear down the generic framebuffer driver.
The thing is the generic code is doing the right thing, it frees the font
because otherwise it would leak memory. However we can assume that if you
are removing the generic firmware driver (vesa/efi/offb), that a new driver
*should* be loading soon after, so we effectively leak the font.
However the old code left a dangling pointer in vc->vc_font.data and we
can now reuse that dangling pointer to load the font into the new
driver, now that we aren't freeing it.
Cc: Kay Sievers <kay.sievers@vrfy.org>
commit d8636a2717bb3da2a7ce2154bf08de90bb8c87b0 upstream.
So we've had a fair few reports of fbcon handover breakage between
efi/vesafb and i915 surface recently, so I dedicated a couple of
days to finding the problem.
Essentially the last thing we saw was the conflicting framebuffer
message and that was all.
So after much tracing with direct netconsole writes (printks
under console_lock not so useful), I think I found the race.
Thread A (driver load) Thread B (timer thread)
unbind_con_driver -> |
vc->vc_sw->con_deinit -> |
fbcon_deinit -> |
console_lock() |
| fbcon_flashcursor timer fires
| console_lock() <- blocked for A
fbcon_del_cursor_timer ->
del_timer_sync
(BOOM)
Of course because all of this is under the console lock,
we never see anything, also since we also just unbound the active
console guess what we never see anything.
Hopefully this fixes the problem for anyone seeing vesafb->kms
driver handoff.
v1.1: add comment suggestion from Alan.
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Tested-by: Josh Boyer <jwboyer@gmail.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Situation as follow:
2 GPUs + vesafb + kms.
GPU 1 is primary, vesafb binds to it as fb0
radeon loads
GPU 0 loads as fb1
GPU 1 loads, vesafb gets kicked off which causes fb0 to unbind
console, which causes the dummy console to rebind.
this means fbcon_deinit gets called, which calls fbcon_exit
since the console isn't bound anymore and we set fbcon_has_exited.
GPU 1 creates a new fb0 which is primary and we want to be console.
fbcon_fb_registered gets called sets the primary up and calls set_con2fb_map,
however as fbcon_has_exited is set nothing further ever happens.
This patch bypasses the fbcon_has_exited and checks if the console is unbound,
if its unbound it calls the fbcon_takeover which calls the vt layer to
call the fbcon_startup method and everthing works.
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
Cc: Greg KH <gregkh@suse.de>
Fix the lockdep warning:
[ 13.657164] INFO: trying to register non-static key.
[ 13.657169] the code is fine but needs lockdep annotation.
[ 13.657171] turning off the locking correctness validator.
[ 13.657177] Pid: 622, comm: modprobe Not tainted 2.6.36-rc3c #8
[ 13.657180] Call Trace:
[ 13.657194] [<c13002c8>] ? printk+0x18/0x20
[ 13.657202] [<c1056cf6>] register_lock_class+0x336/0x350
[ 13.657208] [<c1058bf9>] __lock_acquire+0x449/0x1180
[ 13.657215] [<c1059997>] lock_acquire+0x67/0x80
[ 13.657222] [<c1042bf1>] ? __cancel_work_timer+0x51/0x230
[ 13.657227] [<c1042c23>] __cancel_work_timer+0x83/0x230
[ 13.657231] [<c1042bf1>] ? __cancel_work_timer+0x51/0x230
[ 13.657236] [<c10582b2>] ? mark_held_locks+0x62/0x80
[ 13.657243] [<c10b3a2f>] ? kfree+0x7f/0xe0
[ 13.657248] [<c105853c>] ? trace_hardirqs_on_caller+0x11c/0x160
[ 13.657253] [<c105858b>] ? trace_hardirqs_on+0xb/0x10
[ 13.657259] [<c117f4cd>] ? fbcon_deinit+0x16d/0x1e0
[ 13.657263] [<c117f4cd>] ? fbcon_deinit+0x16d/0x1e0
[ 13.657268] [<c1042dea>] cancel_work_sync+0xa/0x10
[ 13.657272] [<c117f444>] fbcon_deinit+0xe4/0x1e0
The warning is caused by trying to cancel an uninitialized work from
fbcon_exit(). Fix it by adding a check for queue.func, similarly to other
places in this code.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
This function's body is good two screenfuls and it has six callsites. No
apparent reason why it is marked inline.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Jesse's initial patch commit said:
"At panic time (i.e. when oops_in_progress is set) we should try a bit
harder to update the screen and make sure output gets to the VT, since
some drivers are capable of flipping back to it.
So make sure we try to unblank and update the display if called from a
panic context."
I've enhanced this to add a flag to the vc that console layer can set to
indicate they want this behaviour to occur. This also adds support to
fbcon for that flag and adds an fb flag for drivers to indicate they want
to use the support. It enables this for KMS drivers.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: James Simmons <jsimmons@infradead.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add fb ops to handle enter/exit of the kernel debugger. If present, the
fb core will register them with KGDB and they'll be called when the
debugger is entered and exited. The new functions are responsible for
switching to an appropriate debug framebuffer and restoring the
interrupted state at exit time.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Many new laptops now come with 2 gpus, one to be used for low power
modes and one for gaming/on-ac applications. These GPUs are typically
wired to the laptop panel and VGA ports via a multiplexer unit which
is controlled via ACPI methods.
4 combinations of systems typically exist - with 2 ACPI methods.
Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method
ATI/ATI - some ASUS - use ATPX ACPI Method
Intel/Nvidia - - use _DSM ACPI method
Nvidia/Nvidia - - use _DSM ACPI method.
TODO:
This patch adds support for the ATPX method and initial bits
for the _DSM methods that need to written by someone with
access to the hardware.
Add a proper non-debugfs interface - need to get some proper
testing first.
v2: add power up/down support for both devices
on W500 puts i915/radeon into D3 and cuts power to radeon.
v3: redo probing methods, no DMI list, drm devices call to
register with switcheroo, it tries to find an ATPX method on
any device and once there is two devices + ATPX it inits the
switcher.
v4: ATPX msg handling using buffers - should work on more machines
v5: rearchitect after more mjg59 discussion - move ATPX handling to
radeon driver.
v6: add file headers + initial nouveau bits (to be filled out).
v7: merge delayed switcher code.
v8: avoid suspend/resume of gpu that is off
v9: rearchitect - mjg59 is always right. - move all ATPX code to
radeon, should allow simpler DSM also proper ATRM handling
v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv
v11: fix bug in resuming Intel for 2nd time.
v12: start fixing up nvidia code blindly.
v13: blindly guess at finishing nvidia code
v14: remove radeon audio hacks - fix up intel resume more like upstream
v15: clean up printks + remove unnecessary igd/dis pointers
mount debugfs
/sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected
+ 2 cards.
DIS - immediate change to discrete
IGD - immediate change to IGD
DDIS - delayed change to discrete
DIGD - delayed change to IGD
ON - turn on not in use
OFF - turn off not in use
Tested on W500 (Intel/ATI) and T500 (Intel/ATI)
Remove fb_save_state() and fb_restore_state operations from frame buffer layer.
They are used only in two drivers:
1. savagefb - and cause bug #11248
2. uvesafb
Usage of these operations is misunderstood in both drivers so kill these
operations, fix the bug #11248 and avoid confusion in the future.
Tested on Savage 3D/MV card and the patch fixes the bug #11248.
The frame buffer layer uses these funtions during switch between graphics
and text mode of the console, but these drivers saves state before
switching of the frame buffer (in the fb_open) and after releasing it (in
the fb_release). This defeats the purpose of these operations.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Reported-by: Jochen Hein <jochen@jochen.org>
Tested-by: Jochen Hein <jochen@jochen.org>
Cc: Michal Januszewski <spock@gentoo.org>
Attempting to unload a framebuffer module calls unregister_framebuffer()
which in turn gets fbcon to release it. If fbcon has no framebuffers
linked to a console, it will also unbind itself from the console driver.
However, if fbcon never registered itself as a console driver, the unbind
will fail causing the framebuffer device entry to persist. In most cases
this failure will result in an oops when attempting to access the now
non-existent device.
This patch ensures that the fbcon unbind request will succeed even if a
bind was never done. It tracks if a successful bind ever occurred & will
only attempt to unbind if needed. If there never was a bind, it simply
returns with no error.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: <stable@kernel.org>
At the moment about half of the framebuffer drivers can return an error
code in fb_set_par. Until now it would be silently ignored by fbmem.c
and fbcon.c. This patch fixes fbmem.c to return the error code and
restore var on error.
But it is not clear in which video mode the device is when fb_set_par
fails. It would be good and reasonable if it were in the old state but
there is no guarantee that this is true for all existing drivers.
Additionally print a message if a failing fb_set_par is detected in
fbmem.c or fbcon.c.
Although most errors should be caught by the previous fb_check_var some
errors can't as they are dynamic (memory allocations, ...) and can only be
detected while performing the operations which is forbidden in
fb_check_var.
This patch shouldn't have a negative impact on normal operation as all
drivers return 0 on success. The impact in case of error depends heavily
on the driver and caller but it's expected to be better than before.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Catalin and kmemleak spotted a leak of a VC screen buffer in
vc_allocate() due to the following chain of events:
vc_allocate()
visual_init(init=1)
vc->vc_sw->con_init(init=1)
fbcon_init()
vc_resize()
vc->screen_buf = kmalloc()
The common way for the VC drivers is to set the screen dimension
parameters manually in the init case and only call vc_resize() for
!init - which allocates a screen buffer according to the new
dimensions.
fbcon instead would do vc_resize() unconditionally and afterwards set
the dimensions manually (again) for !init - i.e. completely upside
down. The vc_resize() allocated buffer would then get lost by
vc_allocate() allocating a fresh one.
Use vc_resize() only for actual resizing to close the leak.
Set the dimensions manually only in initialization mode to remove the
redundant setting in resize mode.
The kmemleak trace from Catalin:
unreferenced object 0xde158000 (size 12288):
comm "Xorg", pid 1439, jiffies 4294961016
hex dump (first 32 bytes):
20 00 20 00 20 00 20 00 20 00 20 00 20 00 20 00 . . . . . . . .
backtrace:
[<c006f74b>] __save_stack_trace+0x17/0x1c
[<c006f81d>] create_object+0xcd/0x188
[<c01f5457>] kmemleak_alloc+0x1b/0x3c
[<c006e303>] __kmalloc+0xdb/0xe8
[<c012cc4b>] vc_do_resize+0x73/0x1e0
[<c012cdf1>] vc_resize+0x15/0x18
[<c011afc1>] fbcon_init+0x1f9/0x2b8
[<c0129e87>] visual_init+0x9f/0xdc
[<c012aff3>] vc_allocate+0x7f/0xfc
[<c012b087>] con_open+0x17/0x80
[<c0120e43>] tty_open+0x1f7/0x2e4
[<c0072fa1>] chrdev_open+0x101/0x118
[<c006ffad>] __dentry_open+0x105/0x1cc
[<c00700fd>] nameidata_to_filp+0x2d/0x38
[<c00788cd>] do_filp_open+0x2c1/0x54c
[<c006fdff>] do_sys_open+0x3b/0xb4
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Tested-by: Dave Young <hidave.darkstar@gmail.com>
fb_notifier_call_chain() is called with info->lock held, i.e. in
do_fb_ioctl() => FBIOPUT_VSCREENINFO => fb_set_var() and the some
notifier callbacks, like fbcon_event_notify(), try to re-acquire
info->lock again.
Remove the lock/unlock_fb_info() in all the framebuffer notifier
callbacks' and be sure to always call fb_notifier_call_chain() with
info->lock held.
Reported-by: Pavel Roskin <proski@gnu.org>
Reported-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Fix a circular locking dependency in the frame buffer console driver
pushing down the mutex fb_info->lock.
Circular locking dependecies occur calling the blocking
fb_notifier_call_chain() with fb_info->lock held. Notifier callbacks can
try to acquire mm->mmap_sem, while fb_mmap() acquires the locks in the
reverse order mm->mmap_sem => fb_info->lock.
Tested-by: Andrey Borzenkov <arvidjaar@mail.ru>
Kill the last remaining vblank cursor blinking user
Add missing check for Atari in free_irq() call, which could cause problems on
multi-platform m68k kernels.
Reported-by: Brad Boyer <flar@allandria.com>
Remove the Mac VBL interrupt code as it doesn't work properly and
doesn't bring any benefit when fixed. Also remove unused
DEFAULT_CURSOR_BLINK_RATE macro and irqres variable.
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Add a call to cancel_work_sync() in fbcon_exit() to cancel any pending
work in the fbcon workqueue.
The current implementation of fbcon_exit() sets the fbcon workqueue
function info->queue.func to NULL, but does not assure that there is no
work pending when it does so. On occasion, depending on system timing,
there will still be pending work in the queue when fbcon_exit() is
called. This results in a null pointer deference when run_workqueue()
tries to call the queue's work function.
Fixes errors on shutdown similar to these:
Console: switching to colour dummy device 80x25
Unable to handle kernel paging request for data at address 0x00000000
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
The commit aef7db4bd5a3b6068dfa05919a3d685199eed116 fixed the problem with
recursive locking in fb blanking code if blank is caused by user setting
the /sys/class/graphics/fb*/blank. However this broke the fbcon timeout
blanking.
If you use a driver that defines ->fb_blank operation and at the same time
that driver relies on other driver (e.g. backlight or lcd class) to blank
the screen, when the fbcon times out and tries to blank the fb, it will
call only fb driver blanker and won't notify the other driver. Thus FB
output is disabled, but the screen isn't blanked.
Restore fbcon blanking and at the same time apply the proper fix for the
above problem: if fbcon_blank is called with FBINFO_FLAG_USEREVENT, we are
already called through notification from fb_blank, thus we don't have to
blank the fb again.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Updatescrollmode is marked inline, but it's big and is called only from
non-critical codepaths (fbcon_resize, fbcon_switch, fbcon_modechanged).
Dropping it saves almost 800 bytes of text size.
23859 287 8448 32594 7f52 drivers/video/console/fbcon.o.before
23065 287 8448 31800 7c38 drivers/video/console/fbcon.o.after
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits)
UIO: Fix mapping of logical and virtual memory
UIO: add automata sercos3 pci card support
UIO: Change driver name of uio_pdrv
UIO: Add alignment warnings for uio-mem
Driver core: add bus_sort_breadthfirst() function
NET: convert the phy_device file to use bus_find_device_by_name
kobject: Cleanup kobject_rename and !CONFIG_SYSFS
kobject: Fix kobject_rename and !CONFIG_SYSFS
sysfs: Make dir and name args to sysfs_notify() const
platform: add new device registration helper
sysfs: use ilookup5() instead of ilookup5_nowait()
PNP: create device attributes via default device attributes
Driver core: make bus_find_device_by_name() more robust
usb: turn dev_warn+WARN_ON combos into dev_WARN
debug: use dev_WARN() rather than WARN_ON() in device_pm_add()
debug: Introduce a dev_WARN() function
sysfs: fix deadlock
device model: Do a quickcheck for driver binding before doing an expensive check
Driver core: Fix cleanup in device_create_vargs().
Driver core: Clarify device cleanup.
echo 3 >> /sys/class/graphics/fbcon/rotate_all, then switch to another
console. Result:
BUG: unable to handle kernel paging request at ffffc20005d00000
IP: [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109
PGD 7e228067 PUD 7e229067 PMD 7bc1f067 PTE 0
Oops: 0002 [1] SMP
CPU 1
Modules linked in: [...a lot...]
Pid: 10, comm: events/1 Not tainted 2.6.26.5-45.fc9.x86_64 #1
RIP: 0010:[bitfill_aligned+149/265] [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109
RSP: 0018:ffff81007d811bc8 EFLAGS: 00010216
RAX: ffffc20005d00000 RBX: 0000000000000000 RCX: 0000000000000400
RDX: 0000000000000000 RSI: ffffc20005d00000 RDI: ffffffffffffffff
RBP: ffff81007d811be0 R08: 0000000000000400 R09: 0000000000000040
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000010000
R13: ffffffff811632f0 R14: 0000000000000006 R15: ffff81007cb85400
FS: 0000000000000000(0000) GS:ffff81007e004780(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: ffffc20005d00000 CR3: 0000000000201000 CR4: 00000000000006e0
Process events/1 (pid: 10, threadinfo ffff81007d810000, task ffff81007d808000)
Stack: ffff81007c9d75a0 0000000000000000 0000000000000000 ffff81007d811c80
ffffffff81163a61 ffff810000000000 ffffffff8115f9c8 0000001000000000
0000000100aaaaaa 000000007cd0d4a0 fffffd8a00000800 0001000000000000
Call Trace:
[cfb_fillrect+523/798] cfb_fillrect+0x20b/0x31e
[soft_cursor+416/436] ? soft_cursor+0x1a0/0x1b4
[ccw_clear_margins+205/263] ccw_clear_margins+0xcd/0x107
[fbcon_clear_margins+59/61] fbcon_clear_margins+0x3b/0x3d
[fbcon_switch+1291/1466] fbcon_switch+0x50b/0x5ba
[redraw_screen+261/481] redraw_screen+0x105/0x1e1
[ccw_cursor+0/1869] ? ccw_cursor+0x0/0x74d
[complete_change_console+48/190] complete_change_console+0x30/0xbe
[change_console+115/120] change_console+0x73/0x78
[console_callback+0/292] ? console_callback+0x0/0x124
[console_callback+97/292] console_callback+0x61/0x124
[schedule_delayed_work+25/30] ? schedule_delayed_work+0x19/0x1e
[run_workqueue+139/282] run_workqueue+0x8b/0x11a
[worker_thread+221/238] worker_thread+0xdd/0xee
[autoremove_wake_function+0/56] ? autoremove_wake_function+0x0/0x38
[worker_thread+0/238] ? worker_thread+0x0/0xee
[kthread+73/118] kthread+0x49/0x76
[child_rip+10/18] child_rip+0xa/0x12
[kthread+0/118] ? kthread+0x0/0x76
[child_rip+0/18] ? child_rip+0x0/0x12
Because fbcon_set_all_vcs()->FBCON_SWAP() uses display->rotate == 0 instead
of fbcon_ops->rotate, and vc_resize() has no effect because it is called with
new_cols/rows == ->vc_cols/rows.
Tested on 2.6.26.5-45.fc9.x86_64, but
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git seems to
have the same problem.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: <stable@kernel.org> [2.6.27.x, 2.6.26.x, maybe 2.6.25.x]
Now that device_create() has been audited, rename things back to the
original call to be sane.
This reverts commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b, and the
subsequent commits that fixed it up:
- afa9b649 "fbcon: prevent cursor disappearance after switching to 512
character font"
- d850a2fa "vt/fbcon: fix background color on line feed"
- 7fe3915a "vt/fbcon: update scrl_erase_char after 256/512-glyph font
switch"
by request of Alan Cox. Quoth Alan:
"Unfortunately it's wrong and its been causing breakages because
various apps like ncurses expect our previous (and correct)
behaviour."
Alexander sent out a similar patch.
Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Tested-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexander V. Lukyanov <lav@netis.ru>
Fix infinite recursive notifier in the fbdev layer. This causes recursive
locking. Dmitry Baryshkov found the problem and confirmed that the patch
fixes the bug.
After doing
# echo 1 > /sys/class/graphics/fb0/blank
I got the following in my kernel log:
[ INFO: possible recursive locking detected ]
2.6.27-rc6-00086-gda63874-dirty #97
echo/1564 is trying to acquire lock:
((fb_notifier_list).rwsem){..--}, at: [<c005a384>] __blocking_notifier_call_chain+0x38/0x6c
but task is already holding lock:
2 locks held by echo/1564:
#0: (&buffer->mutex){--..}, at: [<c00ddde0>] sysfs_write_file+0x30/0x80
#1: ((fb_notifier_list).rwsem){..--}, at: [<c005a384>] __blocking_notifier_call_chain+0x38/0x6c
stack backtrace:
[<c0029fe4>] (dump_stack+0x0/0x14) from [<c0060ce0>] (print_deadlock_bug+0xa4/0xd0)
[<c0060c3c>] (print_deadlock_bug+0x0/0xd0) from [<c0060e54>] (check_deadlock+0x148/0x17c)
r6:c397a1e0 r5:c397a530 r4:c04fcf98
[<c0060d0c>] (check_deadlock+0x0/0x17c) from [<c00637e8>] (validate_chain+0x3c4/0x4f0)
[<c0063424>] (validate_chain+0x0/0x4f0) from [<c0063efc>] (__lock_acquire+0x5e8/0x6b4)
[<c0063914>] (__lock_acquire+0x0/0x6b4) from [<c006402c>] (lock_acquire+0x64/0x78)
[<c0063fc8>] (lock_acquire+0x0/0x78) from [<c0316ca8>] (down_read+0x4c/0x60)
r7:00000009 r6:ffffffff r5:c0427a40 r4:c005a384
[<c0316c5c>] (down_read+0x0/0x60) from [<c005a384>] (__blocking_notifier_call_chain+0x38/0x6c)
r5:c0427a40 r4:c0427a74
[<c005a34c>] (__blocking_notifier_call_chain+0x0/0x6c) from [<c005a3d8>] (blocking_notifier_call_chain+0x20/0x28)
r8:00000009 r7:c086d640 r6:c3967940 r5:00000000 r4:c38984b8
[<c005a3b8>] (blocking_notifier_call_chain+0x0/0x28) from [<c014baa0>] (fb_notifier_call_chain+0x1c/0x24)
[<c014ba84>] (fb_notifier_call_chain+0x0/0x24) from [<c014c18c>] (fb_blank+0x64/0x70)
[<c014c128>] (fb_blank+0x0/0x70) from [<c0155978>] (fbcon_blank+0x114/0x1bc)
r5:00000001 r4:c38984b8
[<c0155864>] (fbcon_blank+0x0/0x1bc) from [<c0170ea8>] (do_blank_screen+0x1e0/0x2a0)
[<c0170cc8>] (do_blank_screen+0x0/0x2a0) from [<c0154024>] (fbcon_fb_blanked+0x74/0x94)
r5:c3967940 r4:00000001
[<c0153fb0>] (fbcon_fb_blanked+0x0/0x94) from [<c0154228>] (fbcon_event_notify+0x100/0x12c)
r5:fffffffe r4:c39bc194
[<c0154128>] (fbcon_event_notify+0x0/0x12c) from [<c005a0d4>] (notifier_call_chain+0x38/0x7c)
[<c005a09c>] (notifier_call_chain+0x0/0x7c) from [<c005a3a0>] (__blocking_notifier_call_chain+0x54/0x6c)
r8:c3b51ea0 r7:00000009 r6:ffffffff r5:c0427a40 r4:c0427a74
r8:00000001 r7:c3a7e000 r6:00000000 r5:00000000 r4:c38984b8
[<c014c128>] (fb_blank+0x0/0x70) from [<c014e450>] (store_blank+0x54/0x7c)
r5:c38984b8 r4:c3b51ec4
[<c014e3fc>] (store_blank+0x0/0x7c) from [<c017981c>] (dev_attr_store+0x28/0x2c)
r8:00000001 r7:c042bf80 r6:c39eba10 r5:c3967c30 r4:c38e0140
[<c01797f4>] (dev_attr_store+0x0/0x2c) from [<c00ddaac>] (flush_write_buffer+0x54/0x68)
[<c00dda58>] (flush_write_buffer+0x0/0x68) from [<c00dde08>] (sysfs_write_file+0x58/0x80)
r8:c3b51f78 r7:c3bcb070 r6:c39eba10 r5:00000001 r4:00000001
[<c00dddb0>] (sysfs_write_file+0x0/0x80) from [<c009de04>] (vfs_write+0xb8/0x148)
[<c009dd4c>] (vfs_write+0x0/0x148) from [<c009e384>] (sys_write+0x44/0x70)
r7:00000004 r6:c3bcb070 r5:00000000 r4:00000000
[<c009e340>] (sys_write+0x0/0x70) from [<c0025d00>] (ret_fast_syscall+0x0/0x2c)
r6:4001b000 r5:00000001 r4:401dc658
Reported-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Testted-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Adjust and honor the vc_scrl_erase_char for 256 and 512 character fonts.
It fixes the issue with disappearing cursor during scrolling
(http://bugzilla.kernel.org/show_bug.cgi?id=11258). The issue was
reported and tracked by Peter Hanzel.
Reported-by: Peter Hanzel <hanzelpeter@gmail.com>
If the 'clear' command is used on the frame buffer with a logo the upper
area is filled by few lines but not scrolled anymore.
Fix this by removing the protected area for the logo if any part of the
logo is cleared.
Make logo_height variable local in the only function it is used.
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
The interlaced and double line mode bits should not be copied to new
console when the console is switched. Otherwise, the new console may be
set to incorrect refresh rate.
Also, the x and y offsets does not need to be copied.
Another addendum to commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b
("vt: fix background color on line feed").
fbcon still was not doing the right thing (read: continued to do old
behavior). fbcon_clear() seems to clear the new line (e.g. where your new
prompt appears after doing echo -en "\e[42mfoo\n"), while scr_memsetw clears
the previous one only (where "foo" appears). So just temporarily set the
video_erase_char to the scrl_erase_char so that fbcon_clear does the right
thing.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Addendum to commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b ("vt: fix
vc->vc_scrl_erase_char was not updated when fbcon switches between
256- and 512-glyph fonts.
A command that causes a line feed while a background color is active,
such as
perl -e 'print "x" x 60, "\e[44m", "x" x 40, "\e[0m\n"'
and
perl -e 'print "x" x 40, "\e[44m\n", "x" x 40, "\e[0m\n"'
causes the line that was started as a result of the line feed to be completely
filled with the currently active background color instead of the default
color.
When scrolling, part of the current screen is memcpy'd/memmove'd to the new
region, and the new line(s) that will appear as a result are cleared using
memset. However, the lines are cleared with vc->vc_video_erase_char, causing
them to be colored with the currently active background color. This is
different from X11 terminal emulators which always paint the new lines with
the default background color (e.g. `xterm -bg black`).
The clear operation (\e[1J and \e[2J) also use vc_video_erase_char, so a new
vc->vc_scrl_erase_char is introduced with contains the erase character used
for scrolling, which is built from vc->vc_def_color instead of vc->vc_color.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Antonino A. Daplas <adaplas@gmail.com>
Cc: Antonino Daplas <adaplas@pol.net>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Adrian Bunk <bunk@stusta.de>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Ben Dooks <ben-linux@fluff.org>
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) /
(d)) but is perhaps more readable.
An extract of the semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@haskernel@
#include <linux/kernel.h>
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP((n),d)
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP(n,(d))
+ DIV_ROUND_UP(n,d)
// </smpl>
The current attr_fgcol_ec / attr_bgcol_ec macros do a simple shift of bits
to get the color from vc_video_erase_char. For a monochrome display
however the attribute does not contain any color, only attribute bits.
Furthermore the reverse bit is lost because it is shifted out, the
resulting color is always 0.
This can bee seen on a monochrome console either directly or by setting it
to inverse mode via "setterm -inversescreen on" . Text is written with
correct color, fb_fillrects from a bit_clear / bit_clear_margins will get
wrong colors.
Signed-off-by: Thomas Pfaff <tpfaff@pcs.com>
After the APUS removal, some code can be removed.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Karsten Keil <kkeil@suse.de>
Cc: James Bottomley <James.Bottomley@steeleye.com>
As reported in Bugzilla Bug 9093, upon switching to X, a small rectangular
cursor can still be seen blinking in the upper left part of the screen. It is
fbcon's text cursor. This is caused by a strange ioctl(..., KDSETMODE,
KD_TEXT) call done by something in userspace, perhaps by X itself, while the
tty is still in graphics mode. And when the tty is in KD_TEXT mode, the
cursor timer is restarted.
Although this is a userspace problem, we can work around it by delaying the
restart of the cursor timer until an fbcon_switch() is called. In other
words, the cursor timer will not be restarted even if a KD_TEXT mode switch is
requested.
Regression potential: Present but low
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
Various console drivers are able to resize the screen via the con_resize()
hook. This hook is also visible in userspace via the TIOCWINSZ, VT_RESIZE and
VT_RESIZEX ioctl's. One particular utility, SVGATextMode, expects that
con_resize() of the VGA console will always return success even if the
resulting screen is not compatible with the hardware. However, this
particular behavior of the VGA console, as reported in Kernel Bugzilla Bug
7513, can cause undefined behavior if the user starts with a console size
larger than 80x25.
To work around this problem, add an extra parameter to con_resize(). This
parameter is ignored by drivers except for vgacon. If this parameter is
non-zero, then the resize request came from a VT_RESIZE or VT_RESIZEX ioctl
and vgacon will always return success. If this parameter is zero, vgacon will
return -EINVAL if the requested size is not compatible with the hardware. The
latter is the more correct behavior.
With this change, SVGATextMode should still work correctly while in-kernel and
stty resize calls can expect correct behavior from vgacon.
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the
checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver
does not use it.
Fix compile warning ('map_override unused') if fbcon is compiled as a module
and CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=n.
[akpm@linux-foundation.org: cleanup]
