path: root/drivers/video/fb_sys_fops.c
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: add fb_read/fb_write functions for framebuffers in system RAMAntonino A. Daplas
The functions fb_read() and fb_write in fbmem.c assume that the framebuffer is in IO memory. However, we have 3 drivers (hecubafb, arcfb, and vfb) where the framebuffer is allocated from system RAM (via vmalloc). Using __raw_read/__raw_write (fb_readl/fb_writel) for these drivers is illegal, especially in other platforms. Create file read and write methods for these types of drivers. These are named fb_sys_read() and fb_sys_write(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
