path: root/drivers/video/fb_draw.h
2009-05-06fbdev: fix fillrect for 24bpp modesMichal Januszewski
The software fillrect routines do not work properly when the number of pixels per machine word is not an integer. To see that, run the following command on a fbdev console with a 24bpp video mode, using a non-accelerated driver such as (u)vesafb: reset ; echo -e '\e[41mtest\e[K' The expected result is 'test' displayed on a line with red background. Instead of that, 'test' has a red background, but the rest of the line (rendered using fillrect()) contains a distored colorful pattern. This patch fixes the problem by correctly computing rotation shifts. It has been tested in a 24bpp mode on 32- and 64-bit little-endian machines. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fb: add support for foreign endiannessAnton Vorontsov
Add support for the framebuffers with non-native endianness. This is done via FBINFO_FOREIGN_ENDIAN flag that will be used by the drivers. Depending on the host endianness this flag will be overwritten by FBINFO_BE_MATH internal flag, or cleared. Tested to work on MPC8360E-RDK (BE) + Fujitsu MINT framebuffer (LE). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: <Valdis.Kletnieks@vt.edu> Cc: Clemens Koller <clemens.koller@anagramm.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fb: fix warning: no return statement in function returning non-voidAnton Vorontsov
Warning is reproducible with selected FB_CFB_REV_PIXELS_IN_BYTE. CC drivers/video/sysfillrect.o In file included from drivers/video/sysfillrect.c:18: drivers/video/fb_draw.h: In function `fb_rev_pixels_in_long': drivers/video/fb_draw.h:94: warning: no return statement in function returning non-void CC drivers/video/syscopyarea.o In file included from drivers/video/syscopyarea.c:22: drivers/video/fb_draw.h: In function `fb_rev_pixels_in_long': drivers/video/fb_draw.h:94: warning: no return statement in function returning non-void Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: copyarea function taught to fully support swapped pixel order in bytePavel Pisa
This correct case, when source and destination X coordinates difference is n multiple of pixels in byte. This is probably rare case, but this case should supported for completeness. Reorganization of FB_READL and FB_WRITEL calls results in code size decrease for normal build without swapping support and size with support enabled is reasonable too. [adaplas] Add missing fb_rev_pixels_in_long() prototype. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: Support for byte-reversed framebuffer formatsPavel Pisa
Allow generic frame-buffer code to correctly write texts and blit images for 1, 2 and 4 bit per pixel frame-buffer organizations when pixels in bytes are organized to in opposite order than bytes in long type. Overhead should be reasonable. If option is not selected, than compiler should eliminate completely all overhead. The feature is disabled at compile time if CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set. [adaplas] Convert helper functions to macros if feature is not enabled. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: consolidate common drawing functions into a header fileAntonino A. Daplas
Consolidate common drawing functions into a single header file. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
