path: root/drivers/video/cyber2000fb.h
2011-02-11VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var()Russell King
2011-02-11VIDEO: cyberpro: remove useless function extreg pointersRussell King
Sub-drivers can call these functions directly, there's no need for this kind of indirection. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11VIDEO: cyberpro: update handling of device structuresRussell King
Provide the framebuffer device with its correct parent (the PCI device for PCI connected cards.) Also, use this struct device to pass to sub-drivers rather than the pci_dev structure, which is really what they want. Also propagate the assigned IRQ, which they were getting direct from the PCI device structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11VIDEO: cyberpro: add support for video capture I2CRussell King
