This is the 3.18.5 stable release
arch/arm/mach-imx/clk-imx6q.c
commit 30ea9c5218651bc11cbdba7820be78f04e2d83bc upstream.
fb_deferred_io_fsync() returns the value of schedule_delayed_work() as
an error code, but schedule_delayed_work() does not return an error. It
returns true/false depending on whether the work was already queued.
Fix this by ignoring the return value of schedule_delayed_work().
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Reset all layers before calling register_framebuffer. Registring
a frame buffer device can lead to panel/layers getting enabled
immediately, especially when using virtual terminals. In this
situation, the other layers have not yet been initialized. Upon
writing the DCU_UPDATE_MODE register, which essentially enables
the controller, the system sometimes freezed. It looks like
the controller relied on stale layer configurations which lead
to a system freeze (probably due to illegal memory accesses).
This has mainly been observed on Colibri VF50 devices. The user
does not see any kernel output because the DCU frame buffer gets
initialized before the serial console. Using earlyprintk, the
last message beeing shown are:
[ 0.914572] VFS: Disk quotas dquot_6.5.2
[ 0.920293] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.948795] NFS: Registering the id_resolver key type
[ 0.955223] Key type id_resolver registered
[ 0.959882] Key type id_legacy registered
[ 0.964701] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.972685] ntfs: driver 2.1.31 [Flags: R/W].
[ 0.981762] fuse init (API version 7.23)
[ 0.989235] msgmni has been set to 220
[ 1.003070] io scheduler noop registered
[ 1.008126] io scheduler deadline registered
[ 1.013165] io scheduler cfq registered (default)
[ 1.056924] backlight supply power not found, using dummy regulator
<freeze>
register_framebuffer() acquires registration_lock, then calls
do_register_framebuffer() which calls fb_notifier_call_chain()
which calls fb_open() which calls get_fb_info() which tries
(at last) to acquire registration_lock again.
This is a workaround.
Signed-off-by: Fabio Erculiani <lxnay@sabayon.org>
The pixel clock polarity setting was still wrong: In contrast what
earlier mentioned, the reference manual is correct! But the kernel
display flags are rather somewhat confusing: The flags specify the
edge where the data should be driven by the controller (and hence not
sampled by the display!). We convert the display flag to the display
centric DCU notation when getting the videomode from device tree.
Add suspend and resume support which disables the panel completely.
Tested with the main frame buffer instance (fb0).
Fix defines for pixel clock and pixel data polarity. Configuring
pixel clock is now actually possible. On most display this needs
to be set, hence until now, some displays showed green or white
artefacts (e.g. EDT 5.7"). This is solved by this commit.
Add video= cmd support through converting the display timings into
a modedb and using the fb_find_mode helper. Because we need to pass
the fb_info struct, we do this for every layer. This is not a clean
solution but proved to work reliable.
Use the display timing configurations hsync-/vsync- and pixelclk-
active properties. The hsync- and vsync-active configuration is
available through the fb_videomode sync field. But pixelclk-active
need to be stored seperately because when converting the struct
display_timing to struct fb_videomode, this information gets lost.
Hence we cannot pick a mode from the modelist and expect that
pixelclk-active is set correctly. But currently modelist is not
used by anything, hence this is no issue.
Use the timing defined in the native-display property by default.
Get display timings from device tree only once in probe instead for
each framebuffer layer again.
Use num_timings when iterating through available timings. This
saves getting the display-timings node again.
The Display Controller Unit (DCU) module is a system master that
fetches graphics stored in internal or external memory and displays
them on a TFT LCD panel. A wide range of panel sizes is supported
and the timing of the interface signals is highly configurable.
Graphics are read directly from memory and then blended in real-time,
which allows for dynamic content creation with minimal CPU intervention.
The features:
(1) Full RGB888 output to TFT LCD panel.
(2) For the current LCD panel, WQVGA "480x272" is supported.
(3) Blending of each pixel using up to 4 source layers dependent on size of panel.
(4) Each graphic layer can be placed with one pixel resolution in either axis.
(5) Each graphic layer support RGB565 and RGB888 direct colors without alpha channel
and BGRA8888 direct colors with an alpha channel.
(6) Each graphic layer support alpha blending with 8-bit resolution.
This driver has been tested on Vybrid VF610TWR board.
Signed-off-by: Alison Wang <b18965@freescale.com>
[add FB_MODE_HELPERS to drivers dependencies]
Without that fix connector-analog-tv driver isn't probed when compiled
as module.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
PLL_SELFREQDCO bitfield is from bit 3 to 1, but the driver writes bits
from 4 to 1. The bit 4 is 'reserved', so this probably should not cause
any issues, but it's better to fix it.
Preload register is dumped twice for video overlays and mflag register
is not dumped for GFX.
Fix the register dump.
The register offset for DISPC_OVL_MFLAG_THRESHOLD is wrong, fix it.
HDMI PLL's REGSD field is only set by the driver if the PLL's output
clock is over 1GHz. This is clearly an error, as REGSD should be set
always.
The PLL settings are committed by setting GO bit, which is then cleared
by the HW when the settings have been taken into use.
The current PLL code handles this wrong: instead of waiting for the bit
to be cleared, it waits for the bit to be set. Usually, the bit is
always set, as the CPU has just set it before. However, if the CPU takes
enough time between setting the GO bit and checking it, the HW may
already have cleared the bit and this leads to timeout error.
Fix the wait to check the bit properly.
omapfb disables all the overlays when freeing resources, but it should
also remove those overlays from overlay managers.
Not doing so causes a crash if omapfb is unbound and bound, or omapfb
module is removed and loaded, while keeping omapdss around.
Fix this by calling unset_manager() for all overlays.
When omapfb is shutting down, it will disable all the overlays. However,
instead of actually disabling all the overlays, it disables only all the
overlays that are currently attached to framebuffers.
On OMAP4+, this leaves the fourth overlay left enabled.
Fix the loop so that we actually go through all the overlays.
We should wait for any pending updates when an overlay manager is
about to be disabled, because the updates will never be finished if the
manager is disabled too early.
If we leave __exit annotation, driver can't be unbound
through sysfs.
Signed-off-by: Felipe Balbi <balbi@ti.com>
omapdss drivers cannot handle devices being unbound while the devices
are part of a connected display pipeline. Module refcounts are used to
prevent unloading the modules, but one can still manually unbind the
devices via sysfs, causing crash.
Set suppress_bind_attrs to disable the bind/unbind support via sysfs.
without MODULE_ALIAS(), omapfb won't get loaded
automatically.
Remove unnecessary mach/cpu.h header to be able to converge to a multiplatform
kernel.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Pull slave-dmaengine updates from Vinod Koul:
"For dmaengine contributions we have:
- designware cleanup by Andy
- my series moving device_control users to dmanegine_xxx APIs for
later removal of device_control API
- minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma
etc"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits)
serial: atmel: add missing dmaengine header
dmaengine: remove FSLDMA_EXTERNAL_START
dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method
carma-fpga: move to fsl_dma_external_start()
carma-fpga: use dmaengine_xxx() API
dmaengine: freescale: add and export fsl_dma_external_start()
dmaengine: add dmaengine_prep_dma_sg() helper
video: mx3fb: use dmaengine_terminate_all() API
serial: sh-sci: use dmaengine_terminate_all() API
net: ks8842: use dmaengine_terminate_all() API
mtd: sh_flctl: use dmaengine_terminate_all() API
mtd: fsmc_nand: use dmaengine_terminate_all() API
V4L2: mx3_camer: use dmaengine_pause() API
dmaengine: coh901318: use dmaengine_terminate_all() API
pata_arasan_cf: use dmaengine_terminate_all() API
dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause()
dmaengine: dw: export probe()/remove() and Co to users
dmaengine: dw: enable and disable controller when needed
dmaengine: dw: always export dw_dma_{en,dis}able
dmaengine: dw: introduce dw_dma_on() helper
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
- new 6x10 font
- various small fixes and cleanups
* tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits)
fonts: Add 6x10 font
videomode: provide dummy inline functions for !CONFIG_OF
video/atmel_lcdfb: Introduce regulator support
fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume
framebuffer: fix screen corruption when copying
framebuffer: fix border color
arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb
arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss
video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info
video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info
video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info
video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info
video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info
video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info
video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy
video: valkyriefb: Fix unused variable warning in set_valkyrie_clock()
video: fbdev: use %*ph specifier to dump small buffers
video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT
video: fbdev: au1200fb: delete double assignment
video: fbdev: sis: delete double assignment
The drivers should use dmaengine_terminate_all() API instead of
accessing the device_control which will be deprecated soon
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Pull drm updates from Dave Airlie:
"This is the main git pull for the drm,
I pretty much froze major pulls at -rc5/6 time, and haven't had much
fallout, so will probably continue doing that.
Lots of changes all over, big internal header cleanup to make it clear
drm features are legacy things and what are things that modern KMS
drivers should be using. Also big move to use the new generic fences
in all the TTM drivers.
core:
atomic prep work,
vblank rework changes, allows immediate vblank disables
major header reworking and cleanups to better delinate legacy
interfaces from what KMS drivers should be using.
cursor planes locking fixes
ttm:
move to generic fences (affects all TTM drivers)
ppc64 caching fixes
radeon:
userptr support,
uvd for old asics,
reset rework for fence changes
better buffer placement changes,
dpm feature enablement
hdmi audio support fixes
intel:
Cherryview work,
180 degree rotation,
skylake prep work,
execlist command submission
full ppgtt prep work
cursor improvements
edid caching,
vdd handling improvements
nouveau:
fence reworking
kepler memory clock work
gt21x clock work
fan control improvements
hdmi infoframe fixes
DP audio
ast:
ppc64 fixes
caching fix
rcar:
rcar-du DT support
ipuv3:
prep work for capture support
msm:
LVDS support for mdp4, new panel, gpu refactoring
exynos:
exynos3250 SoC support, drop bad mmap interface,
mipi dsi changes, and component match support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (640 commits)
drm/mst: rework payload table allocation to conform better.
drm/ast: Fix HW cursor image
drm/radeon/kv: add uvd/vce info to dpm debugfs output
drm/radeon/ci: add uvd/vce info to dpm debugfs output
drm/radeon: export reservation_object from dmabuf to ttm
drm/radeon: cope with foreign fences inside the reservation object
drm/radeon: cope with foreign fences inside display
drm/core: use helper to check driver features
drm/radeon/cik: write gfx ucode version to ucode addr reg
drm/radeon/si: print full CS when we hit a packet 0
drm/radeon: remove unecessary includes
drm/radeon/combios: declare legacy_connector_convert as static
drm/radeon/atombios: declare connector convert tables as static
drm/radeon: drop btc_get_max_clock_from_voltage_dependency_table
drm/radeon/dpm: drop clk/voltage dependency filters for BTC
drm/radeon/dpm: drop clk/voltage dependency filters for CI
drm/radeon/dpm: drop clk/voltage dependency filters for SI
drm/radeon/dpm: drop clk/voltage dependency filters for NI
drm/radeon: disable audio when we disable hdmi (v2)
drm/radeon: split audio enable between eg and r600 (v2)
The kernel used to contain two functions for length-delimited,
case-insensitive string comparison, strnicmp with correct semantics and
a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp
was renamed to strncasecmp, and strnicmp made into a wrapper for the new
strncasecmp to avoid breaking existing users.
To allow the compat wrapper strnicmp to be removed at some point in the
future, and to avoid the extra indirection cost, do
s/strnicmp/strncasecmp/g.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen updates from David Vrabel:
"Features and fixes:
- Add pvscsi frontend and backend drivers.
- Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses.
- Try and keep memory contiguous during PV memory setup (reduces
SWIOTLB usage).
- Allow front/back drivers to use threaded irqs.
- Support large initrds in PV guests.
- Fix PVH guests in preparation for Xen 4.5"
* tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits)
xen: remove DEFINE_XENBUS_DRIVER() macro
xen/xenbus: Remove BUG_ON() when error string trucated
xen/xenbus: Correct the comments for xenbus_grant_ring()
x86/xen: Set EFER.NX and EFER.SCE in PVH guests
xen: eliminate scalability issues from initrd handling
xen: sync some headers with xen tree
xen: make pvscsi frontend dependant on xenbus frontend
arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options
xen-scsifront: don't deadlock if the ring becomes full
x86: remove the Xen-specific _PAGE_IOMAP PTE flag
x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings
x86: skip check for spurious faults for non-present faults
xen/efi: Directly include needed headers
xen-scsiback: clean up a type issue in scsiback_make_tpg()
xen-scsifront: use GFP_ATOMIC under spin_lock
MAINTAINERS: Add xen pvscsi maintainer
xen-scsiback: Add Xen PV SCSI backend driver
xen-scsifront: Add Xen PV SCSI frontend driver
xen: Add Xen pvSCSI protocol description
xen/events: support threaded irqs for interdomain event channels
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
The DEFINE_XENBUS_DRIVER() macro looks a bit weird and causes sparse
errors.
Replace the uses with standard structure definitions instead. This is
similar to pci and usb device registration.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
This adds regulator support to enable/disable the LCD voltage, using
'lcd-supply' as regulator name.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
When the PM domain containing the HDMI hardware block is powered down,
the HDMI register values (incl. interrupt polarity settings) are lost.
During resume, after powering up the PM domain, interrupts are
re-enabled, and an interrupt storm happens due to incorrect interrupt
polarity settings:
irq 163: nobody cared (try booting with the "irqpoll" option)
Disabling IRQ #163
To fix this, re-initialize the interrupt polarity settings, and the
htop1 register block (if present), during resume.
As the .suspend_noirq() and .resume_noirq() callbacks are not called
when using the generic PM domain, the normal .resume() callback is used,
and the device interrupt needs to be disabled/enabled manually.
This fixes resume from s2ram with power down of the A4MP PM domain on
r8a7740/Armadillo.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The function bitcpy_rev has a bug that may result in screen corruption.
The bug happens under these conditions:
* the end of the destination area of a copy operation is aligned on a long
word boundary
* the end of the source area is not aligned on a long word boundary
* we are copying more than one long word
In this case, the variable shift is non-zero and the variable first is
zero. The statements FB_WRITEL(comp(d0, FB_READL(dst), first), dst) reads
the last long word of the destination and writes it back unchanged
(because first is zero). Correctly, we should write the variable d0 to the
last word of the destination in this case.
This patch fixes the bug by introducing and extra test if first is zero.
The patch also removes the references to fb_memmove in the code that is
commented out because fb_memmove was removed from framebuffer subsystem.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
Replace the use of nested functions where a normal function will suffice.
Nested functions are not liked by upstream kernel developers in general. Their
use breaks the use of clang as a compiler, and doesn't make the code any
better.
This code now works for both gcc and clang.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Reviewed-by: Felipe Balbi <balbi@ti.com>
better.
from fb_info
Use container_of instead of casting first structure member.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
fb_info
Replacing strncpy with strlcpy to avoid strings that lacks null terminate.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
If CONFIG_ADB_CUDA=n:
drivers/video/fbdev/valkyriefb.c: In function ‘set_valkyrie_clock’:
drivers/video/fbdev/valkyriefb.c:267: warning: unused variable ‘i’
drivers/video/fbdev/valkyriefb.c:266: warning: unused variable ‘req’
Move the variable declarations inside the existing #ifdef section to fix
this.
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
This is requested to get the fixes for intel and radeon into the
same tree for future development work.
i915_display.c: fix missing dev_priv conflict.
