Fixed index calculation when parsing E-EDID block SVD entry
in fb_edid_add_monspecs().
Change-Id: I0273e2f29e86687607923d07faf99a30696f5ead
Signed-off-by: Eric Laurent <elaurent@google.com>
Looks for ieee registration number 0x000c03 as per HDMI spec.
CEA-861-E section D.6.8.
Change-Id: I6875b24c66e8754510edabcb4f9ba682a50d6ac1
Signed-off-by: Erik Gilling <konkers@android.com>
Signed-off-by: Lajos Molnar <molnar@ti.com>
CEA defines multiple timings with dual timing ratios that cannot
be distinguished from timings parameters. Added 2 new fb flags
to specify 4:3 or 16:9 display ratios.
Also added a flag that denotes CEA formats that require repeating
pixels.
Change-Id: I75d413babdcb4048a0ccce6548ed386ad0e52318
These mode are directly from the CEA-861-E spec.
Change-Id: Ic29390fb8dfc4605da1f95aaee0e2e775dfc0a4a
This reverts commit c326f06779fb6bdd7f92c3ede8d1bebbe2fafbfa.
Looks for ieee registration numver 0x000c03 as per HDMI spec.
Add parsing of E-EDID SVD entries. In this first version only a few
CEA/EIA-861E modes are implemented, more can be added as needed.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
fb_edid_add_monspecs() should also be exported for use in modules, and it
requires a dummy version for the case, when CONFIG_FB_MODE_HELPERS is not
selected. This patch also improves the algorithm by removing a redundant
memory allocation, adds function documentation, adds data verification and
replaces memmove() with memcpy().
Modern monitors/tvs have more extended EDID information blocks which can
contain extra detailed modes. This adds a fb_edid_add_monspecs function
which drivers can use to parse those additions blocks.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
There's some odd bug in gcc-4.2 where it miscompiles a simple loop whent
he loop counter is of type 'unsigned char' and it should count to 128.
The compiler will incorrectly decide that a trivial loop like this:
unsigned char i, ...
for (i = 0; i < 128; i++) {
is endless, and will compile it to a single instruction that just
branches to itself.
This was triggered by the addition of '-fno-strict-overflow', and we
could play games with compiler versions and go back to '-fwrapv'
instead, but the trivial way to avoid it is to just make the loop
induction variable be an 'int' instead.
Thanks to Krzysztof Oledzki for reporting and testing and to Troy Moure
for digging through assembler differences and finding it.
Reported-and-tested-by: Krzysztof Oledzki <olel@ans.pl>
Found-by: Troy Moure <twmoure@szypr.net>
Gcc-bug-acked-by: Ian Lance Taylor <iant@google.com>
Cc: stable@kernel.org
The current EDID parser in the linux kernel ignores interlace modes. The
patch looks for the edid interlace flag and adjusts the vertical
resolution if it is found.
Signed-off-by: Jon Dufresne <jon.dufresne@gmail.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
The width and height members of fb_var_screeninfo are __u32. The code
initializes them to -1 which seems wrong, and 0 seems like an equally good
default value.
Signed-off-by: Ville Syrjala <syrjala@sci.fi>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Signed-off-by: Andre Haupt <andre@bitwigglers.org>
This fixes a sparse warning about symbol 'i' shadowing an earlier one.
Looking at the code flow, `int first' in fb_create_modedb() should be static.
[adaplas]
Better for 'int first' to be moved outside the loop.
[akpm@linux-foundation.org: kill stray semicolon]
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
This particular monitor does not have a limits block and has only one set of
monitor timings. Fix by adding a limits block to the EDID and extend the
horizontal sync frequency range to 30 kHz and 75 Khz.
- move some structs and arrays to the read-only (.rodata) section
[akpm@osdl.org: build fix]
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: James Simmons <jsimmons@infradead.org>
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a
function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h
allows all of the framebuffer and VT console drivers to remove their
dependency on tty.h.
[akpm@osdl.org: fix alpha build]
Signed-off-by: Jon Smirl <jonsmir@gmail.com>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
- make firmware edid independent from framebuffer (No need to choose
framebuffer just to disable this option
- enable this option in X86_64
- check if VBE/DDC function is implemented before calling actual function
The EDID block should specify the display's operating limits (vertical and
horizontal sync ranges, and maximum dot clock). If not given by the EDID
block, the ranges are extrapolated from the modelist. However, the
computation used is only a rough approximation, and the resulting values may
not reflect the actual capability of the display. This problem is frequently
encountered when the EDID block has a single entry, the single mode entry will
fail validation.
To prevent this, calculate the values based on the same method used in
fb_validate_mode().
Remove unneeded duplicate #include's of the same header file.
In the case of fbmon.c linux/pci.h is now #include'd unconditional, but
this should be safe.
DDC reading via the Video BIOS may take several tens of seconds with some
combination of display cards and monitors.
Make this option configurable. It defaults to `y' to minimise disruption.
Replace kmalloc with kzalloc
calc_mode_timings() and fb_get_mode() are using more than 500 bytes off the
stack. Fix.
Rearrange mode database entries such that preferred timings are entered first,
and less preferred timings are entered last. (Detailed, VESA,
established/standard).
Some EDID blocks set the flag "prefer first detailed timing" without providing
any detailed timing at all. Clear this flag if the block does not provide
detailed timings.
The var structure in calc_mode_timings is not properly initialized (zero set)
which leads to undefined behavior when it is passed to fb_get_mode().
For the i386, code is already present in video.S that gets the EDID from the
video BIOS. Make this visible so drivers can also use this data as fallback
when i2c does not work.
To ensure that the EDID block is returned for the primary graphics adapter
only, by check if the IORESOURCE_ROM_SHADOW flag is set.
Fix rounding error when mode frequency is very close to monitor limit
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
This patch removes some completely unused code.
infrastructure for it.
Let it rip!
