It reads linetable[] before checking bounds of index, and ARRAY_SIZE is
required because linetable[] are unsigned shorts.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Fix build broken by accaa24c492f1aa3b9c37226d868dc59c3007531:
CC drivers/video/console/newport_con.o
drivers/video/console/newport_con.c: In function 'newport_show_logo':
drivers/video/console/newport_con.c:111: error: assignment of read-only location
drivers/video/console/newport_con.c:111: warning: assignment makes integer from pointer without a cast
drivers/video/console/newport_con.c:112: error: assignment of read-only location
drivers/video/console/newport_con.c:112: warning: assignment makes integer from pointer without a cast
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Add logo.nologo kernel boot option to disable the logo in order to provide
more screen space for kernel messages; especially useful when debugging and
screen space is more critical.
newport_con driver changes are untested.
[akpm@linux-foundation.org: cleanups, coding-style fixes]
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
drivers/video/console/newport_con.c: In function `newport_console_init':
drivers/video/console/newport_con.c:743: warning: return makes integer from pointer without a cast
Although one wonders whether that should have been -ENODEV...
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a
function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h
allows all of the framebuffer and VT console drivers to remove their
dependency on tty.h.
[akpm@osdl.org: fix alpha build]
Signed-off-by: Jon Smirl <jonsmir@gmail.com>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
- move register ioremap from newport_startup() to newport_console_init()
- fonts are freed multiple times, do it only once
There are more sparse warnings but fixing those will require some more work
than I want to do without hardware for testing at hand.
infrastructure for it.
Let it rip!
