path: root/drivers/video/edid.h
2011-03-22video: Fix EDID macros H_SYNC_WIDTH and H_SYNC_OFFSETMartin Decky
The macros for getting the values for horizontal sync width and offset do not respect the EDID specification. Both these values are 10 bit values according to [1], not 6 bit values. The lower 8 bits are stored in byte 8 and byte 9 of the DTD respectively, while two additional bits for each value are stored in byte 11. The original macros just slammed the bits together. Although the original macros usually worked fine because the higher two bits are rarely used, it can cause severe problems on plasma panels running at 1920x1080 @ 50 Hz with drivers that rely on the correct parsing of the EDID data by fbmon.c (e.g. udlfb). The patch should apply cleanly to both the fbdev-2.6.git branch and linux-next.git branch. [1] VESA Enhanced Extended Display Identification Data Standard, Release A, Revision 2, page 34, notes 7 & 8, VESA, Sep 2006 Signed-off-by: Martin Decky <martin@decky.cz> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
